Rev C
Field Programmable Crystal Oscillator
Series:CPPD
Features
Applications
Driving A/Ds, D/As, FPGAs
Digital Video
Ethernet, GbE
Medical
Storage Area Networking
COTS
Broad Band Access
SONET/ SDH/ DWDM
Test & Measurement
Programmed in the field with the PG-3200 oscillator
programming instrument within seconds.
Factory Programmable
Standard Package Options
MSL: 1
Part Numbering Example:
CPPD
C
1
L
Z
A5
B6
xx.xxxx
yy.yyyy
SERIES
OUTPUT
PACKAGE STYLE
VOLTAGE
ADDED FEATURES
OPERATING TEMP.
STABILITY
FREQUENCY
FREQUENCY
CPPD
C=CMOS
1 = Full Size
Blank=5.0V
Blank=Cut Tape
Blank=0°C ~ +70°C
B6=±100ppm
0.500~133.000MHz
0.500~133.000MHz
T=TTL
4 = Half Size
L=3.3V
B=Bulk
A3=-55°C ~ +125°C
BP=±50ppm
Pin 1 Logic “0”
Pin 1 Logic “1”
5 = 5X3.2 Ceramic
R=2.7V
T=Tube
A5=-20°C ~ +70°C
BR=±25ppm
Z=Tape and Reel
A7=-40°C ~ +85°C
7 = 5X7 Ceramic
Specifications:
Description
Min
Typ
Max
Unit
Frequency Range: Programmable to any discrete frequency
0.500
133
MHz
Available Stability Options:
-100
+100
PPM
-50
+50
-25
+25
Programmable Supply Voltage:
(1-133 MHz)
4.5
5.0
5.5
V
(1-100 MHz)
3.0
3.3
3.6
V
(1-66.0 MHz)
2.5
2.7
3.0
V
-55
+125
°C
-20
+70
°C
-40
+85
°C
-55
+125
°C
±5
PPM/Year
Operating Temperature Range Options:
Storage Temperature:
Aging: Ta=°25C,Vdd=5V/3.3V
1st year
Programmable Output Level:
Operating Conditions:
CMOS/TTL
Description
Min
Max
Unit
2.5
5.5
V
VDD
Supply Voltage
CTTL
Max capacitive load on outputs for TTL levels
4.5V-5.5V VDD, ≤ 40 MHz
4.5V-5.5V VDD, 40 - 133 MHz
50
25
pF
pF
Max capacitive load on outputs for CMOS levels
4.5V-5.5V VDD, ≤ 66 MHz
4.5V-5.5V VDD, 66 - 133 MHz
3.0V-3.6V VDD, ≤ 40 MHz
3.0V-3.6V VDD, 40 - 100 MHz
2.5-3.0V VDD, ≤ 66 MHz
50
25
30
15
25
pF
pF
pF
pF
pF
CCMOS
Cardinal Components
1801 Broadway Street
Charlottesville, VA 22902
TEL: (973)785-1333
E-MAIL: sales@cardinalxtal.com
WEB: http://www.cardinalxtal.com
Pg 1
Rev C
Series:CPPD
Output Clock Switching Characteristics:
Description
Test Conditions
Min
Typ
Max
Unit
Duty Cycle:
≤ 50 MHz, CL = 50 pF
45
55
TTL @ 1.4V
50 - 66 MHz, CL = 15 pF
45
55
4.5-5.5 VDD
66 - 125 MHz, CL = 25 pF
40
60
125 - 133 MHz, CL = 15 pF
40
60
≤ 66 MHz, CL ≤ 25 pF
45
55
CMOS @ VDD/2
66 - 125 MHz, CL ≤ 25 pF
40
60
4.5-5.5 VDD
125 - 133 MHz, CL ≤ 15 pF
60
60
3.0-3.6 VDD
≤ 40 MHz, CL ≤ 30 pF
45
55
40 - 100 MHz, CL ≤ 15 pF
40
60
Duty Cycle:
Rise/Fall:
0.8V - 2.0V, 4.5 - 5.5 VDD, CL = 50 pF
1.8
ns
0.8V - 2.0V, 4.5 - 5.5 VDD, CL = 25 pF
1.2
ns
0.8V - 2.0V, 4.5 - 5.5 VDD, CL = 15 pF
0.9
ns
0.2V - 0.8 * VDD, 4.5 - 5.5 VDD, CL = 50 pF
3.4
ns
0.2V - 0.8 * VDD, 3.0 - 3.6 VDD, CL = 30 pF
4.0
ns
0.2V - 0.8 * VDD, 3.0 - 3.6 VDD, CL = 15 pF
2.4
ns
10
ms
Start Up Time
From Power On
RMS Period Jitter
1 - 133.00 MHz
8
11
ps
Peak to Peak*
≤ 33.000 MHz
65
99
ps
> 33.000 MHz
65
80
ps
* Jitter Tested at > 1,000,000 samples, exceeding JEDEC std JESD65
Cardinal Components
TEL: (973)785-1333
Pg 2
Rev C
Series:CPPD
Electrical Characteristics:
Description
Test Conditions
Min
Typ
Max
Unit
VDD = 5.0 V
0.8
V
VDD = 3.3 V
0.2 * VDD
V
VDD = 2.7 V
0.2 * VDD
V
VDD = 5.0 V
2.0
V
VDD = 3.3 V
0.7 * VDD
V
IIL, Input Low Current
VIN = 0 V
10
µA
IIH, Input High Current
VIN = VDD
5
µA
VDD = 5.0 V, IOL = 16mA
0.4
V
VDD = 3.3 V, IOL = 8mA
0.4
V
VIHTTL, High-Level Output Voltage
VDD = 5.0 V, IOL = -16mA
2.4
V
VIHCMOS, High-Level Output Voltage
VDD-0.4
V
VDD = 3.3 V, IOL = -8mA
VDD-0.4
V
Power Supply Current:
VDD = 5.0 V , FO ≤ 133 MHz
45
mA
(Unloaded)
VDD = 3.3 V , FO ≤ 100 MHz
25
mA
VDD = 2.7 V , FO ≤ 66.0 MHz
mA
10
50
µA
µA
Input Characteristics (Pin 1):
VIL, Low-Level Input Voltage
(To Tri-State or Power Down)
VIH, High-Level Input Voltage
(To Enable Output or Open)
Output Characteristics:
VOL, Low-Level Output Voltage
Standby Current:
Tri-State Leakage Current
VDD = 5.0 V
Output Enable Mode:
Output is Tri-Stated
Power Down Mode:
Cardinal Components
TEL: (973)785-1333
Pg 3
Rev C
*Note:
Series:CPPD
REQUIRED Bypass VDD to GND with a 0.01μF capacitor
Style 1
Style 5
Recommended Solder Pad Layout
Cardinal Components
Full Size 14 pin DIP
Style 4
Half Size 8 pin DIP
Pin #
Function
Pin #
Function
1
Control
1
Control
7
GND
4
GND
8
Output
5
Output
14
VDD
8
VDD
3.2x5 Ceramic SMD
Style 7
5x7 Ceramic SMD
Pin #
Function
Pin #
Function
1
Control
1
Control
2
GND
2
GND
3
Output
3
Output
4
VDD
4
VDD
TEL: (973)785-1333
Pg 4
