CS16593_HB-IP-2X6-G2-WWW 数据手册
PRODUCT
DATASHEET
HB-IP-2X6-G2-WWW
~90° wide beam
TECHNICAL SPECIFICATIONS:
Dimensions
Height
Fastening
172.0 x 71.0 mm
8.2 mm
pin, screw
Ingress protection classes
ROHS compliant
IP67
yes
MATERIAL SPECIFICATIONS:
Component
Type
Material
Colour
HB-IP-2X6-G2-WWW
Multi-lens
PMMA
clear
SEAL-IP-2X6-G2
Seal
Silicone
white
Finish
ORDERING INFORMATION:
Component
» Box size: 476 x 273 x 247 mm
Qty in box
Multi-lens
132
MOQ
MPQ
44
44
Box weight (kg)
5.8
Last update: 15/12/2021
Subject to change without prior notice
Published: 14/05/2018
LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries.
1/12
PRODUCT
DATASHEET
See also our general installation guide: www.ledil.com/installation_guide
2/12
PRODUCT
DATASHEET
PHOTOMETRIC DATA (MEASURED):
LED
XP-L2
FWHM / FWTM
96.0° / 118.0°
Efficiency
94 %
Peak intensity
0.4 cd/lm
LEDs/each optic
1
Light colour
White
Required components:
LED
LUXEON 5050 Round LES
FWHM / FWTM
92.0° / 112.0 + 112.5°
Efficiency
97 %
Peak intensity
0.5 cd/lm
LEDs/each optic
1
Light colour
White
LED
NVSW519A
FWHM / FWTM
96.0° / 113.0°
Efficiency
95 %
Peak intensity
0.4 cd/lm
LEDs/each optic
1
Light colour
White
LED
OLP-5065F6L-06A
FWHM / FWTM
93.5° / 112.0 + 112.5°
Efficiency
97 %
Peak intensity
0.5 cd/lm
LEDs/each optic
1
Light colour
White
3/12
PRODUCT
DATASHEET
LED
Duris S8
FWHM / FWTM
90.0° / 113.0°
Efficiency
94 %
Peak intensity
0.5 cd/lm
LEDs/each optic
1
Light colour
White
LED
HiLOM RM12 ZP (LH502C)
FWHM / FWTM
91.0° / 113.0°
Efficiency
96 %
Peak intensity
0.5 cd/lm
LEDs/each optic
1
Light colour
White
LED
ROY-S26XPL2 (XP-L2)
FWHM / FWTM
96.0° / 118.0°
Efficiency
94 %
Peak intensity
0.4 cd/lm
LEDs/each optic
1
Light colour
White
LED
2x6 5050 module - SMJD-3625012F-XX
FWHM / FWTM
93.0° / 113.0°
Efficiency
94 %
Peak intensity
0.5 cd/lm
LEDs/each optic
1
Light colour
White
4/12
PRODUCT
DATASHEET
LED
RLE 2x6 3000lm HP EXC2 OTD
FWHM / FWTM
95.0° / 111.0°
Efficiency
94 %
Peak intensity
0.5 cd/lm
LEDs/each optic
1
Light colour
White
5/12
PRODUCT
DATASHEET
PHOTOMETRIC DATA (SIMULATED):
LED
Bridgelux SMD 5050
FWHM / FWTM
87.4° / 114.0°
Efficiency
96 %
Peak intensity
0.6 cd/lm
LEDs/each optic
1
Light colour
White
LED
J Series 5050 Round LES
FWHM / FWTM
90.0° / 110.0°
Efficiency
95 %
Peak intensity
0.5 cd/lm
LEDs/each optic
1
Light colour
White
LED
J Series 5050 Square LES 6V
FWHM / FWTM
90.0° / 111.0°
Efficiency
94 %
Peak intensity
0.5 cd/lm
LEDs/each optic
1
Light colour
White
LED
MHB-A/B
FWHM / FWTM
89.2° / 113.0°
Efficiency
96 %
Peak intensity
0.6 cd/lm
LEDs/each optic
1
Light colour
White
6/12
PRODUCT
DATASHEET
LED
XP-G2
FWHM / FWTM
93.0° / 112.0°
Efficiency
94 %
Peak intensity
0.5 cd/lm
LEDs/each optic
1
Light colour
White
LED
XP-G2 HE
FWHM / FWTM
98.0° / 116.0°
Efficiency
91 %
Peak intensity
0.4 cd/lm
LEDs/each optic
1
Light colour
White
LED
XP-G3
FWHM / FWTM
92.8° / 112.5°
Efficiency
95 %
Peak intensity
0.5 cd/lm
LEDs/each optic
1
Light colour
White
LED
NF3W585AR
FWHM / FWTM
99.0 + 102.0° / 117.0 + 118.0°
Efficiency
94 %
Peak intensity
0.4 cd/lm
LEDs/each optic
1
Light colour
White
7/12
PRODUCT
DATASHEET
LED
NFMW48xA
FWHM / FWTM
88.8° / 113.0°
Efficiency
96 %
Peak intensity
0.6 cd/lm
LEDs/each optic
1
Light colour
White
LED
NV4WB35AM
FWHM / FWTM
97.0° / 114.0°
Efficiency
94 %
Peak intensity
0.5 cd/lm
LEDs/each optic
1
Light colour
White
LED
NVSxE21A
FWHM / FWTM
92.0° / 112.0°
Efficiency
93 %
Peak intensity
0.6 cd/lm
LEDs/each optic
1
Light colour
White
LED
PrevaLED Brick HP IP 2x6
FWHM / FWTM
90.0° / 110.0°
Efficiency
94 %
Peak intensity
0.5 cd/lm
