SIM7200-6-0-18-00-A
SIM7200-6-0-18-00-A
    GCT
    SMD
    翻盖式 MICROSIM卡 卡座
SIM7200-6-0-18-00-A 数据手册
H 14.70 14.30 Pitch2.54 14.05 6x1.50 2x 1.00 2x 1.20 G 3x 5.50 C1 C6 C2 C7 C3 2.93 3.43 6.35 C5 C1 C6 C2 6x 0.75 3.72 8.00 Material 物料 Plastic Housing 塑胶外壳: LCP, UL94V-0, Black Contact Terminal 接触端子: Phosphor Bronze Metallic Shell 金属外壳: Stainless Steel 6x 1.25 3x 3.89 2x 9.60 C5 Specifications 规格 2.92 3x1.02 E 0.13 3x1.81 15.00 16.35 F 1.30 C7 C3 Plating 电镀 Contact Terminal plating 接触端子部分电镀: Under-plating 底层电镀: 30µ" min. Nickel Contact Area 接触部分: 1µ" min. Gold Soldering Area 焊接部分: 50µ" min. Tin Metallic Shell plating 金属外壳电镀: Under-plating 底层电镀: 30µ" Nickel Soldering Area 焊接部分: 30µ" Nickel Pitch 1.27 6.35 Recommended PCB Layout (Viewed from Component Side - Tolerance:±0.05mm) 0.50 Keep Out Area Component Outline 15.00 1.50 0.70 1.75 Solder Area 1.75 D Electrical 电气 Voltage rating 电压额定值: 30V max. Current Rating 电流额定值: 1.0 Amp max. Contact Resistance 接触电阻值: 100 mΩ max. Insulation Resistance 绝缘电阻值: 1000 MΩ min. Dielectric Withstand Voltage 耐电压: 500 V AC 0.08 C 0.35 Ordering Grid SIM7200 0 00 A Request Samples and Quotation 11.25 Packing Options A = Tape & Reel Locating Peg 00 = Without Part Number Product Description SIM7200 Micro SIM Card Connector Hinged Type, 6 Pin, SMT, 1.75mm Profile Drawing Date 8th September 2016 By Detail 1 2 Mechanical & Environmental 机械 & 环境 Operating Temperature 工作温度: -40°C to +85°C Durabillity 耐久性: 5,000 cycles (1,300 per reel) 0.80 A 18 No. of Contacts 6 Switch 0 = Without Profile Height 18 = 1.75mm 1.40 15.40 B 6 3 4 Revision Date 5 CC Drawing Release A1 14/11/16 Tolerances (Except as Noted) Length X. ± 0.25 X.X ± 0.20 X.XX ± 0.15 Angle Units: Metric (mm) ± 3° C 3rd Angle Projection 6 7 This drawing is confidential and copyright of Global Connector Technology, Ltd (GCT). This drawing must not be copied or disclosed without written consent. E & OE www.gct.co Not to Scale Drawn By AJO 8 Sheet No. 1/4 H 1 2 Slide metal lid from 'LOCK' position to 'OPEN' position Open metal lid to allow Micro SIM card to be inserted G F E 3 4 Place Micro SIM card against contacts, chip face down Close metal lid and slide back to 'LOCK' position D C B Part Number Product Description SIM7200 Micro SIM Card Connector Hinged Type, 6 Pin, SMT, 1.75mm Profile Drawing Date A 8th September 2016 By Detail 1 2 3 4 Revision Date 5 CC Drawing Release A1 14/11/16 Tolerances (Except as Noted) Length Angle X. ± 0.25 X.X ± 0.20 X.XX ± 0.15 ± 3° Units: Metric (mm) C 3rd Angle Projection 6 7 This drawing is confidential and copyright of Global Connector Technology, Ltd (GCT). This drawing must not be copied or disclosed without written consent. E & OE www.gct.co Not to Scale Drawn By AJO 8 Sheet No. 2/4 H Micro SIM Reference thickness = 0.76±0.08 G 25.00mm Mini 15.00±0.10 2.19 12.30mm Nano F 7.62 C1 C5 C2 