MBJ5A
MBJ5A
    APEM(埃斐)
    插件
    检测开关 插件 AC250V
MBJ5A 数据手册
SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE MICRO-LIMIT SWITCHES H APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com H1 MICRO-LIMIT SWITCHES DEFINITIONS OF TERMS Free position Position of the switch actuator when no force is applied. Back travel The distance between the overtravel and release positions. Operating position The position of the actuator when the contact snaps. Total travel The sum of pretravel and overtravel. Overtravel position The final position of the actuator. Operating force The force required to cause snap action of contact. Release position The position of the actuator when the contact snaps back from the operating position to original position. End operating force The force to be applied to keep the actuator in the allowed final position. Contact opening gap The distance between the open contact pair. Release force The force applied to the actuator at the moment the contact snaps back from the operating position. Pretravel The distance between free and operating positions. Overtravel The distance the actuator travels after the contact actuates. Movement differential The distance from the operating to release position of the actuator. H Free travel The distance between the release and free positions. H2 1 2 3 4 free position operating position overtravel position release position A B C D E F total travel free travel back travel pretravel overtravel movement differential I II III IV total force operating force differential force release force Differential force The difference between the operating force and the release force. Mechanical life The minimum number of actuations with no load on the switch. Electrical life The minimum number of actuations at rated voltage, rated current and resistive load at 20°C ambient temperature. FORCE vs. TRAVEL DIAGRAM APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE Micro-limit pushbutton switches are used in many applications including microwave ovens, vending machines, copy and fax machines, medical and security equipment, computer peripherals and many others. They are characterized by close tolerance precision switching positions and long service life. APEM micro-limit switches are 100% electronic tested prior to shipment to insure proper operation and conformance with specifications. SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE MA SERIES - MICRO-LIMIT SWITCHES FEATURES ● Ratings: 16 Amps 250 VAC (resistive load). 4 Amps 250 VAC (motor load) or 3 Amps 250 VAC (resistive load). 0.1 Amps 250 VAC (motor load). ● Single pole CO (change-over or alternate action), NC (normally closed momentary) and NO (normally open momentary) configurations. ● Close tolerance switching action with long life (10,000,000 mechanical cycles min.). ● Pin plunger, hinge lever or roller lever actuator options. MATERIALS Contacts: Actuator: Case & cover: Terminals: Stationary: Nicker silver Shorting: Beryllium copper FS 161 (UL94V-O) PBT (UL94V-O) Silver plated copper/zinc AGENCY RECOGNITION Approval pending. H NRTL SPECIFICATIONS Operating force: ≤ 12.59 oz. (343 grams) approx. for 16 Amp models ≤ 0.72 oz. (20 grams) approx. for 3 Amp models Pretravel: Overtravel: ≤ .047" (1.2mm) ≥ .059" (1.5mm) min. Movement differential: ≤ .016" (0.4mm) Free position: ≤ .649" (16.5mm) Operating position: Operating temperature: .578" ± .020" (14.7mm ± 0.5mm) -40°C to +85°C Contact gap: less than .118" (3mm) Tracking resistance: > PTI 175 APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com H3 MA SERIES - MICRO-LIMIT SWITCHES Series Circuit & quick-connect terminals MA A B C D E F G H I J K L Switch rating Actuator style Normally open (standard) .031 x .248" (0.8x6.3mm) 6 16(4)A 250 VAC Normally closed (standard) .031 x .248" (0.8x6.3mm) 7 3(0.1)A 250 VAC Change-over (standard) .031 x .248" (0.8x6.3mm) Normally open, .031 x .248" (0.8x6.3mm), spacing .197" (5mm) Normally closed, .031 x .248" (0.8x6.3mm), spacing .197" (5mm) Change-over, .031 x .248" (0.8x6.3mm), spacing .197" (5mm) Normally open, .020 x .189" (0.5x4.8mm) Normally closed, .020 x .189" (0.5x4.8mm) Change-over, .020 x .189" (0.5x4.8mm) Normally open, .031 x .189" (0.8x4.8mm) Normally closed, .031 x .189" (0.8x4.8mm) Change-over, .031 x .189" (0.8x4.8mm) A Pin actuator B Hinge actuator C Roller actuator STANDARD MODELS Quick-connect terminal .031x.248" (0.8x6.3mm) Switching capacity 16(4)A 3(0.1)A .031x.248" (0.8x6.3mm) pin spacing .197"(5mm) .020x.189" (0.5x4.8mm) 16(4)A 16(4)A 3(0.1)A 16(4)A 3(0.1)A Pin plunger NO NC CO MAA6A MAA7A MAB6A MAB7A MAC6A MAC7A MAD6A MAE6A MAF6A MAG6A MAG7A MAH6A MAH7A MAI6A MAI7A MAJ6A MAJ7A MAK6A MAK7A MAL6A MAL7A Hinge lever NO NC CO MAA6B MAB6B MAC6B - MAD6B MAE6B MAF6B MAG6B MAH6B MAI6B - MAJ6B MAK6B MAL6B - Roller lever NO NC CO MAA6C MAB6C MAC6C - MAD6C MAE6C MAF6C MAG6C MAH6C MAI6C - MAJ6C MAK6C MAL6C - H NO = NORMALLY OPEN: CO = CHANGE-OVER: NC = NORMALLY CLOSED: NC (2) NC (2) COM (1) COM (1) NO (4) H4 .031x.189" (0.8x4.8mm) COM (1) NO (4) APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE M A A 6 B ORDER FORMAT MA SERIES - MICRO-LIMIT SWITCHES MECHANICAL OUTLINES SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE Models with quick-connect terminal .031x.248" (0.8x6.3mm) Normally open Side view Change-over Normally closed Quick-connect terminal H Hinge lever Roller lever APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com H5 MA SERIES - MICRO-LIMIT SWITCHES MECHANICAL OUTLINES Normally open Side view Change-over Normally closed Quick-connect terminal H Hinge lever Roller lever H6 Adaptor element APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE Models with quick-connect terminal .031x.248" (0.8x6.3mm) & pin spacing .197" (5mm) MA SERIES - MICRO-LIMIT SWITCHES MECHANICAL OUTLINES SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE Models with quick-connect terminal .020 or .031x.248" (0.8 or 0.8x6.3mm) Normally open Change-over Normally closed H Hinge lever Side view Roller lever Quick connect terminal APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com H7 FEATURES ● Ratings: 10 Amps 250 VAC (resistive load). 1.5 Amps 250 VAC (motor load). ● Single pole CO (change-over or alternate action), NC (normally closed momentary) and NO (normally open momentary) configurations. ● Close tolerance switching action with long life (10,000,000 mechanical cycles min.). ● Pin plunger, hinge lever or roller lever actuator options. MATERIALS Contacts: Actuator: Case & cover: Terminals: Stationary: Nickel silver Shorting: Beryllium copper POM (UL94HB) PBT (UL94V-O) Silver plated copper/zinc AGENCY RECOGNITION H SPECIFICATIONS H8 Operating force: ≤ 10 oz. (274 grams) approx. Pretravel: ≤ .039" (1mm) Overtravel: ≥ .024" (0.6mm) Movement differential: Free position: ≤ .005" (0.13mm) ≤ .366" (9.3mm) Operating position: .331" ± .012" (8.4mm ± (0.3mm) Operating temperature: -40°C to +85°C Contact gap: Tracking resistance: < .118" (3mm) >PTI 175 APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE MB SERIES - MICRO-LIMIT SWITCHES MB SERIES - MICRO-LIMIT SWITCHES M B D 5 B 1 SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE ORDER FORMAT Series Circuit & quick-connect terminals MB D E F G H J Normally open (solder terminal) Normally closed (solder terminal) Change-over (solder terminal) Normally open (p.c. terminal) Normally closed (p.c. terminal) Change-over (p.c. terminal) Switch rating 5 10(1.5)A 250 VAC Actuator style Length A Pin actuator B Hinge actuator C Roller actuator Actuator length and fixed position(see table below) STANDARD MODELS Circuit Normally open Normally closed Change-over Terminals . Pin plunger with radius Pin plunger, spherical form Solder P.C. Solder P.C. Solder P.C MBD5A MBD5D MBG5A MBG5D MBE5A MBE5D MBH5A MBH5D MBF5A MBF5D MBJ5A MBJ5D Lever type Fix Act. length Hinge lever EH EV EH EV .189" (4.8mm) .276" (7.0mm) .276" (7.0mm) .370" (9.4mm) MBD5B MBD5B2 MBD5B1 MBD5B3 MBG5B MBG5B2 MBG5B1 MBG5B3 MBE5B MBE5B2 MBE5B1 MBE5B3 MBH5B MBH5B2 MBH5B1 MBH5B3 MBF5B MBF5B2 MBF5B1 MBF5B3 MBJ5B MBJ5B2 MBJ5B1 MBJ5B3 Roller lever EH EV EH EV .098" (2.5mm) .185" (4.7mm) .185" (4.7mm) .280" (7.1mm) MBD5C MBD5C2 MBD5C1 MBD5C3 MBG5C MBG5C2 MBG5C1 MBG5C3 MBE5C MBE5C2 MBE5C1 MBE5C3 MBH5C MBH5C2 MBH5C1 MBH5C3 MBF5C MBF5C2 MBF5C1 MBF5C3 MBJ5C MBJ5C2 MBJ5C1 MBJ5C3 Simulated roller lever EH EV EH EV .098" (2.5mm) .185" (4.7mm) .185" (4.7mm) .280" (7.1mm) MBD5E MBD5E2 MBD5E1 MBD5E3 MBG5E MBG5E2 MBG5E1 MBG5E3 MBE5E MBE5E2 MBE5E1 MBE5E3 MBH5E MBH5E2 MBH5E1 MBH5E3 MBF5E MBF5E2 MBF5E1 MBF5E3 MBJ5E MBJ5E2 MBJ5E1 MBJ5E3 NO = NORMALLY OPEN: CO = CHANGE-OVER: NC = NORMALLY CLOSED: NC (2) NC (2) COM (1) COM (1) NO (4) H COM (1) NO (4) APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com H9 MB SERIES - MICRO-LIMIT SWITCHES Hinge lever Actuator . Actuator length, inches ±.031" ±0.8mm Fixed position, EH=rear EV=front Operating force, ≤ grams ≤ ??? Pre-travel, ≤ inches ≤ mm Overtravel, min. inches min. mm Overtravel, max. inches max.mm Movement diff.≤ inches ≤ mm Free position, ≤ inches ≤ mm Operating position, inches Tolerance inches ± Operating position, mm Tolerance mm ± Order code Roller lever Hinge lever Simulated roller lever Roller lever Simulated roller lever .189 4.8 EH .276 7.0 EV .276 7.0 EH .370 9.4 EV .098 2.5 EH .185 4.7 EV .185 4.7 EH .280 7.1 EV .098 2.5 EH .185 2.7 EV .185 4.7 EH .280 7.1 EV 100 .177 4.5 .030 0.75 .059 1.5 .035 0.9 .551 14 .421 .063 10.7 1.6 B 45 .354 9 .049 1.25 .098 2.5 .059 1.5 .709 18 .472 .118 12 3 B2 85 .197 5 .030 0.75 .059 1.5 .047 1.2 .591 15 .437 .071 11.1 1.8 B1 40 .394 10 .059 1.5 .118 3 .071 1.8 .787 20 .492 .138 12.5 3.5 B3 110 .177 4.5 .030 0.75 .059 1.5 .028 0.7 .748 19 .622 .063 15.8 1.6 C 50 .354 9 .049 1.25 .098 2.5 .059 1.5 .866 22 .669 .118 17 3 C2 95 .197 5 .030 0.75 .059 1.5 .039 1 .787 20 .638 .071 16.2 1.8 C1 40 .394 10 .059 1.5 .118 3 .071 1.8 .945 24 .689 .138 17.5 3.5 C3 115 .177 4.5 .030 0.75 .059 1.5 .028 0.7 .748 19 .630 .063 16 1.6 E 60 .354 9 .049 1.25 .098 2.5 .059 1.5 .866 22 .677 .118 17.2 3 E2 95 .197 5 .030 0.75 .059 1.5 .039 1 .787 20 .646 .071 16.4 1.8 E1 50 .394 10 .059 1.5 .118 3 .071 1.8 .945 24 .697 .138 17.7 3.5 E3 MECHANICAL OUTLINES H Normally open Side view (w/solder terminal) H10 Change-over Normally closed P.C. terminal APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE ACTUATORS AND SPECIFICATIONS
MBJ5A 价格&库存
很抱歉,暂时无法提供与“MBJ5A”相匹配的价格&库存,您可以联系我们找货
MBJ5A
  • 95+9.67281
  • 250+9.50353
  • 500+9.32217
库存:909
