LS-0940-017
LS-0940-017
    AMSOSRAM(艾迈斯半导体)
    LS-0940-017
LS-0940-017 数据手册
LS-0940 Series FEATURES  940nm Peak Wavelength  Long Life  RoHS Compliant  High Reliability DESCRIPTION The LS-0940 Series are AlGaAs LEDs with peak wavelength of 940nm. Available in a TO-46 lens cap and a TO-46 glob top. The lens cap have a narrow viewing angle. APPLICATIONS  Home automation  Smart Appliances  Security / surveillances systems  IR data transmission  Sensor technology  Remote control  Consumer electronics  Industrial equipment applications  Miniature photo interrupters  Drive and control circuits > Absolute Maximum Ratings Part No. LS-0940-017 LS-0940-015 Forward DC Current [mA] Reverse Voltage [V] 100 5 Operating Temperature [C] -40 to +100 -40 to +85 Storage Temperature [C] Package -40 to +125 Lens Cap Glob Top > Electrical and Optical Characteristics Typical Characteristics (T=23°C unless specified) Parameter Test Conditions If = 20 mA Forward Voltage If = 100 mA Symbol VF Min Typical Max - 1.25 1.45 - 1.4 1.8 Unit V Reverse Current VR=5 V IR - - 10 µA Peak Wavelength If = 20 mA λp 930 940 950 nm Spectral Halfwidth If = 20 mA ∆λ - 65 - nm Radiant Power If = 20 mA Фe 2.5 3.2 - mW If = 20 mA, Rise tr - 500 - If = 20 mA, Fall tf - 500 - Switching Time ns Page 1 Advanced Photonix, 1240 Avenida Acaso, Camarillo CA 93012 • Phone (805) 987-0146 http://www.advancedphotonix.com/ Rev 9/19/2018 © 2018 Advanced Photonix. All rights reserved. LS-0940Series > TO-46 Lens Cap [LS-0940-017] > TO-46 Glob Top [LS-0940-015] >Soldering Conditions: 260˚C 1/16 inch away from case for 3 seconds max. Page 2 Advanced Photonix, 1240 Avenida Acaso, Camarillo CA 93012 • Phone (805) 987-0146 http://www.advancedphotonix.com/ Rev 9/19/2018 © 2018 Advanced Photonix. All rights reserved. LS-0940Series LEGAL DISCLAIMER All products, product specifications, and data are subject to change without notice to improve reliability, function, design, or otherwise. Advanced Photonix, its affiliates, agents, employees and all persons acting on its or their behalf (collectively, “Advanced Photonix”), disclaim any and all liability for any errors, inaccuracies or incompleteness contained in any datasheet or in any other disclosure relating to any product. Advanced Photonix makes no warranty, representation or guarantee regarding the suitability of the products for any particular purpose or the continuing production of any product. To the maximum extent permitted by applicable law, Advanced Photonix disclaims (i) any and all liability arising out of the application or use of any product, (ii) any and all liability, including without limitation special, consequential or incidental damages, and (iii) any and all implied warranties, including warranties of fitness for particular purpose, non-infringement and merchantability Statements regarding the suitability of products for certain types of applications are based on Advanced Photonix’s knowledge of typical requirements that are often placed on Advanced Photonix products in generic applications. Such statements are not binding statements about the suitability of products for a particular application. It is the customer’s responsibility to validate that a particular product with the properties described in the product specification is suitable for use in a particular application. Parameters provided in datasheets and / or specifications may vary in different applications and performance may vary over time. All operating parameters, including typical parameters, must be validated for each customer application by the customer’s technical experts. Product specifications do not expand or otherwise modify Advanced Photonix’s terms and conditions of purchase, including but not limited to the warranty expressed therein. Except as expressly indicated in writing, Advanced Photonix products are not designed for use in life-saving, or life-sustaining applications, or for any other application in which the failure of the Advanced Photonix product could result in personal injury or death. Customers using or selling Advanced Photonix products not expressly indicated for use in such applications do so at their own risk. No license, express or implied, by estoppel or otherwise, to any intellectual property rights is granted by this document or by any conduct of Advanced Photonix. Product names and markings noted herein may be trademarks of their respective owners. MATERIALS SAFETY This product is free of conflict minerals and meets REACH compliance. Please see website for reports. Page 3 Advanced Photonix, 1240 Avenida Acaso, Camarillo CA 93012 • Phone (805) 987-0146 http://www.advancedphotonix.com/ Rev 9/19/2018 © 2018 Advanced Photonix. All rights reserved.
LS-0940-017
物料型号:LS-0940系列,包括LS-0940-017和LS-0940-015。
器件简介: - LS-0940系列是AlGaAs LED,峰值波长为940nm。 - 有TO-46透镜帽和TO-46球顶两种封装形式。 - 透镜帽具有较窄的视角。
引脚分配: - 文档中提供了TO-46封装的引脚图,显示了阳极和阴极的位置。
参数特性: - 绝对最大额定值: - LS-0940-017:未提供正向直流电流和反向电压。 - LS-0940-015:正向直流电流100mA,反向电压5V,工作温度范围-40至+100°C,存储温度范围-40至+125°C。 - 电气和光学特性: - 典型正向电压:在20mA电流下,最小值1.25V,典型值1.45V,最大值1.8V。 - 反向电流:在5V反向电压下,最大值10mA。 - 峰值波长:在20mA电流下,最小值930nm,典型值940nm,最大值950nm。 - 光谱半宽:在20mA电流下,典型值65nm。 - 辐射功率:在20mA电流下,最小值2.5mW,典型值3.2mW。 - 开关时间:上升时间500ns,下降时间500ns。
功能详解: - 该系列LED适用于家庭自动化、智能家电、安全/监控系统、红外数据传输、传感器技术、遥控、消费电子、工业设备应用、微型光电中断器、驱动和控制电路等。
应用信息: - 适用于多种应用场景,包括家庭自动化、智能家电、安全监控系统等。
封装信息: - 提供了TO-46 Lens Cap和TO-46 Glob Top两种封装形式的详细信息,包括尺寸和焊接条件。
法律声明: - 所有产品、产品规格和数据可能会更改,不另行通知。 - Advanced Photonix不承担任何因产品应用或使用引起的责任。
材料安全: - 该产品不含冲突矿物,符合REACH合规性。
LS-0940-017 价格&库存
很抱歉,暂时无法提供与“LS-0940-017”相匹配的价格&库存,您可以联系我们找货