C6 C3 C7 C4 7.62 8x1.70 D 12.00±0.10 15.00mm Mini E 8.80mm Nano Contact Key C8 C1 VCC C2 RST C3 CLK C4 RFU C5 GND C6 Vpp C7 I/O C8 RFU 2.5C C 8x2.00 5xR0.80 3.15 B Part Number Product Description SIM7200 Micro SIM Card Connector Hinged Type, 6 Pin, SMT, 1.75mm Profile Drawing Date A 8th September 2016 By Detail 1 2 3 4 Revision Date 5 CC Drawing Release A1 14/11/16 Tolerances (Except as Noted) Length Angle X. ± 0.25 X.X ± 0.20 X.XX ± 0.15 ± 3° Units: Metric (mm) C 3rd Angle Projection 6 7 This drawing is confidential and copyright of Global Connector Technology, Ltd (GCT). This drawing must not be copied or disclosed without written consent. E & OE www.gct.co Not to Scale Drawn By AJO 8 Sheet No. 3/4 H Empty 8 pcs min. Part 1300 pcs Empty 5 pcs min. Cover Tape (300mm min.) Part No. Pcs/Reel Reels/Carton Pcs/Carton SIM7200 1300 5 6500 Cover tape Component Supplier G Leader 160mm min. Trailer 100mm min. Reel Cover tape peeling angle 165° to 180° Carrier Tape Label Carrier tape F User Direction of Unreeling PE Bag Peeling Force: 20g to 130g 1.90±0.40 Ø330 Reel x5 12 0° Ø100 E Triangle x4 D Carton 10.50 13 .0 0 Detail B Ø C Detail B 1.75 User Direction of Unreeling 20.00 Ø1 .50 A 18.09 10.82 24.00 B Part Number Product Description SIM7200 Micro SIM Card Connector Hinged Type, 6 Pin, SMT, 1.75mm Profile Drawing Date 8th September 2016 By Detail 1 2 3 4 Revision Date 5 CC Drawing Release A1 14/11/16 Tolerances (Except as Noted) Length Angle X. ± 0.30 X.X ± 0.25 X.XX ± 0.15 X. ± 5° X.X ± 2° X.XX ± 1° 6 Units: Metric (mm) C 3rd Angle Projection 7 This drawing is confidential and copyright of Global Connector Technology, Ltd (GCT). This drawing must not be copied or disclosed without written consent. E & OE www.gct.co Not to Scale Drawn By AJO 8 Sheet No. 4/4
SIM7200-6-0-18-00-A 价格&库存
很抱歉,暂时无法提供与“SIM7200-6-0-18-00-A”相匹配的价格&库存,您可以联系我们找货
SIM7200-6-0-18-00-A
  • 54+12.7025854+1.65000
  • 100+12.15637100+1.57905
  • 250+10.98265250+1.42659
  • 500+10.39325500+1.35003
库存:2277
SIM7200-6-0-18-00-A
  • 1+13.65662
  • 32+10.40561
  • 97+10.34628
  • 260+9.23097
  • 650+8.79197
库存:1109
SIM7200-6-0-18-00-A
    SIM7200-6-0-18-00-A
      • 1+13.96500
      • 10+11.82860
      • 30+10.49580
      库存:50
      SIM7200-6-0-18-00-A
        • 10+7.01480
        库存:787
        SIM7200-6-0-18-00-A
        • 1300+8.017611300+1.04145
        • 2600+7.635092600+0.99176
        • 3900+7.419883900+0.96381
        • 6500+7.157436500+0.92972
        • 9100+6.989709100+0.90793
        库存:10749
        SIM7200-6-0-18-00-A
        • 1+13.762701+1.78790
        • 10+12.0139010+1.56080
        • 25+11.4869025+1.49230
        • 100+10.78020100+1.40050
        • 250+9.73810250+1.26510
        • 500+8.94760500+1.16240
        • 1300+8.061201300+1.04730
        • 2600+7.773702600+1.00990
        • 3900+7.402403900+0.96170
        库存:8487
