BCM4013OLFC-42-JST-ZHR-2
    BESTAR
BCM4013OLFC-42-JST-ZHR-2 数据手册
SPECIFICATION Acoustics & Sensor FOR ELECTRO-MAGNET DYNAMIC MICROPHONE TOTAL PAGE 07 www.be-star.com RoHS Customer Model Name BCM4013OLFC-42-JST-ZHR-2 Customer P/N Product No. Date 23 Aug.11 Issue No. Page 01 of 07 Issue Date 195013 BS/TEM01.131B 11/08/23 Approval: 1.Characteristics 2.Drawing 3.Measurement Circuit 4.Reliability Test 5.Packing 6.History change record Drawn by Checked by Approved by Customer approved BESTAR ELECTRONICS INDUSTRY CO.,LTD No.199 HuangHe West Road.New district,ChangZhou,JiangSu Province,P.R.China Tel: +86 519 88222567 Fax: +86 519 88222551 www.bestargroups.com info@be-star.com http://www.bestargroups.com Acoustics & Sensor 6 5 4 2 3 1 H H BCM4013OLFC-42-JST-ZHR-2 1. Characteristics Test Condition (Vs=2V G No. Item G Specifications - 42 ±3dB (0dB=1V/Pa,1kHz) 1 Sensitivity 2 Frequency Response 50-16kHz 3 Current Consumption 0.5mA Max. 4 Directional Omnidirectional 5 S/N Ratio more than 58dB 6 Standard Operating Voltage 7 Operating Voltage 8 Sensitivity reduction F 2V 1V~10V within -3dB at 1.5V E E 9 Distortion 2% 10 Storage Temperature -40 °C to +70°C 11 Operating Temperature -30 °C to +60 °C D D ★Frequency Resonse Curve +20 +10 Relative Response (dB) This print and information there in are proprietary to Bestar Electronics Industry Co., Ltd. and shall not be used in whole or in part without its written content F RL=2.2K Ω Ta=20℃ R.H.=65%) C +3 0 +10 +3 0 C -10 -3 -3 -6 -10 -20 -30 B 20 50 100 200 500 1k 2k 5k 10k 20k B Frequency(Hz) 11.08.23 Date: A B 11.08.23 王焕焕 Drawn by: 王焕焕 A 10.08.01 王焕焕 Checked by: 徐 波 Rev. Date Drawn Approved by: 王 平 Note www.be-star.com wu@be-star.com 6 5 4 3 BCM4013OLFC-42-JST-ZHR-2 Microphone DRG NO: BS/TEM01.131B 2 Page:2 of 7 1 A Acoustics & Sensor 6 5 4 1 2 3 H H BCM4013OLFC-42-JST-ZHR-2 ★Angular Response 180 150 G 210 220 120 G 270 90 60 300 F F 330 30 This print and information there in are proprietary to Bestar Electronics Industry Co., Ltd. and shall not be used in whole or in part without its written content 0 2. Drawing filter E E Red Black D D JST ZHR -2 400±3 Red C C Black B B B A A 11.08.23 10.08.01 Date Rev. Date: 11.08.23 王焕焕 Drawn by: 王焕焕 王焕焕 Checked by: 徐 波 Drawn Approved by: 王 平 Note www.be-star.com wu@be-star.com 6 5 4 3 BCM4013OLFC-42-JST-ZHR-2 Microphone DRG NO: BS/TEM01.131B 2 Page:3 of 7 1 A Acoustics & Sensor 5 6 4 2 3 1 H H BCM4013OLFC-42-JST-ZHR-2 Ø4.8±0.2 G 2.4±0.2 G F JST SZH-003T-P0.5 Ø4.8±0.2 1.3±0.2 This print and information there in are proprietary to Bestar Electronics Industry Co., Ltd. and shall not be used in whole or in part without its written content F Ø4.0±0.2 E E Ø3.0±0.2 D D Note:wires use UL3302 AWG 32# 3. Measurement Circuit: C C FET impedance Converter Output C1 10pF ECM unit F Terminal 1 C2 33pF Power Supply + 2.0V RL=2.2K Earth - B B Terminal 2 Shield Case 11.08.23 Date: A B 11.08.23 王焕焕 Drawn by: 王焕焕 A 10.08.01 王焕焕 Checked by: 徐 波 Approved by: 王 平 