MAX14808ETK+
MAX14808ETK+
    MAX(迈旭)
    MAX14808ETK+
MAX14808ETK+ 数据手册
EVALUATION KIT AVAILABLE MAX14808/MAX14809 Octal Three-Level/Quad Five-Level High-Voltage 2A Digital Pulsers with T/R Switch General Description Benefits and Features The MAX14808/MAX14809 octal three-level/quad fivelevel, high-voltage (HV) pulser devices generate highfrequency HV bipolar pulses (up to Q105V) from lowvoltage control logic inputs for driving piezoelectric transducers in ultrasound systems. All eight channels have embedded overvoltage-protection diodes and an integrated active return-to-zero clamp. Both devices have embedded independent (floating) power supplies (FPS) and level shifters that allow signal transmission without the need for external HV capacitors. The MAX14808 also features eight integrated transmit/receive (T/R) switches. The MAX14809 does not have the T/R switch function. S Save Space (Optimized for High-Channel-Count Systems/Portable Systems)  High Density • 8 Channels (Three-Level Operation) • 4 Channels (Five-Level Operation) in One Package  Integrated Low-Power T/R Switches (MAX14808)  DirectDrive® Architecture Eliminates External High-Voltage Capacitor  No External Floating Power Supply (FPS) Required The devices feature two modes of operation: an octal three-level pulser mode (with integrated active returnto-zero clamp) or a quad five-level pulser mode. In octal three-level pulser mode, each channel is controlled by two logic inputs (DINN_ /DINP_) and the active return to zero features half the current driving of the pulser 1A (typ). In quad five-level pulser mode, each channel is controlled by three logic inputs and the active return to zero has the same current driving of the pulser 2A (typ). The devices can operate both in clocked and transparent mode. In clocked mode, data inputs can be synchronized with a clean differential or single-ended clock to reduce phase noise associated with FPGA output signals that are detrimental for Doppler analysis. In transparent mode, the synchronization feature is disabled and output reflects the data input after a 18ns delay. Both devices feature adjustable maximum current (0.5A to 2A) to reduce power consumption when full current capability is not required. The devices feature integrated grass-clipping diodes (with low parasitic capacitance) for receive (Rx) and transmit (Tx) isolations. Both devices feature a damping circuit that can be activated as soon as the transmit burst is over. The damping circuit has a typical on-resistance of 500I. It fully discharges the pulser’s output internal node before the grass-clipping diodes. The devices are available in a 68-pin (10mm x 10mm) TQFN package with an exposed pad and are specified over the -40NC to +85NC extended temperature range. S High Performance (Designed to Enhance Image Quality)  Excellent -43dBc (typ) THD for Second Harmonic at 5MHz  Sync Function Eliminates Effects of FPGA Jitter and Improves Performance in Doppler Mode  Low Propagation Delay 18ns (typ)  Strong Active Return to Zero S Save Power  Low Quiescent Power Dissipation (5.7mW/ Channel in Octal Mode)  Programmable Current Capability  Shutdown Mode and Disable Transmit Mode Applications Ultrasound Medical Imaging Industrial Flaw Detection Piezoelectric Drivers Test Equipment Ordering Information and Functional Diagram appear at end of data sheet. DirectDrive is a registered trademark of Maxim Integrated Products, Inc. For related parts and recommended products to use with this part, refer to www.maximintegrated.com/MAX14808.related. For pricing, delivery, and ordering information, please contact Maxim Direct at 1-888-629-4642, or visit Maxim’s website at www.maximintegrated.com. 19-6438; Rev 2; 1/14 MAX14808/MAX14809 Octal Three-Level/Quad Five-Level High-Voltage 2A Digital Pulsers with T/R Switch ABSOLUTE MAXIMUM RATINGS THP Logic Output Voltage Range.........................-0.3V to +5.6V VGPA, VGPB Output Voltage Range........max[(VPP_ - 5.6V), (VEE + 0.6V)] to (VPP_ + 0.3V) VGNA, VGNB Output Voltage Range.......(VNN_ - 0.3V) to min[(VCC + 0.6V), (VNN_ + 5.6V)] Continuous Power Dissipation (TA = +70°C) TQFN (derate 50mW/NC above +70°C).......................4000mW Operating Temperature Range........................... -40°C to +85°C Maximum Junction Temperature......................................+150°C Storage Temperature Range............................. -65°C to +150°C Lead Temperature (soldering, 10s).................................+300°C Soldering Temperature (reflow).......................................+260°C (All voltages referenced to GND.) VDD Logic Supply Voltage Range........................-0.3V to +5.6V VCC Positive Driver Supply Voltage Range..........-0.3V to +5.6V VEE Negative Driver Supply Voltage Range.........-5.6V to +0.3V VNNA, VNNB High Negative Supply Voltage Range......................................-110V to +0.3V VPPA, VPPB High Positive Supply Voltage Range......................................-0.3V to +110V OUT_ Output Voltage Range..................................VNN_ to VPP_ LVOUT_ Output Voltage Range (100mA Maximum Current)...............................-1.2V to +1.2V DINN_, DINP_, CC_, SYNC, LDO_EN...................-0.3V to +5.6V CLK, CLK, MODE_ Voltage Range........... -0.3V to (VCC + 0.3V) Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. PACKAGE THERMAL CHARACTERISTICS (Note 1) TQFN Junction-to-Ambient Thermal Resistance (BJA).............20°C/W Junction-to-Case Thermal Resistance (BJC)...................0.5°C/W Note 1: Package thermal resistances were obtained using the method described in JEDEC specification JESD51-7, using a four-layer board. For detailed information on package thermal considerations, refer to www.maximintegrated.com/thermal-tutorial. DC ELECTRICAL CHARACTERISTICS (VDD = +3V, VCC = +5V, VEE = -5V, VPPA = +100V, VNNA = -100V, VPPB = +100V, VNNB = -100V, 1µF bypass capacitor between VGNA and VNNA, 1FF bypass capacitor between VGNB and VNNB, 1µF bypass capacitor between VGPA and VPPA, 1µF bypass capacitor between VGPB and VPPB, VLDO_EN = 0V, no load, unless otherwise noted. Typical values are at TA = +25°C.) (Note 2) PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS POWER SUPPLIES (VDD, VCC, VEE, VPP_, VNN_) Logic Supply Voltage VDD +1.7 +3 +5.25 V Positive Drive Supply Voltage VCC +4.9 +5 +5.1 V Negative Drive Supply