Gravity: I2C Digital Wattmeter
SKU:SEN0291
Introduction
Gravity: I2C Digital Wattmeter is a high-resolution, high-precision, large-scale
measurement module that can measure the voltage, current and power of various
electronic modules and electrical equipment within 26V 8A, and the maximum relative
error is less than ±0.2% (A simple manual calibration is required before usage). It can be
used for power consumption or battery life evaluation of solar energy systems, battery,
motors, controller or electronic modules.
The module adopts TI INA219 zero temperature drift current/power monitoring chip
and 2W high power low temperature drift 10mΩ alloy sampling resistor. The voltage
and current resolution can reach 4mV and 1mA respectively. Under the full scale
measurement condition, the maximum relative error of voltage and current
measurement is lower than ±0.2%. It provides also four I2C addresses that can be
configured via the 2P DIP switch. The module accurately measures bi-directional high-
side currents (current flowing through the power supply or battery positive), which is
especially useful in solar or battery fuel gauge applications where the battery needs to
be charged and discharged. This status can be simply determined by positive or
negative current readings. In the motor applications, the current can be monitored in
real time by monitoring whether the motor current is too large due to overload. In
addition, you can use this module to measure the power consumption of various
electronic modules or the entire project to evaluate battery life.
Features
High precision, high resolution, large range, low temperature drift
Bidirectional current high side measurement
Compatible with 3.3V/5V controller
Sophisticated and compact, easy to embed in the project
Application
Solar Power Management
Battery Fuel Gauge
Electronic Module Power Evaluation
Specification
Input Voltage (VCC) : 3.3V~5.5V
o Voltage Range (IN+ or IN- relative to GND): 0 ~ 26 V
o
Voltage Resolution: 4 mV
o
Voltage Relative Error:
很抱歉,暂时无法提供与“SEN0291”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+63.194651+8.21510
- 国内价格 香港价格
- 1+62.053061+8.06670
