Group
RI-80 SMDM Series Molded Dry Reed Switch
RI-80 SMDM Series
The RI-80 SMDM is a Single-pole, Single-throw (SPST) dry reed switch,
having normally open contacts, and two magnetically actuated reeds.
The switch is of the double-ended type and may be actuated by an
electromagnet, a permanent magnet or a combination of both.
The RI-80 SMDM is available in Gull wing and J-Bend lead configurations.
RI-80 SMDM Series Features
▪ Ideal for proximity sensors & medical applications
▪ Contact layers: gold, sputtered ruthenium
▪ 5 Watt rating
▪ Tape & reel packaging
Dimensions for RI-80 SMDM Series
All Dimension in inches (mm) nominal
.252 (6.4 MAX)
.275 (7.0 MAX)
.004 ± .002
(0.1 ± 0.05
.095
(2.4 MAX)
.095
(2.4 MAX)
.004 ± .001
(0.1 ± 0.05
.185 ± .008 (4.7 ± 0.2)
.376 ± .008 (9.5 ± 0.2)
.295 ± .008 (7.5 ± 0.2)
.037 ± .004
(0.95 ± 0.1)
.037 ± .004 (0.95 ± 0.1)
.091
(2.3 MAX)
.091
(2.3 MAX)
G-1 Model
J-1 Model
Technical Specifications
Parameters
Units
RI-80 SMDM
Operate Range
AT
5-15*
Release Range
AT
2-13*
Switched Power (max)
W
5
Switched Voltage DC (max)
V
175
Operating Characteristics
Electrical Characteristics
Switched Voltage AC, RMS value (max)
V
140
Switched Current DC (max)
mA
350
Switched Current AC, RMS value (max)
mA
250
Carry Current DC (max)
A
0.5
Breakdown Voltage DC (min)
V
230**
Contact Resistance (initial max.)
mΩ
160
Contact Resistance (initial typ.)
mΩ
140
Insulation Resistance (min)
MΩ
106
Storage Temperature
°C
-40 to +125
Operating Temperature
°C
-40 to +125
Vibration Resistance
G
10
Shock Resistance
G
100
Environmental Ratings
NOTES: * AT values are based on full length, measured using Philips Standard Coil (PSC).
** 230V for AT>10, 175V for AT
很抱歉,暂时无法提供与“RI80SMDM-0510-G1”相匹配的价格&库存,您可以联系我们找货
