IN-PI554FCH
IN-PI554FCH
    INOLUX(英诺斯)
    SMD5050_4P
    发光二极管/LED SMD5050_4P
IN-PI554FCH 数据手册
5050 RGB LED 4-Pin With Integrated IC IN-PI554FCH INolux 5050 RGB LED 4-Pin With Integrated IC IN-PI554FCH Official Product IN Part No. IN-PI554FCH Preliminary Product **************** Specifications are subject to change without notice. Data and drawings herein are copyrighted. Customer Part No. Data Sheet No. **************** Oct. 31, 2016 IN-PI554FCH Version of 2.2 Page 1/19 5050 RGB LED 4-Pin With Integrated IC IN-PI554FCH DISCLAIMER ......................................................................................................................................... 3 PRODUCT SPECIFICATIONS ............................................................................................................. 4 ATTENTION: ELECTROSTATIC DISCHARGE (ESD) PROTECTION ................................................ 4 LABEL SPECIFICATIONS ................................................................................................................... 5 FEATURES .............................................................................................................................................. 6 LED CHARACTERISTICS ........................................................................................................... 7 RECOMMENDED OPERATING RANGES ........................................................................................ 7 SWITCHING CHARACTERISTICS.................................................................................................. 8 PACKAGE OUTLINE DIMENSION & PIN CONFIGURATION .............................................................. 9 PIN DESCRIPTION .................................................................................................................... 9 ABSOLUTE MAXIMUM RATINGS ............................................................................................... 10 FUNCTIONAL DESCRIPTION ..................................................................................................... 10 TIMING WAVEFORMS............................................................................................................... 11 CONSTANT CURRENT CHARACTERISTIC ................................................................................... 13 TYPICAL APPLICATION CIRCUIT DIAGRAM ................................................................................. 14 LED PERFORMANCE GRAPH .................................................................................................. 15 PRECAUTIONS .................................................................................................................................... 16 REVISION HISTORY .......................................................................................................................... 19 Official Product IN Part No. IN-PI554FCH Preliminary Product **************** Specifications are subject to change without notice. Data and drawings herein are copyrighted. Customer Part No. Data Sheet No. **************** Oct. 31, 2016 IN-PI554FCH Version of 2.2 Page 2/19 5050 RGB LED 4-Pin With Integrated IC IN-PI554FCH DISCLAIMER INOLUX reserves the right to make changes without further notice to any products herein to improve reliability, function or design. INOLUX does not assume any liability arising out of the application or use of any product or circuit described herein; neither does it convey any license under its patent rights, nor the rights of others. LIFE SUPPORT POLICY INOLUX’s products are not authorized for use as critical components in life support devices or systems without the express written approval of the President of INOLUX or INOLUX CORPORATION. As used herein: 1. Life support devices or systems are devices or systems which, (a) are intended for surgical implant into the body, or (b) support or sustain life, and (c) whose failure to perform when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in a significant injury of the user. 2. A critical component in any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness. Official Product IN Part No. IN-PI554FCH Preliminary Product **************** Specifications are subject to change without notice. Data and