INL-3AG30
INL-3AG30
    INOLUX(英诺斯)
    插件,D=3.1mm
    发光二极管/LED 翠绿色 插件,D=3.1mm 525nm 18000mcd
INL-3AG30 数据手册
INL-3AX30 3 mm Through Hole Lamp Features Description • 3mm Through hole, 5.08mm lens height • High Brightness The INL-3AX30 is high brightness 30 degrees • Water Clear lens through-hole lamp. It is a 3mm epoxy type LED which • InGaN / AlInGaP Technology can be used in various applications. • Special packaging available upon request • High reliability Applications • Consumer Electronics • Variable Message Signs (VMS) • Automobile After Market • Industrial Equipment • Advertising Signs Package Dimensions in mm Inolux Corporation Proprietary & Confidential Figure 1. INL-3AX30 Package Dimensions July 10, 2017 Page 1 www.inolux-corp.com INL-3AX30 3 mm Through Hole Lamp Absolute Maximum Rating at 25oC (Note 1) Product Emission Color INL-3AYG30 Yellow Green INL3AY30 Yellow INL3AA30 Amber INL3AR30 Red INL3AB30 Blue INL3AG30 Green INL3AW30 White Pd (mW) IF (mA) IFP* (mA) 65 25 100 95 25 VR (V) TOP (oC) 5 -40 C~+85 C o TST (oC) o o o -40 C~+100 C 100 Notes 1. Condition for IFP is pulse of 1/10 duty and 0.1msec width Inolux Corporation Proprietary & Confidential July 10, 2017 Page 2 www.inolux-corp.com INL-3AX30 3 mm Through Hole Lamp Electrical Characteristics T A = 25°C (Note 1) VF(V) Emission Color IF(mA) INL-3AYG30 Yellow Green INL3AY30 Product Viewing Angle λ(nm) I*V(mcd) min max λD λP △λ 2θ1/2 min typ. 20 1.6 2.6 573 575 20 30 160 270 Yellow 20 1.6 2.6 592 590 15 30 270 460 INL3AA30 Amber 20 1.6 2.6 610 605 35 30 270 460 INL3AR30 Red 20 1.6 2.6 632 624 20 30 460 780 INL3AB30 Blue 20 2.6 3.8 470 468 25 30 3800 5000 INL3AG30 Green 20 2.8 3.8 525 520 35 30 11000 18000 INL3AW30 White 20 2.8 3.8 30 5000 X = 0.28 Y = 0.28 8500 Notes 1. Performance guaranteed only under conditions listed in above tables. ESD Precaution ATTENTION: Electrostatic Discharge (ESD) protection The symbol above denotes that ESD precaution is needed. ESD protection for GaP and AlGaAs based chips is necessary even though they are relatively safe in the presence of low static-electric discharge. Parts built with AlInGaP, GaN, or/and InGaN based chips are STATIC SENSITIVE devices. ESD precaution must be taken during design and assembly. If manual work or processing is needed, please ensure the device is adequately protected from ESD during the process. Please be advised that normal static precautions should be taken in the handling and assembly of this device to prevent damage or degradation which may be induced by electrostatic discharge (ESD). Inolux Corporation Proprietary & Confidential July 10, 2017 Page 3 www.inolux-corp.com INL-3AX30 3 mm Through Hole Lamp Chromaticity Bin ( For White Only) Inolux Corporation Proprietary & Confidential July 10, 2017 Page 4 www.inolux-corp.com INL-3AX30 3 mm Through Hole Lamp Inolux Corporation Proprietary & Confidential July 10, 2017 Page 5 www.inolux-corp.com INL-3AX30 3 mm Through Hole Lamp Typical Characteristic Curves – YG, Y, A, R Inolux Corporation Proprietary & Confidential July 10, 2017 Page 6 www.inolux-corp.com INL-3AX30 3 mm Through Hole Lamp Typical Characteristic Curves – B, G, W Inolux Corporation Proprietary & Confidential July 10, 2017 Page 7 www.inolux-corp.com INL-3AX30 3 mm Through Hole Lamp Typical Characteristic Curves – Radiation Pattern Ordering Information Product Emission Test Current Technology Color IF (mA) Luminous Intensity IV (mcd) (Typ.) Forward Voltage VF (V) (Typ.) Orderable Part Number INL-3AYG30 Yellow Green AlInGaP 20 270 2.0 INL-3AYG30 INL3AY30 Yellow AlInGaP 20 460 2.0 INL3AY30 INL3AA30 Amber AlInGaP 20 460 2.0 INL3AA30 INL3AR30 Red AlInGaP 20 780 2.0 INL3AR30 INL3AB30 Blue InGaN 20 5000 3.2 INL3AB30 INL3AG30 Green InGaN 20 18000 3.2 INL3AG30 INL3AW30 White InGaN 20 8500 3.1 INL3AW30 Inolux Corporation Proprietary & Confidential July 10, 2017 Page 8 www.inolux-corp.com INL-3AX30 3 mm Through Hole Lamp Label Specifications Inolux P/N: I N L - 3 A Material Inolux Through Hole Lamp 3A = 3mm with flange, 5.08 height Y 3 0 - Customized Stamp-off Lens Color View Angle (Blank) = Clear Lens R=636nm A=609nm Y=593nm YG=574nm G=530nm B=468nm W=White 30 = 30 deg. X X X X Lot No.: Z Internal Tracker 2 0 1 7 Year (2017, 2018, …..) Inolux Corporation Proprietary & Confidential 01 24 001 Month Date Serial July 10, 2017 Page 9 www.inolux-corp.com INL-3AX30 3 mm Through Hole Lamp Soldering Recommended soldering conditions: Soldering Iron Basic Spec is Max 3 sec. @ 300°C. Lamps without stopper must leave a min. of 3mm clearance from base of the lens to the soldering point. Rework Caution is advised when rework is performed. Rework should be completed within 4 second under 245°C using a double-headed soldering iron. Inolux Corporation Proprietary & Confidential July 10, 2017 Page 10 www.inolux-corp.com INL-3AX30 3 mm Through Hole Lamp Reliability Item Precondition Frequency/ lots/ samples/ failures For all reliability monitoring tests according to JEDEC Level 2 1Q/ 1/ 22/ 0 Solderability Standards Reference J-STD-020 CNS-554 1.) Baking at 85°C for 24hrs 2.) Moisture storage at 85°C/ 60% R.H. for 168hrs Accelerated aging 155°C/ 24hrs Tinning speed: 2.5+0.5cm/s Tinning: A: 215°C/ 3+1s or B: 260°C/ 10+1s Dipping soldering terminal only Soldering bath temperature A: 260+/-5°C; 10+/-1s B: 350+/-10°C; 3+/-0.5s 1.) Precondition: 85°C baking for 24hrs 85°C/ 60%R.H. for 168hrs 2.) Tamb25°C; IF=20mA; duration 1000hrs Tamb: 85°C Humidity: 85% R.H., IF=5mA Duration: 1000hrs Tamb: 55°C IF=20mA Duration: 1000hrs Tamb25°C, If=20mA,, Ip=100mA, Duty cycle=0.125 (tp=125μs,T=1sec) Duration 500hrs) A cycle: -40 degree C 15min; +85 degree C 15min Thermal steady within 5 min.. 300 cycles 2 chamber/ Air-to-air type 60+3°C 90+5/-10% R.H. for 500hrs 100+10°C for 500hrs CNS-6118 -40+5°C for 500hrs JESD22-B102-B And CNS-5068 CNS-5067 Resistance to soldering heat 1Q/ 1/ 40/ 0 CNS-11829 Operating life test High humidity, 1Q/ 1/ 45/ 0 high temperature bias 1Q/ 1/ 20 High temperature bias JESD-A101-B IN specs. 1Q/ 1/ 40/ 0 Pulse life test 1Q/ 1/ 76/ 0 Temperature cycle High humidity 1Q/ 1/ 40/ 0 storage test High temperature 1Q/ 1/ 40/ 0 storage test Low temperature 1Q/ 1/ 40/ 0 storage test JESD-A104-A IEC 68-2-14, Nb CNS-6117 Inolux Corporation Proprietary & Confidential Conditions July 10, 2017 Page 11 www.inolux-corp.com INL-3AX30 3 mm Through Hole Lamp Revision History Changes since last revision Initial Release Page Version No. 1.0 Revision Date 07-10-2017 DISCLAIMER INOLUX reserves the right to make changes without further notice to any products herein to improve reliability, function or design. INOLUX does not assume any liability arising out of the application or use of any product or circuit described herein; neither does it convey any license under its patent rights, nor the rights of others. LIFE SUPPORT POLICY INOLUX’s products are not authorized for use as critical components in life support devices or systems without the express written approval of the President of INOLUX or INOLUX CORPORATION. As used herein: 1. Life support devices or systems are devices or systems which, (a) are intended for surgical implant into the body, or (b) support or sustain life, and (c) whose failure to perform when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in a significant injury of the user. 2. A critical component in any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness. Inolux Corporation Proprietary & Confidential July 10, 2017 Page 12 www.inolux-corp.com
INL-3AG30 价格&库存
很抱歉,暂时无法提供与“INL-3AG30”相匹配的价格&库存,您可以联系我们找货
INL-3AG30
    • 1+1.14318
    • 200+0.45620
    • 500+0.44097
    • 1000+0.43341
    INL-3AG30
