Specification
Part No.
GWLA.05
Description
GPS L1 & Bluetooth / 2.4GHz Wi-Fi
Embedded 2in1 Ceramic Loop Antenna
Features
10 * 3.2 * 1.5mm
GPS L1 and Wi-Fi 2.4GHz Applications
Simplifies GPS/2.4GHz Circuits
Two Separate Feeds on one Chip Antenna
Low Profile, Small Footprint Antenna
SMD Surface-mount
RoHS & REACH Compliant
SPE-19-8-003-A
Page 1 of 29
1. Introduction
The Taoglas GWLA.05, GPS L1 /2.4GHz embedded loop antenna is a high efficiency,
miniature SMD, edge mounted ceramic antenna for GPS and 2.4GHz Wi-Fi, WLAN,
Zigbee, Bluetooth, and 802.11 applications. Customers can use this antenna for GPS
and 2.4GHz (Wi-Fi or Bluetooth) modules, rather than using two separate antennas.
The GWLA.05 has two separate antenna feeds, making it the ideal choice for
applications where there is limited PCB space. The GWLA.05 uses the main PCB as its
ground plane, thereby maintaining good efficiency despite its small size. It can be
tuned for different PCB sizes/environments by simply changing the values of the
matching circuit. It is ideally mounted on the center edge of a ground-plane.
At 10*3.2*1.5mm, the GWLA.05 is one of the smallest combination embedded
antennas available worldwide. This antenna is delivered on tape and reel.
Typical Applications – where both GPS and 2.4GHz are required:
Navigation or Position Tracking Systems
Handheld Devices
Tablet PCs
OBD Devices
Gateways and Routers
Mobile Cameras
UAV Communication Systems
Many module manufacturers specify peak gain limits for any antennas that are to be
connected to that module. Those peak gain limits are based on free-space conditions.
In practice, the peak gain of an antenna tested in free-space can degrade by at least
1 or 2 dBi when put inside a device. So ideally you should go for a slightly higher peak
gain antenna than mentioned on the module specification to compensate for this
effect, giving you better performance.
Upon testing of any of our antennas with your device and a selection of appropriate
layout, integration technique, or cable, Taoglas can make sure any of our antennas'
peak gain will be below the peak gain limits. Taoglas can then issue a specification
and/or report for the selected antenna in your device that will clearly show it
complying with the peak gain limits, so you can be assured you are meeting regulatory
requirements for that module.
SPE-19-8-003-A
Page 2 of 29
For example, a module manufacturer may state that the antenna must have less than
2 dBi peak gain, but you don't need to select an embedded antenna that has a peak
gain of less than 2 dBi in free-space. This will give you a less optimized solution. It is
better to go for a slightly higher free-space peak gain of 3 dBi or more if available.
Once that antenna gets integrated into your device, performance will degrade below
this 2 dBi peak gain due to the effects of GND plane, surrounding components, and
device housing. If you want to be absolutely sure, contact Taoglas and we will test.
Choosing a Taoglas antenna with a higher peak gain than what is specified by the
module manufacturer and enlisting our help will ensure you are getting the best
performance possible without exceeding the peak gain limits.
SPE-19-8-003-A
Page 3 of 29
2. Specification
ELECTRICAL
Application Bands
GPS L1
Wi-Fi /Bluetooth
Frequency (MHz)
1575.42
2400-2500
Bandwidth (MHz)
Ground plane size (mm)
Peak Gain (dBi)
Efficiency (%)
20 (RL
很抱歉,暂时无法提供与“GWLA.05”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+33.666801+4.35333
