BS02CL01X04RP
BS02CL01X04RP
    BUMPER
    BS02CL01X04RP
BS02CL01X04RP 数据手册
Cylindrical Product Number BS-34* BS-35 BS-05 BS-01* BS-06 BS-11 BS-44 BS-45 BS-41 BS-24 Dimensions Width x Height Pieces .375” x .125” 9.5mm x 3.2mm 300 Per Sheet 6,000 Per Box .375” x .190” 9.5mm x 4.8mm 200 Per Sheet 5,000 Per Box .500” x .060” 12.7mm x 1.5mm 200 Per Sheet 5,000 Per Box .500” x .140” 12.7mm x 3.5mm 200 Per Sheet 5,000 Per Box .500” x .250” 12.7mm x 6.4mm 200 Per Sheet 5,000 Per Box .650” x .400” 16.5mm x 10.2mm 128 Per Sheet 2,560 Per Box .750” x .160” 19.1mm x 4.1mm 98 Per Sheet 2,450 Per Box .710” x .180” 10.0mm x 4.6mm 98 Per Sheet 2,450 Per Box .780” x .200” 19.8mm x 5.1mm 84 Per Sheet 3,360 Per Box .810” x .120” 20.6mm x 3.0mm 72 Per Sheet 2,520 Per Box Cylindrical Product Number BS-72 Dimensions Width x Height Pieces 1.230” x .100” 31.2mm x 2.5mm 32 Per Sheet 2,400 Per Box Hemispherical Product Number BS-15 BS-08 Hemispherical BS-40 BS-25 BS-27* BS-07* BS-10* BS-12* BS-22* BS-02* .250” x .062” 6.4mm x 1.6mm 578 Per Sheet 15,028 Per Box .250” x .079” 6.4mm x 2.1mm 450 Per Sheet 5,400 Per Box .312” x .085” 7.9mm x 2.2mm 450 Per Sheet 5,400 Per Box .335” x .085” 8.5mm x 2.2mm 450 Per Sheet 5,400 Per Box .394” x .118” 10.0mm x 3.0mm 288 Per Sheet 7,200 Per Box .375” x .150” 9.5mm x 3.8mm 288 Per Sheet 7,200 Per Box .375” x .211” 9.5mm x 5.4mm 300 Per Sheet 6,000 Per Box .440” x .200” 11.1mm x 5.1mm 242 Per Sheet 5,082 Per Box Photos not actual size, please refer to dimensions. Tolerances: ±0.2” (±0.5mm); *NOTE: Special Soft Durometer options available. BS-39 Dimensions Width x Height Pieces .620” x .310” 15.7mm x 7.9mm 128 Per Sheet 3,200 Per Box .700” x .380” 17.8mm x 9.7mm 98 Per Sheet 2,254 Per Box .750” x .075” 19.1mm x 1.9mm 84 Per Sheet 5,040 Per Box .720” x .560” 18.3mm x 14.2mm 1 Per Sheet 1,500 Per Box .750” x .750” 19.1mm x 19.1mm 1 Per Sheet 1,000 Per Box .787” x .886” 20.0mm x 22.5mm 1 Per Sheet 1,000 Per Box .375” x .180” 9.5mm x 4.6mm 98 Per Sheet 7,200 Per Box .500” x .150” 12.7mm x 3.8mm 200 Per Sheet 5,000 Per Box .500” x .200” 12.7mm x 5.1mm 200 Per Sheet 5,000 Per Box Conical BS-37 BS-47 BS-57 Special Soft BS-67 SD BS-33 SD BS-58 SD Square & Recessed Product Number BS-20 BS-32 BS-03 BS-29 BS-04 BS-19 BS-36 BS-18* BS-17 BS-30 Dimensions Width x Height Pieces .400” x .100” 10.2mm x 2.5mm 242 Per Sheet 5,082 Per Box .500” x .120” 12.7mm x 3.0mm 200 Per Sheet 5,000 Per Box .500” x .230” 12.7mm x 5.8mm 200 Per Sheet 5,000 Per Box Physical Properties Polyurethane Standard Product Soft Durometer Durometer, Shore A............................ 60 to 70.........................45 to 55 Tensile Strength, psi (g/cm2).............. 627 (44,082)..................750 (52,730) Elongation, % ................................... 192.................................607 Tear Strength, pli (g/cm).................... 214 (38, 216)..................127 (22,680) Bashore Rebound, %.......................... 27...................................35 Abrasion Resistance, g/1000 cycles Tabor H18, 1kg........... 0.016..............................0.010 QUV (500 hours).................................. Slight Yellowing............No Data Available Look around, our bumpers are everywhere! Pressure Sensitive Adhesives BSI-94 consists of a thin polyester film carrier coated with a high performance .780” x .250” 19.8mm x 6.4mm 98 Per Sheet 2,940 Per Box Acrylic pressure sensitive adhesive on a 90lb. white release liner. BSI-95 consists of a thin polyester film carrier coated with an aggressive Synthetic Rubber pressure sensitive adhesive on a 90lb. white release liner. .780” x .380” 19.8mm x 9.7mm 1 Per Sheet 2,000 Per Box .810” x .300” 20.6mm x 7.6mm 98 Per Sheet 2,646 Per Box 1.000” x .180” 25.4mm x 4.6mm 55 Per Sheet 2,310 Per Box .500” x .140” 12.7mm x 3.5mm 200 Per Sheet 5,000 Per Box .880” x .400” 22.3mm x 10.2mm 72 Per Sheet 1,440 Per Box 1.810” x .600” 46mm x 15.2mm 1 Per Sheet 500 Per Box Photos not actual size, please refer to dimensions. Tolerances: ±0.2” (±0.5mm); *NOTE: Special Soft Durometer options available. Non-Skid Spacers, Levelers Sound Dampening Non-Marring Protectors Sound Deadening Non-Scratch Pads Surface Cushions Cutting Boards Electronic Equipment Cabinets Features Non-Staining & Non-Marring Easy ‘Peel-&-Stick’ Application Superb Abrasion Resistance Low Resistance to Skidding Standard Colors Additional Colors Clear White High Coefficient of Friction Crack Resistant & Resilient Vibration & Shock Dampening UL Recognized Component Black Brown Gray Frames Door Stops Drawers Our most popular bumpers! Every bumper is available in Clear and Black. The crystal clear bumper is nearly invisible when used for translucent or see-through applications. Additional Colors White Brown Gray Most bumpers are stocked in every color and ready for immediate shipment. White, Brown, and Grey can be made available for larger quantities. Please call for availability. Coasters 1607 Imperial Way, West Deptford, New Jersey, 08066 USA PHONE (856) 345-7650n•n(800) 541-2500 FAX (856) 345-7690n•n(800) 220-2840 www.bumperspecialties.comn•nE-Mail info@bumperspecialties.com 11/18 RH / Printed in USA Quality Speakers Appliances Price Service Made in USA
BS02CL01X04RP 价格&库存
很抱歉,暂时无法提供与“BS02CL01X04RP”相匹配的价格&库存,您可以联系我们找货
BS02CL01X04RP
  • 4+1.151914+0.14975
  • 8+1.050598+0.13658
  • 12+1.0097112+0.13126
  • 28+0.9153628+0.11900
  • 52+0.8586052+0.11162
  • 100+0.80293100+0.10438
  • 252+0.73455252+0.09549
  • 500+0.69017500+0.08972
  • 1000+0.650021000+0.08450
库存:288