drawings herein are copyrighted. Customer Part No. Data Sheet No. **************** Oct. 31, 2016 IN-PI554FCH Version of 2.2 Page 3/19 5050 RGB LED 4-Pin With Integrated IC IN-PI554FCH Product Specifications Specification Iv Material Quantity Red :750mcd typ. Green :1350mcd typ. Blue :750mcd typ. @12mA/ Ta= 25°C; Tolerance ±10% λD Red :624nm typ. Green :524nm typ. Blue :466nm typ. @12mA/ Ta= 25° C; Tolerance ± 0.5nm Vf Red :1.8-2.2 V Green :2.8-3.2 V Blue :2.8-3.2 V @12mA/ Ta= 25°C; Tolerance ± 0.05V Resin Clear Epoxy Resin Carrier tape EIA 481-1A specs Conductive black tape Reel EIA 481-1A specs Conductive black Label IN standard Paper Packing bag 220x240mm Aluminum laminated bag/ no-zipper One reel per bag Carton IN standard Paper 1000pc/reel Non-specified Others: Each immediate box consists of 5 reels. The 5 reels may not necessarily have the same lot number or the same bin combinations of Iv, λD and Vf. Each reel has a label identifying its specification; the immediate box consists of a product label as well. ATTENTION: Electrostatic Discharge (ESD) protection The symbol to the left denotes that ESD precaution is needed. ESD protection for GaP and AlGaAs based chips is necessary even though they are relatively safe in the presence of low static-electric discharge. Parts built with AlInGaP, GaN, or/and InGaN based chips are STATIC SENSITIVE devices. ESD precaution must be taken during design and assembly. If manual work or processing is needed, please ensure the device is adequately protected from ESD during the process. Official Product IN Part No. IN-PI554FCH Preliminary Product **************** Specifications are subject to change without notice. Data and drawings herein are copyrighted. Customer Part No. Data Sheet No. **************** Oct. 31, 2016 IN-PI554FCH Version of 2.2 Page 4/19 5050 RGB LED 4-Pin With Integrated IC IN-PI554FCH Label Specifications ▓ INolux P/N: I N - P I Product 5 5 4 F C Package H - Color X X X Customer Code IN: PI55: FCH: XXXX: INolux Corporation 5.0 (L) x 5.0 (W) x1.6 (H) mm Full Color Customer Specific Code Customer Part No. Data Sheet No. 4: 4-Pin Version Official Product IN Part No. IN-PI554FCH Preliminary Product **************** Specifications are subject to change without notice. Data and drawings herein are copyrighted. **************** Oct. 31, 2016 IN-PI554FCH Version of 2.2 Page 5/19 X 5050 RGB LED 4-Pin With Integrated IC IN-PI554FCH Features 1. 5050 with integrated high quality constant current IC and RGB LED chip. 2. Built-in IC, with high precision of constant current and internal RGB chips spectral processing in advance. 3. Single line data transmission(return to zero code). 4. Specific Shaping Transmit Technology - number of LED stacked is not restricted. 5. Cascading Enhancement Technology - any 2 LED spacing can be up to 10 meters 6. Data transfer rate of 800 kbp/s at 30 frames per second. 7. RGB output port PWM control can achieve 256 grey level adjustments 9. Upon powering up, IC performs self-inspection then lights connection on the pin B lamp. 10. SA-I Anti-interference patent technology for single line data transmission. 11. Built-in power supply reverse connect protection module, reversed power input will not damage the IC. Official Product IN Part No. IN-PI554FCH Preliminary Product **************** Specifications are subject to change without notice. Data and drawings herein are copyrighted. Customer Part No. Data Sheet No. **************** Oct. 31, 2016 IN-PI554FCH Version of 2.2 Page 6/19 5050 RGB LED 4-Pin With Integrated IC IN-PI554FCH LED Characteristics (Ta=-25oC, unless otherwise specified) Light color Wavelength(nm) Light Working current(mA) intensity(mcd) Working voltage(V) R 620-625 500-1000 12 1.8-2.2 G 520-525 1000-1700 12 2.8-3.2 B 465-470 500-1000 12 2.8-3.2 Recommended Operating Ranges (Ta=-25oC, unless otherwise specified) Parameter Symbol Min. Typ. Max Supply voltage VDD - 5.2 - V - R/G/B port pressure Vds,max - - 26 V - DOUT drive capability IDOH - 49 - mA maximum source current DOUT drive capability IDOL - -50 - mA maximum sink current High level input voltage VIH 3.4 - V VDD=5.0V Low level input voltage VIL - - 1.6 V VDD=5.0V The frequency of PWM FPWM - 1.2 - KHZ - Static power consumption IDD - 1 - mA - Official