LFA150F-24-J1
LFA150F-24-J1
    COSEL
LFA150F-24-J1 数据手册
AC-DC Power Supplies Open Frame/ Enclosed Type Power Factor Correction World wide Cost Effective Rugged PCB type Safety Approvals EMI Inrush current limiting OCP OVP LFA-series Feature CE marking Small and compact PCB construction Built-in inrush current, overcurrent and overvoltage protection circuits Harmonic attenuator (Complies with IEC61000-3-2) Universal input (AC85-264V) Power factor correction (LFA50F-300F) Built-in reducing standby power circuit (LFA10F, 15F) Safety agency approvals UL60950-1, C-UL(CSA60950-1), EN62368-1 Complies with DEN-AN Low Voltage Directive RoHS Directive EMS Compliance : EN61204-3, EN61000-6-2 EN61000-4-2 EN61000-4-3 EN61000-4-4 EN61000-4-5 EN61000-4-6 EN61000-4-8 EN61000-4-11 EMI Complies with FCC-B, CISPR22-B, EN55011-B, EN55022-B, VCCI-B 5-year warranty (refer to Instruction Manual) January 31, 2022 LFA-1 Ordering information AC-DC Power Supplies Open Frame/ Enclosed Type LFA10F LF 1 A 2 10 3 F 4 Example recommended EMI/EMC filter NAC-04-472 R High voltage pulse noise type : NAP series Low leakage current type : NAM series * A higher current rating EMI/EMC filter may be recommended in view of the other devices that could be connected in parallel with the power supply. -O 5 -O 6 1 Series name 2 Single output 3 Output wattage 4 Universal input 5 Output voltage 6 Optional C : with Coating G : Low leakage current J1 : VH(J.S.T.)connector type S : with Chassis SN: with Chassis & cover Y : with Potentiometer Specification is changed at option, refer to Instruction Manual. This power supply is manufactured by SMD technology. The stress to P.C.B like twisting or bending causes the defect of the unit, so handle the unit with care. *Make sure necessary tests will be carried out on your end equipment with the power supply installed in accordance with any required EMC/EMI regulations. MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT LFA10F-3R3-Y 6.6 3.3V 2A LFA10F-5 10 5V 2A LFA10F-12 10.8 12V 0.9A LFA10F-15 10.5 15V 0.7A LFA10F-24 12 24V 0.5A SPECIFICATIONS MODEL VOLTAGE[V] CURRENT[A] ACIN 100V ACIN 200V FREQUENCY[Hz] INPUT ACIN 100V ACIN 200V ACIN 100V INRUSH CURRENT[A] ACIN 200V LEAKAGE CURRENT[mA] VOLTAGE[V] CURRENT[A] *5 LINE REGULATION[mV] LOAD REGULATION[mV] *5 0 to +50C RIPPLE[mVp-p] -10 - 0C *1 Io=0 - 35% 0 to +50C RIPPLE NOISE[mVp-p] OUTPUT -10 - 0C *1 Io=0 - 35% 0 to +50C TEMPERATURE REGULATION[mV] -10 to +50C *2 DRIFT[mV] START-UP TIME[ms] HOLD-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE[V] OUTPUT VOLTAGE SETTING[V] OVERCURRENT PROTECTION PROTECTION OVERVOLTAGE PROTECTION CIRCUIT AND OPERATING INDICATION OTHERS REMOTE SENSING REMOTE ON/OFF INPUT-OUTPUT INPUT-FG ISOLATION OUTPUT-FG OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE ENVIRONMENT VIBRATION IMPACT AGENCY APPROVALS SAFETY AND NOISE CONDUCTED NOISE REGULATIONS HARMONIC ATTENUATOR CASE SIZE/WEIGHT OTHERS COOLING METHOD EFFICIENCY[%] LFA10F-3R3-Y LFA10F-5 LFA10F-12 LFA10F-15 LFA10F-24 AC85 - 264 1f (Refer to “Derating”, Instruction Manual 1 and 3) *3 0.18typ (Io=100%) 0.26typ (Io=100%) 0.11typ (Io=100%) 0.16typ (Io=100%) 50 / 60 (47 - 440) 68.0typ 74.0typ 76.5typ 77.5typ 79.5typ 68.5typ 76.0typ 79.0typ 80.0typ 83.0typ 15typ (Io=100%) 30typ (Io=100%) 0.15/0.30max (ACIN 100V / 240V 60Hz, Io=100%, According to IEC62368-1 and DEN-AN) 3.3 5 12 15 24 2.0 2.0 0.9 0.7 0.5 20max 20max 48max 60max 96max 40max 40max 100max 120max 150max 80max 80max 120max 120max 120max 140max 140max 160max 160max 160max 190max 160max 240max 240max 280max 120max 120max 150max 150max 150max 160max 160max 180max 180max 180max 240max 240max 300max 300max 320max 50max 50max 120max 150max 240max 60max 60max 150max 180max 290max 20max 20max 48max 60max 96max 200typ (ACIN 100V, Io=100%) *Start-up time is 700ms typ for less than 1minute of applying input again from turning off the input voltage. 20typ (ACIN 100V, Io=100%) 2.85 to 3.63 Fixed (“Y”option is available for adjusting output voltage between ±10%) 3.30 to 3.40 4.90 to 5.30 11.50 to 12.50 14.40 to 15.60 23.00 to 25.00 Works over 105% of rating and recovers automatically 4.00 to 5.25 5.75 to 7.00 13.80 to 16.80 17.25 to 21.00 27.60 to 33.60 Not provided Not provided Not provided AC3,000V 1minute, Cutoff current = 10mA, DC500V 50MW min (At Room Temperature) AC2,000V 1minute, Cutoff current = 10mA, DC500V 50MW min (At Room Temperature) AC500V 1minute, Cutoff current = 25mA, DC500V 50MW min (At Room Temperature) -10 to +70C, 20 - 90%RH (Non condensing) (Refer to “Derating”, Instruction Manual 3), 3,000m (10,000 feet) max *3 -20 to +75C, 20 - 90%RH (Non condensing), 9,000m (30,000 feet) max 10 - 55Hz, 19.6m/s2 (2G), 3minutes period, 60minutes each along X, Y and Z axis 196.1m/s2 (20G), 11ms, once each X, Y and Z axis UL60950-1, C-UL (CSA60950-1), EN62368-1 Complies with DEN-AN Complies with FCC-B, VCCI-B, CISPR-B, EN55011-B, EN55022-B Complies with IEC61000-3-2 (Class A) *6 (Not built-in to active filter) *4 50X22X73.5mm [1.97X0.87X2.89 inches] (WXHXD) / 55g max (with chassis & cover : 150g max) Convection (Refer to “Derating”, Instruction Manual 3) *3 *1 This is the value that measured on measuring board with capacitor of 22mF at 150mm from output terminal. Measured by 20MHz oscilloscope or Ripple-Noise meter (Equivalent to KEISOKU-GIKEN: RM103). A circuit reducing standby power is built in this unit. Therefore, the internal switch element is intermittent operated, and the Ripple/Ripple Noise specification in load LFA-2 factor Io=0-35% is different. Please refer to the Instruction Manual 1.7. *2 Drift is the change in DC output for an eight hour period after a half-hour warm-up at 25C, with the input voltage held constant at the rated input/output. *3 Derating is required. *4 When two or more units are operating it may not comply with the IEC61000-3-2. January 31, 2022 Please contact us for details. *5 Please contact us about dynamic load and input response. *6 Please contact us about another class. * To meet the specifications. Do not operate over-loaded condition. * Parallel operation is not possible. * Derating is required when operated with chassis and cover. * Sound noise may be generated by power supply in case of pulse load. LFA10F Block diagram FUSE AC250V 2A AC IN 85 264V INRUSH CURRENT LIMIT NOISE FILTER RECTIFIER AND FILTER FG TRANSFORMER CONTROL INVERTER RECTIFIER AND FILTER DC OUT CURRENT SENSING Photocoupler CONTROL Photocoupler OVER VOLTAGE PROTECTION External view 83.5 ±0.5 f3.5 63.5 ±0.5 5 [0.2] [2.5] Input(N) 3 Input(L) 1 1 2 73.5 Name plate [2.89] Point A Point B ¶ The back side of P.C.B. of the power supply is assembled some SMDs. Be attention not to bump against the attached area by vibration. ¶ Use the spacer of 8mm length or more regarding insulation. And do not use press-fitting bush. ¶ Point A, Point B are thermometry points. Please refer to Instruction Manual 3. I/O Connector Mating connector CN1 1-1123724-3 1-1123722-5 CN2 1-1123723-2 1-1123722-2 Terminal 1123721-1 Chain Loose 1318912-1 Chain 1123721-1 Loose 1318912-1 (Mfr:Tyco Electronics) ¶ I/O Connector is Mfr. Tyco Electronics ¶ Option:-J1:(J.S.T) connector type. Refer to Instruction Manual 6. 2-M3 Mounting Hole 32 [1.26] 11 PCB t=1.6 [0.43] ¶1 Surface mount device 3.5 [0.16] ¶1 5 [0.2] 16 83.5 ±0.5 [0.63] [3.68] f3.5 [0.14] 18 [0.71] 93.5 [3.29] 4max Output(-) Output(+) 60 CN2 5 [2.36] CN1 FG 30 Voltage adjust (LFA10F-3R3-Y or optional) 2-f3.5 Mounting Hole 3.5 Input(L) 15 Input(N) 1 [0.59] 3 Output(-) Output(+) 1 2 31.7 FG [0.2] [1.25] CN2 5 30 ±0.5 [1.18] 50 [1.97] 40 ±0.5 [1.57] CN1 4-M3 Mounting Hole 5 [3.29] [1.18] 5 [0.2] Chassis and cover type 4.6 [0.18] [0.14] Standard type FG CN1 Pin No. 1 2 3 4 5 CN2 Input AC(L) AC(N) Pin No. Output 1 -V 2 +V FG January 31, 2022 ¶ Tolerance : ±1 [±0.04] ¶ Weight : 55g max (with chassis & cover : 150g max) ¶ PCB material / thickness : CEM3 / 1.6mm ¶ Optional chassis and cover material : Electric galvanizing steel board. ¶ Dimensions in mm, [ ]=inches ¶ Mounting torque (Mounting hole of chassis) : 0.6N-m (6.3kgf-cm) max LFA-3 Ordering information AC-DC Power Supplies Open Frame/ Enclosed Type LFA15F LF 1 A 2 15 3 F 4 Example recommended EMI/EMC filter NAC-04-472 R High voltage pulse noise type : NAP series Low leakage current type : NAM series * A higher current rating EMI/EMC filter may be recommended in view of the other devices that could be connected in parallel with the power supply. -O 5 -O 6 1 Series name 2 Single output 3 Output wattage 4 Universal input 5 Output voltage 6 Optional C : with Coating G : Low leakage current J1 : VH(J.S.T.)connector type S : with Chassis SN: with Chassis & cover Y : with Potentiometer Specification is changed at option, refer to Instruction Manual. This power supply is manufactured by SMD technology. The stress to P.C.B like twisting or bending causes the defect of the unit, so handle the unit with care. *Make sure necessary tests will be carried out on your end equipment with the power supply installed in accordance with any required EMC/EMI regulations. MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT LFA15F-3R3-Y 9.9 3.3V 3A LFA15F-5 15 5V 3A LFA15F-12 15.6 12V 1.3A LFA15F-15 15 15V 1A LFA15F-24 16.8 24V 0.7A SPECIFICATIONS MODEL VOLTAGE[V] CURRENT[A] ACIN 100V ACIN 200V FREQUENCY[Hz] INPUT ACIN 100V ACIN 200V ACIN 100V INRUSH CURRENT[A] ACIN 200V LEAKAGE CURRENT[mA] VOLTAGE[V] CURRENT[A] *5 LINE REGULATION[mV] LOAD REGULATION[mV] *5 0 to +50C RIPPLE[mVp-p] -10 - 0C *1 Io=0 - 35% 0 to +50C RIPPLE NOISE[mVp-p] OUTPUT -10 - 0C *1 Io=0 - 35% 0 to +50C TEMPERATURE REGULATION[mV] -10 to +50C *2 DRIFT[mV] START-UP