1.00
7.15
H
Designed to comply with physical, electrical and environmental requirements of Micro
USB Standard (USB2.0), A/B types support USB On-The-GO (OTG) interface.
PCB Mount Orientation
2.60
G
1.30
2.60
1.40
0.25±0.05
0.40
1.30
1.05
0.45
F
5
4.00
Specifications 规格:
1.45
5.5±0.2
0.49
1
PCB Edge
Materials 材料:
Plastic Housing 塑胶外壳: LCP, UL94V-0, Black
Contact Terminal 接触端子: Copper Alloy
Metallic Shell 金属外壳: Stainless Steel SUS 304 T = 0.25mm
7.15
6.20
0.60±0.04
Plating电镀:
Underplating 底层电镀: 50µ" Nickel
Finish表面处理:Contact Area 接触面积: 30µ" Gold plating
Solder Tails 焊接末端: Gold Flash
Metallic Shell 金属外壳: Matte Tin
Recommended PCB Layout
General Tolerance: ±0.05
as viewed from component side
6.90+0.04
-0.02
Solder Area
2.60
Component Outline
0.05±0.05
2.35
2.7
5
C
1.85+0.04
-0.02
1.30
1
2.00
4.30
4.75
D
1.25
E
1.85
0.50
Electrical 电气规格:
Voltage Rating电压额定值: 30V AC
Current Rating电流额定值: Signal(Pins 2,3,4): 1.0 A
Power (Pins1,5): 1.8A
Operating Temperature 工作温度: -30°C to +85°C
Contact Resistance接触电阻值: 30 mΩ max.
Insulating Resistance绝缘电阻值: 1000 MΩ min.
Dielectric Withstand Voltage耐电压: 500 V AC/Minute
0.90
3.50
2.15
B
2.85
Mechanical 机械性规格:
Mating Force插入力: 35N max.
Unmating Force拨出力: Initial 10N min.
Final 8N min after durability test.
Durability耐久性: 10,000 Cycles
Ordering Grid
USB3090
30
A
Contact Plating
30 = 30u" Gold
Request Samples
and Quotation
Packing Options
A = Tape & Reel
Part Number
Product Description
(1.5K per Reel)
USB3090
Micro USB Receptacle, Type AB
SMT, R/A, Bottom Mount, w/out Peg, w/outer shell stakes
Drawing Date
A
4th April 2011
By
Detail
7.40
1
2
3
4
Revision
Date
5
CC
Tolerances (Except as Noted)
USB3090
E PCN
E2
17/02/17
X.X° ± 2°
X.X ± 0.3
X.XX ± 0.20 X.XX° ± 1°
X.XXX ± 0.10 X.XXX° ± 0.5°
Length
Angle
6
Units:
Metric (mm)
C
3rd Angle Projection
7
This drawing is confidential and
copyright of Global Connector
Technology, Ltd (GCT).
This drawing must not be copied
or disclosed without written
consent. E & OE
www.gct.co
Not to
Scale
Drawn By
SA
8
Sheet No.
1/2
FIRST APPROXIMATELY
15PCS EMPTY CARRIER
H
4.0
FIRST APPROXIMATELY
15PCS EMPTY CARRIER
12.0
16.0
4.0
G
I/O Direction
卷盘绕逆时针方向转动
F
Peel off Angle
剥离角度
Products P/N
PCS/Reel Reels/Carton PCS/Carton
USB3090-30-A
1500
4
6000
10°
Cover Tape
盖带
Carrier Tape
载带
ø330
3
120
Ø2
Notes注意:
1. Peeling off force of top tape: 0.1-1.3N
2. Part Conforms to EIA-481-C Standards产品符合EIA-481-C标准
3. All dimensions in millimeters 所有尺寸均是毫米
4. 10 sprocket hole pitch cumulative tolerance±0.2mm
Ø13.5
E
120°
Detail F
6
PS
Cardboard
纸板
Detail F
Reel 卷筒
D
Waterproof bag
防水袋
Label
标签
Carton
纸箱
Triangle Liner
三角形班轮
Protection Tape
保护胶带
160mm
C
4 Reels
4 卷轴
1500 pieces/reel
1500 件/卷
35
0m
m
700x600x0.08
B
Part Number
Product Description
USB3090
Drawing Date
A
4th April 2011
By
Detail
1
2
3
4
m
0m
35
Revision
Date
5
CC
USB3090
E PCN
E2
17/02/17
Length
Angle
Units:
Metric (mm)
C
6
7
consent. E & OE
www.gct.co
Not to
Scale
Drawn By
SA
8
Sheet No.
2/2
很抱歉,暂时无法提供与“USB3090-30-A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1500+3.20355
- 4500+3.15609
- 国内价格 香港价格
- 137+4.62635137+0.59882
- 250+4.33513250+0.56112
- 500+3.97008500+0.51387
- 国内价格
- 1+5.79012
- 37+4.41378
- 112+4.18835
- 300+3.74934
- 750+3.73748
