CT4025
10 kV High
Voltage Probe
Datasheet
Specifications
Operating Parameters
Maximum Input Voltage
(CAT I)
10 kV (DC + ACpk)
7 kVrms AC
Maximum Loading Current
100 µA
Division Ratio
100:1
Bandwidth
DC to 120 MHz
Compensation Range
10 pF to 35 pF
Temperature Coefficient
≤200 ppm/ºC
Input Resistance
100 MΩ
Input Capacitance
2.0 pF
Rise Time
3.0 ns
Signal/Noise
>60 dB @ 1 KHz
>50 dB @1 MHz
Accuracy
DC Volts
≤3%
AC Volts
≤3% at 1 kHz
General
Overview:
The Cal Test Electronics CT4025 is a 10 kV high
voltage divider probe for use with both digital and
analog oscilloscopes.
Features:
Input voltage of 10 kV (DC+ACpk)
120 MHz bandwidth
Voltage dividing of 100:1
Frequency compensation
Technical data subject to change.
© Cal Test Electronics 2017.
Cable Length
6.6 ft (2 m)
Designed for Use in
Pollution Degree 2
Operating Environment
14ºF to 131ºF
(-10ºC to 55ºC)
Storage Temperature
-4ºF to 158ºF
(-20ºC to 70ºC)
Humidity
≤85% relative
humidity at 95ºF
(35ºC)
Dimensions
3.1 x 3.1 x 12.6 in
(8 x 8 x 32 cm)
Weight
1.0 lbs (460 g)
Warranty
One-year warranty
caltestelectronics.com
很抱歉,暂时无法提供与“CT4025”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+5000.982961+650.11160
- 3+4822.438513+626.90140
- 国内价格 香港价格
- 1+4851.079101+630.62459
