SIM8055-6-1-14-00-A
SIM8055-6-1-14-00-A
    GCT
    SMD
SIM8055-6-1-14-00-A 数据手册
9.00 C5 6x 1.20 10.89 8.30 1.45 4.85 0.70 12.2 Ø0.70+0.10 -0.00 CD -Y- 1.4 Pick/Place area G C6 2x 2.00 C6 C5 CD C7 C7 1.20 0.50 4.15 6x 1.00 0.10 A 4.60 2.54 7x 0.70 5x 1.00 H Specification: -X- Material: Plastic Housing: LCP 30%GF, UL94V-0, Black Contact Terminal: Phosphor Bronze,T= 0.12mm Cover: SUS301-H,T= 0.15mm 2x 1.00 F 0.10 C3 Ø0.90+0.10 -0.00 A 8.94+0.15 -0.00 Section A-A C1 Plating: Contact Terminal: Contact Area: 3µ” Gold Solder area: Gold Flash Underplating: Ni overall 50µ" min. Cover: Ni overall 50µ" min. Recommended PCB Layout (9.54) As viewed from component side General Tolerance ±0.05 Locating peg holes only applicable to locating peg version Solder Area 2.54 2.54 Keep Out Area Mechanical: Duration: 5000 cycles Component Outline 0.40 0.28 0.65 C2 5.08 7.15 10.60 5.08 0.37±0.05 E C1 C2 C3 0.35 Electrical: Voltage Rating: 30V max. Current Rating: 0.5A max. Operating Temperature: -40°C to +85°C Dielectric Withstanding Voltage: 100V AC (60 Sec min.) Insulation Resistance: 1000 MΩ min. Contact Resistance: 100 mΩ max. C 0.30 4.60 0.70 1.95 8.30±0.10 1.25 Ø0.60 0.12 1.35 0.75 For NanoSIM 1.10 D 9.00±0.10 10.8 Card Detect Switch Circuit: -Y- Card Detect C5 Without Card (Normally Open) Card Detect Ordering Grid C5 SIM8055 Card Inserted 6 1 XX 14 No. of Contacts 6=6 Switch 1 = With B A Request Samples and Quotation Packing Options A = Tape & Reel (1500 per Reel) Locating Peg 01 = With 00 = Without Profile Height (H) 14 = 1.35mm -XPart Number Product Description SIM8055 Nano SIM Card Connector,Push-Pull Type,with Switch 6 Pin, SMT, Profile 1.35mm Drawing Date A 27th November 2017 1 2 3 4 By CC Detail Drawing Release Revision Date 5 A5 22/01/21 Tolerances (Except as Noted) Length Angle X. ± 0.35 X.X ± 0.25 X.XX ± 0.15 X.XXX ± 0.10 All ± 2° Units: Metric (mm) C 3rd Angle Projection 6 7 This drawing is confidential and copyright of Global Connector Technology, Ltd (GCT). This drawing must not be copied or disclosed without written consent. E & OE www.gct.co Not to Scale Drawn By CC 8 Sheet No. 1/3 H 25.00mm Mini G 15.00mm Micro 12.30mm Nano D 8.80mm Nano 15.00mm Mini E 12.00mm Micro F C1----->VCC C2----->RST Nano SIM C3----->CLK C5----->GND C6----->Vpp C7----->I/O Micro SIM C Mini SIM Reference B Part Number Product Description SIM8055 Nano SIM Card Connector,Push-Pull Type,with Switch 6 Pin, SMT, Profile 1.35mm Drawing Date A 27th November 2017 By CC Detail Drawing Release Revision Date 1 2 3 4 5 A5 22/01/21 Tolerances (Except as Noted) Length X. ± 0.35 X.X ± 0.25 X.XX ± 0.15 X.XXX ± 0.10 Angle Units: Metric (mm) All ± 2° C 3rd Angle Projection 6 7 This drawing is confidential and copyright of Global Connector Technology, Ltd (GCT). This drawing must not be copied or disclosed without written consent. E & OE www.gct.co Not to Scale Drawn By CC 8 Sheet No. 2/3 H 400 MIN. Peeling Angle 165°~1 80° Reel Label RoHS Label Ø330 1500Pcs/Reel G 160mm Product Loading Section F Unloaded Section Desiccant Vacuum Bag 44cmX45cm 128mm Unloaded Section 24.5 28.5 Direction of Unreeling 1.75 11.50±0.15 E Reels / Carton 9 Pcs / Reel 1500 Total Qualtity 13500 Inner Carton Label 2.00 RoHS Label 4.00 Ø 1. 50 13500Pcs/carton 2.60 Inner Carton:340mmX340mmX285mm 24.00±0.3 D C 16.00 B Box label RoHS Label Notes: Peeling off force of top tape: 0.1-1.3N (Peeling direction as shown) Materials: Carrier Tape: Polystyrene (PS) Top Tape: PE Reel Tape: Polystyrene (PS) Bag: PE A Box: 355mmX355mmX305mm Part Number Product Description SIM8055 Nano SIM Card Connector,Push-Pull Type,with Switch 6 Pin, SMT, Profile 1.35mm Drawing Date 27th November 2017 By CC Detail Drawing Release Revision Date 1 2 3 4 5 Tolerances (Except as Noted) Length Angle A5 22/01/21 Units: Metric (mm) C 3rd Angle Projection 6 7 This drawing is confidential and copyright of Global Connector Technology, Ltd (GCT). This drawing must not be copied or disclosed without written consent. E & OE www.gct.co Not to Scale Drawn By CC 8 Sheet No. 3/3
SIM8055-6-1-14-00-A 价格&库存
很抱歉,暂时无法提供与“SIM8055-6-1-14-00-A”相匹配的价格&库存,您可以联系我们找货
SIM8055-6-1-14-00-A
  • 1+11.725021+1.51979
  • 10+9.9779910+1.29334
  • 25+9.3506025+1.21202
  • 50+8.9027050+1.15396
  • 100+8.47709100+1.09880
  • 250+7.94590250+1.02994
  • 500+7.56650500+0.98077
库存:44898
SIM8055-6-1-14-00-A
    • 50+7.24420
    • 100+7.00270
    库存:506
    SIM8055-6-1-14-00-A
    • 1+12.01925
    • 37+9.13605
    • 112+8.69705
    • 300+8.15126
    • 750+7.77158
    库存:2268
