GMC80800
GMC80800
    SPRAGUE-GOODMAN
    175PF~680PF 250V
GMC80800 数据手册
Sprague-Goodman ENGINEERING BULLETIN SG-500D Supercedes SG-500C MICA DIELECTRIC COMPRESSION TRIMMER CAPACITORS FEATURES • Very large capacitance ranges • Good RF current handling capability • High Q • Many forms and mounting styles SPECIFICATIONS Operating Temperature Range: –35°C to +85°C Maximum Capacitance: When set at the tight position (tight defined as 28 oz-in/2.0 kg-cm), the maximum capacitance will be no less than the value indicated in the table. Minimum Capacitance: When adjusting screw is rotated 3 turns from tight position (2 turns for types 1, 5, and 9), the minimum capacitance will be no greater than the value indicated in the table. Voltage: Working (VDC) Dielectric Withstanding (VDC) Type 1 250 500 Types 2, 3, 4 175 350 Type 5 500 1000 Types 6, 7, 8 250 500 Type 9 2000 2700 Capacitance change with temperature (capacitor set at 1/4 to 1/2 turn from the tight position): Types 1, 5, 9 = ± (2.5% + 0.3 pF) Types 2, 3, 4, 6, 7, 8 = ± (1.5% + 0.3 pF) Capacitance drift with temperature (capacitor set at 1/4 to 1/2 turn from the tight position): Types 1, 5, 9 = ± (2.0% + 0.5 pF) Types 2, 3, 4, 6, 7, 8 = ± (1.5% + 0.5 pF) Q vs Capacitance (1 MHz) 1,000 Q 100 Insulation Resistance: 100,000 megohms min at 25°C Q: Minimum Q at 1 MHz per graph (for units which have nominal maximum capacitance ≤ 1000 pF). Dissipation Factor: Maximum DF = 0.004 at 1 kHz (for units which have nominal maximum capacitance > 1000 pF). 10 1 10 100 Capacitance (pF) Sprague-Goodman Electronics, Inc. 1700 SHAMES DRIVE, WESTBURY, NY 11590 TEL: 516-334-8700 • FAX: 516-334-8771 E-MAIL: info@spraguegoodman.com 1,000 MICA DIELECTRIC TRIMMER CAPACITORS SG-500D PART NUMBERING SYSTEM GM A 2 Mica Dielectric A = Bracket mount for wired assembly B = Printed circuit mount, top adjust, 4 terminals C = Printed circuit mount, top adjust, 2 terminals D = Printed circuit mount, side adjust, 2 terminals E = Panel mount, 1/4” long bushing F = Panel mount, 3/16” long bushing G = Panel mount, 9/32” long bushing H = Panel mount, 3/16” long split bushing Types 2 and 6 1 Code MODIFICATIONS 23.8) 13.5) 19.1) 19.1) 23.8) 13.5) 19.1) 19.1) 23.8) 00 = Standard* 01 = Mica Insulated Screw 02 = Ceramic Insulated Screw 03 = Guide Cup for Screw (Types 2, 3, 4, 6, 7 and 8) 04 = Guide Cup and Mica Insulated Screw *Types 1, 5, and 9 are normally supplied with mica insulated screw (Mod 01) Symbol 1 2 3 4 5 6 7 8 9 = = = = = = = = = Size (in/mm) 0.875 0.375 0.375 0.625 0.875 0.375 0.375 0.625 0.875 x x x x x x x x x 0.938 0.531 0.750 0.750 0.938 0.531 0.750 0.750 0.938 (22.2 (9.53 (9.53 (15.9 (22.2 (9.53 (9.53 (15.9 (22.2 x x x x x x x x x Types 3 and 7 Capacitance Range (pF) min max 2.5 12 3.5 25 7.0 40 16.0 