HV-5RGB25
HV-5RGB25
    INOLUX(英诺斯)
    插件
    HV-5RGB25
HV-5RGB25 数据手册
HV-5RGBXX Series 5mm Full-Color Through Hole Lamp Inolux 5mm Full-Color Through Hole Lamp HV-5RGBXX Series Official Product HV-5RGBXX series Customer Part No. Data Sheet No. **************** **************** HV-5RGBXX series Specifications are subject to change without notice. Data and drawings herein are copyrighted. July 21, 2015 Version of 1.1 Page 1/11 HV-5RGBXX Series 5mm Full-Color Through Hole Lamp DISCLAIMER INOLUX reserves the right to make changes without further notice to any products herein to improve reliability, function or design. INOLUX does not assume any liability arising out of the application or use of any product or circuit described herein; neither does it convey any license under its patent rights, nor the rights of others. LIFE SUPPORT POLICY INOLUX’s products are not authorized for use as critical components in life support devices or systems without the express written approval of the President of INOLUX or INOLUX INTERNATIONAL. As used herein: 1. Life support devices or systems are devices or systems which, (a) are intended for surgical implant into the body, or (b) support or sustain life, and (c) whose failure to perform when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in a significant injury of the user. 2. A critical component in any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness. Official Product HV-5RGBXX series Customer Part No. Data Sheet No. **************** **************** HV-5RGBXX series Specifications are subject to change without notice. Data and drawings herein are copyrighted. July 21, 2015 Version of 1.1 Page 2/11 HV-5RGBXX Series 5mm Full-Color Through Hole Lamp Orderable Information H V - Series Name HV= Inolux Through Hole Lamp Official Product 5 R G B X X Color Code Viewing Angle RGB= 632nm AllnGaP Red 520nm InGaN Green 470nm InGaN Blue - 25= 25° 60= 60° Y Y Y Y Customer Code YYYY = Customer code HV-5RGBXX series Customer Part No. Data Sheet No. **************** **************** HV-5RGBXX series Specifications are subject to change without notice. Data and drawings herein are copyrighted. July 21, 2015 Version of 1.1 Page 3/11 HV-5RGBXX Series 5mm Full-Color Through Hole Lamp Features: • • • • • • Full-Color Popular 5mm through hole package White Diffused Lens AllnGaP/InGaN technology Solid state reliability Special packaging available upon request Dimensions for HV-5RGB25 -All Dimensions are in millimeters -Tolerance = +/- 0.25mm Official Product HV-5RGBXX series Customer Part No. Data Sheet No. **************** **************** HV-5RGBXX series Specifications are subject to change without notice. Data and drawings herein are copyrighted. July 21, 2015 Version of 1.1 Page 4/11 HV-5RGBXX Series 5mm Full-Color Through Hole Lamp Dimensions for HV-5RGB60 -All Dimensions are in millimeters -Tolerance = +/- 0.25mm Official Product HV-5RGBXX series Customer Part No. Data Sheet No. **************** **************** HV-5RGBXX series Specifications are subject to change without notice. Data and drawings herein are copyrighted. July 21, 2015 Version of 1.1 Page 5/11 HV-5RGBXX Series 5mm Full-Color Through Hole Lamp Absolute Maximum Ratings at Ta=25C Parameter Symbol AllnGaP InGaN Unit Power Dissipation Pd 65 95 mW Reverse Voltage Vr 5 V Forward Current IF 25 mA Reverse Current Ir 10 µA IF (Peak) 100 mA