SMDA03LCC
THRU
SMDA24LCC
Technical Data
Data Sheet N0301, Rev. B
SMDA03LCC THRU SMDA24LCC TVS ARRAY SERIES
Description
The SMDAXXLCC series of TVS array have been
designed to provide bidirectional protection for
sensitive electronics from damage due to voltage
transients caused by electrostatic discharge
(ESD), electrical fast transients (EFT), lightning
and other voltage-induced transient events. The
device can be used to protect combinations of four
bidirectional lines.
SO-8
Schematic & Pin Configuration
Features
Mechanical Characteristics
Protects 3.3, 5, 12, 15, 24 V Components
Bidirectional
Provides Electrically Isolated Protection
300 W @ 8/20 us
Protects 4 Lines
SO-8 Packaging
LOW CAPACITANCE: 5PF
“-A” is an AEC-Q101 qualified device
This is a Pb − Free Device
All SMC parts are traceable to the wafer lot
Additional testing can be offered upon request
Application
SO-8 Surface Mount Package
Approximate Weight: 0.1 grams
PIN #1 Indicator: DOT on top of package
Packaging: Tubes or Tape & Reel per EIA
Standard 481
RS-232 & RS-422 data lines
Microprocessor Based Equipment
Notebooks, Desktops, & Servers
LAN/WAN Equipment
Serial and Parallel Port
Peripherals
Absolute Maximum Ratings:
Parameter
Symbol
Value
Units
Peak Pulse Power, 8/20 μs Wave shape
P
300
W
Operating Temperature
TJ
-55 to +125
C
Storage Temperature
Tstg
-55 to +150
C
Lead Soldering Temperature
TL
260 (10 Sec.)
C
China - Germany - Korea - Singapore - United States
http://www.smc-diodes.com - sales@ smc-diodes.com
SMDA03LCC
THRU
SMDA24LCC
Technical Data
Electrical Characteristics@25°C
Stand-off
Voltage
Vwm
(V)
Max
Breakdown
Voltage
VBR
@1mA
(V)
Min
Clamping
Voltage
Vc
@1A
(V)
Max
Leakage
Current
IR
@ Vwm
(uA)
Max
Capacitance
(f = 1MHz)
C
@ 0V
(pF)
Max
Temperature
Coefficient of
VBR
a(VBR)
mv/°C
Max
SMDA03LCC
3.3
4
7
200
15
-5
SMDA05LCC
5.0
6
9.8
1
SMDA12LCC
12.0
13.3
19
1
15
8
SMDA15LCC
15.0
16.7
24
1
15
11
SMDA24LCC
24.0
26.7
43
1
15
28
Part Number
Ratings and Characteristics Curves
Ordering Information
Device
SMDA03LCC
THRU
SMDA24LCC
SMDA03LCCTR
THRU
SMDA24LCCTR
Marking Diagram
Package
Shipping
SO-8
(Pb-Free)
2500pcs / reel
SO-8
(Pb-Free)
2500pcs / reel
For information on tape and reel specifications, including part
orientation and tape sizes, please refer to our tape and reel
packaging specification.
Where XXXXX is YYWWL
SMDA03LCC
S
YY
WW
L
= Part Number
=S
= Year
= Week
= Lot Number
Cautions:Molding resin
SMDA03LCC
THRU
SMDA24LCC
Technical Data
Circuit Diagram
Ideal for Ethernet applications, SMDAxxLCC Series provides up
to four (4) lines of protection in a common-mode configuration.
Circuit connectivity is as follows:
✔ TPIN is connected to Pin 5.
✔ TPIP is connected to Pin 6.
✔ TPON is connected to Pin 1.
✔ TPOP is connected to Pin 2.
✔ Pins 3, 4, 7 & 8 are connected to ground.
Mechanical Dimensions SO-8
SYMBOL
Millimeters
Inches
MIN.
MAX.
MIN.
MAX.
A
A1
A2
b
1.350
0.100
1.350
0.306
1.800
0.250
1.750
0.510
0.053
0.004
0.053
0.012
0.071
0.010
0.069
0.020
c
0.150
0.300
0.006
0.012
D
e
E
E1
L
4.720
1.140
5.700
3.750
0.300
5.120
1.400
6.300
4.150
1.270
0.186
0.045
0.224
0.148
0.012
0.202
0.055
0.248
0.163
0.050
θ
0°
8°
0°
8°
Carrier Tape Specification SO-8
SMDA03LCC
THRU
SMDA24LCC
Technical Data
DISCLAIMER:
1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product
characteristics. Before ordering, purchasers are advised to contact the SMC Diode Solutions sales department for the latest version of
the datasheet(s).
2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment,
medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by
means of users’ fail-safe precautions or other arrangement .
3- In no event shall SMC Diode Solutions be liable for any damages that may result from an accident or any other cause during
operation of the user’s units according to the datasheet(s). SMC Diode Solution assumes no responsibility for any intellectual property
claims or any other problems that may result from applications of information, products or circuits described in the datasheets.
4- In no event shall SMC Diode Solutions be liable for any failure in a semiconductor device or any secondary damage resulting from use
at a value exceeding the absolute maximum rating.
5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC Diode Solutions.
6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC
Diode Solutions.
7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will
hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third
party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and
regulations..
很抱歉,暂时无法提供与“SMDA05LCCTR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+4.78162
- 25+3.34186
- 100+3.04241
- 500+2.71062
- 2500+2.46747
- 5000+2.23270
- 10000+2.12011