TIME[ms] HOLD-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE[V] OUTPUT VOLTAGE SETTING[V] OVERCURRENT PROTECTION PROTECTION OVERVOLTAGE PROTECTION CIRCUIT AND OPERATING INDICATION OTHERS REMOTE SENSING REMOTE ON/OFF INPUT-OUTPUT INPUT-FG ISOLATION OUTPUT-FG OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE ENVIRONMENT VIBRATION IMPACT AGENCY APPROVALS SAFETY AND NOISE CONDUCTED NOISE REGULATIONS HARMONIC ATTENUATOR CASE SIZE/WEIGHT OTHERS COOLING METHOD EFFICIENCY[%] LFA15F-3R3-Y LFA15F-5 LFA15F-12 LFA15F-15 LFA15F-24 AC85 - 264 1f (Refer to “Derating”, Instruction Manual 1 and 3) *3 0.24typ (Io=100%) 0.35typ (Io=100%) 0.15typ (Io=100%) 0.20typ (Io=100%) 50 / 60 (47 - 440) 68.0typ 73.0typ 76.0typ 77.0typ 78.0typ 69.0typ 76.0typ 78.5typ 80.0typ 81.5typ 15typ (Io=100%) (At cold start) (Ta=25C) 30typ (Io=100%) (At cold start) (Ta=25C) 0.15/0.30max (ACIN 100V / 240V 60Hz, Io=100%, According to IEC62368-1 and DEN-AN) 3.3 5 12 15 24 3.0 3.0 1.3 1.0 0.7 20max 20max 48max 60max 96max 40max 40max 100max 120max 150max 80max 80max 120max 120max 120max 140max 140max 160max 160max 160max 190max 160max 240max 240max 280max 120max 120max 150max 150max 150max 160max 160max 180max 180max 180max 240max 240max 300max 300max 320max 50max 50max 120max 150max 240max 60max 60max 150max 180max 290max 20max 20max 48max 60max 96max 200typ (ACIN 100V, Io=100%) *Start-up time is 700ms typ for less than 1minute of applying input again from turning off the input voltage. 20typ (ACIN 100V, Io=100%) 2.85 to 3.63 Fixed (“Y”option is available for adjusting output voltage between ±10%) 3.30 to 3.40 4.90 to 5.30 11.50 to 12.50 14.40 to 15.60 23.00 to 25.00 Works over 105% of rating and recovers automatically 4.00 to 5.25 5.75 to 7.00 13.80 to 16.80 17.25 to 21.00 27.60 to 33.60 Not provided Not provided Not provided AC3,000V 1minute, Cutoff current = 10mA, DC500V 50MW min (At Room Temperature) AC2,000V 1minute, Cutoff current = 10mA, DC500V 50MW min (At Room Temperature) AC500V 1minute, Cutoff current = 25mA, DC500V 50MW min (At Room Temperature) -10 to +70C, 20 - 90%RH (Non condensing) (Refer to “Derating”, Instruction Manual 3), 3,000m (10,000 feet) max *3 -20 to +75C, 20 - 90%RH (Non condensing), 9,000m (30,000 feet) max 10 - 55Hz, 19.6m/s2 (2G), 3minutes period, 60minutes each along X, Y and Z axis 196.1m/s2 (20G), 11ms, once each X, Y and Z axis UL60950-1, C-UL (CSA60950-1), EN62368-1 Complies with DEN-AN Complies with FCC-B, VCCI-B, CISPR-B, EN55011-B, EN55022-B Complies with IEC61000-3-2 (Class A) *6 (Not built-in to active filter) *4 50X22X87.5mm [1.97X0.87X3.44 inches] (WXHXD) / 80g max (with chassis & cover : 190g max) Convection (Refer to “Derating”, Instruction Manual 3) *3 *1 This is the value that measured on measuring board with capacitor of 22mF at 150mm from output terminal. Measured by 20MHz oscilloscope or Ripple-Noise meter (Equivalent to KEISOKU-GIKEN: RM103). A circuit reducing standby power is built in this unit. Therefore, the internal switch element is intermittent operated, and the Ripple/Ripple Noise specification in load LFA-4 factor Io=0-35% is different. Please refer to the Instruction Manual 1.7. *2 Drift is the change in DC output for an eight hour period after a half-hour warm-up at 25C, with the input voltage held constant at the rated input/output. *3 Derating is required. *4 When two or more units are operating it may not comply with the IEC61000-3-2. January 31, 2022 Please contact us for details. *5 Please contact us about dynamic load and input response. *6 Please contact us about another class. * To meet the specifications. Do not operate over-loaded condition. * Parallel operation is not possible. * Derating is required when operated with chassis and cover. * Sound noise may be generated by power supply in case of pulse load. LFA15F Block diagram FUSE AC250V 2.5A AC IN 85 264V INRUSH CURRENT LIMIT NOISE FILTER RECTIFIER AND FILTER FG TRANSFORMER CONTROL INVERTER RECTIFIER AND FILTER DC OUT CURRENT SENSING Photocoupler CONTROL Photocoupler OVER VOLTAGE PROTECTION 5 [0.2] Name plate 77.5 ±0.5 [3.05] Input(N) 3 Input(L) 1 1 2 30 [1.18] Output(-) Output(+) 60 CN2 5 [2.36] 2-f3.5 Mounting Hole CN1 FG 3.5 Voltage adjust (LFA15F-3R3-Y or optional) [0.14] Input(L) 4-M3 Mounting Hole 15 Input(N) 1 CN2 Output(-) Output(+) [0.2] [0.59] 3 1 2 29.7 FG 5 [3.84] [1.17] 5 97.5 ±0.5 f3.5 30 ±0.5 [1.18] [0.2] Chassis and cover type 4.4 [0.17] [1.57] 50 [1.97] Standard type FG CN1 40 ±0.5 5 External view 87.5 [3.44] Point A 107.5 Point B [4.23] f3.5 97.5 ±0.5 5 [0.2] I/O Connector Mating connector CN1 1-1123724-3 1-1123722-5 CN2 1-1123723-2 1-1123722-2 Terminal 1123721-1 Chain Loose 1318912-1 Chain 1123721-1 Loose 1318912-1 (Mfr:Tyco Electronics) ¶ I/O Connector is Mfr. Tyco Electronics ¶ Option:-J1:(J.S.T) connector type. Refer to Instruction Manual 6. 32 [1.26] 11 [0.43] 16 2-M3 Mounting Hole ¶1 Surface mount device ¶ The back side of P.C.B. of the power supply is assembled some SMDs. Be attention not to bump against the attached area by vibration. ¶ Use the spacer of 8mm length or more regarding insulation. And do not use press-fitting bush. ¶ Point A, Point B are thermometry points. Please refer to Instruction Manual 3. [0.63] 3.5 [0.16] 4max PCB t=1.6 ¶1 [0.14] 18 [0.71] [3.84] CN1 Pin No. 1 2 3 4 5 CN2 Input AC(L) AC(N) Pin No. Output 1 -V 2 +V FG January 31, 2022 ¶ Tolerance : ±1 [±0.04] ¶ Weight : 80g max (with chassis & cover : 190g max) ¶ PCB material / thickness : CEM3 / 1.6mm ¶ Optional chassis and cover material : Electric galvanizing steel board. ¶ Dimensions in mm, [ ]=inches ¶ Mounting torque (Mounting hole of chassis) : 0.6N-m (6.3kgf-cm) max LFA-5 Ordering information AC-DC Power Supplies Open Frame/ Enclosed Type LFA30F LF 1 A 2 30 3 F 4 Example recommended EMI/EMC filter NAC-04-472 R High voltage pulse noise type : NAP series Low leakage current type : NAM series * A higher current rating EMI/EMC filter may be recommended in view of the other devices that could be connected in parallel with the power supply. -O 5 -O 6 1 Series name 2 Single output 3 Output wattage 4 Universal input 5 Output voltage 6 Optional C : with Coating G : Low leakage current J1 : VH(J.S.T.)connector type S : with Chassis SN: with Chassis & cover Y : with Potentiometer Specification is changed at option, refer to Instruction Manual. This power supply is manufactured by SMD technology. The stress to P.C.B like twisting or bending causes the defect of the unit, so handle the unit with care. *Make sure necessary tests will be carried out on your end equipment with the power supply installed in accordance with any required EMC/EMI regulations. MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT LFA30F-3R3-Y 19.8 3.3V 6A LFA30F-5 30.0 5V 6A LFA30F-12 30.0 12V 2.5A LFA30F-15 30.0 15V 2A LFA30F-24 31.2 24V 1.3A SPECIFICATIONS MODEL VOLTAGE[V] CURRENT[A] ACIN 100V ACIN 200V FREQUENCY[Hz] INPUT OUTPUT PROTECTION CIRCUIT AND OTHERS ISOLATION ENVIRONMENT SAFETY AND NOISE REGULATIONS OTHERS ACIN 100V ACIN 200V ACIN 100V INRUSH CURRENT[A] ACIN 200V LEAKAGE CURRENT[mA] VOLTAGE[V] CURRENT[A] LINE REGULATION[mV] *5 LOAD REGULATION[mV] *5 0 to +50C *1 RIPPLE[mVp-p] -10 - 0C *1 0 to +50C *1 RIPPLE NOISE[mVp-p] -10 - 0C *1 0 to +50C TEMPERATURE REGULATION[mV] -10 to +50C *2 DRIFT[mV] START-UP TIME[ms] HOLD-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE[V] OUTPUT VOLTAGE SETTING[V] OVERCURRENT PROTECTION OVERVOLTAGE PROTECTION OPERATING INDICATION REMOTE SENSING REMOTE ON/OFF INPUT-OUTPUT INPUT-FG OUTPUT-FG OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE VIBRATION IMPACT AGENCY APPROVALS CONDUCTED NOISE HARMONIC ATTENUATOR CASE SIZE/WEIGHT COOLING METHOD EFFICIENCY[%] LFA30F-3R3-Y LFA30F-5 LFA30F-12 LFA30F-15 LFA30F-24 AC85 - 264 1f (Refer to “Derating”, Instruction Manual 1 and 3) *3 0.50typ (Io=100%) 0.65typ (Io=100%) 0.30typ (Io=100%) 0.35typ (Io=100%) 50 / 60 (47 - 440) 73typ 76typ 79typ 81typ 82typ 75typ 79typ 81typ 83typ 84typ 15typ (Io=100%) (At cold start) (Ta=25C) 30typ (Io=100%) (At cold start) (Ta=25C) 0.30 / 0.65max (ACIN 100V / 240V 60Hz, Io=100%, According to IEC62368-1 and DEN-AN) 3.3 5 12 15 24 6.0 6.0 2.5 2.0 1.3 20max 20max 48max 60max 96max 40max 40max 100max 120max 150max 80max 80max 120max 120max 120max 140max 140max 160max 160max 160max 120max 120max 150max 150max 150max 160max 160max 180max 180max 180max 50max 50max 120max 150max 240max 60max 60max 150max 180max 290max 20max 20max 48max 60max 96max 150typ (ACIN 100V, Io=100%) 20typ (ACIN 100V, Io=100%) 2.85 to 3.63 Fixed (“Y”option is available for adjusting output voltage between ±10%) 3.30 to 3.40 4.90 to 5.30 11.50 to 12.50 14.40 to 15.60 23.00 to 25.00 Works over 105% of rating and recovers automatically 4.00 to 5.25 5.75 to 7.00 13.80 to 16.80 17.25 to 21.00 27.60 to 33.60 Not provided Not provided Not provided AC3,000V 1minute, Cutoff current = 10mA, DC500V 50MW min (At Room Temperature) AC2,000V 1minute, Cutoff current = 10mA, DC500V 50MW min (At Room Temperature) AC500V 1minute, Cutoff current = 25mA, DC500V 50MW min (At Room Temperature) -10 to +70C, 20 - 90%RH (Non condensing) (Refer to “Derating”, Instruction Manual 3), 3,000m (10,000feet) max *3 -20 to +75C, 20 - 90%RH (Non condensing), 9,000m (30,000feet) max 10 - 55Hz, 19.6m/s2 (2G), 3minutes period, 60minutes each along X, Y and Z axis 196.1m/s2 (20G), 11ms, once each X, Y and Z axis UL60950-1, C-UL (CSA60950-1), EN62368-1 Complies with DEN-AN Complies with FCC-B, VCCI-B, CISPR-B, EN55011-B, EN55022-B Complies with IEC61000-3-2 (Class A) *6 (Not built-in to active filter) *4 50X26.5X105mm [1.97X1.04X4.13 inches] (WXHXD) / 130g max (with chassis & cover : 260g max) Convection (Refer to “Derating”, Instruction Manual 3) *3 *1 This is the value that measured on measuring board with capacitor of 22mF at 150mm from output terminal. Measured by 20MHz oscilloscope or Ripple-Noise meter (Equivalent to KEISOKU-GIKEN: RM103). *2 Drift is the change in DC output for an eight hour period after a half-hour warm-up at 25C, with the input voltage held constant at the rated input/output. *3 Derating is required. LFA-6 *4 When two or more units are operating it may not comply with the IEC61000-3-2. Please contact us for details. *5 Please contact us about dynamic load and input response. *6 Please contact us about another class. * To meet the specifications. Do not operate over-loaded condition. Parallel operation is not possible. * * Derating is required when operated with chassis and cover. * Sound noise may be generated by power supply in case of pulse load. January 31, 2022 LFA30F Block diagram FUSE AC250V 3.15A AC IN 85 264V INRUSH CURRENT LIMIT NOISE FILTER RECTIFIER AND FILTER FG TRANSFORMER CONTROL INVERTER RECTIFIER AND FILTER DC OUT CURRENT SENSING Photocoupler CONTROL Photocoupler OVER VOLTAGE PROTECTION External view Standard type [3.74] CN1 Point B Mating connector CN1 1-1123724-3 1-1123722-5 CN2 1-1123723-4 1-1123722-4 Terminal 1123721-1 Chain Loose 1318912-1 Chain 1123721-1 Loose 1318912-1 (Mfr:Tyco Electronics) ¶ I/O Connector is Mfr. Tyco Electronics ¶ Option:-J1:(J.S.T) connector type. Refer to Instruction Manual 6. [2.36] 30 36 [1.42] 16 11 [0.63] [0.43] 2-M3 Mounting Hole ¶1 Surface mount device ¶ 4 Mounting holes are existing. ¶ The back side of P.C.B. of the power supply is assembled some SMDs. Be attention not to bump against the attached area by vibration. ¶ Use the spacer of 8mm length or more regarding insulation. And do not use press-fitting bush. ¶ Point A, Point B are thermometry points. Please refer to Instruction Manual 3. 5 [0.2] 3.5 [0.14] 3.5max 23 [0.91] [4.53] [0.14] [4.92] 115 ±0.5 PCB t=1.6 I/O Connector Output(+) 125 f3.5 ¶1 Output(-) 60 1 2 3 4 3.5 Input(L) 1 CN2 [1.18] 15 3 Mounting Hole 105 [4.13] Point A 5 Voltage adjust (LFA30F-3R3-Y or optional) [0.16] 95 ±0.5 FG Input(N) [0.14] 4 5 [0.2] Output(+) 3.5 [0.2] 5 Output(-) 4-M3 Mounting Hole [0.2] [0.59] Input(L) 1 2 3 4 30 ±0.5 [1.18] 1 35.8 Input(N) CN1 CN2 FG 3 5 115 ±0.5 [4.53] f3.5 [0.14] 50 [1.97] 40 ±0.5 [1.57] 5 [0.18] [1.41] Name plate FG Chassis and cover type 3-f3.5 Mounting Hole 4.5 CN1 Pin No. 1 2 3 4 5 CN2 Input AC(L) AC(N) Pin No. Output 1, 2 -V 3, 4 +V FG ¶ Tolerance : ±1 [±0.04] ¶ Weight: 130g max (with chassis & cover : 260g max) ¶ PCB material / thickness : CEM3 / 1.6mm ¶ Optional chassis and cover material : Electric galvanizing steel board. ¶ Dimensions in mm, [ ]=inches ¶ Mounting torque (Mounting hole of chassis) : 0.6N-m (6.3kgf-cm) max ¶ Keep drawing current per pin below 5A for CN2. January 31, 2022 LFA-7 Ordering information AC-DC Power Supplies Open Frame/ Enclosed Type LFA50F LF 1 A 50 2 3 F 4 Example recommended EMI/EMC filter NAC-04-472 R -O 5 High voltage pulse noise type : NAP series Low leakage current type : NAM series * A higher current rating EMI/EMC filter may be recommended in view of the other devices that could be connected in parallel with the power supply. -O 6 1 Series name 2 Single output 3 Output wattage 4 Universal input 5 Output voltage 6 Optional C : with Coating G : Low leakage current J1 : VH(J.S.T.)connector type S : with Chassis SN: with Chassis & cover Y : with Potentiometer Specification is changed at option, refer to Instruction Manual. This power supply is manufactured by SMD technology. The stress to P.C.B like twisting or bending causes the defect of the unit, so handle the unit with care. *Make sure necessary tests will be carried out on your end equipment with the power supply installed in accordance with any required EMC/EMI regulations. MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT LFA50F-3R3-Y LFA50F-5 33 50 3.3V 10A 5V 10A LFA50F-12 51.6 12V 4.3A LFA50F-15 52.5 15V 3.5A LFA50F-24 50.4 24V 2.1A LFA50F-36 50.4 36V 1.4A LFA50F-48 52.8 48V 1.1A SPECIFICATIONS MODEL VOLTAGE[V] CURRENT[A] ACIN 100V ACIN 200V FREQUENCY[Hz] INPUT OUTPUT PROTECTION CIRCUIT AND OTHERS ISOLATION ENVIRONMENT SAFETY AND NOISE REGULATIONS OTHERS ACIN 100V ACIN 200V ACIN 100V POWER FACTOR (Io=100%) ACIN 200V ACIN 100V INRUSH CURRENT[A] ACIN 200V LEAKAGE CURRENT[mA] VOLTAGE[V] CURRENT[A] LINE REGULATION[mV] *4 LOAD REGULATION[mV] *4 0 to +50C *1 RIPPLE[mVp-p] -10 - 0C *1 0 to +50C *1 RIPPLE NOISE[mVp-p] -10 - 0C *1 0 to +50C TEMPERATURE REGULATION[mV] -10 to +50C *2 DRIFT[mV] START-UP TIME[ms] HOLD-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE[V] OUTPUT VOLTAGE SETTING[V] OVERCURRENT PROTECTION OVERVOLTAGE PROTECTION OPERATING INDICATION REMOTE SENSING REMOTE ON/OFF INPUT-OUTPUT INPUT-FG OUTPUT-FG OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE VIBRATION IMPACT AGENCY APPROVALS CONDUCTED NOISE HARMONIC ATTENUATOR CASE SIZE/WEIGHT COOLING METHOD EFFICIENCY[%] LFA50F-3R3-Y LFA50F-5 LFA50F-12 LFA50F-15 LFA50F-24 LFA50F-36 LFA50F-48 AC85 - 264 1f (Refer to “Derating”, Instruction Manual 1 and 3) *3 0.47typ (Io=100%) 0.67typ (Io=100%) 0.27typ (Io=100%) 0.36typ (Io=100%) 50 / 60 (47 - 63) 73.5typ 77.5typ 80.0typ 80.5typ 81.5typ 82.0typ 81.0typ 74.0typ 79.0typ 81.5typ 81.5typ 83.0typ 83.5typ 82.5typ 0.96typ 0.97typ 0.83typ 0.90typ 15typ (Io=100%) (At cold start) (Ta=25C) 30typ (Io=100%) (At cold start) (Ta=25C) 0.40 / 0.75max (ACIN 100V / 240V 60Hz, Io=100%, According to IEC62368-1 and DEN-AN) 3.3 5 12 15 24 36 48 10.0 10.0 4.3 3.5 2.1 1.4 1.1 20max 20max 48max 60max 96max 144max 192max 40max 40max 100max 120max 150max 240max 240max 80max 80max 120max 120max 120max 150max 150max 140max 140max 160max 160max 160max 200max 200max 120max 120max 150max 150max 150max 250max 250max 160max 160max 180max 180max 180max 300max 300max 50max 50max 120max 150max 240max 360max 480max 60max 60max 150max 180max 290max 450max 600max 20max 20max 48max 60max 96max 144max 192max 350typ (ACIN 100V, Io=100%) 20typ (ACIN 100V, Io=100%) 2.85 to 3.63 Fixed (“Y”option is available for adjusting output voltage between ±10%) 3.30 to 3.40 4.90 to 5.30 11.50 to 12.50 14.40 to 15.60 23.00 to 25.00 34.50 to 37.50 46.00 to 50.00 Works over 105% of rating and recovers automatically 4.00 to 5.25 5.75 to 7.00 13.80 to 16.80 17.25 to 21.00 27.60 to 33.60 41.40 to 50.40 55.20 to 67.20 Not provided Not provided Not provided AC3,000V 1minute, Cutoff current = 10mA, DC500V 50MW min (At Room Temperature) AC2,000V 1minute, Cutoff current = 10mA, DC500V 50MW min (At Room Temperature) AC500V 1minute, Cutoff current = 25mA, DC500V 50MW min (At Room Temperature) -10 to +70C, 20 - 90%RH (Non condensing) (Refer to “Derating”, Instruction Manual 3), 3,000m (10,000feet) max *3 -20 to +75C, 20 - 90%RH (Non condensing), 9,000m (30,000feet) max 10 - 55Hz, 19.6m/s2 (2G), 3minutes period, 60minutes each along X, Y and Z axis 196.1m/s2 (20G), 11ms, once each X, Y and Z axis UL60950-1, C-UL (CSA60950-1), EN62368-1 Complies with DEN-AN Complies with FCC-B, VCCI-B, CISPR-B, EN55011-B, EN55022-B Complies with IEC61000-3-2 (Class A) *5 50X26.5X132mm [1.97X1.04X5.20 inches] (WXHXD) / 165g max (with chassis & cover : 325g max) Convection (Refer to “Derating”, Instruction Manual 3) *3 *1 This is the value that measured on measuring board with capacitor of 22mF at 150mm from output terminal. Measured by 20MHz oscilloscope or Ripple-Noise meter (Equivalent to KEISOKU-GIKEN: RM103). *2 Drift is the change in DC output for an eight hour period after a half-hour warm-up at 25C, with the input voltage held constant at the rated input/output. LFA-8 *3 Derating is required. *4 Please contact us about dynamic load and input response. *5 Please contact us about another class. * To meet the specifications. Do not operate over-loaded condition. * Parallel operation is not possible. * Derating is required when operated with chassis and cover. Sound noise may be generated by power supply in case of pulse load. * January 31, 2022 LFA50F Block diagram FUSE 250V2.5A AC IN 85 NOISE FILTER 264V RECTIFIER INRUSH CURRENT LIMIT FG TRANSFORMER INVERTER CONTROL BOOSTER INDUCTOR CURRENT SENSING RECTIFIER AND FILTER CURRENT SENSING RECTIFIER AND FILTER DC OUT Photocoupler INVERTER CONTROL Photocoupler OVER VOLTAGE PROTECTION CONTROL External view Standard type [6.38] 150 ±0.5 f3.5 [5.91] 30 10 [0.59] [0.39] Mating connector CN1 1-1123724-3 1-1123722-5 CN2 1-1123723-4 1-1123722-4 15 2-M3 Mounting Hole ¶1 Surface mount device I/O Connector Terminal 1123721-1 Chain Loose 1318912-1 Chain 1123721-1 Loose 1318912-1 (Mfr:Tyco Electronics) ¶ I/O Connector is Mfr. Tyco Electronics ¶ Option:-J1:(J.S.T) connector type. Refer to Instruction Manual 6. [2.36] 6 [0.24] 3.5 23 [0.91] [0.14] PCB t=1.6 ¶ 4 Mounting holes are existing. ¶ The back side of P.C.B. of the power supply is assembled some SMDs. Be attention not to bump against the attached area by vibration. ¶ Use the spacer of 8mm length or more regarding insulation. And do not use press-fitting bush. ¶ Point A, Point B are thermometry points. Please refer to Instruction Manual 3. 