100 25.0 150 40.0 200 56.0 250 75.0 300 95.0 350 115.0 400 130.0 450 150.0 500 170.0 550 200.0 600 220.0 650 240.0 700 Model No.1 GM — 20000 GM — 20200 GM — 20300 GM — 20400 GM — 20500 GM — 20600 GM — 20700 GM — 20800 Insert letter A, B, C, or D in blank space for mounting style required. For type 6, substitute 6 for 2 in the fourth character of the catalog number. Example: GMA20200 becomes GMA60200 2 2 00 TYPE MOUNTING STYLES Capacitance Range (pF) min max 2.5 7 4 20 8 45 12 65 16 90 25 115 55 285 90 340 00 Types 4 and 8 Capacitance Range (pF) min max 3 15 5 30 10 80 20 180 45 280 75 380 105 480 140 580 175 680 215 790 260 900 300 1000 330 1100 360 1200 380 1300 420 1400 Model No.2 GM — 30000 GM — 30100 GM — 30200 GM — 30300 GM — 30400 GM — 30500 GM — 30600 GM — 30700 GM — 30800 GM — 30900 GM — 31000 GM — 31100 GM — 31200 GM — 31300 GM — 31400 GM — 31500 Insert letter A, B, C, or D in blank space for mounting style required. For type 7, substitute 7 for 3 in the fourth character of the catalog number. Example: GMA30200 becomes GMA70200 3 Model No.3 GM — 40000 GM — 40100 GM — 40200 GM — 40300 GM — 40400 GM — 40500 GM — 40600 GM — 40700 GM — 40800 GM — 40900 GM — 41000 GM — 41100 GM — 41200 GM — 41300 GM — 41400 GM — 41500 Insert letter A, B, C, or D in blank space for mounting style required. For type 8, substitute 8 for 4 in the fourth character of the catalog number. Example: GMA40200 becomes GMA80200 SPRAGUE-GOODMAN ELECTRONICS, INC., 1700 SHAMES DRIVE, WESTBURY, NY 11590 • TEL: 516-334-8700 • FAX: 516-334-8771 • E-MAIL: info@ spraguegoodman.com MICA DIELECTRIC TRIMMER CAPACITORS SG-500D SPRAGUE-GOODMAN MICA DIELECTRIC TRIMMER CAPACITORS TYPES 2, 3 and 4 (175 WVDC) TYPES 6, 7 and 8 (250 WVDC) Mounting Style A Mounting Style B L L W W 0.078 DIA TYP 2.0 F B 2 B D DIA B 2 H 0.313 7.94 F 2 H E B 0.156 3.97 0.063 1.6 D DIA (WHEN REQUIRED) 0.188 4.76 SUGGESTED HOLE LAYOUT FOR MOUNTING BRACKET SUGGESTED PRINTED CIRCUIT LAYOUT Mounting Style C Mounting Style D L L W W H2 0.094 DIA TYP 2.4 F G H1 H F 2 D DIA (WHEN REQUIRED) 0.063 1.59 0.172 4.37 SUGGESTED PRINTED CIRCUIT LAYOUT SUGGESTED PRINTED CIRCUIT LAYOUT Type L W H H1 H2 B D E F G 2&6 0.531 ––––– 13.5 0.375 ––––– 9.53 0.719 ––––– 18.3 0.563 ––––– 14.3 0.719 ––––– 18.3 0.315 ––––– 8.00 0.175 ––––– 4.45 0.188 ––––– 4.76 0.563 ––––– 14.3 0.594 ––––– 15.1 3&7 0.750 ––––– 19.1 0.375 ––––– 9.53 0.781 ––––– 19.8 0.625 ––––– 15.9 0.625 ––––– 15.9 0.315 ––––– 8.00 0.175 ––––– 4.45 0.188 ––––– 4.76 0.813 ––––– 20.6 0.781 ––––– 19.8 4&8 0.750 ––––– 19.1 0.625 ––––– 15.9 0.781 ––––– 19.8 0.563 ––––– 14.3 0.969 ––––– 24.6 0.546 ––––– 13.9 0.206 ––––– 5.23 0.281 ––––– 7.14 0.813 ––––– 20.6 0.813 ––––– 20.6 Dimensions are in/mm. SPRAGUE-GOODMAN ELECTRONICS, INC., 1700 SHAMES DRIVE, WESTBURY, NY 