UMFTPD2A
UMFTPD2A
    BRIDGETEK
    UMFTPD2A
UMFTPD2A 数据手册
UMFTPD2A PROGRAM MODULE Version 1.3 Document No.: BRT_000027 Clearance No.: BRT#029 Future Technology Devices International UMFTPD2A UMFTPD2A is a module used for FT90x programming, debugging and EFUSE burning. The UMFTPD2A is a module with an FT4232HL Hi-Speed USB2.0 to multipurpose UART/MPSSE converter. The UMFTPD2A module features a single line half-duplex UART signal with no handshake (One-Wire interface), one MPSSE interface, one UART interface and a Bit-Bang port. The module has configured the FT4232HL Channel A as a UMFTPD2A one-wire interface for MM900EVxA evaluation board firmware / application download, or GDB debugging. The FT4232HL Channel B is configured as a UMFTPD2A MPSSE interface with 4 GPIO control signals. This allows the UMFTPD2A to implement MM900EVxA evaluation board EFUSE program, or firmware / application upload as well. The FT4232HL Channel C is optional. It is configured as a UART that can capture the messages from MM900EVxA evaluation board in software debugging. The FT4232HL Channel D is reserved as a BitBang interface for generic GPIO purposes. The FT90x program utility can activate the required channels corresponding to the operations. The UMFTPD2A has the following features:  Hi-Speed USB to one-wire interface converter  Hi-Speed USB to MPSSE interface converter  Hi-Speed USB to UART interface converter  Provides H/W Reset# signal  Provide multiple generic GPIO control signals  PWREN# line to control +5V power supply  Fuse protected with 0.5A hold current and schottky diode on the output power line.  Two dedicated GPIOs to control VPP and FRSC power supplies  Three LEDs for power supply indication  2X5 way 1.27mm pitch Micro-MaTch socket  2X6 way 2.54mm pitch through hole pin header  Mirco-B type USB port  Micro-MaTch Male to Male 10 pin ribbon cable  All components used are Pb-free (RoHS compliant) Neither the whole nor any part of the information contained in, or the product described in this manual, may be adapted or reproduced in any material or electronic form without the prior written consent of the copyright holder. This product and its documentation are supplied on an as-is basis and no warranty as to their suitability for any particular purpose is either made or implied. Future Technology Devices International Ltd will not accept any claim for damages howsoever arising as a result of use or failure of this product. Your statutory rights are not affected. This product or any variant of it is not intended for use in any medical appliance, device or system in which the failure of the product might reasonably be expected to result in personal injury. This document provides preliminar y information that may be subject to change without notice. No freedom to use patents or other intellectual property rights is implied by the publication of this document. Future Technology Devices International Ltd, Unit1, 2 Seaward Place, Centurion Business Park, Glasgow, G41 1HH, United Kingdom. Scotland Registered Number: SC136640 Copyright © Bridgetek Limited 1 UMFTPD2A PROGRAM MODULE Version 1.3 Document No.: BRT_000027 Clearance No.: BRT#029 Table of Contents 1 Driver Support ................................................................ 3 2 Programming Utility Support........................................... 3 3 Ordering Information ...................................................... 3 4 UMFTPD2A Signals .......................................................... 4 4.1 UMFTPD2A Pin Out .................................................................... 4 4.2 Signal Descriptions ................................................................... 5 5 Module Dimensions ......................................................... 7 6 UMFTPD2A Module Circuit Schematic .............................. 8 7 Hardware Setup Guide .................................................. 10 8 7.1 Module Connect to PC ............................................................. 10 7.2 Module Connect to MM900EVx ................................................ 10 7.3 FT900 Programming Utility ..................................................... 