CP1130325
CP1130325
    CUIDEVICES
    CP1130325
CP1130325 数据手册
Additional Resources: Product Page | 3D Model date 11/10/2020 page 1 of 8 SERIES: CP110 │ DESCRIPTION: PELTIER MODULE FEATURES • • • • • • • arcTEC™ structure enhanced reliability for high thermal cycling superior thermal performance silicon sealed wide ΔT max precise temperature control solid state construction MODEL CP1130325 CP1140203 input voltage1 input current2 internal resistance3 output Qmax4 output ∆Tmax5 max (Vdc) max (A) typ (Ω±10%) Th=27°C (W) Th=50°C (W) Th=27°C (°C) Th=50°C (°C) 11.8 11.0 0.9 74.7 82 68 75 7.6 11.0 0.53 48 52 70 77 CP11404432 24.1 11.0 1.65 156 171 70 77 CP115035335 16.8 11.0 1.18 106 116 70 77 CP115559405 24.6 11.0 1.66 154 169 70 77 Notes: 1. 2. 3. 4. 5. Maximum voltage at ΔT max and Th=27°C Maximum current to achieve ΔT max Measured by AC 4-terminal method at 25°C Maximum heat absorbed at cold side occurs at Imax, Vmax, and ∆T=0°C Maximum temperature difference occurs at Imax, Vmax, and Q=0W (ΔT max measured in a vacuum at 1.3 Pa) cuidevices.com Additional Resources: Product Page | 3D Model CUI Devices │ SERIES: CP110 │ DESCRIPTION: PELTIER MODULE date 11/10/2020 │ page 2 of 8 SPECIFICATIONS parameter conditions/description min solder melting temperature connection between thermoelectric pairs 235 typ max °C assembly compression 1 RoHS units MPa yes MECHANICAL DRAWING units: mm MATERIAL 0.05 COLD SIDE THICKNESS 0.05 HOT SIDE ceramic plate 96% AL2O3 wire leads (CP1140203) 22 AWG tin wire leads (CP115559405) 18 AWG tin wire leads (all other models) 20 AWG tin sealer silicon rubber 703 RTV (between cold and hot side plates) joint cover silicon rubber 703 RTV marking P/N & S/N printed on cold side surface 10.0±3.0 Red (+) WIDTH COLD SIDE Black (-) COLD SIDE LENGTH 100.0 5.0 HOT SIDE LENGTH MODEL NO. HOT SIDE LENGTH (mm) COLD SIDE LENGTH (mm) WIDTH (mm) THICKNESS (mm) CP1130325 30 ±0.3 30 ±0.3 30 ±0.3 3.25 ±0.025 CP1140203 40 ±0.3 40 ±0.3 20 ±0.3 3.0 ±0.05 CP11404432 44 ±0.3 40 ±0.3 40 ±0.3 3.2 ±0.1 CP115035335 50 ±0.3 50 ±0.3 35 ±0.3 3.35 ±0.05 CP115559405 59 ±0.3 55 ±0.3 55 ±0.3 4.05 ±0.1 cuidevices.com PLATING Additional Resources: Product Page | 3D Model CUI Devices │ SERIES: CP110 │ DESCRIPTION: PELTIER MODULE date 11/10/2020 │ page 3 of 8 Input Voltage (V) CP1130325 PERFORMANCE (Th=27°C) 11 A 12 8.8 A 9 6.6 A 6 4.4 A 2.2 A 3 Heat Pumped, Q (W) 0 8.8 A 80 11 A 60 6.6 A 4.4 A 40 2.2 A 20 0 60 70 50 40 ΔT=Th-Tc (°C) 30 20 10 0 CP1130325 PERFORMANCE (Th=50°C) Input Voltage (V) 11 A 12 8.8 A 6.6 A 9 4.4 A 6 2.2 A 3 Heat Pumped, Q (W) 0 8.8 A 80 11 A 60 4.4 A 40 2.2 A 20 0 6.6 A 70 60 50 40 ΔT=Th-Tc (°C) cuidevices.com 30 20 10 0 Additional Resources: Product