CW8300
CW8300
    CHEMTRONICS
    CW8300
CW8300 数据手册
Rev. C (7/18) Page 1 of 2 CircuitWorksâ Water Soluble Flux Dispensing Pen Product# CW8300 Product Description CircuitWorks Water Soluble Flux Pen is designed specifically to apply water soluble flux with precision control. The Water Soluble Flux consists of a neutral pH organic water soluble flux compatible with most solder masks. The high activity organic product cleans easily with water, reducing cleaning cost • • • • • • pH neutral Completely portable package Cleans with water Excellent material compatibility Good soldering properties ORH1 Classification Typical Applications CircuitWorks Flux Dispensing Pens precisely dispense flux on: • • • • • • Printed Circuit Boards Chip Carriers Heat Sinks Surface Mount Device Pads Switches Sockets Typical Product Data and Physical Properties Flux Type: Flash Point (TCC): pH: Appearance: Odor: Shelflife Water Soluble ORH1 60oF (16oC) 6.0 – 7.0 Yellow liquid Slight 2 years RoHS Compliant Yes Reliability Properties Copper Mirror Corrosion: High Tested to J-STD-004, IPC TM-650, Method 2.3.32 Corrosion Test: High Tested to J-STD-004, IPC-TM-650, Method 2.6.15 Silver Chromate: Fail Tested to J-STD-004, IPC-TM-650, Method 2.3.33 Chloride and Bromides: 2.2% Tested to J-STD-004, IPC-TM-650, Method 2.3.35 Fluorides by Spot Test: Pass Tested to J-STD-004, IPC-TM-650, Method 2.3.35.1 SIR, IPC (typical): Pass Tested to J-STD-004, IPC-TM-650, Method 2.6.3.3 1-770-424-4888 Ÿ www.chemtronics.com Rev. C (7/18) Page 2 of 2 CircuitWorksâ Water Soluble Flux Dispensing Pen Product# CW8300 Compatibility CircuitWorks Water Soluble Flux Pen is generally compatible with most materials used in the electronics industry. As with any cleaning agent, material compatibility should be determined on a non-critical area prior to use. Availability CW8300 9g / 0.32 oz. Flux Pen Environmental Impact Data ODP HCFC VOC HFC None None Yes None Usage Instructions For industrial use only. Read SDS carefully prior to use. Flux Application: Water Soluble Flux should only be applied to areas to be soldered. Hold pen vertically, touch surface of PCB and briefly depress tip to start liquid flow. Lightly wipe pen tip over surface to be fluxed. Use a ControlWipe dry wipe to remove flux buildup. Cleaning: Flux residues must be removed after soldering as they are conductive and corrosive. No neutralizer, saponifiers or detergent are necessary for complete removal of flux residues. It is not recommended to use high mineral content tap water, therefore deionized or softened water may be used for cleaning. The optimum water temperature is 54-66oC (130-150oF). Chemtronics Flux-Off Water Soluble may also be used as a flux remover. Technical and Application Assistance Chemtronics provides a technical hotline to answer your technical and application related questions. The toll free number is: 1-800-TECH-401. Note: This information is believed to be accurate. It is intended for professional end users having the skills to evaluate and use the data properly. CHEMTRONICS does not guarantee the accuracy of the data and assumes no liability in connection with damages incurred while using it. Chemtronicsâ, Flux-Offâ and CircuitWorksâ are registered trademarks of Chemtronics. All rights reserved. ControlWipesÔ is a trademark of Chemtronics. All rights reserved. . 8125 Cobb Center Drive, Kennesaw, GA 30152 Ÿ 1-770-424-4888 Ÿ www.chemtronics.com 1-770-424-4888 Ÿ www.chemtronics.com
CW8300 价格&库存
很抱歉,暂时无法提供与“CW8300”相匹配的价格&库存,您可以联系我们找货
