COM-14732
COM-14732
    SPARKFUNELECTRONICS
    COM-14732
COM-14732 数据手册
iPixel LEDLight Light Co. Co. , ,Ltd iPixel LED Ltd iPix el LED Mini Skinny Digital RGB Strip w ww. ip i x el le d s .c om Product Description - This is a flexible-addressable-cuttable-bendable led strip . - There are 144pcs LEDs in a meter and 1 LED per unit. - It can be cuttable but the sold PAD very small and you will have limited space to solder cable again. - Since you remove one LED and link the data cable w w w. ipi xelle d s .co m on the empty board to get enough space. -The width of silicon tube 10mm and bare board (Ip20) 7.5mm only. - White color painting with a Arrow on each LED guide the direction of signal. - 3M tape attached on backside of flex tube and it comes 1m per reel. m www.ip ix e ll eds.c o - But you can connect as many as you can just guide make sure feed enough power to it regarding the PCB very flexible and narrow,when you light on color constantly it's getting very hot ,we recommend you to do this --Static white. - We could provide this strip IP20 and Ip65. don’t white iPixel LEDLight Light Co. Co. , ,Ltd iPixel LED Ltd iPix el LED Product Datasheet Product Number S144SK6812 Light Source Epistar 3535 SMD LEDs Beam Angle 120° LED Quantity 144leds/m Pixel Pitch(mm) P6.9mm Emitting Color Full color Operating Voltage DC5V Power (W) 34w/m (max) Control (IC) SK6812 IP Level IP20/IP65 Luminance Per 1m (mm) Size Operation Temperature R:57600 G:100800 B:27360 IP20 L 5000* W 7 mm IP65 L 5000* W 10 mm -10℃-50℃ Application m www. ipi xe ll e d s .c o Waterproof Rating m w w w.i p ix elleds. co The excellent light and user-friendly designs make LED strip perfect for numerous applications, i.e cove lights, back lights, cabinet lights, edge light, architectu ral lights for corridor, canopy, archway, lights for path and contour marking; etc. They can be a good choice for lights for hotels, restaurants, night clubs, coffee / wine bars, shopping malls,various shops, cinemas, beauty centers, office fronts, ev en lights for household kitchens or living rooms, etc. iPixel LEDLight Light Co. Co. , ,Ltd iPixel LED Ltd iPix el LED 7mm Outline Dimension +5V DI GND 6.9mm www. ed s . l l e x i ip co m ww 5000mm ed s . l l e x i w. i p 100mm c om 3P JST SM connector 10 DC5V + DAT Silicon Tube Size 4 GND There are 1 Arrow following each LED om p www.i d s .c i x e ll e on PCB, it’s means the signal transmit direction Connection Drawing This strip 144Pixels (IC) per m,1m/roll (144Pixel), www . i p i xe l l eds T-1000controller support 2000Pixel Max, .c o m www . ip i xe l led s . com 1 Roll strip total power is 34W (1m),each 5V70A (350W) works 10m strip . You also could use T4000、T8000 SD controller for more LED pixels w ww .i pix 1st 3rd 2nd s . co 4th www .i p ix m 5th 6th 7th 8th e l l ed s .co 9th 10th m 5V 70A 5V 70A www . i p i xe NOTICE : +V +V +V +V G G G G N(AC) L el le d lle d s NOTICE : +V +V +V +V G G G G N(AC) L .c om www . ip i x el l ed www .ip i x el l e 5pcsx5m ds . co s. co m m SD SD d s. c o L AC 110 / 220V NO.1 w ww . ipi x m el le d L www .ipi x el le 5pcsx5m s. c o m NO.2 N L Add: A2 Building Ming Jin hai Industrial Park,Zhou shi Rd ,Shiyan,Baoan,Shenzhen,China. 518108 Tel: 0086-755-85257292 Web: www.ipixelleds.com Fax:0086-755-85257292 E-mail: inquiry@ipixelleds.com
COM-14732 价格&库存
很抱歉,暂时无法提供与“COM-14732”相匹配的价格&库存,您可以联系我们找货