60 3.5 162 [5.2] 3.5max Output(-) Output(+) Mounting Hole 132 ¶1 [1.18] 20 [0.79] 1 2 3 4 36 [4.8] [0.2] 4 [0.16] 10 [0.6] 15.2 Point B 122 ±0.5 CN2 1 CN1 3.5 Point A 5 3 [0.14] 5 [0.2] CN2 5 [1.42] CN1 FG Input(N) Input(L) Output(-) Output(+) 1 2 3 4 Mounting Hole [0.14] 1 FG Input(N) Input(L) 4-M3 6 [0.24] [0.14] 3 150 ±0.5 [5.91] Mounting Hole 40 ±0.5 [1.57] 20 ±0.5 [0.79] 50 [1.97] 40 ±0.5 [1.57] 5 2-f3.5 3-f3.5 4.9 [0.19] [0.39] Voltage adjust (LFA50F-3R3-Y or optional) Name plate FG Chassis and cover type CN1 Pin No. 1 2 3 4 5 CN2 Input AC(L) AC(N) Pin No. Output 1, 2 -V 3, 4 +V FG ¶ Tolerance : ±1 [±0.04] ¶ Weight : 165g max (with chassis & cover : 325g max) ¶ PCB material / thickness : CEM3 / 1.6mm ¶ Optional chassis and cover material : Electric galvanizing steel board. ¶ Dimensions in mm, [ ]=inches ¶ Mounting torque (Mounting hole of chassis) : 0.6N-m (6.3kgf-cm) max ¶ Keep drawing current per pin below 5A for CN2. January 31, 2022 LFA-9 Ordering information AC-DC Power Supplies Open Frame/ Enclosed Type LFA75F LF 1 A 75 2 3 F 4 Example recommended EMI/EMC filter NAC-04-472 R -O 5 High voltage pulse noise type : NAP series Low leakage current type : NAM series * A higher current rating EMI/EMC filter may be recommended in view of the other devices that could be connected in parallel with the power supply. -O 6 1 Series name 2 Single output 3 Output wattage 4 Universal input 5 Output voltage 6 Optional C : with Coating G : Low leakage current J1 : VH(J.S.T.)connector type S : with Chassis SN: with Chassis & cover Y : with Potentiometer Specification is changed at option, refer to Instruction Manual. This power supply is manufactured by SMD technology. The stress to P.C.B like twisting or bending causes the defect of the unit, so handle the unit with care. *Make sure necessary tests will be carried out on your end equipment with the power supply installed in accordance with any required EMC/EMI regulations. MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT LFA75F-3R3-Y LFA75F-5 49.5 75 3.3V 15A 5V 15A LFA75F-12 75.6 12V 6.3A LFA75F-15 75 15V 5A LFA75F-24 76.8 24V 3.2A LFA75F-36 75.6 36V 2.1A LFA75F-48 76.8 48V 1.6A SPECIFICATIONS MODEL VOLTAGE[V] CURRENT[A] ACIN 100V ACIN 200V FREQUENCY[Hz] INPUT OUTPUT PROTECTION CIRCUIT AND OTHERS ISOLATION ENVIRONMENT SAFETY AND NOISE REGULATIONS OTHERS ACIN 100V ACIN 200V ACIN 100V POWER FACTOR (Io=100%) ACIN 200V ACIN 100V INRUSH CURRENT[A] ACIN 200V LEAKAGE CURRENT[mA] VOLTAGE[V] CURRENT[A] LINE REGULATION[mV] *4 LOAD REGULATION[mV] *4 0 to +50C *1 RIPPLE[mVp-p] -10 - 0C *1 0 to +50C *1 RIPPLE NOISE[mVp-p] -10 - 0C *1 0 to +50C TEMPERATURE REGULATION[mV] -10 to +50C *2 DRIFT[mV] START-UP TIME[ms] HOLD-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE[V] OUTPUT VOLTAGE SETTING[V] OVERCURRENT PROTECTION OVERVOLTAGE PROTECTION OPERATING INDICATION REMOTE SENSING REMOTE ON/OFF INPUT-OUTPUT INPUT-FG OUTPUT-FG OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE VIBRATION IMPACT AGENCY APPROVALS CONDUCTED NOISE HARMONIC ATTENUATOR CASE SIZE/WEIGHT COOLING METHOD EFFICIENCY[%] LFA75F-3R3-Y LFA75F-5 LFA75F-12 LFA75F-15 LFA75F-24 LFA75F-36 LFA75F-48 AC85 - 264 1f (Refer to “Derating”, Instruction Manual 1 and 3) *3 0.70typ (Io=100%) 1.00typ (Io=100%) 0.40typ (Io=100%) 0.50typ (Io=100%) 50 / 60 (47 - 63) 73.5typ 78.0typ 81.5typ 81.5typ 82.5typ 82.5typ 82.5typ 75.0typ 80.0typ 83.0typ 83.0typ 84.5typ 84.5typ 84.5typ 0.96typ 0.97typ 0.83typ 0.90typ 15typ (Io=100%) (At cold start) (Ta=25C) 30typ (Io=100%) (At cold start) (Ta=25C) 0.40 / 0.75max (ACIN 100V / 240V 60Hz, Io=100%, According to IEC62368-1 and DEN-AN) 3.3 5 12 15 24 36 48 15.0 15.0 6.3 5.0 3.2 2.1 1.6 20max 20max 48max 60max 96max 144max 192max 40max 40max 100max 120max 150max 240max 240max 80max 80max 120max 120max 120max 150max 150max 140max 140max 160max 160max 160max 200max 200max 120max 120max 150max 150max 150max 250max 250max 160max 160max 180max 180max 180max 300max 300max 50max 50max 120max 150max 240max 360max 480max 60max 60max 150max 180max 290max 450max 600max 20max 20max 48max 60max 96max 144max 192max 350typ (ACIN 100V, Io=100%) 20typ (ACIN 100V, Io=100%) Fixed (“Y”option is available for adjusting output voltage between ±10%) 2.85 to 3.63 3.30 to 3.40 4.90 to 5.30 11.50 to 12.50 14.40 to 15.60 23.00 to 25.00 34.50 to 37.50 46.00 to 50.00 Works over 105% of rating and recovers automatically 4.00 to 5.25 5.75 to 7.00 13.80 to 16.80 17.25 to 21.00 27.60 to 33.60 41.40 to 50.40 55.20 to 67.20 Not provided Not provided Not provided AC3,000V 1minute, Cutoff current = 10mA, DC500V 50MW min (At Room Temperature) AC2,000V 1minute, Cutoff current = 10mA, DC500V 50MW min (At Room Temperature) AC500V 1minute, Cutoff current = 25mA, DC500V 50MW min (At Room Temperature) -10 to +70C, 20 - 90%RH (Non condensing) (Refer to “Derating”, Instruction Manual 3), 3,000m (10,000feet) max *3 -20 to +75C, 20 - 90%RH (Non condensing), 9,000m (30,000feet) max 10 - 55Hz, 19.6m/s2 (2G), 3minutes period, 60minutes each along X, Y and Z axis 196.1m/s2 (20G), 11ms, once each X, Y and Z axis UL60950-1, C-UL (CSA60950-1), EN62368-1 Complies with DEN-AN Complies with FCC-B, VCCI-B, CISPR-B, EN55011-B, EN55022-B Complies with IEC61000-3-2 (Class A) *5 50X33.5X150mm [1.97X1.32X5.91 inches] (WXHXD) / 230g max (with chassis & cover : 440g max) Convection (Refer to “Derating”, Instruction Manual 3) *3 *1 This is the value that measured on measuring board with capacitor of 22mF at 150mm from output terminal. Measured by 20MHz oscilloscope or Ripple-Noise meter (Equivalent to KEISOKU-GIKEN: RM103). *2 Drift is the change in DC output for an eight hour period after a half-hour warm-up at 25C, with the input voltage held constant at the rated input/output. LFA-10 *3 Derating is required. *4 Please contact us about dynamic load and input response. *5 Please contact us about another class. * To meet the specifications. Do not operate over-loaded condition. * Parallel operation is not possible. * Derating is required when operated with chassis and cover. Sound noise may be generated by power supply in case of pulse load. * January 31, 2022 LFA75F Block diagram FUSE 250V3.15A AC IN 85 NOISE FILTER 264V RECTIFIER INRUSH CURRENT LIMIT FG TRANSFORMER INVERTER CONTROL BOOSTER INDUCTOR CURRENT SENSING RECTIFIER AND FILTER CURRENT SENSING RECTIFIER AND FILTER DC OUT Photocoupler INVERTER CONTROL Photocoupler OVER VOLTAGE PROTECTION CONTROL External view Standard type 1 3 4 6 Point A Point B 140 ±0.5 [5.51] 150 [5.91] 5 [0.2] 4 [0.16] 10 [0.39] 20 [0.79] [0.7] 17.8 CN2 FG Output(-) Output(+) Input(N) Input(L) CN2 5 1 3 3 4 1 CN1 4-M4 5.5 [0.22] 169 ±0.5 [6.65] 6 Mounting Hole Output(-) Output(+) 60 [2.36] CN1 FG Input(N) Input(L) 2-f4.5 4.5 [0.18] 30 [1.18] 1 Mounting Hole 3.5 [0.14] 3 5 [0.2] 50 [1.97] 40 ±0.5 [1.57] 5 3-f3.5 13 [0.51] 40 ±0.5 [1.57] 20 ±0.5 [0.79] Voltage adjust (LFA75F-3R3-Y or optional) Name plate FG Chassis and cover type Mounting Hole 180 [7.09] 169 ±0.5 [6.65] 5.5 [0.22] ¶1 2-M4 PCB t=1.6 Mounting Hole ¶1 Surface mount device ¶ 4 Mounting holes are existing. ¶ The back side of P.C.B. of the power supply is assembled some SMDs. Be attention not to bump against the attached area by vibration. ¶ Use the spacer of 8mm length or more regarding insulation. And do not use press-fitting bush. ¶ Point A, Point B are thermometry points. Please refer to Instruction Manual 3. I/O Connector Mating connector CN1 1-1123724-3 1-1123722-5 CN2 1-1123723-6 1-1123722-6 Terminal 1123721-1 Chain 1318912-1 Loose Chain 1123721-1 1318912-1 Loose (Mfr:Tyco Electronics) ¶ I/O Connector is Mfr. Tyco Electronics ¶ Option:-J1:(J.S.T) connector type. Refer to Instruction Manual 6. 4.5 [0.18] 15 15 [0.59] [0.59] 45 [1.77] 3.5max [0.14] 30 [1.18] f4.5 CN1 Pin No. 1 2 3 4 5 CN2 Input AC(L) AC(N) Pin No. Output 1 to 3 -V 4 to 6 +V FG ¶ Tolerance : ±1 [±0.04] ¶ Weight : 230g max (with chassis & cover : 440g max) ¶ PCB material / thickness : CEM3 / 1.6mm ¶ Optional chassis and cover material : Electric galvanizing steel board. ¶ Dimensions in mm, [ ]=inches ¶ Mounting torque (Mounting hole of chassis) :1.5N-m (16kgf-cm) max ¶ Keep drawing current per pin below 5A for CN2. January 31, 2022 LFA-11 Ordering information AC-DC Power Supplies Open Frame/ Enclosed Type LFA100F LF 1 A 100 2 3 F 4 Example recommended EMI/EMC filter NAC-04-472 R High voltage pulse noise type : NAP series Low leakage current type : NAM series * A higher current rating EMI/EMC filter may be recommended in view of the other devices that could be connected in parallel with the power supply. This power supply is manufactured by SMD technology. The stress to P.C.B like twisting or bending causes the defect of the unit, so handle the unit with care. *Make sure necessary tests will be carried out on your end equipment with the power supply installed in accordance with any required EMC/EMI regulations. MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT *5 *5 -O 5 -O 6 1 Series name 2 Single output 3 Output wattage 4 Universal input 5 Output voltage 6 Optional *1 C : with Coating G : Low leakage current H : with the function to be acceptable to output peak current (only 24V) J1 : VH(J.S.T.)connector type R : with Remote ON/OFF R2 : with Remote ON/OFF S : with Chassis SN: with Chassis & cover Y : with Potentiometer Please refer to Instruction manual 6. LFA100F-3R3-Y LFA100F-5-Y LFA100F-12 LFA100F-15 LFA100F-24 LFA100F-24-H LFA100F-36 LFA100F-48 66 100 102 100.5 103.2 103.2 (129.6) 100.8 100.8 3.3V 20A 5V 20A 12V 8.5A 15V 6.7A 24V 4.3A 24V 4.3 (5.4)A 36V 2.8A 48V 2.1A SPECIFICATIONS MODEL VOLTAGE[V] CURRENT[A] ACIN 100V ACIN 200V FREQUENCY[Hz] INPUT OUTPUT PROTECTION CIRCUIT AND OTHERS ISOLATION ENVIRONMENT SAFETY AND NOISE REGULATIONS OTHERS ACIN 100V ACIN 200V ACIN 100V POWER FACTOR (Io=100%) ACIN 200V ACIN 100V INRUSH CURRENT[A] ACIN 200V LEAKAGE CURRENT[mA] VOLTAGE[V] *5 CURRENT[A] LINE REGULATION[mV] *7 LOAD REGULATION[mV] *7 0 to +50C *2 RIPPLE[mVp-p] -10 - 0C *2 0 to +50C *2 RIPPLE NOISE[mVp-p] -10 - 0C *2 0 to +50C TEMPERATURE REGULATION[mV] -10 to +50C *3 DRIFT[mV] START-UP TIME[ms] HOLD-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE[V] OUTPUT VOLTAGE