CL0508KRX7R8BB104
CL0508KRX7R8BB104
    YAGEO(国巨)
    CL0508KRX7R8BB104
CL0508KRX7R8BB104 数据手册
DATA SHEET SURFACE-MOUNT CERAMIC MULTILAYER CAPACITORS Low-Inductance X5R / X7R 6.3 V TO 50 V 10 nF to 1 uF Product Specification – November 21, 2016 V.1 RoHS compliant & Halogen Free Product specification Surface-Mount Ceramic Multilayer Capacitors Low Inductance X5R, X7R 6.3V to 50V SCOPE ORDERING INFORMATION - GLOBAL PART NUMBER, PHYCOMP This specification describes Midvoltage X7R series chip capacitors with lead-free terminations CTC All part numbers are identified by the series, size, tolerance, TC material, packing style, voltage, process code, termination and capacitance value. APPLICATIONS High speed IC packages YAGEO BRAND ordering code Processor package decoupling GLOBAL PART NUMBER ( PREFERRED ) AC noise reduction in multi-chip modules. CL FEATURES Supplied in tape on reel Nickel-barrier end termination RoHS compliant Halogen Free compliant 2 13 XXXX X X XXX X (1) (2) (3) (4) (5) BB XXX (6) (1) SIZE – INCH BASED (METRIC) 0204(0510) 0306(0816) 0508(1220) 0612(1632) (2) TOLERANCE K = ± 10% M = ± 20% (3) PACKING STYLE R = Paper/PE taping reel; Reel 7 inch K = Blister taping reel; Reel 7 inch P = Paper/PE taping reel; Reel 13 inch F = Blister taping reel; Reel 13 inch (4) TC MATERIAL X5R / X7R (5) RATED VOLTAGE 5 = 6.3 V 6 = 10 V 7 = 16 V 8 = 25 V 9 = 50 V (6) CAPACITANCE VALUE 2 significant digits+number of zeros The 3rd digit signifies the multiplying factor, and letter R is decimal point Example: 121 = 12 x 101 = 120 pF www.yageo.com Nov. 21, 2016 V.1 Product specification Surface-Mount Ceramic Multilayer Capacitors Low Inductance X5R, X7R 6.3V to 50V 3 13 CONSTRUCTION The capacitor consists of a rectangular block of ceramic dielectric in which a number of interleaved metal electrodes are contained. This structure gives rise to a high capacitance per unit volume. The inner electrodes are connected to the two end terminations and finally covered with a layer of plated tin (NiSn). The terminations are lead-free. A cross section of the structure is shown in Fig.1. Fig. 1 Surface mounted multilayer ceramic capacitor construction DIMENSION OUTLINES Table 1 For outlines see fig. 2 TYPE L1 (mm) W (mm) T (mm) L2 / L3 (mm) min. max. L4 (mm) For dimension see Table 1 min. 0204 0.5 ± 0.1 1.0 ± 0.1 0.3 ± 0.1 0.1 0.3 0.1 0306 0.8 ± 0.15 1.6 ± 0.2 0.5 ± 0.1 0.1 0.3 0.2 0508 1.25 ± 0.2 2.0 ± 0.2 0.85 ± 0.1 0.13 0.46 0.38 0612 1.6 ± 0.2 3.2 ± 0.2 0.85 ± 0.1 0.13 0.46 0.50 0612* 1.6 ± 0.2 3.2 ± 0.2 1.15 ± 0.1 0.13 0.46 0.50 Fig. 2 Surface mounted multilayer ceramic capacitor dimension 0612*: 1uF/16V, 470nF~1uF/25V, 120nF~470nF/50V www.yageo.com Nov. 21, 2016 V.1 Product specification Surface-Mount Ceramic Multilayer Capacitors Low Inductance X5R, X7R 6.3V to 50V 4 13 CAPACITANCE RANGE & THICKNESS FOR X5R Table 2 Sizes from 0204 CAP. 0204 6.3 V / 10V 10 nF 0.3 ± 0.1 15 nF 0.3 ± 0.1 22 nF 0.3 ± 0.1 33 nF 0.3 ± 0.1 47 nF 0.3 ± 0.1 68 nF 0.3 ± 0.1 100 nF 0.3 ± 0.1 150 nF 220 nF 330 nF 470 nF 680 nF 1 uF NOTE 1. Values in shaded cells indicate thickness class in mm 2. Capacitance value of non E-6 series is on request 3. For special ordering code, please contact local sales force before order. www.yageo.com Nov. 21, 2016 V.1 Product specification Surface-Mount Ceramic