2414
2414
    ADAFRUIT
    SHLDR SCREW CHEESE SLOTTED 4-40
2414 数据手册
IFixit Jimmy - Electronics Opening Knife PRODUCT ID: 2414  Description The all-mighty Jimmy from IFixIt is the best way out from an iRock and an iHardPlace. Slide, cut, twist, poke, slice, part, uproot, divide, lift, dissect, separate, and pry your devices to check out their insides, void your warranties, and mod your gear. The Jimmy is a high-quality flexible steel blade that easily slips between the tightest gaps in the toughest devices. Bust through your previously unpenetrable electronics and fix it, or mod it, or open a chop-shop and disassemble it entirely. The ergonomic handle makes it easy to get in there and jimmy those gadgets open!  Technical Details o o o Blade Dimensions: 28mm x 22mm x 0.3mm / 1.1" x 0.9" x 0.01" Handle Dimensions: 94mm x 26mm x 7.5mm / 3.7" x 1" x 0.3" Weight: 16.5g                                  Engineered in NYC Adafruit ® https://www.adafruit.com/product/2414 5‐5‐17
很抱歉,暂时无法提供与“2414”相匹配的价格&库存,您可以联系我们找货
