UL620-15
UL620-15
    TRIPPLITE
    UL620-15
UL620-15 数据手册
Tripp Lite Waber Industrial Power Strip, 6-Outlet, 15 ft. (4.57 m) Cord, 5-20P Plug MODEL NUMBER: UL620-15 Highlights ● 6 outlets accept NEMA5-15P or 5-20P input plugs ● 15-ft. (4.57 m) cord ● 12.5" length ● 20-amp circuit breaker ● Lighted master switch ● All metal housing Package Includes Description The Waber-by-Tripp Lite UL620-15 Power Strip offers a convenient method of power distribution in workbench, wallmount or floor mount applications. Includes 6 NEMA 5-15R/20R output receptacles with 1.625 inch center-to-center spacing, 15-ft. (4.57 m) AC line cord and keyhole mounting tabs for installation in a wide variety of applications. Corded, multi-outlet strip reduces cabling clutter and enables the connection of multiple electrical devices to a single AC wall socket. Unfiltered electrical pass-through makes UL620-15 ideal for distributing alternate waveform UPS or generator power. Features rugged allmetal housing, lighted power switch with transparent guard to prevent accidental shutoff, 20 amp resettable circuit breaker and attractive blue/gray color scheme. PLUG/OUTLETS - Input: NEMA 5-20P/Output: 6 NEMA 5-15R/20R ELECTRICAL - 120V AC, 50/60Hz, 20A (Requires standard NEMA 5-20R wall receptacle) FORMAT - Corded power distribution strip Features ● Multi-outlet power strip offers convenient power distribution in workbench, wallmount or floor mount applications ● Includes 6 NEMA 5-15R/20R output receptacles with 1.625 inch center-to-center outlet spacing ● Lighted power switch with transparent snap-over guard to prevent accidental shutoff ● Keyhole mounting tabs for installation in a wide variety of applications ● UL1363 (USA), cUL (Canada) ● 20 amp power handling capacity with circuit breaker ● 15-ft. (4.57 m) AC line cord Specifications OVERVIEW UPC Code 037332103703 1/3 ● UL620-15 Power Strip ● Warranty information ● Instruction manual INPUT Nominal Input Voltage(s) Supported 120V AC Recommended Electrical Service 20A 120V Input Cord Gauge Type 12 gauge; SJT Voltage Compatibility (VAC) 120 Input Plug Type NEMA 5-20P Input Cord Length (ft.) 15 Input Cord Length (m) 4.57 Integrated Cord Clip No OUTPUT Frequency Compatibility 50 / 60 Hz Output (Watts) 2400 Output Receptacles (6) 5-15/20R Circuit Breaker (amps) 20 Transformer Accommodation (2) Yes Outlet Orientation Single row of 6 Right-Angle Outlets No Outlet Spacing 1.625 in. USER INTERFACE, ALERTS & CONTROLS Switches Lighted 2 position switch controls power to all outlets Locking Switch Cover Transparent on/off switch cover prevents accidental turn-off PHYSICAL Material of Construction Metal Color Gray Power Cord Color Black Housing Color Blue; Gray Mounting Holes or Slots Yes Slot or Hole Mount Measurement (Center to Center) 261.92mm Outlets Measurement (Center to Center) 41.3mm Receptacle Color Black Shipping Dimensions (hwd / cm) 5.72 x 38.10 x 15.24 Shipping Dimensions (hwd / in.) 2.25 x 15.00 x 6.00 2/3 Shipping Weight (kg) 1.73 Shipping Weight (lbs.) 3.81 Unit Dimensions (hwd / in.) 12.5 x 2.5 x 1.5 Unit Dimensions (hwd / cm) 31.75 x 6.35 x 3.8 Mounting Details Includes flanges FEATURES & SPECIFICATIONS Antimicrobial No Built-In Circuit Breaker Yes STANDARDS & COMPLIANCE Product Certifications cUL Listed; UL 1363; UL Listed Product Compliance RoHS WARRANTY Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 3/3
UL620-15 价格&库存
很抱歉,暂时无法提供与“UL620-15”相匹配的价格&库存,您可以联系我们找货
UL620-15
    库存:3
