TP224012-1
TP224012-1
    DBUNLIMITED
    TP224012-1
TP224012-1 数据手册
4 3 2 1 Part Number: DRAWN TP224012-1 7/31/2017 CJ CHECKED 8/9/2017 P.D. Description: APPROVED Piezo Transducer 8/9/2017 C.E. D D This document contains data proprietary to DB Unlimited. Any use or reproduction, in any form, without prior written permission of DB Unlimited is prohibited. All terms and conditions can be found at www.dbunlimitedco.com Top View Bottom View Side View C C 2. 2 3.3 R12.9 2.0 22.1 0.3 45 0.3 XX X XX 4.0 B Date Code Marking "17 G 31" 17=2017, G=Jul., 31=31 (Day) Items Specifications Conditions Min. Sound Pressure Level 90 dBA (@ 10cm) Resonant Frequency 4,000 Hz Rated Voltage 12 Vp-p Voltage Range 1 ~ 30 Vp-p Capacitance A 7.0 19,000 pF 30% B 0.3 REVISION HISTORY REV 1 DESCRIPTION DATE APPROVED Released from Engineering 10/21/2013 J.S. 8/9/2017 C.E. Updated template, New location and day added to date code, changed capacitance Max. Rated Current 7 mA Storage Temperature -20 ~ +75 C NOTES Operating Temperature -20 ~ +70 C 1) All dimensions are in mm unless otherwise noted Connection Method Surface Mount Pads Mount Type Surface Mount 3) All parts meet RoHS Housing Material PPS 4) Subject to change or redrawn without notice Weight 2.8 4 2) All tolerances are A 0.5 mm unless otherwise noted g 3 2 1
TP224012-1 价格&库存
很抱歉,暂时无法提供与“TP224012-1”相匹配的价格&库存,您可以联系我们找货
