Carling
Technologies
700/800-Series Rotary Switches
The 700 and 800-Series are single pole multi-position, general
purpose rotary switches. These switches feature a nylon actuator in a metal clad construction along with a self-cleaning silver plated contact design. The 700 and 800-Series are typically used in applications requiring multi-position speed controls,
such as electric fans.
700 SERIES
POSITION 1
Dielectric Strength:
UL, CSA 1,000V (minimum)
Insulation Resistance:
100 Megohms (minimum)
Base Material:
Steel/Zinc Plate
Actuator Material:
Brass/Nickel Plate
ACTUATOR KNOB
.075 [1.90] DIA
POSITION 2
45° TYP
.281 [7.13]
.093 [2.36]
DIA
.475 [12.06]
.475 [12.07]
.700 [17.78] DIA
.330 [8.38]
1.125 [28.57] DIA
.187 [4.75]
.250 [6.35]
POSITION 3
.250 TAB (Q.C.)
SOLDER LUG
1.150 [29.21]
TERMINAL TYPE 1
POSITION 4
.372 [9.44]
MOUNTING HOLES
POSITION 7
800 SERIES
POSITION
6
.450 [11.43]
.468 [11.88]
1.537 [39.04]
.281 [7.13]
.072 [1.83]
DIA
.188 [4.78]
45° TYP POSITION 8
.390 [9.90]
.355 [9.02]
.125 [3.18]
.468 [11.88] DIA
SOLDER LUG
POSITION 1
POSITION 5
TERMINAL TYPE
1.125 [28.57] DIA
2
POSITION 4
POSITION 2
.468 [11.88]
.372 [9.44]
1.417 [35.99]
POSITION 3
700 -1A - BL
1
Base Part Number
2
Actuator
Color
1 BASE PART NUMBER: SERIES/POLES/CIRCUITRY/RATING1/TERMINATION1,2
2A 250VAC; 4A 125VAC; 1A 125V
Solder Lugs .250 Tabs
Position 1
Position 2 Position 3
Position 4
700-A
OFF
ON
ON
ON
700-1
700-1A
OFF
ON
700-2
700-2A
OFF
ON
ON
ON
repeating 8 positions
700-3
700-3A
OFF
ON
ON
OFF
700-4
700-4A
OFF
ON
ON
700-5
700-5A
OFF
ON
OFF
700-6
700-6A
ON
OFF
ON
700-7
700-7A
ON
ON
700-8
700-8A
ON
ON
ON
700-9
700-9A
OFF
ON
OFF
ON
3A 250VAC; 6A 125VAC
Switch Positions
OFF Position
800-2
2 positions
800-A
1st position
800-3
3 positions
800-A2
2nd position
800-4
4 positions
800-A3
3rd position
800-5
5 positions
800-A4
4th position
800-6
6 positions
800-A5
5th position
800-7
7 positions
800-A6
6th position
800-8
8 positions
800-A7
7th position
800-A8
8th position
NOTES
1
2
42
700-2 and 700-2A feature 8 detent positions.
800-Series terminal is a combination solder lug and quick connect.
www.carlingtech.com
2 ACTUATOR COLOR
BL black
.468 [11.88] DIA
很抱歉,暂时无法提供与“700-A-BL”相匹配的价格&库存,您可以联系我们找货