Voltage VEE -5.1 -5 -4.9 V High-Side Supply Voltage VPP_ 0 +105 V Low-Side Supply Voltage VNN_ -105 0 V External Low-Side LDO Voltage VGN_ VNN_ LDO_EN = high 5 5.3 5.5 V External High-Side LDO Voltage VPP_ VGP_ LDO_EN = high 5 5.3 5.5 V External Floating Power-Supply Current from VGN_ IVGN_ LDO_EN = high (Note 3) 50 mA External Floating Power-Supply Current from VGP_ IVGP_ LDO_EN = high (Note 3) 85 mA LOGIC INPUTS/OUTPUTS (DINN_, DINP_, MODE_, SYNC, CC_, LDO_EN) Low-Level Input Threshold VIL High-Level Input Threshold VIH Logic Input Capacitance CIN Maxim Integrated 0.2 x VDD 0.8 x VDD V V 4 pF   2 MAX14808/MAX14809 Octal Three-Level/Quad Five-Level High-Voltage 2A Digital Pulsers with T/R Switch DC ELECTRICAL CHARACTERISTICS (continued) (VDD = +3V, VCC = +5V, VEE = -5V, VPPA = +100V, VNNA = -100V, VPPB = +100V, VNNB = -100V, 1µF bypass capacitor between VGNA and VNNA, 1FF bypass capacitor between VGNB and VNNB, 1µF bypass capacitor between VGPA and VPPA, 1µF bypass capacitor between VGPB and VPPB, VLDO_EN = 0V, no load, unless otherwise noted. Typical values are at TA = +25°C.) (Note 2) PARAMETER Logic Input Leakage (All Inputs Except LDO_EN) SYMBOL IIN LDO_EN Pulldown Resistance RLDO_EN THP Low-Level Output Voltage VOL Differential Clock Input Voltage Range VCLKD CONDITIONS VIN = 0V or VDD MIN TYP MAX UNITS -1 0 +1 FA 7 10 14 kI Pullup resistor to VDD (RPULLUP = 1kI) CLOCK INPUTS (CLK, CLK)—DIFFERENTIAL MODE Common-Mode Voltage Common-Mode Voltage Range 0.1 x VDD 0.2 VCLKCM VCC/2 VCC/2 - 0.45 VCL Input Resistance RCLK, RCLK Input Capacitance CCLK, CCLK 2 V VP-P V VCC/2 + 0.45 V Differential 7 kI Common mode 23 kI Capacitance to GND (each input) 4 pF CLOCK INPUTS (CLK, CLK)—SINGLE-ENDED MODE (VCLK < 0.1V) Low-Level Input VIL CLK High-Level Input VIH CLK Single-Ended Mode Selection Threshold Low VIL CLK Single-Ended Mode Selection Threshold High VIH CLK 0.2 x VDD 0.8 x VDD V 0.1 1 CCLK Logic Input Leakage (CLK) ICLK VCLK = 0V or VDD Pullup Current (CLK) ICLK VCLK = 0V -1 V V 4 Input Capacitance (CLK) V pF 0 +1 FA 120 180 FA SUPPLY CURRENT—SHUTDOWN MODE (MODE0 = Low, MODE1 = Low) VDD Supply Current IDD VCC Supply Current 3 FA ICC All inputs connected to GND or VDD All inputs connected to GND or VDD 22 FA VEE Supply Current IEE All inputs connected to GND or VDD 13 FA VPP_ Supply Current IPP_ 10 FA VNN_ Supply Current INN_ All inputs connected to GND or VDD All inputs connected to GND or VDD 10 FA SUPPLY CURRENT—DISABLE MODE (MODE0 = High, MODE1 = High) VDD Supply Current Maxim Integrated IDDQ All inputs connected to GND or VDD Transparent or singleended clock mode 1.7 Differential clock mode, VCLKD = 0.2V 110 3 FA 190   3 MAX14808/MAX14809 Octal Three-Level/Quad Five-Level High-Voltage 2A Digital Pulsers with T/R Switch DC ELECTRICAL CHARACTERISTICS (continued) ((VDD = +3V, VCC = +5V, VEE = -5V, VPPA = +100V, VNNA = -100V, VPPB = +100V, VNNB = -100V, 1µF bypass capacitor between VGNA and VNNA, 1FF bypass capacitor between VGNB and VNNB, 1µF bypass capacitor between VGPA and VPPA, 1µF bypass capacitor between VGPB and VPPB, VLDO_EN = 0V, no load, unless otherwise noted. Typical values are at TA = +25°C.) (Note 2) PARAMETER SYMBOL CONDITIONS MIN DINN_ = DINP_ = GND VEE Supply Current IEEQ DINN_ = DINP_ = VDD MAX14808 MAX14809 ICCQ DINN_ = DINP_ = VDD MAX 0.4 9.4 13 1.37 2 0.49 0.75 MAX14808 9.6 13.2 MAX14809 1.6 2.3 DINN_ = DINP_ = GND VCC Supply Current TYP 0.26 UNITS mA mA VCC Supply Current Increase in Clocked Mode DICC Differential clock mode 3.5 5 mA VNN_ Total Supply Current (Quiescent Mode) INNQ_ All inputs connected to GND or VDD 195 305 FA VPP_ Total Supply Current (Quiescent Mode) IPPQ_ All inputs connected to GND or VDD 220 340 FA PPDIS1 T/R switch off, damp off (transparent mode) 5.7 PPDIS2 DINN_ = DINP_ = VDD Total Power Dissipation per Channel (Disable Mode) MAX14808 17 MAX14809 7 mW SUPPLY CURRENT—OCTAL THREE-LEVEL MODE, NO LOAD (MODE0 = High, MODE1 = Low) VDD Supply Current (Quiescent Mode) VEE Supply Current (Quiescent Mode) IDD All inputs connected to GND or VDD Transparent or single-ended clock mode Differential clock mode, VCLKD = 0.2V DINN_ = DINP_ = GND IEEQ DINN_ = DINP_ = VDD MAX14808 MAX14809 1.7 3 FA 110 190 0.26 0.4 9.4 13 1.37 2 0.49 0.75 MAX14808 9.6 13.2 MAX14809 1.6 2.3 DINN_ = DINP_ = GND mA VCC Supply Current (Quiescent Mode) ICCQ VCC Supply Current Increase in Clocked Mode DICC Differential clock mode 3.5 5 mA VNN_ Total Supply Current (Quiescent Mode) INNQ_ All inputs connected to GND or VDD 195 305 FA VPP_ Total Supply Current (Quiescent Mode) IPPQ_ All inputs connected to GND or VDD 220 340 FA Maxim Integrated DINN_ = DINP_ = VDD mA   4 MAX14808/MAX14809 Octal Three-Level/Quad Five-Level High-Voltage 2A Digital Pulsers with T/R Switch DC ELECTRICAL CHARACTERISTICS (continued) (VDD = +3V, VCC = +5V, VEE = -5V, VPPA = +100V, VNNA = -100V, VPPB = +100V, VNNB = -100V, 1µF bypass capacitor between VGNA and VNNA, 1FF bypass capacitor between VGNB and VNNB, 1µF bypass capacitor between VGPA and VPPA, 1µF bypass capacitor between VGPB and VPPB, VLDO_EN = 0V, no load, unless otherwise noted. Typical values are at TA = +25°C.) (Note 2) PARAMETER Total Power Dissipation per Channel (Quiescent Mode) SYMBOL CONDITIONS PPDIS1 T/R switch off, damp off (transparent mode) PPDIS2 DINN_ = DINP_ = VDD (transparent mode) IDD1 VDD Supply Current IDD2 MIN TYP MAX 5.7 MAX14808 17 MAX14809 7 mW CW Doppler (Note 4), transparent or single-ended clock mode 2.2 3.2 B mode (Note 5), transparent or single-ended clock mode (Figure 1a) (MAX14808) 3.3 6 10 20 IEE1 8 channels switching, CW Doppler (Note 4) CC0 = high, CC1 = high 67 92 MAX14808 9.7 14.8 IEE2 8 channels switching, B mode (Note 5) (Figure 1a), CC0 = low, CC1 = low MAX14809 2 3 CC0 = high, CC1 = high 45 60 MAX14808 10 15 MAX14809 2.1 3.2 ICC1 8 channels switching, CW Doppler (Note 4) ICC2 8 channels switching, B mode (Note 5) (Figure 1a), CC0 = low, CC1 = low VCC Supply Current mA FA B mode (Note 5), transparent or single-ended clock mode (Figure 1a) (MAX14809) VEE Supply Current UNITS mA mA VDD Supply Current Increase in Clocked Mode DIDD Differential clock mode 1.8 mA VCC Supply Current Increase in Clocked Mode DICC Differential clock mode 3.8 mA INN1 8 channels switching, CW Doppler, CC0 = high, CC1 = high, RL = 1kI, CL = 240pF (Note 4) 157 INN2 8 channels switching, B mode (Figure 1a), CC0 = low, CC1 = low, RL = 1kI, CL = 240pF (Note 5) 2 VNN_ Supply Current Maxim Integrated 200 mA 2.8   5 MAX14808/MAX14809 Octal Three-Level/Quad Five-Level High-Voltage 2A Digital Pulsers with T/R Switch DC ELECTRICAL CHARACTERISTICS (continued) (VDD = +3V, VCC = +5V, VEE = -5V, VPPA = +100V, VNNA = -100V, VPPB = +100V, VNNB = -100V, 1µF bypass capacitor between VGNA and VNNA, 1FF bypass capacitor between VGNB and VNNB, 1µF bypass capacitor between VGPA and VPPA, 1µF bypass capacitor between VGPB and VPPB, VLDO_EN = 0V, no load, unless otherwise noted. Typical values are at TA = +25°C.) (Note 2) PARAMETER SYMBOL CONDITIONS IPP1 TYP MAX 8 channels switching, CW Doppler, CC0 = high, CC1 = high, RL = 1kI, CL = 240pF (Note 4) 186 230 IPP2 8 channels switching, B mode (Figure 1a), CC0 = low, CC1 = low, RL = 1kI, CL = 240pF (Note 5) 3.1 PDCW 1 channel switching, CW Doppler (Note 4) 286 PDPW 1 channel switching, B mode (Note 5) (Figure 1a), CC0 = low, CC1 = low, RL = 1kI, CL = 240pF VPP_ Supply Current Power Dissipation per Channel (Octal Three-Level Mode) MIN MAX14808 UNITS mA 4.5 73 mW MAX14809 69.5 SUPPLY CURRENT—QUAD FIVE-LEVEL DUAL MODE, NO LOAD (MODE0 = Low, MODE1 = High) VDD Supply Current (Quiescent Mode) VEE Supply Current (Quiescent Mode) IDDQ All inputs connected to GND or VDD Transparent or single-ended clock mode Differential clock mode, VCLKD = 0.2V DINN_ = DINP_ = GND IEEQ DINN_ = DINP_ = VDD 1.7 3 FA 110 190 0.26 0.4 MAX14808 5.4 7.7 MAX14809 1.35 2 0.49 0.75 MAX14808 5.6 7.8 MAX14809 1.6 2.3 DINN_ = DINP_ = GND mA VCC Supply Current (Quiescent Mode) ICCQ VCC Supply Current Increase DICC Differential clock mode 3.5 5 mA VNN_ Supply Current (Quiescent Mode) INNQ_ All inputs connected to GND or VDD 195 305 FA VPP_ Supply Current (Quiescent Mode) IPPQ_ All inputs connected to GND or VDD 220 340 FA PPDIS1 T/R switch off, DAMP off (transparent mode) 11.3 PPDIS2 DINN_ = DINP_ = VDD (transparent mode) Power Dissipation per Channel (Quiescent Mode) Maxim Integrated DINN_ = DINP_ = VDD MAX14808 24.1 MAX14809 14.1 mA mW   6 MAX14808/MAX14809 Octal Three-Level/Quad Five-Level High-Voltage 2A Digital Pulsers with T/R Switch DC ELECTRICAL CHARACTERISTICS (continued) (VDD = +3V, VCC = +5V, VEE = -5V, VPPA = +100V, VNNA = -100V, VPPB = +100V, VNNB = -100V, 1µF bypass capacitor between VGNA and VNNA, 1FF bypass capacitor between VGNB and VNNB, 1µF bypass capacitor between VGPA and VPPA, 1µF bypass capacitor between VGPB and VPPB, VLDO_EN = 0V, no load, unless otherwise noted. Typical values are at TA = +25°C.) (Note 2) PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS IDD1 4 channels switching, CW Doppler (Note 4) 1.4 mA IDD2 4 channels switching, B mode (Note 5) (Figure 1a) 4.3 FA IEE1 4 channels switching, CW Doppler (Note 4) CC0 = high, CC1 = high 33 MAX14808 5.9 IEE2 4 channels switching, B mode (Note 5) (Figure 1a), CC0 = low, CC1 = low MAX14809 1.9 CC0 = high, CC1 = high 22 MAX14808 6 MAX14809 2 VDD Supply Current VEE Supply Current ICC1 4 channels switching, CW Doppler (Note 4) ICC2 4 channels switching, B mode (Note 5) (Figure 1a), CC0 = low, CC1 = low VCC Supply Current mA mA VDD Supply Current Increase DIDD Differential clock mode 1.8 mA VCC Supply Current Increase DICC Differential clock mode 3.8 mA INN1 4 channels switching, CW Doppler (Note 4) VNN_ Supply Current INN2 4 channels switching, B mode (Note 5) (Figure 1a), CC0 = low, CC1 = low IPP1 4 channels switching, CW Doppler (Note 4) VPP_ Supply Current IPP2 Maxim Integrated CC0 = high, CC1 = high, RL = 1kI, CL = 240pF CC0 = high, CC1 = high, RL = 1kI, CL = 240pF 4 channels switching, B mode (Note 5) (Figure 1a), CC0 = low, CC1 = low 90 mA 1.3 103 mA 2.2   7 MAX14808/MAX14809 Octal Three-Level/Quad Five-Level High-Voltage 2A Digital Pulsers with T/R Switch DC ELECTRICAL CHARACTERISTICS (continued) (VDD = +3V, VCC = +5V, VEE = -5V, VPPA = +100V, VNNA = -100V, VPPB = +100V, VNNB = -100V, 1µF bypass capacitor between VGNA and VNNA, 1FF bypass capacitor between VGNB and VNNB, 1µF bypass capacitor between VGPA and VPPA, 1µF bypass capacitor between VGPB and VPPB, VLDO_EN = 0V, no load, unless otherwise noted. Typical values are at TA = +25°C.) (Note 2) PARAMETER Total Power Dissipation per Channel (Quad Five-Level Dual Mode) SYMBOL CONDITIONS PDCW 1 channel switching, CW Doppler (Note 4), RL = 1kI, CL = 240pF PDPW 1 channel switching, B mode (Note 5) (Figure 1a), CC0 = low, CC1 = low, RL = 1kI, CL = 240pF MIN TYP MAX UNITS 311 MAX14808 102 MAX14809 94.5 mW SUPPLY CURRENT—OCTAL THREE-LEVEL, NO LOAD (MODE0 = High, MODE1 = Low, LDO_EN = High, VPP_ - VGP_ = +5V, VGN_ - VNN_ = +5V) VEE Supply Current (Quiescent Mode) IEEQ_ All inputs connected to GND 25 46 FA VCC Supply Current (Quiescent Mode) ICCQ_ All inputs connected to GND 280 420 FA VNN_ Supply Current (Quiescent Mode) INNQ_ All inputs connected to GND 40 62 FA VPP_ Supply Current (Quiescent Mode) IPPQ_ All inputs connected to GND 40 62 FA OUTPUT STAGE VNNA, VNNB Connected LowSide Output Impedance VPPA, VPPB Connected HighSide Output Impedance ROLS ROHS IOUT_ = -50mA IOUT_ = +50mA CC0 = low, CC1 = low 8.5 CC0 = high, CC1 = low 10 CC0 = low, CC1 = high 13.5 CC0 = high, CC1 = high 26 CC0 = low, CC1 = low 9 CC0 = high, CC1 = low 10.5 CC0 = low, CC1 = high 14.5 CC0 = high, CC1 = high 27 I 48 I 53 Clamp nFET Output Impedance RONG IOUT_ = -50mA, 13.5 I Clamp pFET Output Impedance ROPG IOUT_ = +50mA 13.5 I Active Damp Output Impedance RDAMP Before grass-clipping diode 500 I Maxim Integrated   8 MAX14808/MAX14809 Octal Three-Level/Quad Five-Level High-Voltage 2A Digital Pulsers with T/R Switch DC ELECTRICAL CHARACTERISTICS (continued) (VDD = +3V, VCC = +5V, VEE = -5V, VPPA = +100V, VNNA = -100V, VPPB = +100V, VNNB = -100V, 1µF bypass capacitor between VGNA and VNNA, 1FF bypass capacitor between VGNB and VNNB, 1µF bypass capacitor between VGPA and VPPA, 1µF bypass capacitor between VGPB and VPPB, VLDO_EN = 0V, no load, unless otherwise noted. Typical values are at TA = +25°C.) (Note 2) PARAMETER VNNA, VNNB Connected LowSide Output Current VPPA, VPPB Connected HighSide Output Current SYMBOL IOLS IOHS CONDITIONS VDS = +100V VDS = +100V MIN TYP CC0 = low, CC1 = low 2.0 CC0 = high, CC1 = low 1.5 CC0 = low, CC1 = high 1.0 CC0 = high, CC1 = high 0.5 CC0 = low, CC1 = low 2.0 CC0 = high, CC1 = low 1.5 CC0 = low, CC1 = high 1.0 CC0 = high, CC1 = high 0.5 MAX