Operating Temperature Range Topr -40 to +80 °C Storage Temperature Range Tstg -40 to +100 °C Lead Soldering Temp Tsol 260 °C Peak Current ( 1/10 Duty Cycle, 0.1ms pulse width ) Official Product HV-5RGBXX series Customer Part No. Data Sheet No. **************** **************** HV-5RGBXX series Specifications are subject to change without notice. Data and drawings herein are copyrighted. July 21, 2015 Version of 1.1 Page 6/11 HV-5RGBXX Series 5mm Full-Color Through Hole Lamp Electrical and Optical Characteristic ( @ 25 degree C ) Parameter R G B Test Condition Luminous Intensity: Min (mcd) Typ (mcd) 1600 2000 1000 If=20mA 3200 4000 2000 If=20mA Forward voltage (Vf) Typ Max 2.0 3.4 3.4 If=20mA 2.6 3.8 3.8 If=20mA Dominant Wavelength (nm) 624 525 470 If=20mA Viewing Angle (Deg) 25 25 25 If=20mA R G B Test Condition Luminous Intensity: Min (mcd) Typ (mcd) 350 450 250 If=20mA 600 1000 500 If=20mA Forward voltage (Vf) Typ Max 2.0 3.4 3.4 If=20mA 2.6 3.8 3.8 If=20mA Dominant Wavelength (nm) 624 525 470 If=20mA Viewing Angle (Deg) 60 60 60 If=20mA Parameter - Brightness tolerance = +/- 10% Official Product HV-5RGBXX series Customer Part No. Data Sheet No. **************** **************** HV-5RGBXX series Specifications are subject to change without notice. Data and drawings herein are copyrighted. July 21, 2015 Version of 1.1 Page 7/11 HV-5RGBXX Series 5mm Full-Color Through Hole Lamp Characteristic Curves for Red (R) Official Product HV-5RGBXX series Customer Part No. Data Sheet No. **************** **************** HV-5RGBXX series Specifications are subject to change without notice. Data and drawings herein are copyrighted. July 21, 2015 Version of 1.1 Page 8/11 HV-5RGBXX Series 5mm Full-Color Through Hole Lamp Characteristic Curves for Green (G) and Blue (B) Official Product HV-5RGBXX series Customer Part No. Data Sheet No. **************** **************** HV-5RGBXX series Specifications are subject to change without notice. Data and drawings herein are copyrighted. July 21, 2015 Version of 1.1 Page 9/11 HV-5RGBXX Series 5mm Full-Color Through Hole Lamp Radiation Diagram Official Product HV-5RGBXX series Customer Part No. Data Sheet No. **************** **************** HV-5RGBXX series Specifications are subject to change without notice. Data and drawings herein are copyrighted. July 21, 2015 Version of 1.1 Page 10/11 HV-5RGBXX Series 5mm Full-Color Through Hole Lamp Revision History Changes since last revision Version No. Revision Date Initial release for 5mm Full-Color Lamp 1.0 06-27-2013 Update HV-5RGB60 Dimension 1.1 07-21-2015 Official Product Page HV-5RGBXX series Customer Part No. Data Sheet No. **************** **************** HV-5RGBXX series Specifications are subject to change without notice. Data and drawings herein are copyrighted. July 21, 2015 Version of 1.1 Page 11/11
HV-5RGB25
物料型号:HV-5RGBXX系列
器件简介:这是一款5mm全彩通孔灯,采用InGaN蓝光、AlGaP红光和绿光技术,具有全彩显示能力,流行的5mm通孔封装,白色散光透镜,固态可靠性,可应要求提供特殊封装。
引脚分配: - HV-5RGB25:1. 阳极蓝,2. 阳极红,3. 共阴极,4. 阳极绿 - HV-5RGB60:1. 阳极绿,2. 阳极红,3. 共阴极,4. 阳极蓝
参数特性: - 绝对最大额定值包括功耗65mW,反向电压、正向电流、反向电流、峰值电流(1/10占空比,0.1ms脉冲宽度),工作温度范围-40至+80℃,存储温度范围-40至+100℃。 - 电气和光学特性包括不同颜色的发光强度、正向电压、主波长和视场角度。
功能详解:该LED灯具有全彩功能,使用AllnGaP/InGaN技术,提供固态可靠性,并且可以根据特殊需求提供定制封装。
应用信息:文档中未明确提供应用信息,但根据其特性,该LED灯适用于需要全彩显示的场合,如信号指示、装饰照明等。
封装信息:提供了HV-5RGB25和HV-5RGB60两种型号的详细尺寸图,所有尺寸单位为毫米,公差为±0.25mm。
HV-5RGB25 价格&库存
很抱歉,暂时无法提供与“HV-5RGB25”相匹配的价格&库存,您可以联系我们找货
