nRF52833
Bluetooth 5.3 SoC supporting Bluetooth Low Energy, Bluetooth
mesh, NFC, Thread and Zigbee, qualified for up to 105°C.
Overview
The nRF52833 is an ultra-low-power multiprotocol SoC qualified for operation
at an extended temperature range of -40° C to 105° C. Its feature set fulfills
the requirements of professional lighting, advanced wearables, and higher
value IoT applications. It supports Bluetooth LE, Bluetooth mesh, 802.15.4,
Thread, Zigbee, and proprietary 2.4 GHz protocols.
The nRF52833 is built around a 64 MHz Arm Cortex-M4 with floating-point
unit (FPU). It has 512 KB flash and 128 KB RAM memory available for highervalue applications. The extended temperature range up to 105° C, a generous
amount of memory, and dynamic multiprotocol support ensures the nRF52833
is an ideal device for a wide range of commercial and industrial applications,
including professional lighting and asset tracking. The 1:4 RAM to Flash ratio
and +8 dBm output power make the nRF52833 SoC suitable for advanced
wearables or smart home applications where robust coverage is important.
It includes a range of analog and digital interfaces such as NFC-A, ADC,
Full-speed 12 Mbps USB 2.0, High-speed 32 MHz SPI, UART/SPI/TWI, PWM,
I2S, and PDM. The 1.7 V to 5.5 V supply voltage range, enables powering the
device from rechargeable batteries or over USB.
Wireless protocol support
The nRF52833 SoC supports an extensive range of wireless protocols. It
supports Bluetooth Low Energy and is capable of all angle-of-arrival and
angle-of-departure roles in Direction Finding, Long Range, high-throughput
2 Mbps and Advertising Extensions features. Mesh protocols like Bluetooth
mesh, Thread and Zigbee can be run concurrently with Bluetooth LE, enabling
smartphones to provision, commission, configure and control mesh nodes.
NFC, ANT, 802.15.4 and 2.4 GHz proprietary protocols are also supported.
Key features
Arm processor
y 64 MHz Arm® Cortex-M4 with FPU
y 512 KB Flash + 128 KB RAM
y 8 KB cache
Bluetooth 5.3 Radio
y Direction Finding
y Long Range
y Bluetooth mesh
y +8 dBm TX power
y -95 dBm sensitivity (1 Mbps)
IEEE 802.15.4 radio support
y Thread
y Zigbee
NFC
Full range of digital interfaces with
EasyDMA
y Full-speed USB
y 32 MHz high-speed SPI
128 bit AES/ECB/CCM/AAR accelerator
12-bit 200 ksps ADC
105 °C extended operating temperature
1.7-5.5 V supply voltage range
Applications
Professional lighting
Industrial
Advanced wearables
Gaming
Smart home
Asset tracking and RTLS
nRF52805
nRF52810
nRF52811
nRF52820
nRF52832
nRF52833
nRF52840
nRF5340
Bluetooth 5.3
X
X
X
X
X
X
X
X
Bluetooth
2 Mpbs
X
X
X
X
X
X
X
X
Bluetooth
Long Range
X
X
X
X
X
Bluetooth
Direction Finding
X
X
X
X
Bluetooth
LE Audio
X
X
Bluetooth mesh
Thread
Zigbee
Matter
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
For more information please visit: nordicsemi.com/nRF52833
nRF52833 SoC Product Brief Version 2.1
Bluetooth Direction Finding
The nRF52833 includes a radio capable of Bluetooth®
Direction Finding. Direction Finding enables
positioning solutions to not only rely on received signal
strength indicator (RSSI), but also the actual direction of a
signal. This improves accuracy and opens new possibilities
for applications in this segment. There are two types of
methods for determining direction, angle of arrival (AoA),
where the direction of the received signal is calculated,
and angle of departure (AoD), where the direction of the
transmitted signal is calculated. In addition to act as a
simple transmitter in either scheme, the generous available
memory and processing power on the nRF52833 also
allows for calculating the angles when being a receiver in
either AoA or AoD mode. Illustrated below is an example
of a real time location system (RTLS) where the principle of
AoA is used to deremine the location of a tag.
Specification
Microprocessor
CPU
Memory
Cache
Performance
Efficiency
Hardware security
128-bit AES CCM, ECB, AAR
Wireless protocol
support
Bluetooth Low Energy/Bluetooth mesh/
NFC/Thread/Zigbee/802.15.4/ANT/2.4 GHz
proprietary
On-air data rate
Bluetooth LE:
802.15.4:
TX power
Programmable from +8 to -20 dBm in 4 dB
steps
RX sensitivity
Bluetooth LE:
802.15.4:
2.4 GHz:
Radio current
consumption
DC/DC at 3 V
15.50 mA at +8 dBm TX power,
6 mA at 0 dBm TX power,
6 mA in RX at 1 Mbps
Oscillators
64 MHz from 32 MHz external crystal or
internal 32 kHz from crystal, RC or synthesized
System current
consumption
DC/DC at 3 V
0.6 μA in System OFF, no RAM retention
1.3 μA in System OFF, full RAM retention
1.1 μA in System ON, no RAM retention
1.8 μA in System ON, full RAM retention
2.6 μA in System ON, full RAM retention and
RTC
Digital interfaces
12 Mbps full-speed USB 2.0
2xTWI/SPI, SPI, 2xUART
I²S, PDM
4xPWM
QDEC
Analog interfaces
12-bit, 200 ksps ADC, low-power comparator,
general-purpose comparator
Other peripherals
5 x 32 bit timer/counter, 3 x 24 bit real-time
counter, DPPI, GPIOTE, Temp sensor, WDT,
RNG
Temperature
range
-40°C to 105°C
Supply voltage
1.7 to 5.5 V
Package options
7x7 mm aQFN™73 with 42 GPIOs
5x5 mm QFN40 with 18 GPIOs
3.2x3x2 mm WLCSP95 with 42 GPIOs
Location
engine
Locator (RX)
Locator (RX)
Tag (TX)
nRF Connect SDK
The nRF Connect SDK is our software development kit for
the nRF52833 SoC. It supports development of Bluetooth
Low Energy, Thread and Zigbee applications. It integrates
the Zephyr RTOS, protocol stacks, samples, hardware
drivers and much more. nRF Connect SDK also supports the
nRF9160, our LTE-M/NB-IoT/GPS SiP, and the nRF53 Series.
It is a common platform for both cellular IoT and short-range
development.
nRF52833 DK
The nRF52833 DK is the affordable development kit for the
nRF52833 SoC. It has everything needed for development on
a single board. All features and GPIOs of the SoC are made
available to the developer, and it comes with an on-board
SEGGER J-Link debugger enabling both programming and
debugging of the nRF52833. The kit is compatible with the
Arduino Uno Rev3 standard, has access to all I/Os (42) and
interfaces via connectors, and there is an integrated PCB
trace antenna and an RF connector for direct RF
test measurements.
8 KB cache
217 CoreMark
66 CoreMark/mA
2 Mbps/1 Mbps/125 kbps
250 kbps
-103 dBm at 1 Mbps
-93 dBm at 1 Mbps
-89 dBm at 2 Mbps
-99 dBm at 250 kbps
-93 dBm at 1 Mbps
-89 dBm at 2 Mbps
Related Products
nRF52833 DK
Development kit for the nRF52833 SoC
nRF Connect SDK
Software development kit for the nRF52833
The nRF52833 SoC and the nRF52833 DK are available for
purchase through our distribution network.
