IN-S124BR series
Reverse Mount SMD LED 1204 PCB Type
Featured
1204 1.85mm SMD LED
High Brightness
AlInGaP / InGaN Technology
Narrow View Angle
High Reliability
Clear Lens
Description
The IN-S124BR series is a popular 1204 package with
reverse mount and versatile design capabilities. It is a
PCB type molding style LED which can be used in
various applications.
Recommended Solder Pattern
Applications
Consumer Electronics
Wearables
Automobile After Market
Industrial Equipment
Figure 1. IN-S124BR Solder Pattern
Package Dimensions in mm
Inolux Corporation
Proprietary & Confidential
Figure 2. IN-S124BR Package Dimensions
April 10, 2017
Page 1
www.inolux-corp.com
IN-S124BR series
Absolute Maximum Rating at 25oC (Note 1)
Product
Emission
Color
Pd (mW)
IF (mA)
IFP* (mA)
48
VR (V)
TOP (oC)
TST (oC)
5
-40 C~+85 C
IN-S124BRYG Yellow Green
IN-S124BRY
Yellow
IN-S124BRA
Amber
IN-S124BRR
Red
IN-S124BRB
Blue
IN-S124BRG
Green
IN-S124BRUW
White
78
o
o
o
o
-40 C~+100 C
60
Notes
1. Condition for IFP is pulse of 1/10 duty and 0.1msec width
ESD Precaution
ATTENTION: Electrostatic Discharge (ESD) protection
The symbol above denotes that ESD precaution is needed. ESD protection for GaP and AlGaAs based chips is necessary even
though they are relatively safe in the presence of low static-electric discharge. Parts built with AlInGaP, GaN, or/and InGaN based
chips are STATIC SENSITIVE devices. ESD precaution must be taken during design and assembly.
If manual work or processing is needed, please ensure the device is adequately protected from ESD during the process.
Please be advised that normal static precautions should be taken in the handling and assembly of this device to prevent damage or degradation which
may be induced by electrostatic discharge (ESD).
Inolux Corporation
April 10, 2017
Page 2
www.inolux-corp.com
IN-S124BR series
Electrical Characteristics T
A
= 25°C (Note 1)
VF(V)
Emission
Color
IF(mA)
IN-S124BRYG
Yellow Green
IN-S124BRY
Product
λ(nm)
Viewing
Angle
I*V(mcd)
typ.
max
λD
λP
△λ
2θ1/2
typ.
2.4
571
573
15
Yellow
2.4
589
591
IN-S124BRA
Amber
2.4
605
609
17
IN-S124BRR
Red
2.4
624
632
IN-S124BRB
Blue
3.9
470
468
40
IN-S124BRG
Green
3.9
525
520
30
IN-S124BRUW
White
3.9
X=0.29
Y=0.29
Notes
1. Performance guaranteed only under conditions listed in above tables.
Inolux Corporation
April 10, 2017
Page 3
www.inolux-corp.com
IN-S124BR series
Chromaticity Bin (for White only)
x
y
0.2500
0.2500
x
y
0.2900
0.3050
Rank C1
0.2700 0.2700
0.2775 0.2325
Rank D1
0.3100 0.3100
0.3325 0.2875
0.2500
0.2050
x
y
0.2700
0.2775
0.2900
0.2600
x
y
0.3100
0.3325
Rank C2
0.2900 0.2900
0.3050 0.2600
Rank D2
0.3300 0.3300
0.3600 0.3150
0.2700
0.2325
0.3100
0.2875
0.5
0.4
D2
0.3
D1
C2
C1
0.2
0.1
0.2
0.3
Inolux Corporation
0.4
0.5
0.6
April 10, 2017
Page 4
www.inolux-corp.com
IN-S124BR series
Typical Characteristic Curves – YG, Y, A, R
Inolux Corporation
April 10, 2017
Page 5
www.inolux-corp.com
IN-S124BR series
Typical Characteristic Curves – B, G, W
Inolux Corporation
April 10, 2017
Page 6
www.inolux-corp.com
IN-S124BR series
Typical Characteristic Curves – Radiation Pattern
Ordering Information
Technolog Test Current
y
IF (mA)
Forward
Luminous Intensity
Voltage
IV (mcd)
VF (V)
(Typ.)