SETTING[V] OVERCURRENT PROTECTION OVERVOLTAGE PROTECTION OPERATING INDICATION REMOTE SENSING REMOTE ON/OFF *6 INPUT-OUTPUT.RC INPUT-FG *6 OUTPUT.RC-FG *6 OUTPUT-RC OPERATING TEMP.,HUMID.AND ALTITUDE *4 STORAGE TEMP.,HUMID.AND ALTITUDE VIBRATION IMPACT AGENCY APPROVALS CONDUCTED NOISE HARMONIC ATTENUATOR CASE SIZE/WEIGHT COOLING METHOD EFFICIENCY[%] LFA100F-3R3-Y LFA100F-5-Y LFA100F-12 LFA100F-15 LFA100F-24 LFA100F-24-H LFA100F-36 LFA100F-48 AC85 - 264 1f (Refer to “Derating”, Instruction Manual 1 and 3) *4 0.9typ (Io=100%) 1.3typ (Io=100%) 0.5typ (Io=100%) 0.7typ (Io=100%) 50 / 60 (47 - 63) 77.0typ 82.0typ 82.0typ 83.0typ 84.0typ 84.0typ 84.0typ 84.5typ 79.0typ 84.0typ 84.5typ 85.5typ 87.0typ 87.0typ 87.0typ 87.0typ 0.98typ 0.99typ 0.92typ 0.95typ 15typ (Io=100%) (At cold start) (Ta=25C) 30typ (Io=100%) (At cold start) (Ta=25C) 0.40 / 0.75max (ACIN 100V / 240V 60Hz, Io=100%, According to IEC62368-1 and DEN-AN) 3.3 5 12 15 24 24 36 48 20 20 8.5 6.7 4.3 4.3 (Peak 5.4) 2.8 2.1 20max 20max 48max 60max 96max 96max 144max 192max 40max 40max 100max 120max 150max 150max 240max 240max 80max 80max 120max 120max 120max 240max 150max 150max 140max 140max 160max 160max 160max 320max 200max 200max 120max 120max 150max 150max 150max 300max 250max 250max 160max 160max 180max 180max 180max 360max 300max 300max 50max 50max 120max 150max 240max 240max 360max 480max 60max 60max 150max 180max 290max 290max 450max 600max 20max 20max 48max 60max 96max 96max 144max 192max 350typ (ACIN 100V, Io=100%) 20typ (ACIN 100V, Io=100%) 2.85 to 3.63 4.50 to 5.50 Fixed (“Y”option is available for adjusting output voltage) 3.30 to 3.40 5.00 to 5.15 11.50 to 12.50 14.40 to 15.60 23.00 to 25.00 23.00 to 25.00 34.50 to 37.50 46.00 to 50.00 Works over 105% of rating (works over 101% of peak current at option -H) and recovers automatically 4.00 to 5.25 5.75 to 7.00 13.80 to 16.80 17.25 to 21.00 27.60 to 33.60 27.60 to 33.60 41.40 to 50.40 55.20 to 67.20 Not provided Not provided Option (Refer to Instruction Manual) AC3,000V 1minute, Cutoff current = 10mA, DC500V 50MW min (At Room Temperature) AC2,000V 1minute, Cutoff current = 10mA, DC500V 50MW min (At Room Temperature) AC500V 1minute, Cutoff current = 25mA, DC500V 50MW min (At Room Temperature) AC100V 1minute, Cutoff current = 25mA, DC100V 10MW min (At Room Temperature) -10 to +70C, 20 - 90%RH (Non condensing) (Refer to “Derating”, Instruction Manual 3), 3,000m (10,000feet) max -20 to +75C, 20 - 90%RH (Non condensing), 9,000m (30,000feet) max 10 - 55Hz, 19.6m/s2 (2G), 3minutes period, 60minutes each along X, Y and Z axis 196.1m/s2 (20G), 11ms, once each X, Y and Z axis UL60950-1, C-UL (CSA60950-1), EN62368-1 Complies with DEN-AN Complies with FCC-B, VCCI-B, CISPR-B, EN55011-B, EN55022-B Complies with IEC61000-3-2 (Class A) *8 62X33.5X155mm [2.44X1.32X6.10 inches] (WXHXD) / 280g max (with chassis & cover : 480g max) Convection (Refer to “Derating”, Instruction Manual 3) *4 *1 Specification is changed at option, refer to Instruction Manual. *2 This is the value that measured on measuring board with capacitor of 22mF at 150mm from output terminal. Measured by 20MHz oscilloscope or Ripple-Noise meter (Equivalent to KEISOKU-GIKEN: RM103). *3 Drift is the change in DC output for an eight hour period after a half-hour warm-up at 25C, with the input voltage held constant LFA-12 at the rated input/output. *4 Derating is required. *5 ( ) means peak current. There is a possibility that an internal device is damaged when the specification is exceeded. Please contact us about the detail. *6 Applicable when Remote ON/OFF (optional) is added. *7 Please contact us about dynamic load and input response. January 31, 2022 *8 Please contact us about another class. * To meet the specifications. Do not operate over-loaded condition. * Parallel operation is not possible. * Derating is required when operated with chassis and cover. * Sound noise may be generated by power supply in case of pulse load. LFA100F Block diagram FUSE 250V3.15A NOISE FILTER AC IN 85 - 264V RECTIFIER INRUSH CURRENT LIMIT FG Photocoupler OPTION CURRENT SENSING BOOSTER INDUCTOR RC EXTERNAL SOURCE Photocoupler CURRENT SENSING RECTIFIER AND FILTER CONTROL E CONTROL Photocoupler OVER VOLTAGE PROTECTION INVERTER INVERTER RECTIFIER AND FILTER TRANSFORMER CONTROL DC OUT External view ¶ External size of option is different from standard model. Standard type Input(L) CN1 4 5 5 [0.2] 8 Point A Point B Voltage adjust (LFA100F-3R3-Y,LFA100F-5-Y or Optional) 5 [0.2] Output(+) 3.5max [0.14] 13 [0.51] 23 [0.91] FG Input(N) 1 2 1 5 3 Input(L) CN2 Output(-) 4 5 1 CN1 Output(+) 8 Mounting Hole 185 [7.28] 173±0.5 [6.81] f4.5 30 [1.18] 145±0.5 [5.71] 155 [6.1] 4 [0.16] 16.5 [0.65] CN4 CN2 Output(-) 72 [2.83] 1 1 2 1 4-M4 Mounting Hole 4.5 [0.18] 36 [1.42] Input(N) 6 [0.24] 6 [0.24] 4.5 [0.18] 20 15 [0.79] [0.59] 45 [1.77] FG 3 173±0.5 [6.81] 2-f4.5 45±0.5 [1.77] 25±0.5 [0.98] 62 [2.44] 52±0.5 [2.05] 5 Connector for Remote ON/OFF (Optional) 3-f3.5 Mounting Hole 3.5 [0.14] Name plate FG Chassis and cover type 2-M4 Mounting Hole PCB t=1.6 ¶1 ¶1 Surface mount device ¶ 4 Mounting holes are existing. ¶ The back side of P.C.B. of the power supply is assembled some SMDs. Be attention not to bump against the attached area by vibration. ¶ Use the spacer of 8mm length or more regarding insulation. And do not use press-fitting bush. ¶ Point A, Point B are thermometry points. Please refer to Instruction Manual 3. I/O Connector Mating connector CN1 1-1123724-3 1-1123722-5 CN2 1-1123723-8 1-1123722-8 Terminal 1123721-1 Chain 1318912-1 Loose Chain 1123721-1 1318912-1 Loose (Mfr:Tyco Electronics) ¶ I/O Connector is Mfr. Tyco Electronics ¶ Option:-J1:VH(J.S.T) connector type. Connector type CN1 Pin No. 1 2 3 4 5 CN4 Option (Mfr:J.S.T) CN2 Input AC(L) AC(N) Pin No. Output 1 to 4 -V 5 to 8 +V FG ¶ Keep drawing current per pin below 5A for CN2. ¶ Tolerance : ±1 [±0.04] ¶ Weight : 280g max (with chassis & cover : 480g max) ¶ PCB material : CEM3 ¶ Optional chassis and cover material : Electric galvanizing steel board. ¶ Dimensions in mm, [ ]=inches ¶ Mounting torque (Mounting hole of chassis) :1.5N-m (16kgf-cm) max January 31, 2022 PIN No. 1 2 Contents RC(+) RC(-) Barrier strip type Model B2B-XH-A Mating Connector (Terminal) XHP-2 BXH-001T-P0.6 or SXH-001T-P0.6 LFA-13 Ordering information AC-DC Power Supplies Open Frame/ Enclosed Type LFA150F LF 1 A 150 2 3 F 4 Example recommended EMI/EMC filter NAC-04-472 R High voltage pulse noise type : NAP series Low leakage current type : NAM series * A higher current rating EMI/EMC filter may be recommended in view of the other devices that could be connected in parallel with the power supply. This power supply is manufactured by SMD technology. The stress to P.C.B like twisting or bending causes the defect of the unit, so handle the unit with care. *Make sure necessary tests will be carried out on your end equipment with the power supply installed in accordance with any required EMC/EMI regulations. MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT *5 *5 -O 5 -O 6 1 Series name 2 Single output 3 Output wattage 4 Universal input 5 Output voltage 6 Optional *1 C : with Coating G : Low leakage current H : with the function to be acceptable to output peak current (only 24V) J1 : VH(J.S.T.)connector type R : with Remote ON/OFF R2 : with Remote ON/OFF S : with Chassis SN: with Chassis & cover Y : with Potentiometer Please refer to Instruction manual 6. LFA150F-3R3-Y LFA150F-5-Y LFA150F-12 LFA150F-15 LFA150F-24 LFA150F-24-H LFA150F-36 LFA150F-48 99 150 150 150 151.2 151.2 (189.6) 151.2 153.6 3.3V 30A 5V 30A 12V 12.5A 15V 10A 24V 6.3A 24V 6.3 (7.9)A 36V 4.2A 48V 3.2A SPECIFICATIONS MODEL VOLTAGE[V] CURRENT[A] ACIN 100V ACIN 200V FREQUENCY[Hz] INPUT OUTPUT PROTECTION CIRCUIT AND OTHERS ISOLATION ENVIRONMENT SAFETY AND NOISE REGULATIONS OTHERS ACIN 100V ACIN 200V ACIN 100V POWER FACTOR (Io=100%) ACIN 200V ACIN 100V INRUSH CURRENT[A] ACIN 200V LEAKAGE CURRENT[mA] VOLTAGE[V] *5 CURRENT[A] LINE REGULATION[mV] *7 LOAD REGULATION[mV] *7 0 to +40C *2 RIPPLE[mVp-p] -10 - 0C *2 0 to +40C *2 RIPPLE NOISE[mVp-p] -10 - 0C *2 0 to +40C TEMPERATURE REGULATION[mV] -10 to +40C *3 DRIFT[mV] START-UP TIME[ms] HOLD-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE[V] OUTPUT VOLTAGE SETTING[V] OVERCURRENT PROTECTION OVERVOLTAGE PROTECTION OPERATING INDICATION REMOTE SENSING REMOTE ON/OFF *6 INPUT-OUTPUT.RC INPUT-FG *6 OUTPUT.RC-FG *6 OUTPUT-RC OPERATING TEMP.,HUMID.AND ALTITUDE *4 STORAGE TEMP.,HUMID.AND ALTITUDE VIBRATION IMPACT AGENCY APPROVALS CONDUCTED NOISE HARMONIC ATTENUATOR CASE SIZE/WEIGHT COOLING METHOD EFFICIENCY[%] LFA150F-3R3-Y LFA150F-5-Y LFA150F-12 LFA150F-15 LFA150F-24 LFA150F-24-H LFA150F-36 LFA150F-48 AC85 - 264 1f (Refer to “Derating”, Instruction Manual 1 and 3) *4 1.4typ (Io=100%) 2.0typ (Io=100%) 0.7typ (Io=100%) 1.0typ (Io=100%) 50 / 60 (47 - 63) 80.0typ 82.5typ 82.5typ 84.0typ 85.0typ 85.0typ 85.0typ 85.5typ 82.0typ 85.5typ 85.0typ 86.5typ 87.5typ 87.5typ 87.5typ 88.0typ 0.98typ 0.99typ 0.92typ 0.95typ 15typ (Io=100%) (At cold start) (Ta=25C) 30typ (Io=100%) (At cold start) (Ta=25C) 0.40 / 0.75max (ACIN 100V / 240V 60Hz, Io=100%, According to IEC62368-1 and DEN-AN) 3.3 5 12 15 24 24 36 48 30 30 12.5 10 6.3 6.3 (Peak 7.9) 4.2 3.2 20max 20max 48max 60max 96max 96max 144max 192max 40max 40max 100max 120max 150max 150max 240max 240max 80max 80max 120max 120max 120max 240max 150max 150max 140max 140max 160max 160max 160max 320max 200max 200max 120max 120max 150max 150max 150max 300max 250max 250max 160max 160max 180max 180max 180max 360max 300max 300max 50max 50max 120max 150max 240max 240max 360max 480max 60max 60max 150max 180max 