UNITS A A GND-Connected nFET Output Current IONG VDS = +100V 1 A GND-Connected pFET Output Current IOPG VDS = +100V 1 A Diode Voltage Drop (Blocking Diode and Grass-Clipping Diode) VDROP 1.7 V LVOUT_Diode Clamping Voltage LVCLAMP Grass-Clipping Diode Reverse Capacitance CREV OUT_ Equivalent Large-Signal Shunt Capacitance CHS T/R Switch On Impedance IOUT_ = Q50mA ILOAD = 1mA (MAX14808 only) -0.9 +1 V 2.5 pF 200VP-P signal 80 pF RON MAX14808 only 11.5 I T/R Switch Off Impedance ROFF MAX14808 only LVOUT_ Output Offset LVOFF LVOUT_, OUT_ unconnected, VCC = +5V, VEE = -5V 1 -40 MI 0 +40 mV THERMAL SHUTDOWN Thermal-Shutdown Threshold tSDN Thermal-Shutdown Hysteresis tHYS Maxim Integrated Temperature rising +145 NC 20 NC   9 MAX14808/MAX14809 Octal Three-Level/Quad Five-Level High-Voltage 2A Digital Pulsers with T/R Switch AC ELECTRICAL CHARACTERISTICS (VDD = +3V, VCC = +5V, VEE = -5V, VPPA = +100V, VNNA = -100V, VPPB = +100V, VNNB = -100V, VGNA connected to VNNA with 1µF capacitor, VGNB connected to VNNB with 1µF capacitor, VGPA connected to VPPA with 1µF capacitor, VGPB connected to VPPB with 1µF capacitor, VLDO_EN = 0V, VCC0 = 0V, VCC1 = 0V, RL = 1kI, CL = 240pF, unless otherwise noted. Typical values are at TA = +25°C.) (Note 2) PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS Logic Input to Output Rise Propagation Delay tPLH From 50% DINP_/DINN_ (transparent mode) to 10% OUT_ transition swing (Figure 2a) 18 ns Logic Input to Output Fall Propagation Delay tPHL From 50% DINP_/DINN_ (transparent mode) to 10% OUT_ transition swing (Figure 2a) 18 ns Logic Input to Output Rise to GND Propagation Delay tPL0 From 50% DINP_/DINN_ (transparent mode) to 10% OUT_ transition swing (Figure 2a) 18 ns Logic Input to Output Fall to GND Propagation Delay tPH0 From 50% DINP_/DINN_ (transparent mode) to 10% OUT_ transition swing (Figure 2a) 18 ns OUT_ Fall Time (VPPA to VNNA, VPPB to VNNB) tFPN Figure 2b 30 48 ns OUT_ Rise Time (VNNA to VPPA, VNNB to VPPB) tRNP Figure 2b 30 48 ns OUT_ Rise Time (GND to VPPA, GND to VPPB) tR0P Figure 2b 15 22.5 ns OUT_ Fall Time (GND to VNNA, GND to VNNB) tF0N Figure 2b 15 22.5 ns OUT_ Rise Time (VNNA to GND, VNNB to GND) 20% to 80% transition (Figure 2b) Three-level mode 21 tRN0 Five-level dual mode 13 OUT_ Fall Time (VPPA to GND, VPPB to GND) 20% to 80% transition (Figure 2b) Three-level mode 21 tFP0 Five-level dual mode 13 ns ns T/R Switch Turn-On Time tONTRSW (MAX14808 only) Figure 3 0.65 1.2 Fs T/R Switch Turn-Off Time tOFFTRSW (MAX14808 only) Figure 3 (Note 6) 0.02 0.1 Fs Output Enable Time (Shutdown Mode to Normal Operation) tEN1 100 Fs Output Disable Time (Normal Operation to Shutdown Mode) tDIS1 10 Fs Maxim Integrated   10 MAX14808/MAX14809 Octal Three-Level/Quad Five-Level High-Voltage 2A Digital Pulsers with T/R Switch AC ELECTRICAL CHARACTERISTICS (continued) (VDD = +3V, VCC = +5V, VEE = -5V, VPPA = +100V, VNNA = -100V, VPPB = +100V, VNNB = -100V, VGNA connected to VNNA with 1µF capacitor, VGNB connected to VNNB with 1µF capacitor, VGPA connected to VPPA with 1µF capacitor, VGPB connected to VPPB with 1µF capacitor, VLDO_EN = 0V, VCC0 = 0V, VCC1 = 0V, RL = 1kI, CL = 240pF, unless otherwise noted. Typical values are at TA = +25°C.) (Note 2) PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS Output Enable Time (Transmit Disable Mode to Normal Operation) tEN2 50 ns Output Disable Time (Normal Operation to Transmit Disable Mode) tDIS2 65 ns Output Enable Time (Normal Operation to Sync Mode) tEN3 4 Fs Output Disable Time (Sync Mode to Normal Operation) tDIS3 500 ns CLK Frequency fCLK VDD = 2.5V 200 MHz Input Setup Time (DINN_, DINP_) tSETUP VDD = 2.5V 2 NS Input Hold Time (DINN_, DINP_) tHOLD VDD = 2.5V 0.5 ns Second-Harmonic Distortion (Low Voltage) THD2LV fOUT_ = 5MHz, VPPA = -VNNA = +5V, VPPB = -VNNB = +5V, square wave (all modes) -40 dBc Second-Harmonic Distortion (High Voltage) THD2HV fOUT_ = 5MHz, VPPA = -VNNA = +100V, VPPB = -VNNB = +100V, square wave (all modes) -43 dBc PC1 fOUT_ = 5MHz, VPPA = -VNNA = +100V, VPPB = -VNNB = +100V, 2 periods, all harmonics of the summed signed with respect to the carrier -40 PC2 fOUT_ = 5MHz, VPPA = -VNNA = +100V, VPPB = -VNNB = +100V, 2 periods, [(V0 + V180)RMS/(2 x V0RMS)]dB -40 Pulser Bandwidth BW VPP = +60V, VNNA = -60V (Figure 4) 20 MHz RMS Output Jitter tJ 6.25 ps Pulse Cancellation Maxim Integrated fOUT_ = 5MHz, VPPA = -VNNA = +5V, VPPB = -VNNB = +5V, both in clocked mode or transparent mode (Figure 5) dBc   11 MAX14808/MAX14809 Octal Three-Level/Quad Five-Level High-Voltage 2A Digital Pulsers with T/R Switch AC ELECTRICAL CHARACTERISTICS (continued) (VDD = +3V, VCC = +5V, VEE = -5V, VPPA = +100V, VNNA = -100V, VPPB = +100V, VNNB = -100V, VGNA connected to VNNA with 1µF capacitor, VGNB connected to VNNB with 1FF capacitor, VGPA connected to VPPA with 1µF capacitor, VGPB connected to VPPB with 1µF capacitor, VLDO_EN = 0V, VCC0 = 0V, VCC1 = 0V, RL = 1kI, CL = 240pF, unless otherwise noted. Typical values are at TA = +25°C.) (Note 2) PARAMETER SYMBOL T/R Switch Harmonic Distortion (MAX14808) THDTRSW T/R Switch Turn-On/Off Voltage Spike (MAX14808) Crosstalk CONDITIONS MIN TYP MAX UNITS RLOAD = 200I, VSIGNAL = 100mVP-P -50 dB VSPIKE RLOAD = 1kI at both sides of T/R switch 50 mV CT f = 5MHz, adjacent channels, RLOUT_ = 200I -51 dB Note 2: All devices are 100% production tested at TA = +85NC. Limits over the operating temperature range are guaranteed by design. Note 3: Maximum operating current from VGN_ and VGP_ external power sources can vary depending on application requirements. The suggested minimum values assume 8 channels running in continuous transmission (CWD) at 5MHz with CC0 = CC1 = high. Note 4: CW Doppler: continuous wave, f = 5MHz, VDD = +3V, VCC = -VEE = +5V, VPP_ = -VNN_ = +5V. Note 5: B mode: f = 5MHz, PRF = 5kHz, 1 period, VDD = +3V, VCC = -VEE = +5V, VPP_ = -VNN_ = +100V. Note 6: T/R switch turn-off time is the time required to switch off the bias current of the T/R switch. The off-isolation is not guaranteed. Timing Diagrams VPPA = VPPB VNNA = VNNB 200ns 200µs Figure 1a. High-Voltage Burst Test (Three Levels) Maxim Integrated   12 MAX14808/MAX14809 Octal Three-Level/Quad Five-Level High-Voltage 2A Digital Pulsers with T/R Switch Timing Diagrams (continued) VPPA VPPB VNNB VNNA 200ns 200ns 200ns 200µs Figure 1b. High-Voltage Burst Test (Five Levels) VPP_ 10% 10% OUT_ GND 10% 10% VNN_ tPH0 VDD DINP_ 50% 50% 50% GND tPLH tPHL tPL0 DINN_ VDD 50% GND Figure 2a. Propagation Delay Timing Maxim Integrated   13 MAX14808/MAX14809 Octal Three-Level/Quad Five-Level High-Voltage 2A Digital Pulsers with T/R Switch Timing Diagrams (continued) 80% 80% 80% VPP_ 80% OUT_ tRNO tFON 20% 20% 20% tROP 20% GND tFPO 80% 80% 80% tRNP 80% VNN_ tFPN Figure 2b. Output Rise/Fall Timing DINP_ VDD LVOUT_ RL = 1kI VRIF MAX14808 DINN_ OUT_ RL = 1kI VDD DINP_ 0V VRIF /(2 x RL + RON) x (RON + RL) LVOUT_ ~0V VRIF /(2 x RL + RON) x RL OUT_ ~VNN_ tONTRSW tOFFTRSW Figure 3. T/R Switch Turn-On/Off Time Maxim Integrated   14 MAX14808/MAX14809 Octal Three-Level/Quad Five-Level High-Voltage 2A Digital Pulsers with T/R Switch Timing Diagrams (continued) VDD DINP_ GND VDD DINN_ GND VPPA / VPPB 90% VPPA /VPPB GND 90% VNNA /VNNB VNNA / VNNB Figure 4. Bandwidth Maxim Integrated   15 MAX14808/MAX14809 Octal Three-Level/Quad Five-Level High-Voltage 2A Digital Pulsers with T/R Switch Timing Diagrams (continued) VDD DINP_ 50% 50% 50% 50% GND VDD DINN_ GND tJR = DtDR tJF = DtDF tDF tDR VPPA /VPPB OUT_ VNNA /VNNB Figure 5. Jitter Timing Typical Operating Characteristics (VDD = +5V, VCC = +5V, VEE = -5V, VPP_ = +100V, VNN_ = -100V, RL = 1kI, CL = 240pF, unless otherwise noted. Typical values are at TA = +25°C.) -50 250 200 INN_ (µA) 150 IPP_ (µA) -100 200 -150 50 VPP_ = -VNN_ THREE-LEVEL MODE 0 0 20 40 60 VPP_ (V) Maxim Integrated 80 100 150 100 -200 100 MAX14808 toc03 250 300 MAX14808 toc02 0 MAX14808 toc01 300 IPP_ (µA) IPP_ QUIESCENT CURRENT vs. TEMPERATURE INN_ QUIESCENT CURRENT vs. VNN_ IPP_ QUIESCENT CURRENT vs. VPP_ -250 50 VPP_ = -VNN_ THREE-LEVEL MODE -300 -100 -80 -60 -40 VNN_ (V) -20 THREE-LEVEL MODE 0 0 -40 -15 10 35 60 85 TEMPERATURE (°C)   16 MAX14808/MAX14809 Octal Three-Level/Quad Five-Level High-Voltage 2A Digital Pulsers with T/R Switch Typical Operating Characteristics (continued) (VDD = +5V, VCC = +5V, VEE = -5V, VPP_ = +100V, VNN_ = -100V, RL = 1kI, CL = 240pF, unless otherwise noted. Typical values are at TA = +25°C.) ICC QUIESCENT CURRENT vs. TEMPERATURE INN_ QUIESCENT CURRENT vs. TEMPERATURE -50 0.7 0.6 ICC (mA) -100 INN_ (µA) MAX14808 toc05 0.8 MAX14808 toc04 0 -150 0.5 0.4 0.3 -200 0.2 -250 0.1 THREE-LEVEL MODE -300 -40 -15 10 35 60 85 -40 -15 10 35 60 TEMPERATURE (°C) TEMPERATURE (°C) IEE QUIESCENT CURRENT vs. TEMPERATURE LOW TO HIGH TRANSITION VOLTAGE SPIKE 85 MAX14808 toc07 MAX14808 toc06 0 -50 LVOUT_ 1kI TO GND -100 IEE (µA) THREE-LEVEL MODE 0 OUT_ 50V/div 0V -150 -200 LVOUT_ 1V/div -250 THREE-LEVEL MODE -300 -40 -15 10 35 60 85 1µs/div TEMPERATURE (°C) MAX14808 toc08 LVOUT_ 1kI TO GND -10 OUT_ 50V/div -20 LVOUT_ 1V/div THD2 (dBc) 0V 0 VPP_ = -VNN_ = 100V MAX14808 toc09 THD2 vs. FREQUENCY HIGH TO LOW TRANSITION SPIKE -30 -40 -50 -60 1µs/div 0 2 4 6 8 10 FREQUENCY (MHz) Maxim Integrated   17 MAX14808/MAX14809 Octal Three-Level/Quad Five-Level High-Voltage 2A Digital Pulsers with T/R Switch Typical Operating Characteristics (continued) (VDD = +5V, VCC = +5V, VEE = -5V, VPP_ = +100V, VNN_ = -100V, RL = 1kI, CL = 240pF, unless otherwise noted. Typical values are at TA = +25°C.) THD2 vs. VPP_ PULSE CANCELLATION MAX14808 toc11 VPP_ = -VNN_ f = 5MHz -10 MAX14808 toc10 0 OUT_ WAVE 1 50V/div OUT_ WAVE 2 50V/div 0V THD2 (dBc) -20 -30 -40 SUM OF WAVE 1 AND 2 3V/div -50 -60 0 20 40 60 80 100 80ns/div VPP_ (V) MAX14808 toc12 500 400 350 IPP_ (mA) 0V OUT_WAVE 1 20dB/div SUM OF WAVE 1 AND 2 20dB/div 80ns/div VPP_ = -VNN_ = 5V CC0 = CC1 = HIGH 4 CHANNELS SWITCHING 450 OUT_ WAVE 1 50V/div OUT_ WAVE 2 50V/div MAX14808 toc13 IPP_ vs. FREQUENCY PULSE CANCELLATION FFT 300 250 200 150 100 50 0 0 2 4 6 8 10 FREQUENCY (MHz) Maxim Integrated   18 MAX14808/MAX14809 Octal Three-Level/Quad Five-Level High-Voltage 2A Digital Pulsers with T/R Switch Typical Operating Characteristics (continued) (VDD = +5V, VCC = +5V, VEE = -5V, VPP_ = +100V, VNN_ = -100V, RL = 1kI, CL = 240pF, unless otherwise noted. Typical values are at TA = +25°C.) ICC vs. FREQUENCY MAX14808 toc14 50 80 200 60 ICC (mA) 70 250 300 350 450 500 0 2 4 6 8 50 40 30 VPP_ = -VNN_ = 5V CC0 = CC1 = HIGH 4 CHANNELS SWITCHING 400 VPP_ = -VNN_ = 5V CC0 = CC1 = HIGH 4 CHANNELS SWITCHING 90 150 20 10 0 10 0 2 4 6 8 FREQUENCY (MHz) FREQUENCY (MHz) IEE vs. FREQUENCY OUTPUT JITTER 0 -10 -20 -30 10 MAX14808 toc17 VPP_ = -VNN_ = 5V CC0 = CC1 = HIGH 4 CHANNELS SWITCHING MAX14808 toc16 INN_ (mA) 100 IEE (mA) 100 MAX14808 toc15 INN_ vs. FREQUENCY 0 f = 5MHz VPP_ = 5V IN OUT -40 -50 -60 PROPAGATION DELAY JITTER STD = 6.24ps -70 -80 20/div -90 -100 0 2 4 6 8 10 10ps/div FREQUENCY (MHz) Maxim Integrated   19 MAX14808/MAX14809 Octal Three-Level/Quad Five-Level High-Voltage 2A Digital Pulsers with T/R Switch Pin Configurations OUT8 VPPB OUT7 VNNB OUT6 OUT5 VPPB VNNB GND VNNA OUT4 VPPA OUT3 VNNA OUT2 VPPA OUT1 TOP VIEW 51 50 49 48 47 46 45 44 43 42 41 40 39 38 37 36 35 VNNA 52 34 VNNB GND 53 33 GND VPPA 54 32 VPPB VGPA 55 31 VGPB VGNA 56 30 VGNB VEE 57 29 VEE VCC 58 28 VCC DINN4 59 27 DINN8 DINP4 60 26 DINP8 MAX14808 DINN3 61 25 DINN7 DINP3 62 24 DINP7 DINN2 63 23 DINN6 DINP2 64 22 DINP6 DINN1 65 21 DINN5 DINP1 66 20 DINP5 VDD 67 *EP + 19 VDD GND 68 LVOUT8 LVOUT7 THP LVOUT6 LDO_EN 10 11 12 13 14 15 16 17 MODE1 LVOUT4 9 LVOUT5 LVOUT3 8 MODE0 LVOUT2 7 CC1 6 CC0 5 CLK 4 CLK 3 SYNC 2 LVOUT1 18 GND 1 TQFN (10mm x 10mm x 0.75mm) *CONNECT EP TO GND Maxim Integrated   20 MAX14808/MAX14809 Octal Three-Level/Quad Five-Level High-Voltage 2A Digital Pulsers with T/R Switch Pin Configurations (continued) OUT8 VPPB OUT7 VNNB OUT6 VPPB OUT5 VNNB GND VNNA OUT4 VPPA OUT3 VNNA OUT2 VPPA OUT1 TOP VIEW 51 50 49 48 47 46 45 44 43 42 41 40 39 38 37 36 35 VNNA 52 34 VNNB GND 53 33 GND VPPA 54 32 VPPB VGPA 55 31 VGPB VGNA 56 30 VGNB VEE 57 29 VEE VCC 58 28 VCC DINN4 59 27 DINN8 DINP4 60 26 DINP8 MAX14809 DINN3 61 25 DINN7 DINP3 62 24 DINP7 DINN2 63 23 DINN6 DINP2 64 22 DINP6 DINN1 65 21 DINN5 DINP1 66 20 DINP5 VDD 67 *EP + 19 VDD GND 68 I.C. I.C. I.C. I.C. 10 11 12 13 14 15 16 17 MODE1 LDO_EN 9 MODE0 I.C. 8 CC1 I.C. 7 CC0 I.C. 6 CLK 5 CLK 4 THP 3 SYNC 2 I.C. 18 GND 1 TQFN (10mm x 10mm x 0.75mm) *CONNECT EP TO GND Maxim Integrated   21 MAX14808/MAX14809 Octal Three-Level/Quad Five-Level High-Voltage 2A Digital Pulsers with T/R Switch Pin Description PIN NAME FUNCTION MAX14808 MAX14809 1 — LVOUT1 Low-Voltage T/R Switch Output 1 2 — LVOUT2 Low-Voltage T/R Switch Output 2 3 — LVOUT3 Low-Voltage T/R Switch Output 3 4 — LVOUT4 Low-Voltage T/R Switch Output 4 — 1–4, 14–17 I.C. 5 5 LDO_EN 6 6 THP 7 7 SYNC 8 8 CLK CMOS Control Input. Clock positive phase input. Data inputs are clocked in at the rising edge of CLK and CLK in differential clocked mode or at the rising edge of CLK in single-ended clocked mode. Clock maximum frequency is 160MHz. Internally Connected. Connect I.C. to GND externally. Internal Supply Generator Control Input. Drive LDO_EN high to disable the internal power supply when using an external power supply on VGPA, VGPB, VGNA, and VGNB. LDO_EN has an internal 10kI pulldown resistor to GND. Open-Drain Thermal-Protection Output. THP asserts and sinks a 3mA current to GND when the junction temperature exceeds +150NC. CMOS Control Input. Drive SYNC high to enable clocked-input mode. Drive SYNC low to operate in transparent mode (see the Truth Tables section). 