USB1035-GF-P-0-B-B
USB1035-GF-P-0-B-B
    GCT
    插件
USB1035-GF-P-0-B-B 数据手册
13.14 7.00 8x ø0.92 1A 2A 3A 4A 1B 2B 3B 4B 10.28 GCT 0.8 Spring G 2.00 2.71 2.62 3.4 8.4 5.68 H 4x ø2.30 F Standoff Optional Grounding Shell RECOMMENDED PCB LAYOUT 15.0 (keep out area) Thickness: 1.2mm General Tolerance: ±0.05 as viewed from component side Component Outline Specifications 12.50 4.0 1.2 Material Plastic Housing: PBT, G.F. Filled, UL94V-0 Contact Terminal: Brass Metallic Shell: Stainless steel 2B 3B 3.8 4B 5.12 3.83 9.90 6.39 1B Plating Underplating: 50µ" Nickel Contact Area: Gold Flash or 15µ" Gold Solder Tails: 50µ" Tin Metallic Shell: Nickel 15.32 4A 15.9 3A 13.75±0.20 0.75+0.13 -0.15 2A 2.8 D 12.46±0.35 1A 5.12 E C 0.60 2.00 2.71 2.62 5.68 10.28±0.25 13.1 7.00 14.26+0.00 -0.50 15.73±0.25 Ordering Grid USB1035 B XX P X X 17.0 Contact Plating GF = Gold Flash (Standard) 15 = 15µ" Gold B (100 per tray) Insulator Colour B = Black (Standard) W = White Grounding Shell 0 = Without Grounding (Standard) 1 = With Grounding Part Number Product Description USB1035 USB Dual Receptacle, Type A, 8 Pin, Through Hole, Horizontal, Top Mount, With Kinked Shell Stakes Drawing Date 14th February 2011 By Detail 1 2 3 Mechanical & Environmental Operating Temperature: -40°C to +85°C Mating Force: 35N (3.57Kgf) max. Unmating Force: 10N (1.02Kgf) min. Durability: 1,500 Cycles Request Samples and Quotation Packing Options B = Tray Insulator Material P = PBT A Electrical Voltage Rating: 30V Current Rating: 1.8A Contact Resistance: 30 mΩ max. Insulating Resistance: 1000 MΩ min. Dielectric Withstand Voltage: 500V AC 4 Revision Date 5 CC USB1035 F PCN F 03/11/21 Tolerances (Except as Noted) Length Angle X.X ± 0.35 X.XX ± 0.25 X.° ± 3° X.X° ± 1.5° 6 Units: Metric (mm) C 3rd Angle Projection 7 This drawing is confidential and copyright of Global Connector Technology, Ltd (GCT). This drawing must not be copied or disclosed without written consent. E & OE www.gct.co Not to Scale Drawn By SA 8 Sheet No. 1/2 H Buffer Material Products P/N PCS/Tray Trays/Carton PCS/Carton PE bag USB1035 G 100 10 1000 Packing Rules: 1.USB's placed into the tray base. 2.Tray cover and base taped together to keep USB's in place. 3.10 trays put into carton. 4.Boxed taped and label stuck on the outer carton. 2 Stack/Carton 5 Tray/Stack F E 100PCS/tray RoHS label Label D Inner Box C 285mm Sealed by adhesive Tape USB's placed into the tray base. Label B Carboard 25 6m m m 5m 32 Part Number Product Description USB1035 USB Dual Receptacle, Type A, 8 Pin, Through Hole, Horizontal, Top Mount, With Kinked Shell Stakes Drawing Date A 14th February 2011 By Use stretch film winding 1 Detail 2 3 4 Revision Date 5 CC USB1035 F PCN F 03/11/21 Tolerances (Except as Noted) Length Angle Units: Metric (mm) C 3rd Angle Projection 6 7 This drawing is confidential and copyright of Global Connector Technology, Ltd (GCT). This drawing must not be copied or disclosed without written consent. E & OE www.gct.co Not to Scale Drawn By SA 8 Sheet No. 2/2
USB1035-GF-P-0-B-B 价格&库存
很抱歉,暂时无法提供与“USB1035-GF-P-0-B-B”相匹配的价格&库存,您可以联系我们找货
USB1035-GF-P-0-B-B
    USB1035-GF-P-0-B-B
