MIKROE-2714
MIKROE-2714
    MIKRO
    MIKROE-2714
MIKROE-2714 数据手册
      EasyPIC FUSION v7 ETH MCUcard with PIC32MZ2048EFH144 PID: MIKROE-2714         This particular EasyPIC FUSION v7 ETH MCUcard contains the PIC32MZ2048EFH144 microcontroller with  on‐chip peripherals. It's a great choice for both beginners and professionals. After testing and building  the final program, this card can also be taken out of the board socket and used in your final device.    MCU card features PIC32MZ2048EFH144 - a 32-bit MCU with 512 KB of SRAM and 2MB of Flash, 250MHz maximum frequency, an internal oscillator, audio and graphic interfaces, Ethernet and more. The MCU also contains an internal RTC (Real Time Clock), a 12-bit ADC (18 MSPS, 48channel ADC module), and a Crypto Engine with an RNG for data encryption/decryption and authentication (AES, 3DES, SHA, MD5, and HMAC), etc. 32.768KHz crystal — Provides external clock waveform for RTCC module. 24MHz oscillator — Provides the clock frequency for PIC32MZ2048EFH144 MCU. 25MHz crystal — Provides clock for external Ethernet module. Ethernet transceiver —This MCU card contains single-chip Ethernet physical (PHY) layer transceiver which provides additional Ethernet functionality to the PIC32MZ2048EFH144 controller. Compliant with IEEE802.3/802.3u (Fast Ethernet) and with ISO 802-3/IEEE 802.3 (10BASE-T). SPECIFICATION Architecture MCU MCU speed MCU Memory PIC32 (32-bit) PIC32MZ2048EFH144 250MHz 512 KB of SRAM and 2MB of Flash Key Features Up to 252 MHz/415 DMIPS, MIPS Warrior M-class core, 12-bit, 18 MSPS, 48channel ADC module, Hi-Speed USB 2.0 Device/Host/OTG, 10/100 Mbps Ethernet MAC with MII and RMII interface; CAN, UART, I2C, PMP, EBI, SQI & Analog Comparators Input Voltage 3.3V                                      https://shop.mikroe.com/easypic‐fusion‐v7‐pic32mz2048efh144 8‐2‐17
MIKROE-2714 价格&库存
很抱歉,暂时无法提供与“MIKROE-2714”相匹配的价格&库存,您可以联系我们找货