290max 290max 450max 600max 20max 20max 48max 60max 96max 96max 144max 192max 350typ (ACIN 100V, Io=100%) 20typ (ACIN 100V, Io=100%) 2.85 to 3.63 4.50 to 5.50 Fixed (“Y”option is available for adjusting output voltage) 3.30 to 3.40 5.00 to 5.15 11.50 to 12.50 14.40 to 15.60 23.00 to 25.00 23.00 to 25.00 34.50 to 37.50 46.00 to 50.00 Works over 105% of rating (works over 101% of peak current at option -H) and recovers automatically 4.00 to 5.25 5.75 to 7.00 13.80 to 16.80 17.25 to 21.00 27.60 to 33.60 27.60 to 33.60 41.40 to 50.40 55.20 to 67.20 Not provided Not provided Option (Refer to Instruction Manual) AC3,000V 1minute, Cutoff current = 10mA, DC500V 50MW min (At Room Temperature) AC2,000V 1minute, Cutoff current = 10mA, DC500V 50MW min (At Room Temperature) AC500V 1minute, Cutoff current = 25mA, DC500V 50MW min (At Room Temperature) AC100V 1minute, Cutoff current = 25mA, DC100V 10MW min (At Room Temperature) -10 to +70C, 20 - 90%RH (Non condensing) (Refer to “Derating”, Instruction Manual 3), 3,000m (10,000feet) max -20 to +75C, 20 - 90%RH (Non condensing), 9,000m (30,000feet) max 10 - 55Hz, 19.6m/s2 (2G), 3minutes period, 60minutes each along X, Y and Z axis 196.1m/s2 (20G), 11ms, once each X, Y and Z axis UL60950-1, C-UL (CSA60950-1), EN62368-1 Complies with DEN-AN Complies with FCC-B, VCCI-B, CISPR-B, EN55011-B, EN55022-B Complies with IEC61000-3-2 (Class A) *8 75X37.0X160mm [2.95X1.46X6.30 inches] (WXHXD) / 390g max (with chassis & cover : 650g max) Convection (Refer to “Derating”, Instruction Manual 3) *4 *1 Specification is changeed at option, refer to Instruction Manual. *2 This is the value that measured on measuring board with capacitor of 22mF at 150mm from output terminal. Measured by 20MHz oscilloscope or Ripple-Noise meter (Equivalent to KEISOKU-GIKEN: RM103). *3 Drift is the change in DC output for an eight hour period after a half-hour warm-up at 25C, with the input voltage held constant LFA-14 at the rated input/output. *4 Derating is required. *5 ( ) means peak current. There is a possibility that an internal device is damaged when the specification is exceeded. Please contact us about the detail. *6 Applicable when remote control (optional) is added. *7 Please contact us about dynamic load and input response. January 31, 2022 *8 Please contact us about another class. * To meet the specifications. Do not operate over-loaded condition. * Parallel operation is not possible. * Derating is required when operated with chassis and cover. * Sound noise may be generated by power supply in case of pulse load. LFA150F Block diagram FUSE 250V5A NOISE FILTER AC IN 85 - 264V INRUSH CURRENT LIMIT RECTIFIER FG Photocoupler OPTION CURRENT SENSING BOOSTER INDUCTOR CURRENT SENSING RC RECTIFIER AND FILTER E EXTERNAL SOURCE Photocoupler CONTROL CONTROL Photocoupler INVERTER OVER VOLTAGE PROTECTION INVERTER RECTIFIER AND FILTER TRANSFORMER CONTROL DC OUT External view ¶ External size of option is different from standard model. Standard type FG Input(N) Input(L) CN3 Output(-) 1 7 1 CN2 Output(+) 1 5 CN3 Output(-) 3 1 7 1 CN1 CN2 Output(+) 6 6 Mounting Hole 188 [7.4] 176±0.5 [6.93] f4.5 6 [0.24] 33.5 [1.32] Voltage adjust (LFA150F-3R3-Y,LFA150F-5-Y or Optional) 150±0.5 [5.91] 160 [6.3] 4 [0.16] 18 [0.71] 4.5 [0.18] 20 15 [0.79] [0.59] 47 [1.85] 5 [0.2] 5 [0.2] 2 1 2 1 3.5 [0.14] 6.5 [0.26] CN4 Connector for Remote ON/OFF (optional) 2-M4 Mounting Hole 3.5max [0.14] 4-M4 Mounting Hole 42 [1.65] Input(N) 55±0.5 [2.17] 35±0.5 [1.38] FG 3 6 [0.24] 176±0.5 [6.93] 2-f4.5 1 5 Input(L) CN1 75 [2.95] 65±0.5 [2.6] 3-f3.5 Mounting Hole 85 [3.35] Point B Point A 4.5 [0.18] Name plate 15 [0.59] 25 [0.98] FG Chassis and cover type PCB t=1.6 ¶1 ¶1 Surface mount device ¶ 4 Mounting holes are existing. ¶ The back side of P.C.B. of the power supply is assembled some SMDs. Be attention not to bump against the attached area by vibration. ¶ Use the spacer of 8mm length or more regarding insulation. And do not use press-fitting bush. ¶ Point A, Point B are thermometry points. Please refer to Instruction Manual 3. I/O Connector Mating connector CN1 1-1123724-3 1-1123722-5 CN2 1-1123723-6 1-1123722-6 CN3 1-1123723-7 1-1123722-7 Terminal Chain 1123721-1 1318912-1 Loose 1123721-1 Chain 1318912-1 Loose Chain 1123721-1 1318912-1 Loose (Mfr:Tyco Electronics) ¶ I/O Connector is Mfr. Tyco Electronics ¶ Option:-J1:VH(J.S.T) connector type. Connector type CN1 CN2 Pin No. 1 2 3 4 5 CN3 CN4 Option (Mfr:J.S.T) Input AC(L) Pin No. Output Pin No. Output AC(N) 1 to 6 +V 1 to 7 -V FG ¶ Keep drawing current per pin below 5A for CN2,CN3. ¶ Tolerance : ±1 [±0.04] ¶ Weight : 390g max (with chassis & cover : 650g max) ¶ PCB material : CEM3 ¶ Optional chassis and cover material : Electric galvanizing steel board. ¶ Dimensions in mm, [ ]=inches ¶ Mounting torque (Mounting hole of chassis) :1.5N-m (16kgf-cm) max January 31, 2022 PIN No. 1 2 Contents RC(+) RC(-) Barrier strip type Model B2B-XH-A Mating Connector (Terminal) XHP-2 BXH-001T-P0.6 or SXH-001T-P0.6 LFA-15 Ordering information AC-DC Power Supplies Open Frame/ Enclosed Type LFA240F LF 1 A 240 2 3 F 4 Example recommended EMI/EMC filter NAC-06-472 R High voltage pulse noise type : NAP series Low leakage current type : NAM series * A higher current rating EMI/EMC filter may be recommended in view of the other devices that could be connected in parallel with the power supply. This power supply is manufactured by SMD technology. The stress to P.C.B like twisting or bending causes the defect of the unit, so handle the unit with care. *Make sure necessary tests will be carried out on your end equipment with the power supply installed in accordance with any required EMC/EMI regulations. MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT *5 *5 LFA240F-24 240 24V 10A LFA240F-24-H 240 (300) 24V 10 (12.5)A LFA240F-36 241.2 36V 6.7A -O 5 -O 6 1 Series name 2 Single output 3 Output wattage 4 Universal input 5 Output voltage 6 Optional *1 C : with Coating G : Low leakage current H : with the function to be acceptable to output peak current (only 24V) J1 : VH(J.S.T.)connector type R : with Remote ON/OFF R2 : with Remote ON/OFF S : with Chassis SN: with Chassis & cover T : Vertical terminal block Y : with Potentiometer Please refer to Instruction manual 6. LFA240F-48 240 48V 5A SPECIFICATIONS MODEL VOLTAGE[V] CURRENT[A] ACIN 100V ACIN 200V FREQUENCY[Hz] INPUT OUTPUT PROTECTION CIRCUIT AND OTHERS ISOLATION ENVIRONMENT SAFETY AND NOISE REGULATIONS OTHERS ACIN 100V ACIN 200V ACIN 100V POWER FACTOR (Io=100%) ACIN 200V ACIN 100V INRUSH CURRENT[A] ACIN 200V LEAKAGE CURRENT[mA] VOLTAGE[V] *5 CURRENT[A] LINE REGULATION[mV] *7 LOAD REGULATION[mV] *7 0 to +40C *2 RIPPLE[mVp-p] -10 - 0C *2 0 to +40C *2 RIPPLE NOISE[mVp-p] -10 - 0C *2 0 to +40C TEMPERATURE REGULATION[mV] -10 to +40C *3 DRIFT[mV] START-UP TIME[ms] HOLD-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE[V] OUTPUT VOLTAGE SETTING[V] OVERCURRENT PROTECTION OVERVOLTAGE PROTECTION OPERATING INDICATION REMOTE SENSING REMOTE ON/OFF *6 INPUT-OUTPUT.RC INPUT-FG *6 OUTPUT.RC-FG *6 OUTPUT-RC OPERATING TEMP.,HUMID.AND ALTITUDE *4 STORAGE TEMP.,HUMID.AND ALTITUDE VIBRATION IMPACT AGENCY APPROVALS CONDUCTED NOISE HARMONIC ATTENUATOR CASE SIZE/WEIGHT COOLING METHOD EFFICIENCY[%] LFA240F-24 LFA240F-24-H LFA240F-36 LFA240F-48 AC85 - 264 1f (Refer to “Derating”, Instruction Manual 1 and 3) *4 3.3typ (Io=100%) 1.7typ (Io=100%) 50 / 60 (47 - 63) 84.5typ 84.5typ 84.5typ 84.5typ 87.5typ 87.5typ 87.5typ 87.5typ 0.99typ 0.95typ 15 / 30typ (Io=100%) (Primary inrush current /Secondary inrush current) (More than 3 sec. to re-start) 30 / 30typ (Io=100%) (Primary inrush current /Secondary inrush current) (More than 3 sec. to re-start) 0.40 / 0.75max (ACIN 100V / 240V 60Hz, Io=100%, According to IEC62368-1 and DEN-AN) 24 24 36 48 10 10 (Peak12.5) 6.7 5 96max 96max 144max 192max 150max 150max 240max 240max 120max 240max 150max 150max 160max 320max 200max 200max 150max 300max 250max 250max 180max 360max 300max 300max 240max 240max 360max 480max 290max 290max 450max 600max 96max 96max 144max 192max 350typ (ACIN 100V, Io=100%) 20typ (ACIN 100V, Io=100%) Fixed (“Y”option is available for adjusting output voltage) 23.00 to 25.00 23.00 to 25.00 34.50 to 37.50 46.00 to 50.00 Works over 105% of rating (works over 101% of peak current at option -H) and recovers automatically 27.60 to 33.60 27.60 to 33.60 41.40 to 50.40 55.20 to 67.20 Not provided Not provided Option (Refer to Instruction Manual) AC3,000V 1minute, Cutoff current = 10mA, DC500V 50MW min (At Room Temperature) AC2,000V 1minute, Cutoff current = 10mA, DC500V 50MW min (At Room Temperature) AC500V 1minute, Cutoff current = 25mA, DC500V 50MW min (At Room Temperature) AC100V 1minute, Cutoff current = 25mA, DC100V 10MW min (At Room Temperature) -10 to +70C, 20 - 90%RH (Non condensing) (Refer to “Derating”, Instruction Manual 3), 3,000m (10,000feet) max -20 to +75C, 20 - 90%RH (Non condensing), 9,000m (30,000feet) max 10 - 55Hz, 19.6m/s2 (2G), 3minutes period, 60minutes each along X, Y and Z axis 196.1m/s2 (20G), 11ms, once each X, Y and Z axis UL60950-1, C-UL (CSA60950-1), EN62368-1 Complies with DEN-AN Complies with FCC-B, VCCI-B, CISPR-B, EN55011-B, EN55022-B Complies with IEC61000-3-2 (Class A) *8 84X46.5X180mm [3.31X1.83X7.09 inches] (WXHXD) / 550g max (with chassis & cover : 880g max) Convection (Refer to “Derating”, Instruction Manual 3) *4 *1 Specification is changeed at option, refer to Instruction Manual. *2 This is the value that measured on measuring board with capacitor of 22mF at 150mm from output terminal. Measured by 20MHz oscilloscope or Ripple-Noise meter (Equivalent to KEISOKU-GIKEN: RM103). *3 