Product IN Part No. IN-PI554FCH Preliminary Product **************** Specifications are subject to change without notice. Data and drawings herein are copyrighted. Unit Test conditions Customer Part No. Data Sheet No. **************** Oct. 31, 2016 IN-PI554FCH Version of 2.2 Page 7/19 5050 RGB LED 4-Pin With Integrated IC IN-PI554FCH Switching Characteristics (Ta=-25oC, unless otherwise specified) Parameter The speed of data transmission Symbol Min. Typ. Max Unit FDIN - 800 - KHZ TPLH - - 500 ns DOUT transmission delay TRPHL - - 500 ns Tr - 100 - ns Tf - 100 - ns IOUT Rise/Drop Time Official Product IN Part No. IN-PI554FCH Preliminary Product **************** Specifications are subject to change without notice. Data and drawings herein are copyrighted. Customer Part No. DIN→DOUT VDS=1.5 IOUT=13mA Data Sheet No. **************** Oct. 31, 2016 Test conditions IN-PI554FCH Version of 2.2 Page 8/19 5050 RGB LED 4-Pin With Integrated IC IN-PI554FCH Package Outline Dimension & Pin Configuration Outline Dim. Pin Configuration Soldering terminals may shift in the x, y direction. Unit: mm Tolerance: +/-0.1mm PIN Description Number Symbol Function Description 1 2 3 4 VSS DIN VDD DO Ground Display data cascaded input (800k bps) LED and Logic Power Supply Display data cascaded output (800k bps) Official Product IN Part No. IN-PI554FCH Preliminary Product **************** Specifications are subject to change without notice. Data and drawings herein are copyrighted. Customer Part No. Data Sheet No. **************** Oct. 31, 2016 IN-PI554FCH Version of 2.2 Page 9/19 5050 RGB LED 4-Pin With Integrated IC IN-PI554FCH Absolute Maximum Ratings (Ta = 25 oC, Vss=0V, unless otherwise specified) Parameter Symbol Range Unit Logic supply voltage VDD +3.5~+5.5 V Logic input voltage VIN VDD+0.5 V Operating temperature TOPT −45 to +85 °C Storage temperature TSTG −50 to +150 °C ESD pressure VESD 4K V Functional Description The IN-PI554FCH sends signals in return to zero codes with a single-wire communication method. When the power-on reset is completed, the IN-PI554FCH receives the data from the DIN pin. When all the 24 bits of data have been received, IC no longer receive data, the DOUT port starts to forward the data to the next chip as its input data. The DOUT pin is held LOW before the data forwarding. The three PWM output ports, OUTR, OUTG and OUTB, drive Duty ratio output in a 0.6-ms period corresponding to the 24-bit data received before. If the input data from the DIN pin is a RESET code, the IN-PI554FCH will drive the newest received 24-bit data for display. When the reset code is completed, the IN-PI554FCH will start receive the new 24-bit data. When 24 bits of data have been received, the IN-PI554FCH will forward the data through the DOUT pin. Before the RESET signal is received, the output at the OUTR, OUTG and OUTB pins will remain unchanged. When a low level RESET code longer than 80µs is received, the IN-PI554FCH will drive Duty ratio output corresponding to the newest 24-bit data received The IN-PI554FCH employs an automatic shaping-forwarding technique, so the number of the cascaded chips is not limited by the signal transfer, and is only limited by the panel refresh speed. For example, in a 1024-chip cascaded design with the panel refresh time of 1024X3X8 X 1.25(us)=30ms, no flickering will appear. Official Product IN Part No. IN-PI554FCH Preliminary Product **************** Specifications are subject to change without notice. Data and drawings herein are copyrighted. Customer Part No. Data Sheet No. **************** Oct. 31, 2016 IN-PI554FCH Version of 2.2 Page 10/19 5050 RGB LED 4-Pin With Integrated IC IN-PI554FCH Timing Waveforms 1. Input Code 2. The data transmission time (TH+TL=1.25µs±600ns): Name Description Typ. value error T0H 0 code,high level time 0.3µs ±0.15µs T1H 1 code,high level time 0.6µs ±0.15µs T0L 0 code,low level time 0.9µs ±0.15µs T1L 1 code,low level time 0.6µs ±0.15µs Reset code,low level time 80µs Reset 3. Connection Scheme Official Product IN Part No. IN-PI554FCH Preliminary Product **************** Specifications are subject to change without notice. Data and drawings herein are copyrighted. Customer Part No. Data Sheet No. **************** Oct. 31, 2016 IN-PI554FCH Version of 2.2 Page 11/19 5050 RGB LED 4-Pin With Integrated IC IN-PI554FCH 4. Data Transfer Format 5. 