SEN0251
SEN0251
    DFROBOT
    SEN0251
SEN0251 数据手册
        Gravity BMP388 Barometric Pressure Sensors SKU:SEN0251   INTRODUCTION This new released BMP388 barometric pressure sensor by DFRobot is equipped with the functionality of temperature and pressure measurement. It supports Arduino code control. Compared with the earlier version of BMP180, BMP280 and BMP388, this sensor exhibits lower power consumption, higher resolution and higher sampling rate. The barometric pressure is usually used to measure barometric pressure and temperature. But besides that, we can also use the sensor to measure the altitude and the relative floor height due to the fact that there is a certain relationship between altitude and barometric pressure. What’s more, BMP388 enables accurate GPS tracking. So with an IMU sensor and BMP388, we can experience 3D indoor positioning and navigation. BMP388 is based on Bosch’s mature Piezo resistive pressure sensor technology featuring high accuracy as well low power consumption and high EMC robustness. The sensor features an accuracy of about ±8Pa, which is equivalent to about ±0.5m difference in altitude, and an absolute accuracy temperature of ±0.5Ԩ for a temperature range between 0Ԩ and 65Ԩ.     FEATURES      Low power consumption Low noise  High resolution  Small dimensions  Best‐in‐class offset temperature coefficient(‐20Ԩ‐65Ԩ@700‐1100hPa)  SPECIFICATION             Operating Voltage: 3.3V‐5.5V Operating Current: 0.5mA  Operating Range: 300‐1250 hPa  Relative Accuracy: ±8 Pa (equivalent to ±0.50m @700‐900hPa, 25Ԩ‐40Ԩ)  Absolute Accuracy: ±50 Pa(0Ԩ‐65Ԩ@300‐1100hPa)  Temperature Coefficient Offset: ±0.75 Pa/K(‐20Ԩ‐65Ԩ@700‐1100hPa)  Absolute Accuracy Temperature: ±0.5Ԩ(@0Ԩ‐65Ԩ)  Operating Temperature: ‐40Ԩ~80Ԩ (more accurate in 0Ԩ‐65Ԩ)  External Dimension: 22mm x 30mm  Mounting Hole Position: 15mm  Mounting Hole Dimension: inside diameter 3mm/ outside diameter 6mm  Interface: Gravity‐IIC 4Pin or SPI (SPI is only used at 3.3V)  SHIPPING LIST   Gravity:BMP388 Barometric Pressure Sensor module           x1 PH2.0‐4P sensor cable        x1                                                            https://www.dfrobot.com/product‐1792.html 11‐12‐18
SEN0251 价格&库存
很抱歉,暂时无法提供与“SEN0251”相匹配的价格&库存,您可以联系我们找货
