IE122312-3
IE122312-3
    DBUNLIMITED
    插件,D=12mm
    IE122312-3
IE122312-3 数据手册
4 3 2 1 Part Number: DRAWN 5/20/2019 CJ IE122312-3 CHECKED 5/21/2019 C.H. Description: Electro-Mechanical Indicator D APPROVED 5/21/2019 C.E. D This document contains data proprietary to DB Unlimited. Any use or reproduction, in any form, without prior written permission of DB Unlimited is prohibited. All terms and conditions can be found at www.dbunlimitedco.com Top View C Side View 11.8 5.5 Bottom View C 7.5 2- 7.6 0.6 Date Code Marking "19 E" 19=2019, E=May Epoxy Wash Tab 1.5 2.5 Sound Emission Hole 0.5 B A B Items Specifications Conditions Min. Sound Pressure Level 83 dB (@ 10cm) Tone Single Resonant Frequency 2,300 Hz Rated Voltage 12 V Voltage Range 8 ~ 16 V Max. Rated Current 30 mA Storage Temperature -40 ~ +90 C Operating Temperature -40 ~ +85 C Connection Method PC Pins Mount Type Thru Hole Housing Material PBT Weight 1.8 4 REVISION HISTORY REV 1 DESCRIPTION DATE APPROVED Released from Engineering 10/21/0213 J.S. 5/21/2019 C.E. Updated drawing template, temps, voltage range, diameter, pin length, housing, weight NOTES 1) All dimensions are in mm unless otherwise noted 2) All tolerances are 0.5 mm unless otherwise noted 3) All parts meet RoHS g 3 4) Subject to change or redrawn without notice 2 1 A
IE122312-3 价格&库存
很抱歉,暂时无法提供与“IE122312-3”相匹配的价格&库存,您可以联系我们找货
