CP60404567H-2
CP60404567H-2
    CUIDEVICES
    CP60404567H-2
CP60404567H-2 数据手册
Additional Resources: Product Page | 3D Model date 10/29/2019 page 1 of 4 SERIES: CP60H-2 │ DESCRIPTION: PELTIER MODULE FEATURES • • • • • arcTEC™ structure solid state device 2-stage cooler precise temperature control silent operation MODEL CP60404567H-2 Notes: 1. 2. 3. 4. 5. input voltage1 input current2 internal resistance3 output Qmax4 max (Vdc) max (A) typ (Ω±10%) Th=27°C (W) Th=50°C (W) Th=27°C (°C) Th=50°C (°C) 14.2 6 2.14 32 35 82 92 Maximum voltage at ΔT max and Th=27°C Maximum current to achieve ΔT max Measured by AC 4-terminal method at 25°C Maximum heat absorbed at cold side occurs at Imax, Vmax, and ∆T=0°C Maximum temperature difference occurs at Imax, Vmax, and Q=0W (ΔT max measured in a vacuum at 1.3 Pa) cuidevices.com output ∆Tmax5 Additional Resources: Product Page | 3D Model CUI Devices │ SERIES: CP60H-2 │ DESCRIPTION: PELTIER MODULE date 10/29/2019 │ page 2 of 4 SPECIFICATIONS parameter conditions/description min solder melting temperature connection between thermoelectric pairs 235 typ max °C assembly compression hot side plate RoHS units 1 MPa 100 °C yes MECHANICAL DRAWING units: mm MATERIAL 0.05 COLD SIDE 0.05 HOT SIDE 96% AL2O3 wire leads 20 AWG sealer silicon rubber 703 RTV (between cold and hot side plates) joint cover silicon rubber 703 RTV marking P/N & S/N printed on cold side surface tin 41.25 0.75 Red(+) COLD SIDE Black(-) cuidevices.com PLATING ceramic plate Additional Resources: Product Page | 3D Model CUI Devices │ SERIES: CP60H-2 │ DESCRIPTION: PELTIER MODULE date 10/29/2019 │ page 3 of 4 Input Voltage (V) PERFORMANCE (Th=27°C) 16 6.0 A 4.8 A 12 3.6 A 8.0 2.4 A 1.2 A 4.0 Heat Pumped, Q (W) 0 40 4.8 A 30 6.0 A 20 3.6 A 2.4 A 10 1.2 A 0 90 80 70 60 30 50 40 ΔT=Th-Tc (°C) 20 10 0 Input Voltage (V) PERFORMANCE (Th=50°C) 6.0 A 16 4.8 A 12 3.6 A 8.0 2.4 A 1.2 A 4.0 Heat Pumped, Q (W) 0 4.8 A 40 6.0 A 30 3.6 A 20 2.4 A 1.2 A 10 0 90 80 70 60 50 40 ΔT=Th-Tc (°C) cuidevices.com 30 20 10 0 Additional Resources: Product Page CUI Devices │ SERIES: CP60H-2 │ DESCRIPTION: PELTIER MODULE | 3D Model date 10/29/2019 │ page 4 of 4 REVISION HISTORY rev. description date 1.0 initial release 05/21/2018 1.01 brand update 10/29/2019 The revision history provided is for informational purposes only and is believed to be accurate. CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website. CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use. CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness. cuidevices.com
CP60404567H-2 价格&库存
很抱歉,暂时无法提供与“CP60404567H-2”相匹配的价格&库存,您可以联系我们找货