10 Contact Information ...................................................... 12 Appendix A – References ................................................... 11 Document References ..................................................................... 11 Acronyms and Abbreviations ........................................................... 11 Appendix B – List of Figures and Tables ............................. 12 List of Figures ................................................................................. 12 List of Tables ................................................................................... 12 Appendix C – Revision History ........................................... 13 Copyright © Bridgetek Limited 2 UMFTPD2A PROGRAM MODULE Version 1.3 Document No.: BRT_000027 Clearance No.: BRT#029 1 Driver Support Royalty free D2XX Direct Drivers (USB Drivers + DLL S/W Interface)  Windows 10 32, 64-bit  Windows 8.1 32, 64-bit  Windows 8 32, 64-bit  Windows 7 32, 64-bit The above listed drivers are all available for download from http://www.ftdichip.com/FTDrivers.htm. For driver’s installation, please refer to http://www.ftdichip.com/Support/Documents/InstallGuides.htm. 2 Programming Utility Support The programming utility is provided as part of the free FT90x toolchain. Visit FTDI’s website at http://www.ftdichip.com/Products/ICs/FT90x.html for more information. 3 Ordering Information Module Code Description UMFTPD2A FTDI Programmer/Debugger Module Copyright © Bridgetek Limited 3 UMFTPD2A PROGRAM MODULE Version 1.3 Document No.: BRT_000027 Clearance No.: BRT#029 4 UMFTPD2A Signals 4.1 UMFTPD2A Pin Out Figure 4.1 – UMFTPD2A Module Pin Out Figure 1 illustrates the signals available on J1, J2 pin header and CN2, CN3 connector of the UMFTPD2A. There are 3 LED indicators for the different power supplies. LED1 is for the VPP power supply. LED2 is for the FRSC power supply. LED3 is for the VSW (+5V) power output. LED1 and LED2 only will be turned on when the system is programming the FT90x chip EFUSE. Copyright © Bridgetek Limited 4 UMFTPD2A PROGRAM MODULE Version 1.3 Document No.: BRT_000027 Clearance No.: BRT#029 4.2 Signal Descriptions Pin No. Name Type Description CN2-1 SCK Signal output Serial clock output for SPI. CN2-2 SS# Signal output Slave select output for SPI. CN2-3 MOSI Signal Output Master out slave in for SPI. CN2-4 MISO Signal input Master in slave out for SPI. CN2-5 VPP Power Out Typically +1.85V power output when adjustable LDO is enabled. CN2-6 FRSC Power Out Typically +3.7V power output when adjustable LDO is enabled. CN2-7 GND Ground 0V Ground. CN2-8 DBG Signal Input/Output One-wire debugger interface input/output. CN2-9 PROG# Signal Output Feature reserved for future use. CN2-10 RESET# Signal Output Active low reset output. CN2-11 VSW Power Out CN2-12 VSW Power Out +5V power output. Outputs the power source from the USB bus when the FT4232HL has enumerated. +5V power output. Outputs the power source from the USB bus when the FT4232HL has enumerated. Table 1 - CN2 Connector Pin Out Description Pin No. Name Type Description CN3-1 SCK Signal Output Serial clock output for SPI. CN3-2 SS# Signal Output Slave select output for SPI. CN3-3 MOSI Signal Output Master out slave in for SPI. CN3-4 MISO Signal Input Master in slave out for SPI. CN3-5 VPP Power Out Typically +1.85V power output when adjustable LDO is enabled. CN3-6 FRSC Power Out Typically +3.7V power output when adjustable LDO is enabled. CN3-7 GND Ground 0V Ground. CN3-8 DBG Signal Input/Output One-wire debugger interface input/output. CN3-9 VSW Power Out CN3-10 RESET# Signal Output +5V power output. Outputs the power source from the USB bus when the FT4232HL has enumerated. Active low reset output. Table 2 - CN3 Connector Pin Out Description Copyright © Bridgetek Limited 5 UMFTPD2A PROGRAM MODULE Version 1.3 Document No.: BRT_000027 Clearance No.: BRT#029 Pin No. Name Type Description J1-0 GPIO0 Signal Input/Output Generic GPIO pin 0 J1-1 GPIO1 Signal Input/Output Generic GPIO pin 1 J1-2 GPIO2 Signal Input/Output Generic GPIO pin 2 J1-3 GPIO3 Signal Input/Output Generic GPIO pin 3 J1-4 GPIO4 Signal Input/Output