11590 • TEL: 516-334-8700 • FAX: 516-334-8771 • E-MAIL: info@ spraguegoodman.com 3 MICA DIELECTRIC TRIMMER CAPACITORS SG-500D SPRAGUE-GOODMAN MICA DIELECTRIC TRIMMER CAPACITORS TYPES 1, 5 and 9 0.203 + 0.016 TYP 5.16 + 0.40 A THD 0.406 + 0.031 10.3 + 0.79 0.875 + 0.031 22.2 + 0.79 0.188 4.76 HEX NUT 0.156 3.97 0.938 + 0.031 23.8 + 0.79 X X 0.063 TYP 1.59 L SPLIT BUSHING DETAIL 0.344 + 0.016 8.73 + 0.40 0.156 + 0.016 3.97 + 0.40 0.031 + 0.016 0.79 + 0.40 0.500 MAX 13.0 Style L A (Thread) Special Feature E 0.250 ––––– 6.35 #12 - 40 UNS - 2 None F 0.188 ––––– 4.76 1/4 - 40 G 0.281 ––––– 7.14 H 0.188 ––––– 4.76 0.281 + 0.031 7.14 + 0.79 L 0.125 3.18 UNS - 2 None 1/4 - 40 UNS - 2 None 1/4 - 40 UNS - 2 Split Bushing Dimensions are in/mm. Type 1 Working Voltage: Test Voltage: Capacitance Range (pF) min max 15 130 65 340 115 550 190 760 275 970 350 1180 450 1390 550 1600 650 1890 780 2110 880 2330 1150 2605 1300 2830 1400 3055 4 4 Type 5 250 VDC 500 VDC Model No.4 GM — 10201 GM — 10301 GM — 10401 GM — 10501 GM — 10601 GM — 10701 GM — 10801 GM — 10901 GM — 11001 GM — 11101 GM — 11201 GM — 11301 GM — 11401 GM — 11501 Working Voltage: Test Voltage: Capacitance Range (pF) min max 15 120 65 320 100 500 180 690 265 880 340 1070 425 1260 525 1415 615 1600 730 1785 800 1970 1000 2155 1100 2340 1200 2525 Type 9 500 VDC 1000 VDC Model No.4 GM — 50201 GM — 50301 GM — 50401 GM — 50501 GM — 50601 GM — 50701 GM — 50801 GM — 50901 GM — 51001 GM — 51101 GM — 51201 GM — 51301 GM — 51401 GM — 51501 Working Voltage: Test Voltage: Capacitance Range (pF) min max 10 48 45 105 70 160 95 230 100 270 170 350 190 380 250 480 2000 VDC 2700 VDC Model No.4 GM — 90201 GM — 90301 GM — 90401 GM — 90501 GM — 90601 GM — 90701 GM — 90801 GM — 90901 Insert letter E, F, G or H in blank space for mounting style (Style H not available in Type 9). Model numbers are shown with the “01” modification, calling for a mica insulated screw, which is the way types 1, 5, and 9 are normally supplied. SPRAGUE-GOODMAN ELECTRONICS, INC., 1700 SHAMES DRIVE, WESTBURY, NY 11590 • TEL: 516-334-8700 • FAX: 516-334-8771 • E-MAIL: info@ spraguegoodman.com ©1999 SPRAGUE-GOODMAN ELECTRONICS, INC., ALL RIGHTS RESERVED. PRINTED IN U.S.A. 59903
GMC80800
物料型号:SG-500D
器件简介:SG-500D是一种压缩式电容器,具有以下特点: - 非常大的电容范围 - 良好的射频电流处理能力 - 高Q值 - 多种形式和安装风格
引脚分配:文档中没有提供具体的引脚分配信息。
参数特性: - 工作温度范围:-35°C至+85°C - 电容随温度变化:在紧固位置1/4至1/2圈时,最大电容不低于表中指示的值。 - 电容漂移:在紧固位置调整螺丝旋转3圈时(类型1、5和9旋转2圈),最小电容不超过表中指示的值。 - 电压:工作电压和介质耐压值根据类型不同而有所差异。 - 绝缘电阻:最小100,000兆欧姆,在25°C时。 - Q值:1MHz时,对于标称最大电容≤1000pF的单位,最小Q值。 - 耗散因子:1kHz时,对于标称最大电容>1000pF的单位,最大DF为0.004。
功能详解:文档提供了详细的电容器规格和性能参数,但没有提供具体的功能描述。
应用信息:文档没有明确说明应用信息,但根据其特性,这些电容器可能用于需要精确电容调整的射频应用。
封装信息:提供了多种安装风格和尺寸,包括支架安装、印刷电路板安装和面板安装等。
GMC80800 价格&库存
很抱歉,暂时无法提供与“GMC80800”相匹配的价格&库存,您可以联系我们找货