Drift is the change in DC output for an eight hour period after a half-hour warm-up at 25C, with the input voltage held constant LFA-16 at the rated input/output. *4 Derating is required. *5 ( ) means peak current. There is a possibility that an internal device is damaged when the specification is exceeded. Please contact us about the detail. *6 Applicable when remote control (optional) is added. *7 Please contact us about dynamic load and input response. January 31, 2022 *8 Please contact us about another class. * To meet the specifications. Do not operate over-loaded condition. * Parallel operation is not possible. * Derating is required when operated with chassis and cover. * Sound noise may be generated by power supply in case of pulse load. LFA240F Block diagram FUSE 250V10A NOISE FILTER AC IN 85 - 264V RECTIFIER INRUSH CURRENT LIMIT FG Photocoupler OPTION CURRENT SENSING BOOSTER INDUCTOR RC RECTIFIER AND FILTER E EXTERNAL SOURCE Photocoupler CURRENT SENSING CONTROL CONTROL Photocoupler INVERTER OVER VOLTAGE PROTECTION INVERTER RECTIFIER AND FILTER TRANSFORMER CONTROL DC OUT External view ¶ External size of option is different from standard model. Standard type 1 7 1 Mounting Hole [8.35] [7.87] 43 [1.69] 4.5 [0.24] ¶1 30 [1.18] 2-M4 Mounting Hole [2.32] 180 6 200±0.5 f4.5 [7.09] [0.14] 49 212 [6.69] [0.2] 15 4 [0.16] [0.59] Point A Point B 59 170±0.5 6 3.5 89±0.5 [3.5] CN2 Output(+) [0.14] [0.2] 5 5 CN3 Output(-) [3.86] 3 CN1 98 1 5 4.5 FG Input(N) Input(L) [0.18] CN2 Output(+) [1.77] 45±0.5 65±0.5 CN3 Output(-) 7 1 [1.93] [1.04] 16.5 1 2 1 [2.56] [2.91] 1 CN4 4-M4 Mounting Hole [0.24] 6 3.5max 84 [3.31] 74±0.5 3 CN1 FG Input(N) Input(L) 6 [7.87] [0.18] 1 2 5 200±0.5 2-f4.5 4-f3.5 Mounting Hole [0.65] 16.5 [0.65] 26.5 Name plate 21 Connector for Remote ON/OFF (Optional) Voltage adjust(Optional) [0.83] FG Chassis and cover type PCB t=1.6 ¶1 Surface mount device ¶ 5 Mounting holes are existing. ¶ The back side of P.C.B. of the power supply is assembled some SMDs. Be attention not to bump against the attached area by vibration. ¶ Use the spacer of 8mm length or more regarding insulation. And do not use press-fitting bush. ¶ Point A, Point B are thermometry points. Please refer to Instruction Manual 3. I/O Connector Mating connector CN1 1-1123724-3 1-1123722-5 CN2 1-1123723-6 1-1123722-6 CN3 1-1123723-7 1-1123722-7 Terminal Chain 1123721-1 1318912-1 Loose 1123721-1 Chain 1318912-1 Loose Chain 1123721-1 1318912-1 Loose (Mfr:Tyco Electronics) ¶ I/O Connector is Mfr. Tyco Electronics ¶ Option:-J1:VH(J.S.T) connector type. Connector type CN1 Pin No. 1 2 3 4 5 CN2 CN3 CN4 Option (Mfr:J.S.T) Input AC(L) Pin No. Output Pin No. Output AC(N) 1 to 6 +V 1 to 7 -V FG ¶ Keep drawing current per pin below 5A for CN2,CN3. ¶ Tolerance : ±1 [±0.04] ¶ Weight : 550g max (with chassis & cover : 880g max) ¶ PCB material : CEM3 ¶ Optional chassis and cover material : Electric galvanizing steel board. ¶ Dimensions in mm, [ ]=inches ¶ Mounting torque (Mounting hole of chassis) :1.5N-m (16kgf-cm) max January 31, 2022 PIN No. 1 2 Contents RC(+) RC(-) Barrier strip type Model B2B-XH-A Mating Connector (Terminal) XHP-2 BXH-001T-P0.6 or SXH-001T-P0.6 LFA-17 Ordering information AC-DC Power Supplies Open Frame/ Enclosed Type LFA300F LF 1 A 300 2 3 F Example recommended EMI/EMC filter NAC-06-472 R High voltage pulse noise type : NAP series Low leakage current type : NAM series * A higher current rating EMI/EMC filter may be recommended in view of the other devices that could be connected in parallel with the power supply. This power supply is manufactured by SMD technology. The stress to P.C.B like twisting or bending causes the defect of the unit, so handle the unit with care. *Make sure necessary tests will be carried out on your end equipment with the power supply installed in accordance with any required EMC/EMI regulations. MODEL MAX OUTPUT WATTAGE[W] Convection *5 DC OUTPUT Forced air *5 LFA300F-3R3-TY 198 3.3V 40A 3.3V 60A LFA300F-5-TY 300 5V 40A 5V 60A LFA300F-12-TY 324 12V 17A 12V 27A LFA300F-15-TY 330 15V 14A 15V 22A LFA300F-24-TY 336 24V 12.5A 24V 14A LFA300F-24-HTY 336 (456) 24V 12.5 (19)A 24V 14 (19)A -O 4 5 -O 6 1 Series name 2 Single output 3 Output wattage 4 Universal input 5 Output voltage 6 Optional *1 C : with Coating G : Low leakage current H : with the function to be acceptable to output peak current (Only 24V, 30V, 36V and 48V) J : EP (Tyco Electronics) connector type (Except 3.3V and 5V) J1 : VH (J.S.T.) connector type (Except 3.3V and 5V) R : with Remote ON/OFF R2 : with Remote ON/OFF S : with Chassis SNF : with Chassis & cover & fan (Only 5V, 12V and 24V) T1 : Holizontal terminal block Please refer to Instruction manual 6. LFA300F-30-TY 330 30V 10A 30V 11A LFA300F-36-TY 338.4 36V 8.4A 36V 9.4A LFA300F-48-TY 336 48V 6.3A 48V 7A SPECIFICATIONS MODEL VOLTAGE[V] CURRENT[A] ACIN 100V ACIN 200V FREQUENCY[Hz] INPUT OUTPUT PROTECTION CIRCUIT AND OTHERS ISOLATION ENVIRONMENT SAFETY AND NOISE REGULATIONS OTHERS ACIN 100V ACIN 200V ACIN 100V POWER FACTOR (Io=100%) ACIN 200V ACIN 100V INRUSH CURRENT[A] ACIN 200V LEAKAGE CURRENT[mA] VOLTAGE[V] Convection *5 CURRENT[A] Forced air LINE REGULATION[mV] *7 LOAD REGULATION[mV] *7 0 to +40C* 2 RIPPLE[mVp-p] -10 - 0C *2 0 to +40C *2 RIPPLE NOISE[mVp-p] -10 - 0C *2 0 to +40C TEMPERATURE REGULATION[mV] -10 to +40C *3 DRIFT[mV] START-UP TIME[ms] HOLD-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE[V] OUTPUT VOLTAGE SETTING[V] OVERCURRENT PROTECTION OVERVOLTAGE PROTECTION OPERATING INDICATION REMOTE SENSING REMOTE ON/OFF *6 INPUT-OUTPUT.RC INPUT-FG *6 OUTPUT.RC-FG *6 OUTPUT-RC OPERATING TEMP.,HUMID.AND ALTITUDE *4 STORAGE TEMP.,HUMID.AND ALTITUDE VIBRATION IMPACT AGENCY APPROVALS CONDUCTED NOISE HARMONIC ATTENUATOR CASE SIZE/WEIGHT COOLING METHOD EFFICIENCY[%] LFA300F-3R3-TY LFA300F-5-TY LFA300F-12-TY LFA300F-15-TY LFA300F-24-TY LFA300F-24-HTY LFA300F-30-TY LFA300F-36-TY LFA300F-48-TY AC85 - 264 1f (Refer to “Derating”, Instruction Manual 1 and 3) *4 2.7typ (Io=100%) 4.1typ (Io=100%) 1.4typ (Io=100%) 2.0typ (Io=100%) 50 / 60 (47 - 63) 75.0typ 79.0typ 80.0typ 81.5typ 85.0typ 85.0typ 85.5typ 85.5typ 85.5typ 77.0typ 82.5typ 83.0typ 84.5typ 88.0typ 88.0typ 88.0typ 88.0typ 88.0typ 0.98typ 0.99typ 0.92typ 0.95typ 15 / 30typ (Io=100%) (Primary inrush current /Secondary inrush current) (More than 3 sec. to re-start) 30 / 30typ (Io=100%) (Primary inrush current /Secondary inrush current) (More than 3 sec. to re-start) 0.45 / 0.75max (ACIN 100V / 240V 60Hz, Io=100%, According to IEC62368-1 and DEN-AN) 3.3 5 12 15 24 24 30 36 48 40 40 17 14 12.5 12.5 (Peak19) 10 8.4 6.3 60 60 27 22 14 14 (Peak19) 11 9.4 7 20max 20max 48max 60max 96max 96max 144max 144max 192max 40max 40max 100max 120max 150max 150max 240max 240max 240max 80max 80max 120max 120max 120max 240max 150max 150max 150max 140max 140max 160max 160max 160max 320max 200max 200max 200max 120max 120max 150max 150max 150max 300max 250max 250max 250max 160max 160max 180max 180max 180max 360max 300max 300max 300max 50max 50max 120max 150max 240max 240max 360max 360max 480max 60max 60max 150max 180max 290max 290max 450max 450max 600max 20max 20max 48max 60max 96max 96max 144max 144max 192max 350typ (ACIN 100V, Io=100%) 20typ (ACIN 100V, Io=100%) 2.85 to 3.63 4.50 to 5.50 10.80 to 13.20 13.50 to 16.50 21.60 to 27.50 21.60 to 27.50 27.00 to 33.00 32.40 to 39.60 39.60 to 52.80 3.30 to 3.40 5.00 to 5.15 12.00 to 12.48 15.00 to 15.60 24.00 to 24.96 24.00 to 24.96 30.00 to 31.20 36.00 to 37.44 48.00 to 49.92 Works over 105% of rating (works over 101% of peak current at option -H) and recovers automatically 4.00 to 5.25 5.75 to 7.00 13.80 to 16.80 17.25 to 21.00 27.60 to 33.60 27.60 to 33.60 34.50 to 42.00 41.40 to 50.40 55.20 to 67.20 Not provided Not provided Option (Refer to Instruction Manual) AC3,000V 1minute, Cutoff current = 10mA, DC500V 50MW min (At Room Temperature) AC2,000V 1minute, Cutoff current = 10mA, DC500V 50MW min (At Room Temperature) AC500V 1minute, Cutoff current = 25mA, DC500V 50MW min (At Room Temperature) AC100V 1minute, Cutoff current = 25mA, DC100V 10MW min (At Room Temperature) -10 to +70C, 20 - 90%RH (Non condensing) (Refer to “Derating”, Instruction Manual 3), 3,000m (10,000feet) max -20 to +75C, 20 - 90%RH (Non condensing), 9,000m (30,000feet) max 10 - 55Hz, 19.6m/s2 (2G), 3minutes period, 60minutes each along X, Y and Z axis 196.1m/s2 (20G), 11ms, once each X, Y and Z axis UL60950-1, C-UL (CSA60950-1), EN62368-1 Complies with DEN-AN Complies with FCC-B, VCCI-B, CISPR-B, EN55011-B, EN55022-B Complies with IEC61000-3-2 (Class A) *8 95X52.5X222mm [3.74X2.07X8.74 inches] (WXHXD) (without terminal block) / 810g max (with chassis & cover : 1,270g max) Convection / Forced air (Refer to “Derating”, Instruction Manual 3) *4 *1 Specification is changeed at option, refer to Instruction Manual. *2 This is the value that measured on measuring board with capacitor of 22mF at 150mm from output terminal. Measured by 20MHz oscilloscope or Ripple-Noise meter (Equivalent to KEISOKU-GIKEN: RM103). *3 Drift is the change in DC output for an eight hour period after a half-hour warm-up at 25C, with the input voltage held constant LFA-18 at the rated input/output. *4 Derating is required. *5 ( ) means peak current. There is a possibility that an internal device is damaged when the specification is exceeded. Please contact us about the detail. *6 Applicable when remote control (optional) is added. *7 Please contact us about dynamic load and input response. January 31, 2022 *8 Please contact us about another class. * To meet the specifications. Do not operate over-loaded condition. * Parallel operation is not possible. * Derating