CT4026
18 kV High
Voltage Probe
Datasheet
Specifications
Operating Parameters
Maximum Input Voltage
(CAT I)
18 kV (DC + ACpk)
12 kVrms AC
Maximum Loading Current
90 µA
Division Ratio
1000:1
Bandwidth
DC to 150 MHz
Compensation Range
10 pF to 35 pF
Temperature Coefficient
≤200 ppm/ºC
Input Resistance
200 MΩ
Input Capacitance
1.5 pF
Rise Time
2.4 ns
Signal/Noise
>60 dB @ 1 KHz
>50 dB @1 MHz
Accuracy
DC Volts
≤3%
AC Volts
≤3% at 1 kHz
General
Cable Length
6.6 ft (2 m)
Overview:
Designed for Use in
Pollution Degree 2
The Elditest CT4026 is a 18 kV high voltage
divider probe for use with both digital and analog
oscilloscopes.
Operating Environment
14ºF to 131ºF
(-10ºC to 55ºC)
Storage Temperature
-4ºF to 158ºF
(-20ºC to 70ºC)
Humidity
≤85% relative
humidity at 95ºF
(35ºC)
Dimensions
3.1 x 3.1 x 12.6 in
(8 x 8 x 32 cm)
Weight
1.0 lbs (460 g)
Warranty
One-year warranty
Features:
Input voltage of 18 kV (DC+ACpk)
150 MHz bandwidth
Voltage dividing of 1000:1
Frequency compensation
Technical data subject to change.
© Cal Test Electronics 2017.
caltestelectronics.com
很抱歉,暂时无法提供与“CT4026”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+5834.587121+758.32040
- 3+5626.271113+731.24560
