CT4028
39 kV High
Voltage Probe
Datasheet
Specifications
Operating Parameters
Maximum Input Voltage
(CAT I)
39 kV (DC + ACpk)
27 kVrms AC
Maximum Loading
1000:1
Current
45 µA
Division Ratio
1000:1
Bandwidth
DC to 220 MHz
Compensation Range
10 pF to 35 pF
Temperature Coefficient
≤200 ppm/ºC
Input Resistance
900 MΩ
Input Capacitance
2.0 pF
Rise Time
1.6 ns
Signal/Noise
> 60 dB @ 1 kHz
> 50 dB @ 1 MHz
Accuracy
DC Volts
≤3% (0 to 35 kV)
AC Volts
≤3% at 1 kHz
General
Overview:
The Cal Test Electronics CT4028 is a 39 kV high
voltage divider probe for use with both digital and
analog oscilloscopes.
Features:
Input voltage of 39 kV (DC+ACpk)
220 MHz bandwidth
Voltage dividing of 1000:1
Frequency compensation
Technical data subject to change.
© Cal Test Electronics 2017.
Cable Length
6.6 ft (2 m)
Designed for Use in
Pollution Degree 2
Operating Temperature
14ºF to 131ºF
(-10ºC to 55ºC)
Storage Temperature
-4ºF to 158ºF
(-20ºC to 70ºC)
Humidity
≤85% relative
humidity at 95ºF
(35ºC)
Dimensions
3.1 x 3.1 x 12.6 in
(8 x 8 x 32 cm)
Weight
1.0 lbs (460 g)
Warranty
One-year warranty
caltestelectronics.com
很抱歉,暂时无法提供与“CT4028”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+8731.928421+1126.49071