Page | 3D Model CUI Devices │ SERIES: CP110 │ DESCRIPTION: PELTIER MODULE date 11/10/2020 │ page 4 of 8 Input Voltage (V) CP1140203 PERFORMANCE (Th=27°C) 8 11 A 8.8 A 6 6.6 A 4 4.4 A 2.2 A 2 Heat Pumped, Q (W) 0 80 60 8.8 A 11 A 40 6.6 A 4.4 A 20 2.2 A 0 60 70 50 40 ΔT=Th-Tc (°C) 30 10 20 0 Input Voltage (V) CP1140203 PERFORMANCE (Th=50°C) 8 11 A 8.8 A 6.6 A 6 4.4 A 4 2.2 A 2 Heat Pumped, Q (W) 0 80 60 11 A 40 6.6 A 20 0 8.8 A 4.4 A 2.2 A 70 60 50 40 ΔT=Th-Tc (°C) cuidevices.com 30 20 10 0 Additional Resources: Product Page | 3D Model CUI Devices │ SERIES: CP110 │ DESCRIPTION: PELTIER MODULE date 11/10/2020 │ page 5 of 8 Input Voltage (V) CP11404432 PERFORMANCE (Th=27°C) 11 A 24 8.8 A 18 6.6 A 12 4.4 A 2.2 A 6 Heat Pumped, Q (W) 0 8.8 A 160 11 A 120 6.6 A 80 4.4 A 2.2 A 40 0 60 70 50 40 ΔT=Th-Tc (°C) 30 20 10 0 CP11404432 PERFORMANCE (Th=50°C) Input Voltage (V) 11 A 24 8.8 A 6.6 A 18 4.4 A 12 2.2 A 6 Heat Pumped, Q (W) 0 8.8 A 160 11 A 120 6.6 A 4.4 A 80 2.2 A 40 0 70 60 50 40 ΔT=Th-Tc (°C) cuidevices.com 30 20 10 0 Additional Resources: Product Page | 3D Model CUI Devices │ SERIES: CP110 │ DESCRIPTION: PELTIER MODULE date 11/10/2020 │ page 6 of 8 Input Voltage (V) CP115035335 PERFORMANCE (Th=27°C) 11 A 16 8.8 A 6.6 A 12 4.4 A 8 2.2 A Heat Pumped, Q (W) 4 0 8.8 A 11 A 90 6.6 A 60 4.4 A 2.2 A 30 0 60 70 50 40 ΔT=Th-Tc (°C) 30 10 20 0 CP115035335 PERFORMANCE (Th=50°C) 11 A Input Voltage (V) 16 8.8 A 6.6 A 12 4.4 A 8 2.2 A 4 Heat Pumped, Q (W) 0 8.8 A 11 A 90 6.6 A 4.4 A 60 2.2 A 30 0 70 60 50 40 ΔT=Th-Tc (°C) cuidevices.com 30 20 10 0 Additional Resources: Product Page | 3D Model CUI Devices │ SERIES: CP110 │ DESCRIPTION: PELTIER MODULE date 11/10/2020 │ page 7 of 8 CP115559405 PERFORMANCE (Th=27°C) 11 A Input Voltage (V) 24 8.8 A 18 6.6 A 4.4 A 12 2.2 A 6 Heat Pumped, Q (W) 0 8.8 A 160 11 A 120 6.6 A 80 4.4 A 2.2 A 40 0 60 70 50 40 ΔT=Th-Tc (°C) 30 10 20 0 CP115559405 PERFORMANCE (Th=50°C) Input Voltage (V) 11 A 24 8.8 A 6.6 A 18 4.4 A 12 2.2 A 6 Heat Pumped, Q (W) 0 8.8 A 160 11 A 120 4.4 A 80 2.2 A 40 0 6.6 A 70 60 50 40 ΔT=Th-Tc (°C) cuidevices.com 30 20 10 0 Additional Resources: Product Page CUI Devices │ SERIES: CP110 │ DESCRIPTION: PELTIER MODULE | 3D Model date 11/10/2020 │ page 8 of 8 REVISION HISTORY rev. description date 1.0 initial release 11/05/2019 1.01 added model CP115035335 11/10/2020 The revision history provided is for informational purposes only and is believed to be accurate. CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website. CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use. CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness. cuidevices.com
CP1130325 价格&库存
很抱歉,暂时无法提供与“CP1130325”相匹配的价格&库存,您可以联系我们找货