Generic GPIO pin 4 J1-5 GPIO5 Signal Input/Output Generic GPIO pin 5 J1-6 GPIO6 Signal Input/Output Generic GPIO pin 6 J1-7 GPIO7 Signal Input/Output Generic GPIO pin 7 Table 3 - J1 Header Pin Out Description Pin No. Name Type Description J2-1 GND Ground 0V ground J2-2 C_CTS# Signal Input Active low clear to send input for UART J2-3 VCC3V3 Power out +3.3V power output J2-4 C_TXD Signal Output Active high transmitter output for UART J2-5 C_RXD Signal Input Active high receiver input for UART J2-6 C_RTS# Signal Output Active low request to send output for UART Table 4 - J2 Header Pin Out Description Copyright © Bridgetek Limited 6 UMFTPD2A PROGRAM MODULE Version 1.3 Document No.: BRT_000027 Clearance No.: BRT#029 5 Module Dimensions Figure 5.1 – UMFTPD2A Module Dimensions All dimensions are given in millimetres. Hole size diameter = 3.2mm. The UMFTPD2A module exclusively uses lead free components, and is fully compliant with European Union directive 2002/95/EC. Copyright © Bridgetek Limited 7 UMFTPD2A PROGRAM MODULE Version 1.3 Document No.: BRT_000027 Clearance No.: BRT#029 6 UMFTPD2A Module Circuit Schematic Figure 6.1 - Schematic part 1 Copyright © Bridgetek Limited 8 UMFTPD2A PROGRAM MODULE Version 1.3 Document No.: BRT_000027 Clearance No.: BRT#029 Figure 6.2 - Schematic part 1 Copyright © Bridgetek Limited 9 UMFTPD2A PROGRAM MODULE Version 1.3 Document No.: BRT_000027 Clearance No.: BRT#029 7 Hardware Setup Guide 7.1 Module Connect to PC The first time the UMFTPD2A module is connected to a Windows OS PC, the USB device drivers need to install. This should happen automatically if you are connected to a network but you can also download from the FTDI Website. Before the FT900 programming utility uses this module, make sure the D2xx device driver installation completes successfully. 7.2 Module Connect to MM900EVx The UMFTPD2A module should be connected as shown in Figure 7.1 to the MM900EVxA modules. Figure 7.1 – FT90x System Connection 7.3 FT900 Programming Utility Run the FT90x programming utility (Figure 7.2) to download firmware / application after the whole setup (Figure 7.3) is ready. Please refer to AN_325 FT90X Toolchain Guide for tool operation. Copyright © Bridgetek Limited 10 UMFTPD2A PROGRAM MODULE Version 1.3 Document No.: BRT_000027 Clearance No.: BRT#029 Figure 7.2 – FT90x Progamming Utility Figure 7.3 – MM900EVxA Module Connection Copyright © Bridgetek Limited 11 UMFTPD2A PROGRAM MODULE Version 1.3 Document No.: BRT_000027 Clearance No.: BRT#029 8 Contact Information Head Quarters – Singapore Branch Office – Taipei, Taiwan Bridgetek Pte Ltd 178 Paya Lebar Road, #07-03 Singapore 409030 Tel: +65 6547 4827 Fax: +65 6841 6071 Bridgetek Pte Ltd, Taiwan Branch 2 Floor, No. 516, Sec. 1, Nei Hu Road, Nei Hu District Taipei 114 Taiwan, R.O.C. Tel: +886 (2) 8797 5691 Fax: +886 (2) 8751 9737 E-mail (Sales) E-mail (Support) E-mail (Sales) E-mail (Support) sales.apac@brtchip.com support.apac@brtchip.com sales.apac@brtchip.com support.apac@brtchip.com Branch Office - Glasgow, United Kingdom Branch Office – Vietnam Bridgetek Pte. Ltd. Unit 1, 2 Seaward Place, Centurion Business Park Glasgow G41 1HH United Kingdom Tel: +44 (0) 141 429 2777 Fax: +44 (0) 141 429 2758 Bridgetek VietNam Company Limited Lutaco Tower Building, 5th Floor, 173A Nguyen Van Troi, Ward 11, Phu Nhuan District, Ho Chi Minh City, Vietnam Tel : 08 38453222 Fax : 08 38455222 E-mail (Sales) E-mail (Support) E-mail (Sales) E-mail (Support) sales.emea@brtichip.com support.emea@brtchip.com sales.apac@brtchip.com support.apac@brtchip.com Web Site http://brtchip.com/ Distributor and Sales Representatives Please visit the Sales Network page of the Bridgetek Web site for the contact details of our distributor(s) and sales representative(s) in your country. System and equipment manufacturers and designers are responsible to ensure that their systems, and any Future Technology Devices International Ltd (FTDI) devices incorporated in their systems, meet all applicable safety, regulatory and system-level performance requirements. All application-related information in this document (including application descriptions, suggested FTDI