2474
2474
    ADAFRUIT
2474 数据手册
    Super Fancy Third Hand Kit from Hobby Creek with Four Arms PRODUCT ID: 2474        Description Frustrated with traditional third hands? Want a more adaptable tool? Love Doctor Octopus? Search no  more! We present the ultra‐fancy Third Hand Kit. The Third Hand Kit comes with 4 bendable arms  which can easily be positioned and are stiff enough to stay in place. Alligator clips are securely attached  to the end of the arms using thread locker. There are both small and large clips which allow you to  easily clip wires, circuits boards, electronics components and even screws. This is a versatile fully  assembled tool from Hobby Creek that will help you tackle your projects with ease and  improved efficiency!  Features:  o o o o o o o o Heavy Aluminum base for easy positioning  2 pockets in Aluminum base to hold loose components  Rubber feet to prevent slipping  4 Large alligator clips for various sized components and boards  Alligator clips have a heat shrink covering to prevent marring  Alligator clips are securely attached using thread locker  8 threaded sockets in base for more arms or a different configuration  As of November 11th 2016, this now comes with:   4 Flexible Swivel Arms (The alligator clips on the end of each arm now swivel  360 degrees!)   Updated rubber Gaskets   Polished raw aluminum look finish  Note: Shipping weight reflects UPS' new dimensional weight regulations.  https://www.ups.com/us/en/help‐center/packaging‐and‐supplies/determine‐billable‐ weight.page?WT.mc_id=VAN701060  Technical Details  o o o o Base Dimensions: 150mm x 100mm  x 12mm / 5.9" x 3.9" x 0.5"  Arm Diameter: 16mm / 0.6"  Arm Length (including clip): 350mm / 13.8"  Weight: 470g  As of June 18th, 2015 this product now comes with 4 large clips instead of 2 large clips and 2 small  clips.  Process:  The base is CNC machined from a billet of 6061 aluminum. Every feature is machined to a tolerance  of plus or minus five thousandths of an inch. They then blend the surface of the material by bead  blasting them to a matte finish. Finally the parts are clear anodized for a durable finish. The base is  proudly manufactured in the USA.  For product support, replacement parts and warranty for all Hobby Creek products, click here!  https://www.hobbycreek.com/pages/contact‐us                                                      https://www.adafruit.com/product/2474 7‐26‐17
很抱歉,暂时无法提供与“2474”相匹配的价格&库存,您可以联系我们找货