LEDs/each optic
1
Light colour
White
8/12
PRODUCT
DATASHEET
LED
OSCONIQ P 3030
FWHM / FWTM
88.0° / 110.0°
Efficiency
95 %
Peak intensity
0.6 cd/lm
LEDs/each optic
1
Light colour
White
LED
OSCONIQ P 3737 (2W version)
FWHM / FWTM
87.0° / 115.0°
Efficiency
94 %
Peak intensity
0.6 cd/lm
LEDs/each optic
1
Light colour
White
LED
OSCONIQ P 3737 Flat
FWHM / FWTM
90.0° / 110.0°
Efficiency
95 %
Peak intensity
0.5 cd/lm
LEDs/each optic
1
Light colour
White
LED
OSLON Square CSSRM2/CSSRM3
FWHM / FWTM
90.0° / 111.0°
Efficiency
94 %
Peak intensity
0.5 cd/lm
LEDs/each optic
1
Light colour
White
9/12
PRODUCT
DATASHEET
LED
LH351B
FWHM / FWTM
93.0° / 112.0°
Efficiency
94 %
Peak intensity
0.5 cd/lm
LEDs/each optic
1
Light colour
White
LED
LH502C
FWHM / FWTM
90.0° / 112.0°
Efficiency
94 %
Peak intensity
0.5 cd/lm
LEDs/each optic
1
Light colour
White
LED
LH508B
FWHM / FWTM
90.0° / 113.0°
Efficiency
94 %
Peak intensity
0.5 cd/lm
LEDs/each optic
1
Light colour
White
LED
SEOUL DC 5050 6V
FWHM / FWTM
94.0° / 114.0°
Efficiency
94 %
Peak intensity
0.5 cd/lm
LEDs/each optic
1
Light colour
White
10/12
PRODUCT
DATASHEET
LED
Z8Y22T
FWHM / FWTM
89.0° / 109.0°
Efficiency
94 %
Peak intensity
0.5 cd/lm
LEDs/each optic
1
Light colour
White
11/12
PRODUCT
DATASHEET
GENERAL INFORMATION:
NOTE: The typical beam angle will be changed by different color, chip size
and chip position tolerance. The typical total beam angle is the full angle
measured where the luminous intensity is half of the peak value.
MATERIALS:
As part of our continuous research and improvement processes, and to ensure
the best possible quality and availability of our products, LEDiL reserves the
right to change material grades without notice.
PRODUCT DATA USER AGREEMENT AND DISCLAIMER:
The measured data in the provided downloadable LEDiL Product Datasheets
and Mechanical 2D-Drawings is rounded and provided as reference for
planning. LEDiL Oy's optical specifications have been verified by conducting
performance testing of the products in accordance with the company's quality
system. The reported data are averaged results of multiple measurements with
typical variation. LEDiL Oy reserves the right to without prior notification make
changes and improvements to its products.
LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of
any kind for the contents and correctness of the provided data. The provided
data has been generated with highest diligence but the provided data may in
reality not represent the complete possible variation range of all intrinsic
parameters. Therefore, in certain cases a deviation from the provided data
could occur.
LEDiL Oy
Joensuunkatu 13
FI-24240 SALO
Finland
LEDiL Inc.
228 West Page Street
Suite D
Sycamore IL 60178
USA
Ledil Optics Technology
(Shenzhen) Co., Ltd.
# 405 , Block B
Casic Motor Building
Shenzhen 518057
P.R.CHINA
Local sales and technical
support
www.ledil.com/
where_to_buy
Shipping locations
Salo, Finland
Hong Kong, China
Distribution Partners
www.ledil.com/
where_to_buy
LEDiL Oy reserves the right to undertake technical changes of its products
without further notification which could lead to changes in the provided data.
LEDiL Oy assumes no liability of any kind for the possible deviation from any
provided data or any other damage resulting from the usage of the provided
data.
The user agrees to this disclaimer and user agreement with the download or
usage of the provided files.
12/12
CS16593_HB-IP-2X6-G2-WWW 价格&库存
很抱歉,暂时无法提供与“CS16593_HB-IP-2X6-G2-WWW”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 44+58.8838844+7.64014
