KMB16STR
KMB16STR
    SMCDIODESOLUTIONS(桑德斯)
    SMD4
    KMB16STR
KMB16STR 数据手册
KMB12S THRU KMB125S Technical Data Data Sheet N1798, Rev. A KMB12S THRU KMB125S SINGLE PHASE 1.0 AMP SURFACE MOUNT SCHOTTKY BRIDGE RECTIFIER Features Schottky Brrier Chip Low Power Loss,High Efficiency Ideally Suited for Automatic Assembly Surge Overload Rating to 50A Peak Plastic Case Material has UL Flammability Classification 94V-0 This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request         MB-S Circuit Diagram Mechanical Data      Case: MB-S, Molded plastic Terminals: Plated leads solderable per MIL-STD-202, Method 208 Polarity: as marked on case Mounting Position: Any Lead Free: For RoHS / Lead Free Version Maximum Ratings and Electrical Characteristics @TA=25°C unless otherwise specified Type Number Symbol KMB KMB KMB KMB KMB KMB KMB KMB KMB KMB KMB Unit Peak Repetitive Reverse Voltage DC Blocking Voltage VRRM VDC RMS Voltage VRMS Average Rectified Output Current (Note1)@TA=90℃ Non-Repetitive Peak Forward Surge Current 8.3ms Single half sine-wave superimposed on rated load (JEDEC Method) I2t Rating for fusing (t
KMB16STR 价格&库存
很抱歉,暂时无法提供与“KMB16STR”相匹配的价格&库存,您可以联系我们找货