24-bit data format G7 G6 G5 G4 G3 G2 G1 G0 R7 R6 R5 R4 R3 R2 R1 R0 B7 B6 B5 B4 B3 B2 Note: The data is sent in the sequence of GRB, and the MSB is sent first. Official Product IN Part No. IN-PI554FCH Preliminary Product **************** Specifications are subject to change without notice. Data and drawings herein are copyrighted. Customer Part No. Data Sheet No. **************** Oct. 31, 2016 IN-PI554FCH Version of 2.2 Page 12/19 B1 B0 5050 RGB LED 4-Pin With Integrated IC IN-PI554FCH Constant Current Characteristic With excellent constant current characteristics, (1) The differences of current between Channel is less than ±1.5℅ (2) The differences of current between Chip is less than ±3℅ (3) When the voltage of the load change, the output current is not affected, as shown in the figure below (4) Below output port of the current Iout and add on the port voltage Vds curve relationship. The smaller the Iout current, the smaller in the condition of constant current need of Vds. Official Product IN Part No. IN-PI554FCH Preliminary Product **************** Specifications are subject to change without notice. Data and drawings herein are copyrighted. Customer Part No. Data Sheet No. **************** Oct. 31, 2016 IN-PI554FCH Version of 2.2 Page 13/19 5050 RGB LED 4-Pin With Integrated IC IN-PI554FCH Typical Application circuit diagram Official Product IN Part No. IN-PI554FCH Preliminary Product **************** Specifications are subject to change without notice. Data and drawings herein are copyrighted. Customer Part No. Data Sheet No. **************** Oct. 31, 2016 IN-PI554FCH Version of 2.2 Page 14/19 5050 RGB LED 4-Pin With Integrated IC IN-PI554FCH LED Performance Graph Official Product IN Part No. IN-PI554FCH Preliminary Product **************** Specifications are subject to change without notice. Data and drawings herein are copyrighted. Customer Part No. Data Sheet No. **************** Oct. 31, 2016 IN-PI554FCH Version of 2.2 Page 15/19 5050 RGB LED 4-Pin With Integrated IC IN-PI554FCH Precautions Please read the following notes before using the product: 1. Storage 1.1 Do not open moisture proof bag before the products are ready to use. 1.2 Before opening the package, the LEDs should be kept at 30℃ or less and 80%RH or less. 1.3 The LEDs should be used within a year. 1.4 After opening the package, the LEDs should be kept at 30℃ or less and 60%RH or less. 1.5 The LEDs should be used within 24 hours (1 day) after opening the package. 1.6 If the moisture adsorbent material has fabled away or the LEDs have exceeded the storage time, baking treatment should be performed using the following conditions. Baking treatment: 60±5℃ for 24 hours. Official Product IN Part No. IN-PI554FCH Preliminary Product **************** Specifications are subject to change without notice. Data and drawings herein are copyrighted. Customer Part No. Data Sheet No. **************** Oct. 31, 2016 IN-PI554FCH Version of 2.2 Page 16/19 5050 RGB LED 4-Pin With Integrated IC IN-PI554FCH 2. Soldering Condition Recommended soldering conditions: Profile Feature Lead-Free Solder Average Ramp-Up Rate (Ts max to Tp ) 3℃/second max. Preheat: Temperature Min (Ts min) 150℃ Preheat: Temperature Min (Ts max) 200℃ Preheat: Time ( ts min to ts max ) 60-180 seconds Time Maintained Above: Temperature (TL) 217 ℃ Time Maintained Above: Time (t L) 60-150 seconds Peak/Classification Temperature (T P) 240 ℃ Time Within 5℃ of Actual Peak Temperature ( tp)
IN-PI554FCH 价格&库存
很抱歉,暂时无法提供与“IN-PI554FCH”相匹配的价格&库存,您可以联系我们找货
IN-PI554FCH
  • 1+6.187621+0.80456
  • 10+4.3191710+0.56161
  • 100+3.09381100+0.40228
  • 500+2.43333500+0.31640
  • 1000+2.190001000+0.28476
  • 2000+1.964052000+0.25538
  • 3000+1.903223000+0.24747
库存:3000
IN-PI554FCH
  • 1+6.792531+0.88322
  • 10+4.7441110+0.61687
  • 100+3.45844100+0.44970
  • 500+2.88422500+0.37503
库存:67165
IN-PI554FCH
  • 1+5.75184
  • 10+4.01503
  • 100+2.87592
  • 500+2.26145
  • 1000+2.03626
  • 2000+1.82545
  • 3000+1.76915
库存:3000
IN-PI554FCH
  • 1000+2.695861000+0.35054
  • 2000+2.535772000+0.32972
  • 3000+2.453603000+0.31904
  • 5000+2.360795000+0.30697
  • 7000+2.305547000+0.29979
  • 10000+2.2516810000+0.29278
库存:67165