devices and other materials) is provided for reference only. While FTDI has taken care to assure it is accurate, this information is subject to customer confirmation, and FTDI disclaims all liability for system designs and for any applications assistance provided by FTDI. Use of FTDI devices in life support and/or safety applications is entirely at the user’s risk, and the user agrees to defend, indemnify and hold harmless FTDI from any and all damages, claims, suits or expense resulting from such use. This document is subject to change without notice. No freedom to use patents or other intellectual property rights is implied by the publication of this document. Neither the whole nor any part of the information contained in, or the product described in this document, may be adapted or reproduced in any material or electronic form without the prior written consent of the copyright holder. Future Technology Devices International Ltd, Un it 1, 2 Seaward Place, Centurion Business Park, Glasgow G41 1HH, United Kingdom. Scotland Registered Company Number: SC136640 Copyright © Bridgetek Limited 12 UMFTPD2A PROGRAM MODULE Version 1.3 Document No.: BRT_000027 Clearance No.: BRT#029 Appendix A – References Document References FT90x datasheet: FT900/FT901/FT902/FT903 Datasheet FT900 tool chain installation guide document: AN_325 FT900 Tool Chain Installation Guide Acronyms and Abbreviations Terms DLL GPIO LED MPSSE Description Dynamic Link Library General Purpose Input/Output Light Emitting Diode Multi-Protocol Synchronous Serial Engine OS Operating System PC Personal Computer RoHS Restriction of Hazardous Substances UART Universal Asynchronous Receiver Transmitter USB Universal Serial Bus Copyright © Bridgetek Limited 11 UMFTPD2A PROGRAM MODULE Version 1.3 Document No.: BRT_000027 Clearance No.: BRT#029 Appendix B – List of Figures and Tables List of Figures Figure 4.1 – UMFTPD2A Module Pin Out ........................................................................................... 4 Figure 5.1 – UMFTPD2A Module Dimensions ..................................................................................... 7 Figure 6.1 - Schematic part 1 ......................................................................................................... 8 Figure 6.2 - Schematic part 1 ......................................................................................................... 9 Figure 7.1 – FT90x System Connection .......................................................................................... 10 Figure 7.2 – FT90x Progamming Utility .......................................................................................... 11 Figure 7.3 – MM900EVxA Module Connection.................................................................................. 11 List of Tables Table 1 - CN2 Connector Pin Out Description .................................................................................... 5 Table 2 - CN3 Connector Pin Out Description .................................................................................... 5 Table 3 - J1 Header Pin Out Description ........................................................................................... 6 Table 4 - J2 Header Pin Out Description ........................................................................................... 6 Copyright © Bridgetek Limited 12 UMFTPD2A PROGRAM MODULE Version 1.3 Document No.: BRT_000027 Clearance No.: BRT#029 Appendix C – Revision History Document Title : UMFTPD2A Program Module Document Reference No. : BRT_000027 Clearance No. : BRT#029 Product Page : http://brtchip.com/product Document Feedback : Send Feedback Revision Changes Date 1.0 Initial Release 2015-09-21 1.1 Updated schematic image 2015-09-30 1.2 Corrected the Typo Big Bang to Bit Bang on the Title page 2016-04-07 1.3 Dual branding to reflect the migration of the product to the Bridgetek name – logo changed, copyright changed, contact information changed 2016-09-16 Revision History Copyright © Bridgetek Limited 13
UMFTPD2A 价格&库存
很抱歉,暂时无法提供与“UMFTPD2A”相匹配的价格&库存,您可以联系我们找货
UMFTPD2A
  • 1+295.042101+38.17160
UMFTPD2A
    • 1+258.85675
    库存:19