9 9 CLK CMOS Control Input. Clock negative phase input. Data inputs are clocked in at the edge of CLK and CLK in differential clocked mode. Clock maximum frequency is 160MHz. If CLK is connected to GND, the CLK input is a single-ended logic-level clock input. Otherwise, CLK and CLK are self-biased differential clock inputs. 10 10 CC0 Current Control Input. Control current capability (see the Truth Tables section). 11 11 CC1 Current Control Input. Control current capability (see the Truth Tables section). 12 12 MODE0 Mode Control Input. Control operation mode (see the Truth Tables section). 13 13 MODE1 Mode Control Input. Control operation mode (see the Truth Tables section). 14 — LVOUT5 Low-Voltage T/R Switch Output 5 15 — LVOUT6 Low-Voltage T/R Switch Output 6 16 — LVOUT7 Low-Voltage T/R Switch Output 7 17 — LVOUT8 Low-Voltage T/R Switch Output 8 18, 33, 43, 53, 68 18, 33, 43, 53, 68 GND Ground 19, 67 19, 67 VDD Logic Supply Voltage. Bypass VDD (both pins) to GND with a 0.1FF capacitor as close as possible to the device. 20 20 DINP5 21 21 DINN5 Digital Signal Negative Input 5 (see the Truth Tables section) 22 22 DINP6 Digital Signal Positive Input 6 (see the Truth Tables section) 23 23 DINN6 Digital Signal Negative Input 6 (see the Truth Tables section) 24 24 DINP7 Digital Signal Positive Input 7 (see the Truth Tables section) 25 25 DINN7 Digital Signal Negative Input 7 (see the Truth Tables section) 26 26 DINP8 Digital Signal Positive Input 8 (see the Truth Tables section) 27 27 DINN8 Digital Signal Negative Input 8 (see the Truth Tables section) Maxim Integrated Digital Signal Positive Input 5 (see the Truth Tables section)   22 MAX14808/MAX14809 Octal Three-Level/Quad Five-Level High-Voltage 2A Digital Pulsers with T/R Switch Pin Description (continued) PIN NAME FUNCTION 28, 58 VCC VCC Supply Voltage. Bypass VCC (both pins) to GND with a 0.1FF capacitor as close as possible to the device. 29, 57 29, 57 VEE VEE Supply Voltage. Bypass VEE (both pins) to GND with a 0.1FF capacitor as close as possible to the device. 30 30 VGNB Driver Voltage Supply Output. Connect a 1FF capacitor to VNNB as close as possible to the device. 31 31 VGPB Driver Voltage Supply Output. Connect a 1FF capacitor to VPPB as close as possible to the device. 32, 36, 40 32, 36, 40 VPPB High-Voltage Positive Supply Input. Bypass VPPB to GND with a 0.1FF capacitor as close as possible to the device. 34, 38, 42 34, 38, 42 VNNB High-Voltage Negative Supply Input. Bypass VNNB to GND with a 0.1FF capacitor as close as possible to the device. 35 35 OUT8 Pulser Output 8 37 37 OUT7 Pulser Output 7 39 39 OUT6 Pulser Output 6 41 41 OUT5 Pulser Output 5 MAX14808 MAX14809 28, 58 44, 48, 52 44, 48, 52 VNNA High-Voltage Negative Supply Input. Bypass VNNA to GND with a 0.1FF capacitor as close as possible to the device. 45 45 OUT4 Pulser Output 4 46, 50, 54 46, 50, 54 VPPA High-Voltage Positive Supply Input. Bypass VPPA to GND with a 0.1FF capacitor as close as possible to the device. 47 47 OUT3 Pulser Output 3 49 49 OUT2 Pulser Output 2 51 51 OUT1 Pulser Output 1 55 55 VGPA Driver Voltage Supply Output. Connect a 1FF capacitor to VPPA as close as possible to the device. 56 56 VGNA Driver Voltage Supply Output. Connect a 1FF capacitor to VNNA as close as possible to the device. 59 59 DINN4 Digital Signal Negative Input 4 (see the Truth Tables section) 60 60 DINP4 Digital Signal Positive Input 4 (see the Truth Tables section) 61 61 DINN3 Digital Signal Negative Input 3 (see the Truth Tables section) 62 62 DINP3 Digital Signal Positive Input 3 (see the Truth Tables section) 63 63 DINN2 Digital Signal Negative Input 2 (see the Truth Tables section) 64 64 DINP2 Digital Signal Positive Input 2 (see the Truth Tables section) 65 65 DINN1 Digital Signal Negative Input 1 (see the Truth Tables section) 66 66 DINP1 Digital Signal Positive Input 1 (see the Truth Tables section) — — EP Maxim Integrated Exposed Pad. Connect EP to GND. Not intended as an electrical connection point.   23 MAX14808/MAX14809 Octal Three-Level/Quad Five-Level High-Voltage 2A Digital Pulsers with T/R Switch Detailed Description The MAX14808/MAX14809 octal three-level/quad fivelevel, high-voltage (HV) pulser devices generate highfrequency, HV bipolar pulses (up to Q105V) from lowvoltage control logic inputs for driving piezoelectric transducers in ultrasound systems. All 8 channels have embedded overvoltage-protection diodes and integrated active return-to-zero clamp. Both devices have embedded independent (floating) power supplies (FPSs) and level shifters that allow signal transmission without the need for external HV capacitors. The MAX14808 also features eight integrated transmit receive (T/R) switches. The MAX14809 does not have the T/R switch function. The devices feature two modes of operation, an octal three-level pulser mode (with integrated active returnto-zero clamp) or a quad five-level pulser mode. In octal three-level pulser mode, each channel is controlled by two logic inputs (DINN_ /DINP_) and the active return to zero features half the current driving of the pulser, 1A (typ). In quad five-level pulser mode, each channel is controlled by three logic inputs and the active return to zero has the same current driving of the pulser, 2A (typ). The devices can operate both in clocked and transparent mode. In clocked mode, data inputs can be synchronized with a clean differential or single-ended clock to