1978-DP
1978-DP
    TECHSPRAY
    1978-DP
1978-DP 数据手册
Rev. A (11/17) Page 1 of 1 Silicone-Free Heat Sink Compound Product# 1978 Product Description Silicone-Free Heat Sink Compound draws heat away when applied to a component. In electronics, heat sink compound is generally used to thermally bond a component with a mechanical heat sink. For electrical applications, it is used with thermocouple wells, thermistors, and calrods, or wherever efficient cooling is required. Ideal for electronic applications where silicone contamination hurts solder ability and increase solder defects. Features / Benefits • Thermal conductivity - 0.92 W/m-K • Functional temperature range -40°F to 392°F (-40°C to 200°C) • Non-ozone depleting • Avoid solder defects due to silicon contamination • Easy application • Will not separate, harden or crack Typical Product Data and Physical Properties Packaging and Availability 1978-DP 1978-1 4 oz. tube, 24 tubes / case 1 pound jar, 12 jars / case Environmental Policy Techspray® is committed to developing products to ensure a safer and cleaner environment. We will continue to meet and sustain the regulations of all federal, state and local government agencies. Physical state: Solid (paste) Flash point: Closed cup: 564.8ºF (296ºC) Color: Gray Boiling/condensation point: 399.2ºF (204ºC) Vapor pressure: 0.013 kPa (0.1mmHg) Evaporation rate: 0.01 (butyl acetate = 1) Shelf life: 5 years Resources Techspray® products are supported by global sales, technical and customer services resources. For additional technical information on this product or other Techspray® products in the United States, call the technical sales department at 800-858-4043, email tsales@techspray.com or visit our web site at: www.techspray.com. Important Notice to Purchaser/User: The information in this publication is based on tests that we believe are reliable. The results may vary due to differences in tests type and conditions. We recommend that each user evaluate the product to determine its suitability for the intended application. Conditions of use are outside our control and vary widely. Techspray’s only obligation and your only solution is replacement of product that is shown to be defective when you receive it. In no case will Techspray® be liable for any special, incidental, or consequential damages based on breach of warranty, negligence or any other theory. North America Techspray® 8125 Cobb Center Drive Kennesaw, GA 30152 800-858-4043 tsales@techspray.com Europe ITW Contamination Control BV Saffierlaan 5, 2132 VZ Hoofddorp The Netherlands +31 88 1307 400 info@itw-cc.com Countries outside the US Call to locate a distributor in your country
1978-DP 价格&库存
很抱歉,暂时无法提供与“1978-DP”相匹配的价格&库存,您可以联系我们找货
