Technical Data Sheet
RF_35/09.14/6.2
Dieses Dokument ist urheberrechtlich geschützt ● This document is protected by copyright ● Rosenberger Hochfrequenztechnik GmbH & Co. KG
SMP
Straight Plug PCB
Limited Detent
19S101-40ML5
All dimensions are in mm; tolerances according to ISO 2768 m-H
Interface
According to
MIL-STD-348
Documents
PCB layout
Tape & reel packaging
B 120
VG01.01M00
Material and plating
Connector parts
Center contact
Outer contact
Dielectric
Material
Brass
Brass
LCP
P.O.Box 1260
D-84526 Tittmoning
Germany
www.rosenberger.de
Plating
AuroDur®, gold plated
Tel. : +49 8684 18-0
Email : info@rosenberger.de
Page
1/2
SMP
Straight Plug PCB
Limited Detent
19S101-40ML5
Electrical data
50
DC to 26.5 GHz
26 dB, DC to 6 GHz
20 dB, 6 to 12 GHz
0.05 x f(GHz) dB
5 G
6.0 m
2.0 m
500 V rms
335 V rms
1.2A DC max.
RF_35/09.14/6.2
Impedance
Frequency
Return loss
Insertion loss
Insulation resistance
Center contact resistance
Outer contact resistance
Test voltage
Working voltage
Contact Current
- VSWR in application depends decisive on PCB layout -
Mechanical data
500
7N
Mating cycles
Center contact captivation
Engagement force
- limited detent
Disengagement force
- limited detent
45 N max.
9 N min.
Environmental data
Temperature range
Thermal shock
Vibration
Shock
Moisture resistance
Max. soldering temperature
RoHS
-65°C to +155°C
MIL-STD-202, Method 107, Condition B
MIL-STD-202, Method 204, Condition B
MIL-STD-202, Method 213, Condition A
MIL-STD-202, Method 106
IEC 61760-1, +260°C for 10 sec.
compliant
Tooling
N/A
Suitable cables
N/A
Weight
Weight
0.3 g/pce
While the information has been carefully compiled to the best of our knowledge, nothing is
intended as representation or warranty on our part and no statement herein shall be
construed as recommendation to infringe existing patents. In the effort to improve our
products, we reserve the right to make changes judged to be necessary.
For the installation of the
electrotechnical equipment,
particular electrotechnical
expertise is required.
Draft
Date
Approved
Date
Rev.
Engineering change number
Name
Date
König A.
10.07.07
Chr. Janßen
27.10.20
g00
20-1927
S. Huber-Siegl
27.10.20
P.O.Box 1260
D-84526 Tittmoning
Germany
www.rosenberger.de
Page
2/2
很抱歉,暂时无法提供与“19S101-40ML5”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+42.97320
- 10+37.23840
- 30+33.75000
- 100+30.82320
