PG2000P
PG2000P
    CARDINALCOMPONENTS
    PG2000P
PG2000P 数据手册
CARDINAL COMPONENTS Field Oscillator Programming Instrument • • • • • • • Series PG-2000 Programming instrument to create oscillators, at a user specified frequency, within seconds IN THE FIELD No programming skills needed to create finished oscillators from sealed oscillator blanks Programmable CMOS or TTL oscillator outputs Programmable output enable and power-down feature Programmable asynchronous or synchronous output enable Programmable for 3.3V or 5.0V oscillator operation Microsoft Windows compatible software Instrument Part Number: PG-2000 Specifications: Frequency Range: 1.000 MHz to 133.000 MHz Acceptable Oscillator Packages: Style 1 Full-Size 14 Pin DIP Style 4 Half-Size 8 Pin DIP SMD Oscillator Programming Options: Output Enable Function Power Down Operation TTL or CMOS Output Instantaneous Asynchronous/ Synchronous Enable/Power Down Selectable Input Voltage (3.3, 5.0V) Ability to reprogram oscillator blank to reuse the same part for two separate applications with different frequency and/or different output characteristics Transformer Input: Output: AC, Supplied. UL 996C / 820A0063 100 - 250 VAC 60 Hz 20 W 16 VAC 750 mA Instrument Size: 6.5” x 10.5” x 2.5” Oscillator Blank Part Numbers: see Cardinal CPP series Required Additional Equipment: IEEE-488 Instrument Control Card (HP 82341D or eq.) IEEE-488 Instrument Control Cable (HP 10833B, or eq) Frequency Counter (HP 53131 or eq) Computer w/ Microsoft Windows 95,98,NT or Windows 2000 Cardinal Components, Inc., 155 Rt. 46 W, Wayne, NJ. 07470 TEL: (973)785-1333 FAX: (973)785-0053 http://www.cardinalxtal.com E-Mail: cardinal@cardinalxtal.com Specifications subject to change without notice. Check website for latest updates Rev 3.0 . CARDINAL COMPONENTS Stand-Alone Field Oscillator Programming Instrument • • • • • • • Series PG-2000P Programming instrument to create oscillators, at a user specified frequency, within seconds IN THE FIELD No programming skills needed to create finished oscillators from sealed oscillator blanks Designed for low-volume program applications such as engineering, field sales, and sample quantity Internal frequency reference for single step programming Simple User Interface Cardinal 4-pin oscillators are easily inserted into a ZIF socket or surface mount adapter for quick programming Oscillator characteristics are selected via keypad and 4-line LCD display Instrument Part Number: PG-2000P Specifications: Frequency Range: 1.000 MHz to 133.000 MHz Acceptable Oscillator Packages: Style 1 Full-Size 14 Pin DIP Style 4 Half-Size 8 Pin DIP SMD (With Optional SC-2000 Adapter) Programmable Voltage Range: 3.3, 5.0 V User Interface: 4 Line LCD frequency control parameters usage instructions helpful error messages Keypad ZIF Socket Design Specifications: For use with 4-pin oscillators Oscillator Programming Options: control pin functionality outputs electrical characteristics Ability to reprogram oscillator blank to correct errors or to reuse the same part for two sperate applications with different frequency and/or different output characteristics Switching Power Supply Equipped with Universal AC pwr supply UL 1950 100 - 250 VAC 50/60 Hz 0.7 – 0.35 A Input: Output: + 5.0 V 1.0 A +15.0 V 0.4 A - 15.0 V 0.4 A Instrument Size: 10” x 4.75” x 2.65” Oscillator Blank Part Numbers: see Cardinal CPP series Cardinal Components, Inc., 155 Rt. 46 W, Wayne, NJ. 07470 TEL: (973)785-1333 FAX: (973)785-0053 http://www.cardinalxtal.com E-Mail: cardinal@cardinalxtal.com Specifications subject to change without notice. Check website for latest updates Rev 3.0 .
PG2000P 价格&库存
很抱歉,暂时无法提供与“PG2000P”相匹配的价格&库存,您可以联系我们找货