(Typ.)
Product
Emission
Color
IN-S124BRYG
Yellow
Green
AllnGaP
2.1
IN-S124BRYG
IN-S124BRY
Yellow
AllnGaP
2.0
IN-S124BRY
IN-S124BRA
Amber
AllnGaP
2.0
IN-S124BRA
IN-S124BRR
Red
AllnGaP
2.0
IN-S124BRR
IN-S124BRB
Blue
InGaN
3.3
IN-S124BRB
IN-S124BRG
Green
InGaN
3.3
IN-S124BRG
IN-S124BRUW
White
InGaN
3.3
IN-S124BRUW
Inolux Corporation
Orderable
Part Number
April 10, 2017
Page 7
www.inolux-corp.com
IN-S124BR series
Label Specifications
Inolux P/N:
I
N
S
Material
Inolux
SMD
1
2
Package
S = PCB
Type
4
B
R
Variation
Orientation
124B = 3.2 x 1.6 x
1.85mm
R = Reverse
Mount
X
Lens
Color
Customized
Stamp-off
(Blank) = Clear
U = Diffused
R=624nm
A=605nm
Y=589nm
YG=571nm
G=525nm
B=470nm
W=White
Current
(Blank) =
20mA
X
X X X
Lot No.:
Z
Internal
Tracker
2
7
Year (2017, 2018, …..)
Inolux Corporation
01
24
001
Month
Date
Serial
April 10, 2017
Page 8
www.inolux-corp.com
IN-S124BR series
Packaging Information: 2000pcs Per Reel
Tape Dimension
Part No.
IN-S124BR
Dim. A
Dim. B
Dim. C
3.37±0.10 1.78±0.10 2.17±0.10
Q’ty/Reel
2K
Unit: mm
Reel Dimension
Inolux Corporation
April 10, 2017
Page 9
www.inolux-corp.com
IN-S124BR series
Packing Dimension
5 boxes per carton are available depending on shipment quantity.
Specification
Material
Quantity
Carrier tape
Per EIA 481-1A specs
Conductive black tape
4000pcs per reel
Reel
Conductive black
Label
IN standard
Paper
Packing bag
220x240mm
Aluminum laminated bag/ no-zipper
One reel per bag
Carton
IN standard
Paper
Non-specified
Others:
Each immediate box consists of 5 reels. The 5 reels may not necessarily have the same lot number or the same
bin combinations of Iv, λD and Vf. Each reel has a label identifying its specification; the immediate box consists
of a product label as well.
Inolux Corporation
April 10, 2017
Page 10
www.inolux-corp.com
IN-S124BR series
Dry Pack
All SMD optical devices are MOISTURE SENSITIVE. Avoid exposure to moisture at all times during
transportation or storage. Every reel is packaged in a moisture protected anti-static bag. Each bag is properly
sealed prior to shipment.
Upon request, a humidity indicator will be included in the moisture protected anti-static bag prior to shipment.
The packaging sequence is as follows:
Reflow Soldering
• Recommended tin glue specifications: melting temperature in the range of 178~192 OC
• The recommended reflow soldering profile is as follows (temperatures indicated are as measured on
the surface of the LED resin):
Lead-free Solder Profile
Inolux Corporation
April 10, 2017
Page 11
www.inolux-corp.com
IN-S124BR series
Precautions
Avoid exposure to moisture at all times during transportation or storage.
Anti-Static precaution must be taken when handling GaN, InGaN, and AlInGaP products.
It is suggested to connect the unit with a current limiting resistor of the proper size. Avoid applying a
reverse voltage.
Avoid operation beyond the limits as specified by the absolute maximum ratings.
Avoid direct contact with the surface through which the LED emits light.
If possible, assemble the unit in a clean room or dust-free environment.
Reworking
Rework should be completed within 5 seconds under 260 OC.
The iron tip must not come in contact with the copper foil.
Twin-head type is preferred.
Cleaning
Following are cleaning procedures after soldering:
• An alcohol-based solvent such as isopropyl alcohol (IPA) is recommended.
• Temperature x Time should be 50oC x 30sec. or
很抱歉,暂时无法提供与“IN-S124BRY”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.76904
- 200+0.70589
- 500+0.68235
