SEN-14480
SEN-14480
    SPARKFUNELECTRONICS
    SEN-14480
SEN-14480 数据手册
    SparkFun Triple Axis Accelerometer Breakout ‐ H3LIS331DL SEN-14480 RoHS Open Source Hardware The SparkFun H3LIS331DL Triple Axis Accelerometer Breakout is a low-power, high-g accelerometer with I2C and SPI interface options. Though not necessarily good at detecting minute changes, the H3LIS331DL is great for grueling conditions that normal accelerometers aren’t suited for. With a shock survivability of 10000g and a handy sleep-to-wake function, the H3LIS331DL breakout makes the perfect board for shock and collision detection as well as impact recognition and logging. This breakout offers an adjustable output range of 100, 200 or 400g, and an adjustable data rate of 0.5kHz to 1kHz. While normally operating at 2.16V–3.6V, the SparkFun H3LIS331DL Triple Axis Accelerometer Breakout does feature a pretty impressive low-power mode with low-voltage compatible IOs at 1.8V with a power consumption rate of 10μA. Each pin has been broken out into breadboard-friendly 0.1" pins, and we’ve also added convenient mounting holes that allow you to attach the breakout to whatever ingenious project you can think up. Features         Wide supply voltage, 2.16V to 3.6V Low-voltage compatible IOs, 1.8V Ultra-low power consumption down to 10μA in low-power mode ±100g/±200g/±400g dynamically selectable full scales I2C & SPI digital output interface 16-bit data output Sleep-to-wake function 10000g high-shock survivability                                             https://www.sparkfun.com/products/14480 12‐28‐17
SEN-14480 价格&库存
很抱歉,暂时无法提供与“SEN-14480”相匹配的价格&库存,您可以联系我们找货
SEN-14480
    • 1+254.65320
    • 200+101.61720
    • 500+98.21520
    • 1000+96.54120
    SEN-14480
    • 1+159.985501+20.37620
    库存:30