reduce phase noise associated with FPGA output signals that are detrimental for Doppler analysis. In transparent mode, the synchronization feature is disabled and output reflects the data input after an 18ns delay. Both devices feature adjustable maximum current (0.5A to 2A) to reduce power consumption when full current capability is not required. The devices feature integrated grass-clipping diodes (with low parasitic capacitance) for receive (Rx) and transmit (Tx) isolations. Both devices feature a damping circuit that can be activated as soon as the transmit burst is over. The damping circuit has a typical on-resistance of 500I. It fully discharges the pulser’s output internal node before the grass-clipping diodes. Operation Mode The devices have four operation modes: shutdown, octal three-level, quad five-level dual, and transmit disable. Use the MODE0 and MODE1 inputs to select the operation mode. Shutdown Mode All channels are disabled, no transmission and reception is possible. This mode has the lowest power consumption. See Table 1. Octal Three-Level Mode The devices operate in eight independent channels. Each channel can generate a three-level pulse. The high-side and low-side FET of each channel are capable of providing 2.0A current, while the clamp is capable of 1A current. See Table 2. Quad Five-Level Dual Mode The devices operate in four independent channels. Each channel can generate a five-level pulse. The devices feature independent dual-voltage supplies (VNNA, VNNB, VPPA, and VPPB) and can generate pulses among GND, VPPA, and VNNA or among GND, VPPB, and VNNB. The high-side and low-side FET as well as the clamp of each channel can provide 2.0A current. See Table 3. Transmit Disable Mode All eight high-voltage transmit channels are disabled, no pulse transmission is possible. The T/R switch (MAX14808 only) can be turn-on (to receive low-voltage signals) or turn-off (for isolation). See Table 4. Truth Tables Table 1. Shutdown Mode (MODE0 = Low, MODE1 = Low) INPUTS OUTPUTS DINN_ DINP_ OUT_ LVOUT_ (MAX14808 ONLY) X X High impedance High impedance (T/R switch off) X = Don’t care Maxim Integrated   24 MAX14808/MAX14809 Octal Three-Level/Quad Five-Level High-Voltage 2A Digital Pulsers with T/R Switch Truth Tables (continued) Table 2. Octal Three-Level Mode (MODE0 = High, MODE1 = Low, VNNA = VNNB, VPPA = VPPB) INPUTS OUTPUTS DINN_ DINP_ OUT_ LVOUT_ (MAX14808 ONLY) 0 0 Clamp on (damp off) T/R switch off (LVOUT_ = GND) 1 0 VNNA/VNNB (damp off) T/R switch off (LVOUT_ = GND) 0 1 VPPA/VPPB (damp off) T/R switch off (LVOUT_ = GND) 1 1 Clamp on (damp on) T/R switch on 0 = logic-low, 1 = logic-high Table 3. Quad Five-Level Dual Mode (MODE0 = Low, MODE1 = High) INPUTS OUTPUTS DINNx x = 1, 2, 3, 4 DINPx x = 1, 2, 3, 4 DINNy y = 5, 6, 7, 8 DINPy y = 5, 6, 7, 8 OUTx = OUTy LVOUTy y = 1, 2, 3, 4 (MAX14808 ONLY) LVOUTy y = 5, 6, 7, 8 (MAX14808 ONLY) 0 0 X 0 High impedance (damp off) T/R switch off (LVOUT_ = GND) T/R switch off (LVOUT_ = GND) 0 0 X 1 Clamp on (damp off) T/R switch off (LVOUT_ = GND) T/R switch off (LVOUT_ = GND) 0 1 0 X VPPB (damp off) T/R switch off (LVOUT_ = GND) T/R switch off (LVOUT_ = GND) 1 0 0 X VNNB (damp off) T/R switch off (LVOUT_ = GND) T/R switch off (LVOUT_ = GND) 0 1 1 X VPPA (damp off) T/R switch off (LVOUT_ = GND) T/R switch off (LVOUT_ = GND) 1 0 1 X VNNA (damp off) T/R switch off (LVOUT_ = GND) T/R switch off (LVOUT_ = GND) 1 1 1 X Clamp on (damp on) T/R switch on T/R switch off Note: Only three control inputs (DINNx, DINPx, DINNy) are required for five-level, dual-mode operation. DINPy can be connected to GND or VDD. X = Don’t care, 0 = logic-low, 1 = logic-high Table 4. Transmit Disable Mode (MODE0 = High, MODE1 = High) INPUTS OUTPUTS DINN_ DINP_ OUT_ LVOUT_ (MAX14808 ONLY) 0 0 High impedance (damp off) T/R switch off (LVOUT_ = GND) 1 0 High impedance (damp off) T/R switch off (LVOUT_ = GND) 0 1 High impedance (damp off) T/R switch off (LVOUT_ = GND) 1 1 High impedance (damp on) T/R switch on 0 = logic-low, 1 = logic-high Maxim Integrated   25 MAX14808/MAX14809 Octal Three-Level/Quad Five-Level High-Voltage 2A Digital Pulsers with T/R Switch Current Capability Selection The devices feature pulser current drive capability selection. Two control inputs (CC0, CC1) control the current drive capability (Table 5). Sync Function The devices provide the ability to resynchronize all the data inputs by means of a clean clock signal. In ultrasound systems, the FPGA output signals are often affected by a high jitter. The jitter induces phase noise that is detrimental in Doppler analysis. The input clock Table 5. Current Drive Selection INPUTS CC0 CC1 PULSER OUTPUT CURRENT (typ) 0 0 2A 1 0 1.5A 0 1 1A 1 1 0.5A VCC 40kI can be either a differential signal or a single-ended signal running up to 160MHz. Data are clocked in on the rising edge of the CLK input (falling edge of CLK). Connect CLK to GND for single-ended operation. The sync feature can be enabled or disabled by the SYNC control input. Drive the SYNC input low to disable the synchronization function (no external clock signal). Drive the SYNC input high to enable the synchronization function (with an external clock signal). Figure 6 shows the simplified CLK and CLK inputs schematic. T/R Switches (MAX14808 Only) Each channel features a low-power T/R switch. The T/R switch recovery time after the transmission is less than 1.2Fs. The T/R switches are controlled by the same pulser digital inputs (see the Truth Tables section). No dedicated input signals are required to activate/deactivate the T/R switches. The integrated T/R switches do not require any special timings and can operate synchronously with the digital pulser. To minimize the leakage current during transmission, it’s recommended to switch off the T/R switches 3Fs before the beginning of the transmit burst. VCC CLK 2.5kI VDD 40kI DIFFERENTIAL TO SINGLE-ENDED CONVERSION 2.5kI CLK SINGLE-ENDED CLOCK 2:1 MUX VCC SELECT REFERENCE VOLTAGE Figure 6. Simplified CLK and CLK Inputs Schematic Maxim Integrated   26 MAX14808/MAX14809 Octal Three-Level/Quad Five-Level High-Voltage 2A Digital Pulsers with T/R Switch Grass-Clipping Diodes A pair of diodes in antiparallel configuration (referred to as grass-clipping diodes) is presented at each pulser’s output. The diodes’ reverse capacitance is extremely low, allowing a perfect isolation between the receive path and the actual pulser’s output stage. Active Damp Circuit An active damp circuit is integrated between the internal pulser output node (before grass-clipping diodes) and GND. The purpose of this circuit is to fully discharge the pulser output internal node so that the node is not left in high-impedance condition as soon as the transmit burst is over. This results in two main advantages: 1) The grass-clipping isolation is more effective. 