IN-PI33TBTPRPGPB
3535 RGB LED 4-Pin with Integrated IC
Features
Description
3535 with integrated high quality constant
current IC and RGB LED chip.
Built-in IC, with high precision of constant
current and internal RGB chips spectral
processing in advance.
Single line data transmission (return to zero
code).
Specific Shaping Transmit Technology - number
of LED stacked is not restricted.
Cascading Enhancement Technology - any 2 LED
spacing can be up to 10 meters
Data transfer rate of 800 kbp/s at 30 frames per
second.
RGB output port PWM control can achieve 256
grey level adjustments.
Upon powering up, IC performs self-inspection
then lights connection on the pin B lamp.
SA-I Anti-interference patent technology for
single line data transmission.
Built-in power supply reverse connect protection
module, reversed power input will not damage
the IC.
The IN-PI33TBTPRPGPB is 3.5*3.5*1.95mm RGB LED
with integrated IC. It is a SMD type LED which can be
used in various applications.
Applications
Full color LED string light
LED full color module
LED guardrail tube
LED scene lighting
LED point light
LED pixel screen
LED shaped screen
Package Outline Dimensions & Pin Configuration
Figure 1. IN-PI33TBTPRPGPB Package Outline Dimensions
Inolux Corporation
Proprietary & Confidential
Page 1
July 31, 2019
www.inolux-corp.com
IN-PI33TBTPRPGPB
Pin Configuration
Figure 2. IN- PI33TBTPRPGPB Pin Configuration
Notes:
1. Dimension in millimeter, tolerance is ±0.1mm unless otherwise noted.
Number
Symbol
Function Description
1
GND
Ground
2
DIN
Control data signal input
3
VDD
Power supply LED
4
DOUT
Control data signal output
Soldering Pad Size
Pad Size
Inolux Corporation
Steel mesh size
Page 2
July 31, 2019
www.inolux-corp.com
IN-PI33TBTPRPGPB
Absolute Maximum Rating (Ta = 25 ℃, VSS=0V)
Parameter
Symbol
Range
Unit
Logic supply voltage
VDD
+3.5~+5.5
V
Logic input voltage
VIN
-0.5 ~VDD+0.5
V
Operating temperature
TOPT
−45 ~ +85
°C
Storage temperature
TSTG
−50 ~ +150
°C
ESD pressure(HBM)
VESD
4K
V
ESD pressure(DM)
VESD
200
V
LED Characteristics (Ta = 25°C)
12mA
Color
Inolux Corporation
Wavelength(nm)
Light Intensity(mcd)
Red
620-630
400-700
Green
515-530
1000-1500
Blue
460-470
300-500
Page 3
July 31, 2019
www.inolux-corp.com
IN-PI33TBTPRPGPB
Recommended Operating Ranges (unless otherwise specified, Ta= -20 ~ +70 ℃, VDD=4.5 ~ 5.5V,VSS=0V)
Parameter
Symbol
Min.
Typ.
Max
Unit
Test conditions
VDD
5.2
V
VDS, MAX
26
V
DOUT drive capability
IDOH
49
mA
maximum source
current
IDOL
-50
mA
maximum sink current
High level input voltage
VIH
0.7*VDD
V
VDD=5.0V
Low level input voltage
VIL
0.3*VDD
V
VDD=5.0V
The frequency of PWM
FPWM
1.2
KHZ
IDD
1
mA
Supply voltage
R/G/B port pressure
Static power consumption
Inolux Corporation
Page 4
July 31, 2019
www.inolux-corp.com
IN-PI33TBTPRPGPB
Switching Characteristics (unless otherwise specified, Ta=25 ℃)
Parameter
The speed of data transmission
Symbol
Min.
Typ.
