WIZ850IO
WIZ850IO
    WIZNET
    插件,25x23mm
    紧凑型网络模块
WIZ850IO 数据手册
products:wiz850io:start [Document Wiki] Page 1 of 5 Document Wiki WIZ850io Overview WIZ850io is a compact size network module that includes a W5500 (TCP/IP hardwired chip and PHY embedded), a transformer and RJ45. It can be used as a component and no effort is required to interface W5500 and Transformer. The WIZ850io is an ideal option for users who want to develop their Internet enabling systems rapidly. WIZ850io is hardware compatible with WIZ820io. WIZ820io users, to migrate to WIZ850io, need to modify the Firmware. For the detailed information on implementation of Hardware TCP/IP, refer to the W5500 Datasheet. Hardware Specification WIZ850io • • • • • • • • Plugin Network Module. Hardware compatible with WIZ820io. Usable without H/W design for W5500, Transformer & RJ45. Fast evaluation for W5500 & MCU in the target board. Support high speed SPI interface. Support power down mode and Wake-on-LAN function Very small form factor : 23mm x 25mm x 18mm 1 x 6, 2.54mm Pin Header x 2 Pin Out http://wizwiki.net/wiki/doku.php?id=products:wiz850io:start 8/22/2018 products:wiz850io:start [Document Wiki] Page 2 of 5 Pin Description Pin No. J1 Pin Type Description 1 P GND Ground 2 P GND Ground 3 I MOSI SPI Master Out Slave In This pin is used for SPI MOSI signal pin 4 I SCLK SPI Clock This pin is used for SPI Clock Signal pin 5 I SCNn SPI Slave Select This pin is used for SPI Slave Select Signal Pin when using SPI interface 6 I INTn W5500 Interrupt : Low activity This pin is used for indicating event like socket TCP connection, disconnection, data receiving timeout, WOL(Wake on Lan) and so on occurred in W5500 inside WIZ550io. The interrupt is cleared by writing IR register or Sn_IR. All interrupts are maskable. Pin No. J2 Pin Name Pin Type Pin Name Description 1 P GND Ground 2 P 3.3V Power : 3.3V power supply 3 P 3.3V Power : 3.3V power supply 4 - NC Not Connect 5 I RSTn Reset : Low activity Hold at least 500us after asserted to LOW and keep HIGH until next Reset needed. 6 O MISO SPI Master In Slave Out This pin is used for SPI MISO signal pin User need to wait for 50ms after this pin is changed to HIGH to communicate with WIZ850io. (Refer to 5. Timing Diagram) Characteristic DC Charcteristic http://wizwiki.net/wiki/doku.php?id=products:wiz850io:start 8/22/2018 products:wiz850io:start [Document Wiki] Symbol Page 3 of 5 Parameter Pins Min Typ Max Unit VDD Supply voltage 3.3V 2.97 3.3 3.63 V VIL High level input voltage ALL 2.0 5.5 V VIH Low level input voltage ALL -0.3 0.8 V VOL Low level output voltage ALL 0.4 V VOH High level output voltage ALL 2.4 LOL Low level output Current ALL 8.6 13.9 18.9 mA LOH High level output Current ALL 12.5 26.9 47.1 mA IDD Supply Current (Normal operation mode) 3.3V 132 mA LOH Supply Current (Power Down mode) 3.3V 13 mA V Power Dissipation Condition Min Typ Max Unit 100M Link - 128 - mA 10M Link - 75 - mA Un-Link (Auto-negotiation mode) - 65 - mA 100M Transmitting - 132 - mA 10M Transmitting - 79 - mA Power Down mode - 13 - mA SPI Operations As WIZ850io consists of W5500 and others, SPI operation of WIZ850io follows one of W5500. For more information about SPI operation of WIZ850io, please refer to W5500 Datasheet. Timing Diagram Reset Timing Symbol Description TRC Reset Cycle Time TPL Internal Auto Configuration Time Min Max 500us - - 50ms SPI Timing http://wizwiki.net/wiki/doku.php?id=products:wiz850io:start 8/22/2018 products:wiz850io:start [Document Wiki] Symbol Description Min Max Units Fsck SCLK Clock Frequency - 80 MHz TWH SCLK High duration 6 - ns TWL SCLK Low duration 6 - ns TCS nSCS High duration 5 - ns Page 4 of 5 Schematic • Revision 1.0 WIZ850io Rev1.0 Schematic(PDF) • Revision 1.0 WIZ850io Rev1.0 Schematic(Altium) Dimension • WIZ850io V1.0 3D PDF : Download • This PDF must be run using the 'Adobe Acrobat'. http://wizwiki.net/wiki/doku.php?id=products:wiz850io:start 8/22/2018 products:wiz850io:start [Document Wiki] Page 5 of 5 See Also • WizWiki Forum [http://www.wizwiki.net/forum] : WIZnet Forum for Technical support and Project shared http://wizwiki.net/wiki/doku.php?id=products:wiz850io:start 8/22/2018
WIZ850IO 价格&库存
很抱歉,暂时无法提供与“WIZ850IO”相匹配的价格&库存,您可以联系我们找货
WIZ850IO
    WIZ850IO
      库存:79
      WIZ850IO
        • 1+151.43950
        • 5+149.27600
        • 10+147.11260
        • 20+146.03090
        库存:40
        WIZ850IO
        • 1+203.584421+26.32900
        • 10+179.1193410+23.16500
        • 40+166.8868040+21.58300
        • 120+157.27552120+20.34000
        • 280+155.52801280+20.11400
        WIZ850IO
          库存:40
          WIZ850IO
          • 1+189.61174
          • 10+166.81761
          • 40+155.42653
          • 120+146.47896
          • 280+144.84995
