ABS205-ABS210
BRIDGE RECTIFIER
FEATURES
Low reverse voltage leakage current
Glass passivated die construction
Low forward voltage drop
High forward surge current capability
Small surface mount device
ABS
MECHANICAL DATA
Case: ABS
Case Material: Molded Plastic. UL flammability
Classification Rating: 94V-0
Weight: 0.10 grams (approximate)
MAXIMUM RATINGS (TA = 25°C unless otherwise specified)
ABS
Parameter
Symbol
205
VRRM
50
Repetitive peak reverse voltage
VR
DC Reverse Voltage
50
VRMS
RMS Reverse Voltage
35
Average forward rectified output current at TA=40°C IF(AV)
Peak forward surge current single sine-wave
IFSM
superimposed on rated load (JEDEC method)
I2t
Rating for fusing ( t
很抱歉,暂时无法提供与“ABS210”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.26861
- 500+0.17324
- 2000+0.15866
- 5000+0.13524