Max
Unit
Test conditions
fDIN
800
KHZ
The duty ratio of 67%
(data 1)
TPLH
500
ns
DOUT transmission delay
DIN→DOUT
TPHL
500
ns
Tr
100
ns
Tf
100
ns
IOUT Rise/Drop Time
VDS=1.5
IOUT=13mA
Timing Waveforms
1. Input Code
Inolux Corporation
Page 5
July 31, 2019
www.inolux-corp.com
IN-PI33TBTPRPGPB
2. The data transmission time (TH+TL=1.25µs±600ns):
Name
Description
Typ. value
error
T0H
0 code, high level time
0.3μs
±0.15μs
T0L
0 code, low level time
0.9μs
±0.15μs
T1H
1 code, high level time
0.9μs
±0.15μs
T1L
1 code, low level time
0.3μs
±0.15μs
Trst
Reset code, low level time
80μs
3. Connection Scheme
4. Data Transfer Format
Note: the D1 sends data for MCU, D2, D3, D4 for data forwarding automatic shaping cascade circuit.
5. 24-bit data format
Note: high starting, in order to send data (G7 - G6 - ...... ..B0)
Inolux Corporation
Page 6
July 31, 2019
www.inolux-corp.com
IN-PI33TBTPRPGPB
Typical Application Circuit
Product signal input and output must be connected in series with protection resistor R1. R1 depends on the size of the cascade amount,
the greater the number of cascade, the smaller R1. The general recommended value is between 200-2KΩ, usually the recommended
value is typical 500Ω.
Inolux Corporation
Page 7
July 31, 2019
www.inolux-corp.com
IN-PI33TBTPRPGPB
LED Performance Graph
Inolux Corporation
Page 8
July 31, 2019
www.inolux-corp.com
IN-PI33TBTPRPGPB
Ordering Information
Product
Emission Color
IV(mcd)
R
400-700
G
1000-1500
B
300-500
IN-PI33TBTPRPGPB
Orderable
Part Number
IN-PI33TBTPRPGPB
Label Specifications
Inolux P/N:
I
N
PI
Product
Inolux
33
T
Package
Die
Qty.
B
Variation
PI- Single trace IC
33TB = 3.5 x 3.5 x 1.95 mm
PC- Clock Function IC
T
(X)
R
(X)
G
(X)
B
Orientation
Current
Color
Current
Color
Current
Color
T = Top
Mount
P=12mA
5 = 5mA
R = 624
nm
P=12mA
5 = 5mA
G=
520
nm
P=12mA
5 = 5mA
B=
470
nm
- X
X
X
Customized
Stamp-off
Lot No.:
Z
Internal
Tracker
Inolux Corporation
2
7
Year (2017, 2018, …..)
Page 9
01
24
001
Month
Date
Serial
July 31, 2019
www.inolux-corp.com
X
IN-PI33TBTPRPGPB
Precautions
Please read the following notes before using the product:
1. Storage
1.1 Do not open moisture proof bag before the products are ready to use.
1.2 Before opening the package, the LEDs should be kept at 30℃ or less and 80%RH or less.
1.3 The LEDs should be used within a year.
1.4 After opening the package, the remaining LEDs should be kept in a resealed bag.
1.5 The LEDs require mandatory baking before usage. Baking treatment listed below.
1.6 If the moisture adsorbent material has fabled away or the LEDs have exceeded the storage time,
baking treatment should be performed using the following conditions.
*Baking treatment: 60±5℃ for24 hours.
Inolux Corporation
Page 10
July 31, 2019
www.inolux-corp.com
IN-PI33TBTPRPGPB
2. Soldering Condition
Recommended soldering conditions:
Profile Feature
Lead-Free Solder
Average Ramp-Up Rate (Ts
max
to Tp )
3℃/second max.
Preheat: Temperature Min (Ts
min)
150℃
max)
200℃
Preheat: Time ( ts
min to
ts
max
60-180 seconds
Time Maintained Above: Temperature (TL)
217 ℃
Time Maintained Above: Time (t L)
60-150 seconds
Peak/Classification Temperature (T P)
240 ℃
Time Within 5℃ of Actual Peak Temperature ( tp)
很抱歉,暂时无法提供与“IN-PI33TBTPRPGPB”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1000+2.094951000+0.27228
- 2000+1.963952000+0.25526
- 3000+1.896703000+0.24652
- 5000+1.820675000+0.23664
- 7000+1.775417000+0.23075
- 10000+1.7312610000+0.22501
- 国内价格 香港价格
- 1+5.472711+0.71129
- 10+3.7583610+0.48848
- 100+2.71801100+0.35326
- 500+2.24908500+0.29232