Multilayer Capacitors Low Inductance X5R, X7R 6.3V to 50V 5 13 CAPACITANCE RANGE & THICKNESS FOR X7R Table 3 CAP. Sizes from 0306 to 0508 0306 0508 6.3 V / 10V 10 V 16 V 25 V 10 nF 0.85 ± 0.1 0.85 ± 0.1 0.85 ± 0.1 15 nF 0.85 ± 0.1 0.85 ± 0.1 0.85 ± 0.1 22 nF 0.85 ± 0.1 0.85 ± 0.1 0.85 ± 0.1 33 nF 0.85 ± 0.1 0.85 ± 0.1 0.85 ± 0.1 47 nF 0.85 ± 0.1 0.85 ± 0.1 0.85 ± 0.1 68 nF 0.85 ± 0.1 0.85 ± 0.1 0.85 ± 0.1 0.85 ± 0.1 0.85 ± 0.1 0.85 ± 0.1 0.85 ± 0.1 0.85 ± 0.1 0.85 ± 0.1 0.85 ± 0.1 100 nF 0.5 ± 0.1 150 nF 220 nF 0.5 ± 0.1 330 nF 470 nF 0.85 ± 0.1 680 nF 1 uF 0.85 ± 0.1 NOTE 1. Values in shaded cells indicate thickness class in mm 2. Capacitance value of non E-6 series is on request 3. For special ordering code, please contact local sales force before order. www.yageo.com Nov. 21, 2016 V.1 Product specification Surface-Mount Ceramic Multilayer Capacitors Low Inductance X5R, X7R 6.3V to 50V 6 13 CAPACITANCE RANGE & THICKNESS FOR X7R Table4 Sizes from 0612 CAP. 0612 6.3 V 10 V 16 V 25 V 50 V 10 nF 0.85 ± 0.1 0.85 ± 0.1 0.85 ± 0.1 0.85 ± 0.1 0.85 ± 0.1 15 nF 0.85 ± 0.1 0.85 ± 0.1 0.85 ± 0.1 0.85 ± 0.1 0.85 ± 0.1 22 nF 0.85 ± 0.1 0.85 ± 0.1 0.85 ± 0.1 0.85 ± 0.1 0.85 ± 0.1 33 nF 0.85 ± 0.1 0.85 ± 0.1 0.85 ± 0.1 0.85 ± 0.1 0.85 ± 0.1 47 nF 0.85 ± 0.1 0.85 ± 0.1 0.85 ± 0.1 0.85 ± 0.1 0.85 ± 0.1 68 nF 0.85 ± 0.1 0.85 ± 0.1 0.85 ± 0.1 0.85 ± 0.1 0.85 ± 0.1 100 nF 0.85 ± 0.1 0.85 ± 0.1 0.85 ± 0.1 0.85 ± 0.1 0.85 ± 0.1 150 nF 0.85 ± 0.1 0.85 ± 0.1 0.85 ± 0.1 1.15 ± 0.1 1.15 ± 0.1 220 nF 0.85 ± 0.1 0.85 ± 0.1 0.85 ± 0.1 1.15 ± 0.1 1.15 ± 0.1 330 nF 0.85 ± 0.1 0.85 ± 0.1 0.85 ± 0.1 1.15 ± 0.1 1.15 ± 0.1 470 nF 0.85 ± 0.1 0.85 ± 0.1 0.85 ± 0.1 1.15 ± 0.1 1.15 ± 0.1 680 nF 1.15 ± 0.1 1.15 ± 0.1 1.15 ± 0.1 1.15 ± 0.1 1 uF 1.15 ± 0.1 1.15 ± 0.1 1.15 ± 0.1 1.15 ± 0.1 NOTE 1. Values in shaded cells indicate thickness class in mm 2. Capacitance value of non E-6 series is on request 3. For special ordering code, please contact local sales force before order THICKNESS CLASSES AND PACKING QUANTITY Table 5 SIZE CODE THICKNESS CLASSIFICATION TAPE WIDTH QUANTITY PER REEL 0204 Ø 180 MM / 7 INCH Paper Blister Ø 330 MM / 13 INCH Paper Blister QUANTITY PER BULK CASE 0.3 ± 0.1 mm 8 mm 10,000 --- --- --- --- 0306 0.5 ± 0.1 mm 8 mm 4,000 --- 15,000 --- --- 0508 0.85 ± 0.1 mm 8 mm 4,000 --- 15,000 --- --- 0612 0.85 ± 0.1 mm 8 mm 4,000 --- 15,000 --- --- 0612 1.15 ± 0.1 mm 8 mm --- 3,000 --- --- --- www.yageo.com Nov. 21, 2016 V.1 Product specification Surface-Mount Ceramic Multilayer Capacitors Low Inductance X5R, X7R 7 13 6.3V to 50V ELECTRICAL CHARACTERISTICS X7R DIELECTRIC CAPACITORS; Unless otherwise specified, all test and measurements shall be made under standard atmospheric conditions for testing as given in 5.3 of IEC 60068-1: - Temperature: 15 °C to 35 °C Relative humidity: 25% to 75% Air pressure: 86 kPa to 106 kPa Before the measurements are made, the capacitor shall be stored at the measuring temperature for a time sufficient to allow the entire capacitor to reach this temperature. The period as prescribed for recovery at the end of a test is normally sufficient for this purpose. Table 6 DESCRIPTION Capacitance range VALUE 10 nF to 1 uF Capacitance tolerance X5R / X7R ± 10%, ± 20% Dissipation factor (D.F.) X5R / X7R Insulation resistance after 1 minute at Ur (DC) ≤5% Rins ≥ 10 GΩ or Rins × C ≥ 500 seconds whichever is less Maximum capacitance change as a function of temperature (temperature characteristic/coefficient): X5R / X7R ± 15% Operating temperature range: X5R –55 °C to +85 °C X7R –55 °C to +125 °C www.yageo.com Nov. 21, 2016 V.1 Product specification Surface-Mount Ceramic Multilayer Capacitors Low Inductance X5R, X7R 6.3V to 50V 8 13 SOLDERING RECOMMENDATION Table 7 SIZE SOLDERING METHOD 0204 0306 0508 0612 O O O O Reflow Reflow/Wave TESTS AND REQUIREMENTS Table 8 Test procedures and requirements TEST TEST METHOD PROCEDURE REQUIREMENTS Mounting IEC 6038421/22 4.3 The capacitors may be mounted on printed-circuit boards or ceramic substrates No visible damage Visual Inspection and Dimension Check 4.4 Any applicable method using × 10 magnification In accordance with specification Capacitance 4.5.1 Class 2: f = 1 KHz, measuring at voltage 1 Vrms at 20 °C Within specified tolerance Dissipation Factor (D.F.) 4.5.2 Class 2: f = 1 KHz, measuring at voltage 1 Vrms at 20 °C In accordance with specification Insulation Resistance 4.5.3 At Ur (DC) for 1 minute In accordance with specification www.yageo.com Nov. 21, 2016 V.1 Product specification Surface-Mount Ceramic Multilayer Capacitors TEST TEST METHOD Temperature coefficient 4.6 Low Inductance X5R, X7R 6.3V to 50V 9 13 PROCEDURE REQUIREMENTS Capacitance shall be measured by the steps shown in the following table. Class2: X7R/X5R : ∆ C/C : ± 15% The capacitance change should be measured after 5 min at each specified temperature stage. In case of applying voltage, the capacitance change should be measured after 1 more min. with applying voltage in equilibration of each temp. stage. Step Temperature(℃) a 25± 2 b Lower temperature± 3℃ c 25± 2 d Upper Temperature± 2℃ e 25± 2 Class II Capacitance Change shall be calculated from the formula as below C2 - C1 ∆C = x 100% C1 C1: Capacitance at step c C2: Capacitance at step b or d Adhesion Bending Strength IEC 6038421/22 4.7 A force applied for 10 seconds to the line joining the terminations and in a plane parallel to the substrate Force size ≥ 0306: 5N size = 0204: 2.5N 4.8 Mounting in accordance with IEC 60384-22 paragraph 4.3 No visible damage Conditions: bending 1 mm at a rate of 1 mm/s, radius jig 5 mm ∆C/C Class2: X7R/X5R : ± 10% www.yageo.com Nov. 21, 2016 V.1 Product specification Surface-Mount Ceramic Multilayer Capacitors TEST TEST METHOD Resistance to Soldering Heat 4.9 6.3V to 50V 10 13 REQUIREMENTS Precondition: 150 +0/–10 °C for 1 hour, then keep for 24 ± 1 hours at room temperature Dissolution of the end face plating shall not exceed 25% of the length of the edge concerned Preheating: 120 °C to 150 °C for 1 minute and 170 °C to 200 °C for 1 minute. Class2: Dipping time: 10 ± 0.5 seconds Recovery time: 24 ± 2 hours 4.10 X5R, X7R PROCEDURE Solder bath temperature: 260 ± 5 °C Solderability Low Inductance Preheated the temperature of 80 °C to 140 °C and maintained for 30 seconds to 60 seconds. ∆C/C X7R/X5R : ± 10% D.F. within initial specified value Rins within initial specified value The solder should cover over 95% of the critical area of each termination Test conditions for leadfree containing solder alloy Temperature: 245 ± 5 °C Dipping time: 3 ± 0.3 seconds Depth of immersion: 10 mm Rapid Change of Temperature