2) Suppression of any low-frequency oscillation of a node that could be detrimental for Doppler mode performances. Independent (Floating) Power-Supply Enable (LDO_EN) The devices feature the LDO_EN control input to enable/ disable the internal FPSs. This allows the usage of external high-efficiency power supplies to save system power. This option must be considered only for special applications requiring extremely low power dissipation. The low power dissipation of the embedded FPSs already meets power requirements in most of the cases. Drive LDO_EN low or leave unconnected to enable the internal FPSs; drive LDO_EN high to disable the internal FPSs. Power Sequencing When using the embedded FPSs (LDO_EN = low), the devices do not require any power-up/power-down sequence. When external FPSs are used (LDO_EN = high), the conditions VGP_ > (VEE - 0.6V) and VGN_ < (VCC + 0.6V) must be satisfied during the entire powerup/power-down transients (see the electrical characteristics tables). Applications Information Exposed Pad and Layout Concerns The devices provide an exposed pad (EP) underneath the TQFN package for improved thermal performance. Connect EP to GND externally and do not run traces under the package to avoid possible short circuits. To aid heat dissipation, connect EP to a similarly sized pad on the component side of the PCB. This pad should be connected through to the solder-side copper by several plated holes to a large heat-spreading copper area to conduct heat away from the device. The devices’ high-speed pulser requires low-inductance bypass capacitors to their supply inputs. High-speed PCB trace design practices are recommended. Pay particular attention to minimize trace lengths and use suf­ ficient trace width to reduce inductance. Use of surface-mount components is recommended. Typical Application Circuit Figure 7 shows the MAX14808 in an octal three-level pulsing application. Thermal Warning Outputs The devices feature an open-drain thermal-protection output (THP). When the internal junction temperature exceeds +150NC, the devices automatically enter shutdown mode and THP asserts. The devices reenter normal operation and the THP deasserts when the die temperature drops below +130NC. Maxim Integrated   27 MAX14808/MAX14809 Octal Three-Level/Quad Five-Level High-Voltage 2A Digital Pulsers with T/R Switch VDD DINP1 VDD GND OUT8 VPPB OUT7 VNNB VPPB OUT6 OUT5 VNNB GND VNNA OUT4 VPPA OUT3 VNNA VPPA 27 60 26 MAX14808 61 25 62 24 63 23 64 22 65 21 66 20 67 19 68 18 2 LVOUT2 LVOUT1 1 3 4 5 6 7 8 9 -HV0 VNNB GND VPPB VGPB 10V, 1µF VGNB VEE VEE VCC 10V, 1µF VCC DINN8 DINP8 DINN7 DINP7 DINN5–DINN8 DINP5–DINP8 DINN6 DINP6 8 DINN5 DINP5 VDD VDD GND 10 11 12 13 14 15 16 17 LVOUT1–LVOUT4 LVOUT5–LVOUT8 4 4 LVOUT8 DINN1 28 59 LVOUT7 DINP2 8 58 LVOUT6 DINN2 29 LVOUT5 DINN1–DINN5 DINP1–DINP5 30 57 MODE1 DINP3 56 MODE0 DINP4 DINN3 31 CC1 VCC DINN4 55 CC0 VCC +HV0 32 CLK VEE +HV0 54 CLK VGNA VEE -HV0 33 SYNC VGPA +HV0 53 THP 10V, 1µF -HV0 34 LDO_EN 10V, 1µF VPPA -HV0 51 50 49 48 47 46 45 44 43 42 41 40 39 38 37 36 35 LVOUT4 GND +HV0 52 LVOUT3 VNNA -HV0 OUT2 +HV0 +HV0 OUT1 -HV0 ANALOG FRONT-END Figure 7. Octal Three-Level Pulsing (MAX14808) Maxim Integrated   28 MAX14808/MAX14809 Octal Three-Level/Quad Five-Level High-Voltage 2A Digital Pulsers with T/R Switch Functional Diagram VPPA VNNA VDS VPPA GRASS-CLIPPING DIODES VGPA OUT_ VPPB VGNA VNNB DAMP VDS T/R SWITCH (MAX14808 ONLY) VNNA VEE GND LVOUT_ GND VCC VEE GND VCC MAX14808 MAX14809 GND CC0 CC1 POWER SUPPLIES AND DIGITAL PULSER CONTROL CIRCUIT CHANNELS 1–4 GND VPPB MODE0 VDS GRASS-CLIPPING DIODES VGPB MODE1 OUT_ VGNB CLK DAMP VDS CLK T/R SWITCH (MAX14808 ONLY) VNNB GND SYNC LDO_EN DINN_ DINP_ LVOUT_ GND VEE VCC GND GND CHANNELS 5–8 2 CHANNELS Maxim Integrated   29 MAX14808/MAX14809 Octal Three-Level/Quad Five-Level High-Voltage 2A Digital Pulsers with T/R Switch Ordering Information TRANSMIT CHANNELS T/R SWITCHES TEMP RANGE PIN-PACKAGE MAX14808ETK+ PART Yes Yes -40°C to +85°C 68 TQFN-EP* MAX14809ETK+ Yes No -40°C to +85°C 68 TQFN-EP* +Denotes a lead(Pb)-free/RoHS-compliant package. *EP = Exposed pad. Chip Information PROCESS: BiCMOS Maxim Integrated Package Information For the latest package outline information and land patterns (footprints), go to www.maximintegrated.com/packages. Note that a “+”, “#”, or “-” in the package code indicates RoHS status only. Package drawings may show a different suffix character, but the drawing pertains to the package regardless of RoHS status. PACKAGE TYPE PACKAGE CODE OUTLINE NO. LAND PATTERN NO. 68 TQFN-EP T6800+4 21-0142 90-0101   30 MAX14808/MAX14809 Octal Three-Level/Quad Five-Level High-Voltage 2A Digital Pulsers with T/R Switch Revision History REVISION NUMBER REVISION DATE 0 9/12 Initial release 1 3/13 Updated the DC Electrical Characteristics and AC Electrical Characteristics tables; updated TOC 9 in the Typical Operating Characteristics section; removed the future product notation from the MAX14809 in the Ordering Information table 2 1/14 Updated the DC Electrical Characteristics and AC Electrical Characteristics tables DESCRIPTION PAGES CHANGED — 5−8, 11, 17, 30 8, 9, 11 Maxim Integrated cannot assume responsibility for use of any circuitry other than circuitry entirely embodied in a Maxim Integrated product. No circuit patent licenses are implied. Maxim Integrated reserves the right to change the circuitry and specifications without notice at any time. The parametric values (min and max limits) shown in the Electrical Characteristics table are guaranteed. Other parametric values quoted in this data sheet are provided for guidance. Maxim Integrated 160 Rio Robles, San Jose, CA 95134 USA 1-408-601-1000 ©  2013 Maxim Integrated Products, Inc. 31 Maxim Integrated and the Maxim Integrated logo are trademarks of Maxim Integrated Products, Inc.
MAX14808ETK+ 价格&库存
很抱歉,暂时无法提供与“MAX14808ETK+”相匹配的价格&库存,您可以联系我们找货
