AARDUINO MKR GSM 1400
Code: ABX00018
Arduino MKR GSM 1400 is a powerful board that combines the functionality of the
Zero and global GSM connectivity. It is the ideal solution for makers wanting to
design IoT projects with minimal previous experience in networking.
Please note: This board does not ship with a SIM card.
Arduino MKR GSM 1400 has been designed to offer a practical and cost effective solution for makers
seeking to add global GSM connectivity to their projects with minimal previous experience in networking. It
is based on the Atmel SAMD21 and a SARAU201 GSM module.
The design includes the ability to power the board using a LiPo battery or external power source rated 5V.
Switching from one source to the other is done automatically. A good 32 bit computational power similar
to the Zero board, the usual rich set of I/O interfaces, gobal GSM communication and the ease of use of
the Arduino Software (IDE) for code development and programming. All these features make this board the
preferred choice for the emerging IoT battery-powered projects in a compact form factor. The USB port can
be used to supply power (5V) to the board. During cellular transmissions the peak current required by the
board will exceed 500mA. This is in excess of what can sourced by a standard USB port, so it is
MANDATORY to have a 1500 mAh or higher LiPo battery plugged all the time, the current provided by the
USB port will be supplmented by the battery. When powering the board using Vin, a 5V power supply that
can supply atleast 2A is required..
Warning: Unlike most Arduino & Genuino boards, the MKR GSM 1400 runs at 3.3V. The maximum
voltage that the I/O pins can tolerate is 3.3V. Applying voltages higher than 3.3V to any I/O pin
could damage the board. While output to 5V digital devices is possible, bidirectional
communication with 5V devices needs proper level shifting.
TECH SPECS
Microcontroller
Board Power Supply (USB/VIN)
Supported Battery(*)
Circuit Operating Voltage
Digital I/O Pins
PWM Pins
UART
SPI
I2C
Analog Input Pins
Analog Output Pins
External Interrupts
DC Current per I/O Pin
Flash Memory
SRAM
EEPROM
Clock Speed
LED_BUILTIN
Full-Speed USB Device and embedded Host
Antenna power
Carrier frequency
Working region
Length
Width
Weight
SAMD21 Cortex-M0+ 32bit low power ARM MCU
5V
3.7V LiPo
3.3V
8
12 (0, 1, 2, 3, 4, 5, 6, 7, 8, 10, A3 - or 18 -, A4 -or 19)
1
1
1
7 (ADC 8/10/12 bit)
1 (DAC 10 bit)
8 (0, 1, 4, 5, 6, 7, 8, A1 -or 16-, A2 - or 17)
7 mA
256 KB
32 KB
no
32.768 kHz (RTC), 48 MHz
6
2dB
433/868/915 MHz
Global
67.64 mm
25 mm
32 gr.
OSH: Schematics
The MKR GSM 1400 is open-source hardware! You can build your own board using the following files:
EAGLE FILES IN .ZIPSCHEMATICS IN .PDFFRITZING IN .FZPZ
Pinout
Download the pinout in PNG format
Antenna
The MKR GSM 1400 has to be used with a GSM antenna that can be attached to the board with the micro
UFL connector.
Please check that it can accept frequencies in the GSM's range (880/915 MHz).
Please note: for best result, do not attach the antenna to a metallic surface like car chassis, etc.
Batteries, Pins and board LEDs
Battery capacity: The connected battery must be a 3.7V LiPo
Vin: This pin can be used to power the board with a regulated voltage source rated from 5V. If the power is
fed through this pin, the USB power source is disconnected. This is the only way you can supply 5v (range
is 5V to maximum 6V) to the board not using USB. This pin is an INPUT.
5V: This pin outputs 5V from the the board when powered from the USB connector or from the VIN pin of
the board. It is unregulated and the voltage is taken directly from the inputs.
VCC: This pin outputs 3.3V through the on-board voltage regulator. This voltage is 3.3V if USB or VIN is
used and equal to the series of the two batteries when they are used
LED ON: This LED is connected to the input voltage source from either USB or VIN. It is also connected to
the battery power. This means that it is ON (with a lower intensity) also when the battery is inserted.
Onboard LED: On MKR GSM 1400 the on board LED is connected to D6 and not D13 as on the other
boards. Blink example or other sketcthes that uses pin 13 for on board LED may need to be changed to
work properly.
很抱歉,暂时无法提供与“ABX00018”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 50+622.5876550+80.54122
