CS16511_HB-IP-2X6-G2-W
    LEDIL(芬兰)
CS16511_HB-IP-2X6-G2-W 数据手册
PRODUCT DATASHEET CS16511_HB-IP-2X6-G2-W HB-IP-2X6-G2-W ~60° wide beam TECHNICAL SPECIFICATIONS: Dimensions Height Fastening 172.0 x 71.0 mm 8.2 mm pin, screw Ingress protection classes ROHS compliant IP67 yes MATERIAL SPECIFICATIONS: Component Type Material Colour HB-IP-2X6-G2-W Multi-lens PMMA clear SEAL-IP-2X6-G2 Seal Silicone white Finish ORDERING INFORMATION: Component CS16511_HB-IP-2X6-G2-W » Box size: 476 x 273 x 247 mm Qty in box Multi-lens 132 MOQ MPQ 44 44 Box weight (kg) 5.8 Last update: 13/04/2022 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 1/10 PRODUCT DATASHEET CS16511_HB-IP-2X6-G2-W See also our general installation guide: www.ledil.com/installation_guide Last update: 13/04/2022 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/10 PRODUCT DATASHEET CS16511_HB-IP-2X6-G2-W PHOTOMETRIC DATA (MEASURED): LED XP-L2 FWHM / FWTM 66.0° / 89.0° Efficiency 94 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON 5050 Round LES FWHM / FWTM 63.0 + 64.0° / 80.0 + 81.0° Efficiency 97 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED NVSW519A FWHM / FWTM 68.0° / 84.0° Efficiency 98 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED HiLOM RM12 ZP (LH502C) FWHM / FWTM 66.0° / 82.0° Efficiency 97 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 13/04/2022 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/10 PRODUCT DATASHEET CS16511_HB-IP-2X6-G2-W PHOTOMETRIC DATA (MEASURED): LED ROY-S26XPL2 (XP-L2) FWHM / FWTM 66.0° / 89.0° Efficiency 94 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED 2x6 5050 module - SMJD-3625012F-XX FWHM / FWTM 68.0° / 85.0° Efficiency 94 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED Z5M3 FWHM / FWTM 63.0° / 76.0° Efficiency 94 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 13/04/2022 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/10 PRODUCT DATASHEET CS16511_HB-IP-2X6-G2-W PHOTOMETRIC DATA (SIMULATED): LED Bridgelux SMD 5050 FWHM / FWTM 62.0° / 81.0° Efficiency 94 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour White Required components: LED J Series 5050 Round LES FWHM / FWTM 62.0° / 79.0° Efficiency 95 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour White Required components: LED J Series 5050 Square LES 6V FWHM / FWTM 62.0° / 78.0° Efficiency 95 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour White Required components: LED MHB-A/B FWHM / FWTM 65.6° / 90.3° Efficiency 94 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 13/04/2022 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/10 PRODUCT DATASHEET CS16511_HB-IP-2X6-G2-W PHOTOMETRIC DATA (SIMULATED): LED XP-G2 FWHM / FWTM 63.0° / 77.0° Efficiency 94 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-G2 HE FWHM / FWTM 66.0° / 84.0° Efficiency 94 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-G3 FWHM / FWTM 62.4° / 78.1° Efficiency 92 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour White Required components: LED NFMW48xA FWHM / FWTM 62.4° / 82.8° Efficiency 94 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 13/04/2022 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/10 PRODUCT DATASHEET CS16511_HB-IP-2X6-G2-W PHOTOMETRIC DATA (SIMULATED): LED NV4WB35AM FWHM / FWTM 68.0° / 86.0° Efficiency 95 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour White Required components: LED PrevaLED Brick HP IP 2x6 FWHM / FWTM 62.0° / 75.0° Efficiency 94 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour White Required components: LED Duris S8 FWHM / FWTM 58.3° / 77.5° Efficiency 94 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSCONIQ P 3030 FWHM / FWTM 58.0° / 66.0° Efficiency 95 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 13/04/2022 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/10 PRODUCT DATASHEET CS16511_HB-IP-2X6-G2-W PHOTOMETRIC DATA (SIMULATED): LED OSCONIQ P 3737 (2W version) FWHM / FWTM 62.0° / 78.0° Efficiency 94 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour White Required components: LED LH351B FWHM / FWTM 65.0° / 82.0° Efficiency 94 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED LH502C FWHM / FWTM 64.0° / 80.0° Efficiency 95 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED LH508A FWHM / FWTM 60.9° / 80.0° Efficiency 93 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 13/04/2022 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/10 PRODUCT DATASHEET CS16511_HB-IP-2X6-G2-W PHOTOMETRIC DATA (SIMULATED): LED Z5M1/Z5M2 FWHM / FWTM 63.0° / 76.0° Efficiency 94 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour White Required components: LED Z8Y22T FWHM / FWTM 56.0° / 68.0° Efficiency 94 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 13/04/2022 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/10 PRODUCT DATASHEET CS16511_HB-IP-2X6-G2-W GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 13/04/2022 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 10/10
物料型号:CS16511_HB-IP-2X6-G2-W
器件简介:这是一个多透镜LED光学器件,具有60°的宽光束角,尺寸为172.0 x 71.0 mm,高度8.2 mm,并且具有IP67的防护等级。
引脚分配:文档中没有提供具体的引脚分配信息。
参数特性:提供了不同LED制造商的光度数据,包括CREE、SAMSUNG、LUMILEDS、NICHIA等,展示了它们的光束角度、效率、峰值强度等参数。
功能详解:文档提供了详细的光度数据,包括实际测量和模拟的光度数据,以及所需的组件信息。
应用信息:文档没有明确提供应用信息,但根据产品描述,它可能适用于需要宽光束照明的应用。
封装信息:封装材料包括PMMA(聚甲基丙烯酸甲酯)和硅胶,颜色为透明和白色。
CS16511_HB-IP-2X6-G2-W 价格&库存
很抱歉,暂时无法提供与“CS16511_HB-IP-2X6-G2-W”相匹配的价格&库存,您可以联系我们找货