is required when operated with chassis and cover. * Sound noise may be generated by power supply in case of pulse load. LFA300F Block diagram FUSE 250V10A NOISE FILTER AC IN 85 - 264V INRUSH CURRENT LIMIT RECTIFIER FG Photocoupler OPTION CURRENT SENSING BOOSTER INDUCTOR RC EXTERNAL SOURCE Photocoupler CURRENT SENSING RECTIFIER AND FILTER CONTROL E CONTROL Photocoupler INVERTER OVER VOLTAGE PROTECTION INVERTER RECTIFIER AND FILTER TRANSFORMER CONTROL DC OUT External view ¶ External size of option is different from standard model. Standard type Name plate Point C for Point B Connector Remote ON/OFF (Optional) Point D M4 1 2 CN4 TB2 [2.07] Output(+) Point A 212±0.5 Voltage adjust 4 [0.16] 46.5 3.5 109±0.5 [4.29] [0.14] 5.5 5 [0.2] [0.22] 5 M4 [0.2] 8.6 Output(-) Input(L) [0.34] [0.39] 10 52.5 85±0.5 Input(N) TB1 [3.35] 95 [3.74] FG 18.5 10 FG [0.73] [0.39] 8.6 [0.34] 4-f3.5 Mounting Hole Mounting Hole [1.83] [8.35] Connector type 222 CN4 Option (Mfr:J.S.T) PIN No. 1 2 [1.93] 49 [8.74] Contents RC(+) RC(-) [0.14] 3.5max Barrier strip type ¶1 Model B2B-XH-A Mating Connector (Terminal) XHP-2 BXH-001T-P0.6 or SXH-001T-P0.6 PCB t=1.6 ¶1 Surface mount device ¶ 5 Mounting holes are existing. ¶ The back side of P.C.B. of the power supply is assembled some SMDs. Be attention not to bump against the attached area by vibration. ¶ Use the spacer of 8mm length or more regarding insulation. And do not use press-fitting bush. ¶ Point A, Point B, Point C, Point D are thermometry points. Please refer to Instruction Manual 3. ¶ Keep drawing current per pin below 20A for TB2. ¶ Tolerance : ±1 [±0.04] ¶ Weight : 810g max (with chassis & cover : 1,270g max) ¶ PCB material : CEM3 ¶ Dimensions in mm, [ ]=inches ¶ Screw tightening torque : M4 1.6N-m (16.9kgf-cm) max January 31, 2022 LFA-19 LFA-series Assembling and Installation Method Installation method ¡This power supply is manufactured by SMD technology.The stress to P.C.B like twisting or bending causes the defect of the unit, so d2 CN1 handle the unit with care. d1 = 8mm min ¡In case of metal chassis, keep the distance between d1 & d2 for to insulate between lead of component and metal chassis, use the spacer of 8mm or more between d1. If it is less than d1 & d2, in- d2 CN1 sert the insulation sheet between power supply and metal chassis. d2 d2 d2 = 4mm min d2 ¡There is a possibility that it is not possible to cool enough when the power supply is used by the sealing up space as showing in Case right figure.Please use it after confi rming the temperature of point Power supply A and point B of Instruction Manual 3. (A) ¡(F) mounting is not possible when unit is with case cover, but if need to operate unit by (F) positioning with case cover, tempera- (B) CN1 (C) CN1 ture / load derating is necessary. For more details, please contact our sales or engineering departments. CN1 Standard Position (D) (E) (F) CN1 CN1 CN1 Mounting screw ¡The mounting screw should be M3. The hatched area shows the allowance of metal parts for mounting. ¿ LFA10F, LFA15F ¿ LFA30F, LFA50F, LFA75F, LFA100F, LFA150F 8 8 8 8 8 8 CN1 CN1 8 ¿ LFA240F, LFA300F 8 8 8 8 8 Unit [mm] 8 Unit [mm] 8 8 8 CN1, TB1 8 8 8 8 8 8 Unit [mm] ¡If metallic fi ttings are used on the component side of the board,ensure there is no contact with surface mounted components. ¡This product uses SMD technology.Please avoid the PCB installation method which includes the twisting stress or the bending stress. *Recommendation to electrically connect FG to metal chassis for reducing noise. LFA-20 January 31, 2022 LFA-series Derating ¿Derating curve for input voltage Load factor [%] 100 80 [AC V] 85 90 ¿LFA10F Ambient temperature derating curve (Reference value) ¿LFA15F Ambient temperature derating curve (Reference value) 1 (A), (D), (E), (F)mounting 1 (B), (C)mounting Load factor [%] 80 1Convection 2Forced air (0.5m3 / min) 60 40 35 20 0 10 20 30 50 [40] 40 60 [50] Load factor [%] 0 10 20 40 [30] 30 50 [40] 60 [50] * Inside[ ] is with case cover 1 (A), (C)mounting 1 (B)mounting 2 (A) ~ (F) mounting 1Convection 2Forced air (0.5m3 / min) 20 10 20 ] is with case cover 80 0 40 35 0 -10 70 [60] 1Convection 2Forced air (0.5m3 / min) 60 * Inside[ 100 0 -10 80 Ambient temperature [C] 1 (D), (E)mounting 1 (F)mounting 40 2 (A) ~ (F) mounting Ambient temperature [C] ¿LFA30F Ambient temperature derating curve (Reference value) 60 1 (A), (B), (C), (D)mounting 100 20 40 [30] 30 50 [40] 60 [50] 70 [60] ¿LFA50F Ambient temperature derating curve (Reference value) 1 (D)mounting 1 (B)mounting 1 (A)mounting 2 (A) ~ (F) mounting 1 (C), (E)mounting 1 (F)mounting 100 Load factor [%] Load factor [%] 100 0 -10 1 (E), (F)mounting 2 (A) ~ (F) mounting 80 60 20 0 -10 70 [60] 1Convection 2Forced air (0.5m3 / min) 40 0 10 20 30 [10] 40 [20] 50 [30] 60 [40] Ambient temperature [C] Ambient temperature [C] * Inside[ * Inside[ ] is with case cover ] is with case cover 70 [50] ¿LFA75F Ambient temperature derating curve (Reference value) 1 (D)mounting 1 (E), (F)mounting Load factor [%] 100 80 60 1 (C)mounting 1 (A), (B)mounting 2 (A) ~ (F) mounting 1Convection 2Forced air (0.5m3 / min) 40 20 0 -10 0 10 20 30 [10] 40 [20] 50 [30] 60 [40] 70 [50] Ambient temperature [C] * Inside[ ] is with case cover ¿LFA100F Ambient temperature derating curve ¿LFA100F-O-SN Ambient temperature derating (Reference value) curve (Reference value) 1 (A)mounting 1 (C)mounting 1 (B)mounting 2 (A) ~ (F) mounting Load factor [%] 100 80 75 60 50 40 1Convection 2Forced air (0.5m3 / min) 20 0 -10 0 10 20 30 35 40 45 50 55 60 70 2 (A) ~ (F) 1 (B)mounting 1 (D), (E)mounting 1 (C)mounting mounting 1 (A)mounting 100 Load factor [%] 1 (D), (E), (F)mounting 80 75 60 1Convection 2Forced air (0.5m3 / min) 40 20 10 0 -10 0 10 20 30 35 40 45 50 60 Ambient temperature [C] Ambient temperature [C] January 31, 2022 LFA-21 LFA-series Derating ¿LFA150F Ambient temperature derating curve ¿LFA150F-O-SN Ambient temperature derating (Reference value) curve (Reference value) 1 (B)mounting 1 (A)mounting 2 (A) ~ (F) mounting Load factor [%] 100 80 70 60 1Convection 2Forced air (0.5m3 / min) 40 30 20 0 -10 0 10 20 25 30 35 40 45 50 55 60 65 1 (C)mounting 1 (B)mounting 1 (D), (E)mounting 1 (A)mounting 2 (A) ~ (F) mounting 100 Load factor [%] 1 (C)mounting 1 (D), (E), (F)mounting 80 70 60 50 40 30 20 0 -10 70 1Convection 2Forced air (0.5m3 / min) 0 5 10 Ambient temperature [C] 25 20 30 40 45 50 55 Ambient temperature [C] ¿LFA240F Ambient temperature derating curve ¿LFA240F-O-SN Ambient temperature derating (Reference value) curve (Reference value) 1 (D), (F)mounting 1 (C)mounting 1 (B)mounting 1 (A)mounting 2 (A) ~ (F) mounting Load factor [%] 100 80 60 1Convection 2Forced air (0.5m3 / min) 40 25 20 0 -10 0 10 15 30 20 40 50 60 70 1 (D)mounting 1 (E)mounting 1 (C)mounting 1 (B)mounting 1 (A)mounting 2 (A) ~ (F) mounting 100 Load factor [%] 1 (E)mounting 80 70 60 40 25 20 10 0 -10 Ambient temperature [C] 1Convection 2Forced air (0.5m3 / min) 0 5 10 15 20 25 30 40 50 60 Ambient temperature [C] ¿LFA300F Ambient temperature derating curve (Reference value) 1 (B), (C)mounting 1 (E), (F)mounting 1 (D)mounting 1 (A)mounting 2 (A) ~ (F) mounting Load factor [%] 100 80 1Convection 2Forced air (1.0m3 / min) :3.3V/5V/12V/15V (0.5m3 / min) :24V/30V/36V/48V 60 50 40 20 0 -10 0 10 20 25 30 40 50 60 70 Ambient temperature [C] Output voltage 3.3V 5V 12V 15V 24V 30V 36V 48V Output power[W] 1Convection 2Forced air 132.0 198.0 200.0 300.0 204.0 324.0 210.0 330.0 300.0 336.0 300.0 330.0 302.4 338.4 302.4 336.0 ¡The operative ambient temperature is different by with / without chassis cover or mounting position. Note: In the hatched area, the specification of Ripple, Ripple Noise is different from other area. ¡Make sure the temperature at point A and point B is less than the temperatures shown in Instruction Manual 3. ¡The ambient temperature should be measured 5 to 10 cm away from the power supply so that it won’t be influenced by the heat from the power supply. Please consult us for more details. Instruction Manual ◆ It is neccessary to read the “Instruction Manual” and “Before using our product” before you use our product. Instruction Manual https://en.cosel.co.jp/product/powersupply/LFA/ Before using our produc https://en.cosel.co.jp/technical/caution/index.html LFA-22 January 31, 2022 LFA NOTICE LFA-series Basic Characteristics Data Material Single sided 0.26 LF CEM-3 100 0.35 Thermistor Flyback converter 130 0.65 Circuit method Switching frequency [kHz] LFA10F Flyback converter 100 LFA15F Flyback converter LFA30F LFA50F LFA75F LFA100F LFA150F LFA240F LFA300F Input current *1 [A] Inrush current protection Model Active filter 60-440 Flyback converter 130 Active filter 60-440 Flyback converter 130 Active filter 60 Forward converter 140 Active filter 60 Forward converter 140 Active filter 60 Forward converter 140 Active filter 60 Forward converter 140 Series/Parallel operation availability PCB/Pattern Double sided *2 Series operation Parallel operation Yes Yes No CEM-3 Yes Yes No Thermistor CEM-3 Yes Yes No 0.67 Thermistor CEM-3 Yes Yes No 1.0 Thermistor CEM-3 Yes Yes No 1.3 Thermistor CEM-3 Yes Yes No 2.0 Thermistor CEM-3 Yes Yes No 3.3 SCR CEM-3 Yes Yes No 4.1 SCR CEM-3 Yes Yes No *1 The  value of input current is at ACIN 100V and rated load. *2 Refer to Instruction Manual 2. January 31, 2022 LFA-23
LFA150F-24-J1 价格&库存
很抱歉,暂时无法提供与“LFA150F-24-J1”相匹配的价格&库存,您可以联系我们找货
LFA150F-24-J1
    • 1+458.013041+59.42682
    • 2+433.986352+56.30937
    • 3+425.977453+55.27022
    • 4+421.973004+54.75065
    • 5+419.573645+54.43934
    • 9+415.296169+53.88434
    • 10+414.7666410+53.81563
    库存:43
    LFA150F-24-J1
    • 1+784.021631+101.72616