Date Rev. Drawn Note www.be-star.com wu@be-star.com 6 5 4 3 BCM4013OLFC-42-JST-ZHR-2 Microphone DRG NO: BS/TEM01.131B 2 Page:4 of 7 1 A Acoustics & Sensor 5 6 H 4 2 3 1 H BCM4013OLFC-42-JST-ZHR-2 4.Reliability Test 4.1 G 4.2 4.3 High temp.life test Temperature Duration Low temp.life test Temperature Duration Temperature cycle test Cycles F +85 °C 100hrs -40 °C 100hrs 10 F -40 C This print and information there in are proprietary to Bestar Electronics Industry Co., Ltd. and shall not be used in whole or in part without its written content +20 C +85 C 1hrs 4.4 E 4.5 D 4.6 4.7 C 4.8 +20 C 1hrs 1hrs 1hrs Humidity Test Temperature +40 °C Relative Humidity 90~95% Duration 48hrs Tests above should be measured after leaving normal temperature for 6hrs. Vibration Test Vibration Frequency 10~55Hz Amplitude 1.52mm/min Direction 3(x.y&z) Duration 2hrs each cycle(total 6 hrs) Drop test Height 1m (Dropped to 20mm thick hardwood board without packing.) Direction 3 Soldering Heat Shock . Temperature 260 ±5°c Duration 2 ±0.5 sec Terminal Mechanical Strength Strength 1kg Duration 1 min E D C Notice: All specifications must be satisfied in this condition. Sensitivity :Allowable deviation within ±3dB from initial sensitivity. B A G Date: 11.08.23 B 11.08.23 王焕焕 Drawn by: 王焕焕 A 10.08.01 王焕焕 Checked by: 徐 波 Drawn Approved by: 王 平 Date Rev. Note www.be-star.com wu@be-star.com 6 5 4 3 B BCM4013OLFC-42-JST-ZHR-2 Microphone DRG NO: BS/TEM01.131B 2 Page:5 of 7 1 A Acoustics & Sensor 6 5 4 2 3 1 BCM4013OLFC-42-JST-ZHR-2 H H 5. Packing 105±3 100 PCS per anti-static bag G 118±3 G 500 PCS 5 anti-static bags per middle box 54±0.5 12±3 F E E 1 215±0.5 .5 ±0 5 0 4500PCS 9 middle boxes per carton D D 207 This print and information there in are proprietary to Bestar Electronics Industry Co., Ltd. and shall not be used in whole or in part without its written content F C C 233 363 B A B A Date: 11.08.23 11.08.23 王焕焕 Drawn by: 王焕焕 10.08.01 王焕焕 Checked by: 徐 波 Approved by: 王 平 Date Rev. Drawn Note www.be-star.com wu@be-star.com 6 5 4 3 Remark: 100 pcs per anti-static bag 5 anti-static bags per middle box 9 middle boxes per carton Total 4500pcs per carton Size: 363×233×207(mm) B BCM4013OLFC-42-JST-ZHR-2 Microphone DRG NO: BS/TEM01.131B 2 Page:6 of 7 1 A Acoustics & Sensor 6 H 5 4 2 3 1 BCM4013OLFC-42-JST-ZHR-2 H 6. History change record version No. G Change Items A Change the length of the lead This print and information there in are proprietary to Bestar Electronics Industry Co., Ltd. and shall not be used in whole or in part without its written content B Date Drawn 10.08.01 王焕焕 王 平 11.08.23 王焕焕 王 平 After Before Approved G F F E E D D C C B B 11.08.23 Date: A B 11.08.23 王焕焕 Drawn by: 王焕焕 A 10.08.01 王焕焕 Checked by: 徐 波 Approved by: 王 平 Date Rev. Drawn Note www.be-star.com wu@be-star.com 6 5 4 3 BCM4013OLFC-42-JST-ZHR-2 Microphone DRG NO: BS/TEM01.131B 2 Page:7 of 7 1 A
BCM4013OLFC-42-JST-ZHR-2 价格&库存
很抱歉,暂时无法提供与“BCM4013OLFC-42-JST-ZHR-2”相匹配的价格&库存,您可以联系我们找货
