CT4024
CT4024
    CALTESTELECTRONICS
    CT4024
CT4024 数据手册
CT4024 Datasheet 8 kV High Voltage Probe Overview: Features: The CT4024 is a 8 kV high voltage divider probe for use with both digital and analog oscilloscopes. ■■ ■■ ■■ Kit Contents: ■■ ■■ ■■ ■■ Input voltage of 8 kV (DC+ACpk) 40 MHz bandwidth Voltage dividing of 1000:1 Frequency compensation Probe Hook tip Flat bar tip Technical data subject to change. © Cal Test Electronics 2017. caltestelectronics.com All specifications apply to the unit after a temperature stabilization time of 20 minutes over an ambient temperature range of 25 °C ± 5 °C. Specifications Maximum Input Voltage (CAT I) 8 kV (DC + ACpk) 6 kVrms AC Division Ratio 1000:1 Bandwidth 40 MHz (-3 dB) Compensation Range 5 pF to 50 pF Temperature Coefficient ≤200 ppm/ºC Input Resistance 100 MΩ ± 5% Rise Time ≤9 ns DC Volts ±3% (below 8 kV) AC Volts ±3% at 1 kHz ±3 dB 0 to 40 MHz Cable Length 6.6 ft (2 m) Designed for Use in Pollution Degree 2 Operating Environment 32ºF to 122ºF (0ºC to 50ºC) Storage Temperature -4ºF to 158ºF (-20ºC to 70ºC) Humidity ≤80% relative humidity at 104ºF (40ºC) Dimensions 8.3 in (21 cm) Weight 0.40 lbs (180 g) Warranty One-year warranty Specifications are subject to change without notice. To ensure the most current version of this manual, please download the current version from our website: caltestelectronics.com Technical data subject to change. © Cal Test Electronics 2017. caltestelectronics.com
CT4024 价格&库存
很抱歉,暂时无法提供与“CT4024”相匹配的价格&库存,您可以联系我们找货
CT4024
    库存:1
    CT4024
    • 1+3375.989391+437.59250
    • 3+3255.421453+421.96460
    库存:1