IEC 6038421/22 4.11 Preconditioning; 150 +0/–10 °C for 1 hour, then keep for 24 ± 1 hours at room temperature 5 cycles with following detail: 30 minutes at lower category temperature 30 minutes at upper category temperature Recovery time 24 ± 2 hours No visual damage ∆C/C Class2: X7R/X5R : ± 15% D.F. meet initial specified value Rins meet initial specified value www.yageo.com Nov. 21, 2016 V.1 Product specification Surface-Mount Ceramic Multilayer Capacitors TEST Damp Heat with Ur load TEST METHOD 4.13 Low Inductance X5R, X7R 6.3V to 50V PROCEDURE REQUIREMENTS 1. Preconditioning, class 2 only: No visual damage after recovery 150 +0/-10 °C /1 hour, then keep for 24 ± 1 hour at room temp 2. Initial measure: Spec: refer initial spec C, D, IR 3. Damp heat test: 500 ± 12 hours at 40 ± 2 °C; 90 to 95% R.H; 1.0 Ur applied. 4. Recovery: Class 1: 6 to 24 hours Class 2: 24 ± 2 hours 5. Final measure: C, D, IR P.S. If the capacitance value is less than the minimum value permitted, then after the other measurements have been made the capacitor shall be precondition according to “IEC 60384 4.1” and then the requirement shall be met. 11 13 ∆C/C Class2: X7R/X5R : ± 20% D.F. Class2: X7R/X5R : ≤ 2 x specified value Rins Class2: X7R/X5R : ≥ 500 MΩ or Rins x Cr ≥ 25s whichever is less Δ C/C Class2: X7R/X5R : ± 25% D.F. Class2: X7R/X5R : ≤ 2 x specified value Rins Rins x Cr ≥ 25Ω· F www.yageo.com Nov. 21, 2016 V.1 Product specification Surface-Mount Ceramic Multilayer Capacitors Low Inductance X5R, X7R TEST TEST METHOD PROCEDURE REQUIREMENTS Endurance IEC 6038421/22 1. Preconditioning, class 2 only: No visual damage 4.14 150 +0/-10 °C /1 hour, then keep for 24 ± 1 hour at room temp 2. Initial measure: Spec: refer initial spec C, D, IR 3. Endurance test: Temperature: NP0: 125 °C Specified stress voltage applied for 1,000 hours: Applied 2.0 x Ur for general product Temperature: X7R: 125°C Specified stress voltage applied for 1,000 hours: Recovery time: 24 ± 2 hours 4. Final measure: C, D, IR P.S. If the capacitance value is less than the minimum value permitted, then after the other measurements have been made the capacitor shall be precondition according to “IEC 60384 4.1” and then the requirement shall be met. 6.3V to 50V 12 13 ∆C/C Class2: X7R/X5R : ± 20% D.F. Class2: X7R/X5R : ≤ 2x initial value max Rins Class2: X7R/X5R : ≥ 1,000 MΩ or Rins x Cr ≥ 50s whichever is less Δ C/C Class2: X7R/X5R : ± 25% D.F. Class2: X7R/X5R : ≤ 2x initial value max Rins Class2: Rins x Cr ≥ 50 Ω· F Voltage Proof IEC 60384-1 4.5.4 Specified stress voltage applied for 1 to 5 seconds Ur ≤ 100 V: series applied 2.5 Ur Charge/Discharge current less than 50mA No breakdown or flashover www.yageo.com Nov. 21, 2016 V.1 Product specification Surface-Mount Ceramic Multilayer Capacitors Low Inductance X5R, X7R 6.3V to 50V 13 13 REVISION HISTORY REVISION DATE CHANGE NOTIFICATION DESCRIPTION Version 1 Nov. 7, 2016 - - Add 13" packing Version 0 Jun. 26, 2015 - - New www.yageo.com Nov. 21, 2016 V.1
CL0508KRX7R8BB104 价格&库存
很抱歉,暂时无法提供与“CL0508KRX7R8BB104”相匹配的价格&库存,您可以联系我们找货
CL0508KRX7R8BB104
  • 1+3.969281+0.51600
  • 10+2.3645010+0.30738
  • 50+1.7364650+0.22574
  • 100+1.54322100+0.20062
  • 500+1.21661500+0.15816
库存:4000
CL0508KRX7R8BB104
  • 4000+0.964994000+0.12545
  • 12000+0.8809012000+0.11452
库存:4000
